IMPORTANT NOTE: PLUGINS ARE CURRENTLY IN THE PROCESS OF BEING MIGRATED TO THE NEW VOLUMIO 3 SYSTEM. NOT ALL OF THE PLUGINS LISTED BELOW ARE AVAILABLE FOR VOLUMIO 3. THE CURRENT STATUS OF TRANSFERS CAN BE FOUND AT Volumio 3 Plugin migration status.
Would all plugin authors please produce a single post for their each of plugins.
PLEASE DO NOT POST ANY COMMENTS IN THIS THREAD:
Use the appropriate [PLUGIN] Plugin_name post, or create a new one.
IMPORTANT NOTES FOR PLUGIN AUTHORS
Would all plugin authors please produce a single post for their each of plugins, including:
Title
Description
How to obtain the plugin eg. Github link, or from the Volumio UI
Author name
Volumio version (2 and/or 3)
Plugin status eg. 'stable on RPi3/x86
Link to separate topic with the topic name ‘[PLUGIN] Your plugin name here’, where ALL discussion about your plugin can take place.
Please start the ‘publishing process’ for the plugin as soon as you consider it to be reasonably stable. You can do it easily with the plugin helper.
Once you send the ‘Pull Request’, your plugin will be reviewed and eventually published for all the available platforms (make it available from within the Volumio UI). There is more information about the publishing process here.
This plugin separates Volumio music processes from other processes. It allows you to select the CPUs and the process priority for selected music services.
Randomizer is a plugin which gives the user three buttons to play: a random album, a number of random tracks, and the album of the currently playing track
Alternative implementation of Rotary Encoder controls using the Linux Kernel driver for Rotaries. It also offers additional features compared to the original RotaryEncoder Plugin.
As the other volspotconnect plugin, this one provides a easy way to use your Volumio device as a Spotify Connect Device.
It is based on librespot, a open source library.
Works on any plateform supported by Volumio
Brutefir Plugin2022-May Deprecated! Do not use with Volumio 3. Use FusionDsp as official DSP plugin
This plugin provides a easy way to install and configure Brutefir ludd.ltu.se/~torger/brutefir.html
With it you can use custom filters to do Digital Room Compensation. (some example filters are included but you have to generate your own with software like Rew and rephase).
This plugin turns on/off a GPIO port depending on the status of volumio. Using AmpSwitch, Volumio can automatically turn an external amplifier on when you press “Play” and turn it off when you press stop/pause. A delay can be specified to avoid premature switching.
Starts playing the last entry in the queue after rebooting volumio.
This is a “must have” for webradios without a modern frontend (http://pin.it/uVFOjQ6).
Notes: This Plugin has been sponsored by JustBoom and its and it works out of the box withJustBoom IR Remote, Odroid Remote and Apple remote. Controls: Play, pause, mute, volume, next, previous, seek, repeat and random
An implementation of SnapCast (server + client) and easy configuration in the plugin settings. Not every option is covered, but the most commonly used are.
Platform: Raspberry Pi; tested on 1 (B and B+), 2 and 3
Note: should work on all armhf devices.
This plugin provides a easy way to backup and restore your device data locally.
Useful before/after re-imaging to new Volumio version, or deploying a setup across multiple devices.
Archived data become available through Volumio’s SMB share, so that it can be copied both ways to preserve and re-deploy.
Please note that sometimes, due to timing issues, the plugin will show as not installed successfully. This is a cosmetic error that I will fix in the near future (it’s actually a bug in Volumio; it uploads the plugin multiple times). <- should be fixed, I will investigate!
Alpha testing was successful, plugins can also be installed.
The first start of the service might take a few seconds, please be patient. Also, the button to open a new tab for the LMS web-interface only works with Volumio 2.296+.
NB: A Squeezelite plugin has been released today (11-09-2017)
