Volumio Plugins Collection
Play on connect
This plugin allows to play the queue when a specific IP is detected on your network, and stop the play when this IP disappears.
Very convenient to hear your favorite track when you’ re back home, and to never forget to stop the music when you leave :wink:
source : github.com/balbuze/volumio-plug … yonconnect
File to download : github.com/balbuze/volumio-plug … onnect.zip
Author : Balbuze
Status : beta
LastFM plugin
Plugin to scrobble music played in Volumio 2.x to LastFM.
Platform: all (runs fully on NodeJS)
Source : github.com/Saiyato/volumio-lastfm-plugin
File to download : volumio-lastfm-plugin.zip
Author: Saiyato
Status: stable
Because the pushState pushes are hard to capture in a fashionable manner I had to write a timer function, I’m not yet fully trusting the timer, but since you can easily delete scrobbles I’m opening the project up for testing.
As the documentation/description states, you don’t need to save your password, an MD5 hash is saved to be used as an authentication token, this suffices. You do need an API key which you can request here; remember to save it! There’s not way to query the given token again!
Happy testing and please provide as much info as you can gather when you’re having troubles. In the plugin you can enable debug logging, which will explode the amount of logging the plugin does.
PS: documentation will follow, but I thought many people would be able to test it without much info. You just need to fill in your info. Saving your password is not needed, nor recommended (because it’s saved in plain text).
[Update 23-10-2017]
Webradio songs can now be scrobbled, see latest update (1.1.x)
[Update 01-12-2017]
Scrobbling for LMS will be incorporated in the Squeezelite plugin, if it uses the volatile state songs can be scrobbled easily.
[Update 20-05-2018]
Scrobbling for Radio paradise and all Spotify plugins has been enabled.
Onedrive Music Library
Plugin for browsing and playing audio files stored on Microsoft Onedrive. The authentication procedure requires some URL-copy-pasting, as explained on the config-page, but should be easy enough.
Source on Github
Download package
Issues / Bugs / Feature requests: Please create an issue on github
Status: beta
Author: Elmar Jansen (elmarj)
Volstereo2mono 2022-May Deprecated! Do not use with Volumio 3. Use FusionDsp as official DSP plugin
This plugin downmix the signal from stereo to mono on both channel. Useful if you want to use it with volumio music box with one speaker !
source : github.com/balbuze/volumio-plug … tereo2mono
File to download for install : github.com/balbuze/volumio-plug … o2mono.zip
Status: beta
Author : balbuze
edit : move category to audio_interface
Volparametriceq 2022-May Deprecated! Do not use with Volumio 3. Use FusionDsp as official DSP plugin
A 4 bands parametric equalizer using EqFA4p (quitte.de/dsp/caps.html#EqFA4p)
For fine sound tuning!
File download to install : github.com/balbuze/volumio-plug … triceq.zip
More info : github.com/balbuze/volumio-plug … rametriceq
We are talking about it here : volumio2-parametric-equalizer-plugin-t8222.html
Author : balbuze
Tested on : Rpi2, Pine64
Status : Beta
Volbinauralfilter 2022-May Deprecated! Do not use with Volumio 3. Use FusionDsp as official DSP plugin
If you use headphones, this plugin is for you!
It uses a the “bauer” stereo to binaural filter. (bs2b.sourceforge.net/)
File download to install : github.com/balbuze/volumio-plug … filter.zip
More info : github.com/balbuze/volumio-plug … auerfilter
We are talking about it here : volumio2-stereo-binaural-filter-plugin-t8177.html
Author : balbuze
Status : Beta
MotionEye
This plugin adds MotionEye functionality (github.com/ccrisan/motioneye) to Volumio.
Running on my Raspberry PIs (1B and 3) with attached USB camera.
Installation takes quite long time.
MotionEye needs to be Enabled in plugin section of Volumio to start deamon.
Can be used from web browser: http://[VolumioIP]:8765
Use admin with empty password when prompted for credentials.
Source: github.com/gogiman/volumio-plug … /motioneye
File to download or install: github.com/gogiman/volumio-plug … ioneye.zip
Author: Pavol Grohol (gogiman)
Status: Beta
Personal Radio
This music service plugin provides Korean radio(KBS, MBC, SBS) and Linn radio. KBS, SBS and MBC are very popular commercial radio station in Korea. Korean radios can’t be added as a Volumio webradio because the streaming URL have one time access token. If you interested in Korean radio, you can enjoy this plugin.
There are many channels in KBS, SBS and MBC radio. I’ll introduce some of popular radio channels as follows.​
  • KBS1 FM is a classic channel in Korean language
  • KBS2 FM and MBC FM4U channel are a K-pop, Pop music and entertainment in Korean language.
  • KBS World channel designed for an international audience and the radio program consists of K-Pop, news, Korean culture with English or other languages.
Platform: all platform includes Raspberry Pi and x86 (no platform specific codes)
​Source : https://github.com/ChrisPanda/volumio-personal-radio-plugin
File to download : https://github.com/ChrisPanda/volumio-personal-radio-plugin/releases/download/v1.1.2/volumio-personal-radio-plugin-v1.1.2.zip
Author: Chris Song (chrispanda)
Status: stable
Rotary encoder plugin
Volumio 2 plugin to configure two simple rotary encoders.
Platform: Raspberry Pi (but possibly multiple board platforms)
Depends on Node JS onoff
Source : github.com/Saiyato/volumio-rota … der-plugin
File to download : volumio-rotary-encoder-plugin.zip
Info:
At this stage I’ve only tested volume control, but since the commands syntax shouldn’t change I trust the rest will work too.
Full testing takes time and I wanted to release early for everyone.
Please note that the plugin emits to the API, so it’s not too responsive, there’s a delay somewhere (Node JS?).
Update [2018-01-18]:
Patched some really nasty bugs last night, it should work ok now.
Update [2018-03-01]:
Merged a PR from diehardsk, which makes the plugin way more reliable.
Author: Saiyato
Status: stable
RemotePi
The plugin enables support for MSL Digital Solutions’ RemotePi boards for Raspberry Pi 4, Pi 3 B+, Pi 3, Pi 2, B+ and B on Volumio.
After activating the plugin the RemotePi board will get signaled as soon as Volumio is shut down via the GUI. This allows the RemotePi board to cut power from the RasPi after the shutdown process has finished.
Further more the plugin detects the signal that is sent by the RemotePi board in case its hardware knob has been pressed or an IR power off signal from a remote control has been received. The plugin then initiates the shutdown of Volumio and sends a signal back to the RemotePi. This allows the board to detect when Volumio’s shutdown process has finished and cut the power afterwards.
The plugin configures Volumio to load the necessary overlay for the IR receiver of the RemotePi board. By default the plugin uses GPIO18 for the IR receiver. But as the hardware of RemotePi boards can be modified to use GPIO17 instead the plugin allows to set up the configuration accordingly.
Note: The plugin will not install and setup LIRC! This can be achieved by installing the IR remote controller plugin. Pay attention to get at least version 1.2.0 of the IR remote controller plugin. Earlier versions will override the gpio_in_pin setting with GPIO25.
How to obtain: Volumio plugin store
Author: gvolt
Volumio version: 2 and 3
Status: stable on Raspberry Pi
Disussion: [PLUGIN] RemotePi
pydPiper plugin
Volumio 2 pydPiper plugin
Source : github.com/Saiyato/volumio-pydpiper-plugin
File to download : volumio-pydpiper-plugin.zip
Info:
The custom pages are only working for the RaspDac OLED
Author: Saiyato
Status: Beta
Update 23-05-2018: uploaded a new version, I2C HD44780 does not have a nice template yet for 24h formats, the rest seems to be working (some fine tuning of the templates is advised).
Audiophonics on/off plugin
Volumio 2 Audiophonics on/off plugin
Source : github.com/Saiyato/volumio-audi … off-plugin
File to download : volumio-audiophonicsonoff-plugin.zip
Info:
A plugin to control just the on/off button in the Audiophonics case, best way to use it is through a Sabre V2/V3/V4; this DAC has an onboard script to have the button blink upon booting/shutting down.
Author: Saiyato
Status: stable
Podcast plugin for Volumio.
User can play podcast item in Volumio with this plugin. Also, user can add or delete podcast RSS feed url at setup configuration in this podcast plugin.
  • Predefined Podcast
  • BBC radio podcasts (radio 1, 2, 3, 4, 4extra, 5live, 5live sports extra, 6music, world service)
    (Note: some of BBC podcast episodes that includes “[UK Only]” at podcast title are played only UK region)
  • Add podcast
  • at podcast plugin setup configuration, type RSS feed link url.
  • for example, if you want to add NPR’s TED Radio Hour Podcast then please type RSS feed url npr.org/rss/podcast.php?id=510298
  • Delete podcast
  • at podcast plugin setup configuration, select podcast item from podcasts list then click delete button.
​Source : github.com/ChrisPanda/volumio-podcast-plugin
File to download : https://github.com/ChrisPanda/volumio-podcast-plugin/releases/download/0.1.0/volumio-podcast-plugin-0.1.0.zip
Forum Topic for Discussion
Status: stable
miniDLNA
The plugin installs and allows to configure a miniDLNA (aka ReadyMedia) server.
Through Volumio’s UI the plugin provides access to all configuration options of the miniDLNA server (except “user to run as” which is set to “volumio”). Currently the options of miniDLNA version 1.1.2 (on Volumio 2) and version 1.2.1 (on Volumio 3) are supported.
The plugin also features a rescan button that allows to force a rescan of all media directories for new media files.
Author: gvolt
Status: stable on Raspberry Pi and x86 (probably also works on other platforms as long as the minidlna package is available)
Disussion: [PLUGIN] miniDLNA
Autostart
Replacement for former Plugin ‘Autoplay’. I reimplemented it with another lib underneath, since many people reported issues.
Starts playing the last entry in the queue after rebooting volumio.
This is a “must have” for webradios without a modern frontend (pin.it/uVFOjQ6).
You just need to install and enable the plugin.
Platform: Raspberry; tested on 3 with HifiBerry
Source: github.com/volumio/volumio-plug … /autostart
Author: Thomas Doerr
Status: stable works since months on my machines, if you have any problems, please contact me.
Title: fmxmtr
Description: Set up and control I2C FM transmitter module by Electhouse based on KT-0803K fm transmitter chip. Should work on any I2C module utilizing the KT-0803 series IC.
How to obtain the plugin: https://github.com/CannonFodderSE/volumio-plugins/tree/gh-pages/plugins/miscellanea/fmxmtr
Author: Randy Bancroft
Contact: randybancroft@verizon.net or user name Randy on Volumio Forums
Plugin status: stable on RPi3’
See initial message announcing release at https://volumio.org/forum/turn-your-volumio-into-radio-station-t9810.html
ES9018K2M control plugin for Volumio
This plugin control es9018k2m chip by i2c so user must connect i2c pins between raspberry pi and es9018k2m DAC.
  • supported platform: Raspberry Pi
  • supported es9018k2m hardware
  • Aoide es9018k2m DAC II (tested)
  • General es9018k2m DAC/DDC that contains i2c pins
  • supported functions
  • volume, mute control
  • adjust balance and switch left/right channel
  • digital filter(fast/slow rolloff, IIR) and de-emphasis filter
  • i2s/DSD DPLL(Digital Phase Locked Loop) Jitter Reduction
​Source : github.com/ChrisPanda/volumio-es9018k2m-plugin
File to download (less than Volumio version 2.411)
File to download (more than Volumio version 2.411)
Status: stable
Onkyo Controller
A simple plugin that is able to turn an Onkyo receiver on the network on and off when playback begins and ends using eISCP.
Features:
  • Automatically or manually detect compatible Onkyo receivers on the network .
  • Send a power on or power off command to an Onkyo receiver when Volumio playback begins or ends.
  • Set the volume on the receiver to a set value when Volumio playback begins.
  • Set the receiver channel on playback beginning.
  • Delay the power off command to the receiver (to allow for pausing music without shutting down).
Platform: Raspberry Pi; tested on 2 and Zero W. It should be platform agnostic though.
Tested with an Onkyo CR-N755 receiver, but should be fine with any receiver that can use the Onkyo remote app.
Installable through volumio plugins menu, or see Github for manual installation.
Author: Orderoftheflame
Status: stable
Github project : github.com/orderoftheflame/volu … yo_control
Discussion thread: onkyo-controller-t10013.html
Radio Paradise Plugin
The Radio Paradise plugin allows to play their streams - including the FLAC version - within volumio. radioparadise.com is a commercial-free listener-sponsored Internet radio station that identifies itself as an “eclectic online rock radio” station. It plays different styles of pop and rock music, but occasionally other genres from jazz to classical to electronic music and world music.
Features:
  • listening to normal streams in different quality (mp3 and aac)
  • listening to the flac version
  • metadata for flac (cover, artist, title)
  • pause/resume
Platform:
Raspberry Pi; tested on 3 and Zero W. It should be platform agnostic though.
Author: marco79cgn
Status: stable
Github project : https://github.com/marco79cgn/volumio-plugins/tree/master/plugins/music_service/radio_paradise
Discussion thread: https://volumio.org/forum/radio-paradise-t9886.html
Phish.in
Plugin to play over 1,500 live Phish audience recordings from Phish.in. Plugin uses the Phish.in API v1. Phish.in and the Volumio Phish.in music service plugin complies with Phish’s official taping policy as described at http://phish.com/#/faq/taping-guidelines.
Features:
  • Find show by year
  • Find show by tour
  • Play shows on today’s date
  • Play random show
Author: Noah McGee (lostmyshape)
Tested on Pi 3b+ but no extra installs so should be fine on any device.
Pull request submitted to install through Volumio; but currently install through zip on GitHub project page.
Status: stable
GitHub project: https://github.com/lostmyshape/volumio-phishin
Discussion: https://volumio.org/forum/phish-for-volumio-t10357.html
