Sure, here you are, this is boot log for first run:
bash-5.0# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.86-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1283 SMP Fri Nov 29 18:37:40 GMT 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 64 MiB at 0x000000003a000000
[ 0.000000] On node 0 totalpages: 1024000
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 827392 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1022272
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:76:43:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 earlycon=ttyAMA0,115200 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=8 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3955060K/4096000K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 75404K reserved, 65536K cma-reserved, 3244032K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 688 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28674 entries in 85 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000022] Switching to timer-based delay loop, resolution 18ns
[ 0.000243] Console: colour dummy device 80x30
[ 0.000804] console [tty1] enabled
[ 0.000859] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000901] pid_max: default: 32768 minimum: 301
[ 0.001179] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001210] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002029] CPU: Testing write buffer coherency: ok
[ 0.002444] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003093] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003266] rcu: Hierarchical SRCU implementation.
[ 0.004125] smp: Bringing up secondary CPUs ...
[ 0.004919] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005822] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006679] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006811] smp: Brought up 1 node, 4 CPUs
[ 0.006875] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006897] CPU: All CPU(s) started in HYP mode.
[ 0.006917] CPU: Virtualization extensions available.
[ 0.007623] devtmpfs: initialized
[ 0.018181] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.018422] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018465] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.020638] pinctrl core: initialized pinctrl subsystem
[ 0.021430] NET: Registered protocol family 16
[ 0.024363] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.025910] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.025941] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.026139] Serial: AMBA PL011 UART driver
[ 0.029069] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.065004] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.067078] vgaarb: loaded
[ 0.067448] SCSI subsystem initialized
[ 0.067661] usbcore: registered new interface driver usbfs
[ 0.067728] usbcore: registered new interface driver hub
[ 0.067838] usbcore: registered new device driver usb
[ 0.080331] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-11-29 18:44, variant start
[ 0.090082] raspberrypi-firmware soc:firmware: Firmware hash is aabb1fb5c19d80db268aeccd67b9f4e0f3d48a2a
[ 0.101878] clocksource: Switched to clocksource arch_sys_counter
[ 0.178768] VFS: Disk quotas dquot_6.6.0
[ 0.178865] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.179029] FS-Cache: Loaded
[ 0.179220] CacheFiles: Loaded
[ 0.188526] NET: Registered protocol family 2
[ 0.189185] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.189231] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.189311] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.189395] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.189525] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.189570] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.189782] NET: Registered protocol family 1
[ 0.190320] RPC: Registered named UNIX socket transport module.
[ 0.190345] RPC: Registered udp transport module.
[ 0.190365] RPC: Registered tcp transport module.
[ 0.190386] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.190414] PCI: CLS 0 bytes, default 64
[ 0.190619] Trying to unpack rootfs image as initramfs...
[ 1.923341] Freeing initrd memory: 22280K
[ 1.937957] Initialise system trusted keyrings
[ 1.938169] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.947133] FS-Cache: Netfs 'nfs' registered for caching
[ 1.947657] NFS: Registering the id_resolver key type
[ 1.947695] Key type id_resolver registered
[ 1.947717] Key type id_legacy registered
[ 1.947748] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.950123] Key type asymmetric registered
[ 1.950149] Asymmetric key parser 'x509' registered
[ 1.950269] bounce: pool size: 64 pages
[ 1.950321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.950495] io scheduler noop registered (default)
[ 1.950520] io scheduler deadline registered
[ 1.950682] io scheduler cfq registered
[ 1.950706] io scheduler mq-deadline registered
[ 1.950727] io scheduler kyber registered
[ 1.994444] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 1.994489] brcm-pcie fd500000.pcie: could not get clock
[ 1.994563] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.994614] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 2.051914] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 2.052205] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 2.052236] pci_bus 0000:00: root bus resource [bus 00-01]
[ 2.052266] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 2.052329] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 2.052479] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 2.055274] PCI: bus0: Fast back to back transfers disabled
[ 2.055305] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.055488] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 2.055561] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 2.055740] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 2.058420] PCI: bus1: Fast back to back transfers disabled
[ 2.058450] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 2.058508] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 2.058541] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 2.058588] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.058618] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 2.058842] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 2.059020] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 2.059190] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 2.059339] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 2.059725] bcm2708_fb soc:fb: FB found 1 display(s)
[ 2.089056] Console: switching to colour frame buffer device 228x61
[ 2.098140] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
[ 2.100267] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 2.102402] iproc-rng200 fe104000.rng: hwrng registered
[ 2.102676] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.103262] vc-sm: Videocore shared memory driver
[ 2.103695] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 2.113598] brd: module loaded
[ 2.123023] loop: module loaded
[ 2.123808] Loading iSCSI transport class v2.0-870.
[ 2.125498] libphy: Fixed MDIO Bus: probed
[ 2.125957] bcmgenet fd580000.genet: failed to get enet clock
[ 2.126027] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 2.126095] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 2.126164] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 2.126241] bcmgenet: Skipping UMAC reset
[ 2.126506] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 2.141912] libphy: bcmgenet MII bus: probed
[ 2.192528] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 2.193493] usbcore: registered new interface driver r8152
[ 2.193610] usbcore: registered new interface driver lan78xx
[ 2.193715] usbcore: registered new interface driver smsc95xx
[ 2.193979] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 2.194058] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 2.196627] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 2.196884] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 2.197605] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.197694] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.197769] usb usb1: Product: xHCI Host Controller
[ 2.197825] usb usb1: Manufacturer: Linux 4.19.86-v7l+ xhci-hcd
[ 2.197888] usb usb1: SerialNumber: 0000:01:00.0
[ 2.198458] hub 1-0:1.0: USB hub found
[ 2.200982] hub 1-0:1.0: 1 port detected
[ 2.203879] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 2.206344] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 2.208802] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 2.211552] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.214061] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.216537] usb usb2: Product: xHCI Host Controller
[ 2.219003] usb usb2: Manufacturer: Linux 4.19.86-v7l+ xhci-hcd
[ 2.221459] usb usb2: SerialNumber: 0000:01:00.0
[ 2.224435] hub 2-0:1.0: USB hub found
[ 2.226901] hub 2-0:1.0: 4 ports detected
[ 2.230414] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.233063] dwc_otg: FIQ enabled
[ 2.235441] dwc_otg: NAK holdoff enabled
[ 2.237793] dwc_otg: FIQ split-transaction FSM enabled
[ 2.240154] Module dwc_common_port init
[ 2.242706] usbcore: registered new interface driver uas
[ 2.245161] usbcore: registered new interface driver usb-storage
[ 2.247674] mousedev: PS/2 mouse device common for all mice
[ 2.251172] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.254975] sdhci: Secure Digital Host Controller Interface driver
[ 2.257340] sdhci: Copyright(c) Pierre Ossman
[ 2.260043] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 2.262822] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.268149] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.270690] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.273263] usbcore: registered new interface driver usbhid
[ 2.275658] usbhid: USB HID core driver
[ 2.278906] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 2.282716] [vc_sm_connected_init]: start
[ 2.291219] [vc_sm_connected_init]: end - returning 0
[ 2.294769] Initializing XFRM netlink socket
[ 2.297139] NET: Registered protocol family 17
[ 2.299530] Key type dns_resolver registered
[ 2.302309] Registering SWP/SWPB emulation handler
[ 2.305175] registered taskstats version 1
[ 2.307431] Loading compiled-in X.509 certificates
[ 2.316434] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 2.318798] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 4.140149] console [ttyAMA0] enabled
[ 4.149537] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
[ 4.160674] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 4.170834] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 4.181517] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 4.190009] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 4.224283] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 4.250815] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.260868] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.270393] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.278340] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 4.290576] of_cfs_init
[ 4.290841] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.295579] of_cfs_init: OK
[ 4.305043] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.324293] Freeing unused kernel memory: 2048K
[ 4.331474] Run /init as init process
[ 4.364780] random: fast init done
[ 4.402425] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 4.420133] mmc1: new high speed SDIO card at address 0001
[ 4.441078] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 4.451333] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 4.462598] mmcblk0: p1 p2 p3
[ 4.499460] initramfs: Booting Volumio for BCM2835
[ 4.506982] initramfs: This script mounts rootfs RO with an overlay RW layer.
[ 4.546134] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.567405] initramfs: IMGPART=/dev/mmcblk0p2
[ 4.574376] initramfs: IMGFILE=/volumio_current.sqsh
[ 4.581957] initramfs: Boot delay (except first time) will be 5 seconds
[ 4.591274] initramfs: /dev/mmcblk0p2 not detected,retrying mdev in 5 seconds
[ 4.603289] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 4.614152] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.623789] usb 1-1: Product: USB2.0 Hub
[ 4.631764] hub 1-1:1.0: USB hub found
[ 4.638183] hub 1-1:1.0: 4 ports detected
[ 4.961913] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[ 5.122477] usb 1-1.1: New USB device found, idVendor=046e, idProduct=3697, bcdDevice= 1.00
[ 5.133412] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.143263] usb 1-1.1: Product: USB Multimedia Keyboard
[ 5.151027] usb 1-1.1: Manufacturer: BTC
[ 5.175300] input: BTC USB Multimedia Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046E:3697.0001/input/input0
[ 5.237995] initramfs: /dev/mmcblk0p2:
[ 5.262484] hid-generic 0003:046E:3697.0001: input,hidraw0: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-0000:01:00.0-1.1/input0
[ 5.293506] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.299367] input: BTC USB Multimedia Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046E:3697.0002/input/input1
[ 5.325023] initramfs: Creating factory image, this will take a minute, please wait...
[ 5.392118] input: BTC USB Multimedia Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046E:3697.0002/input/input2
[ 5.413201] hid-generic 0003:046E:3697.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-0000:01:00.0-1.1/input1
[ 44.242372] initramfs: Factory image created
[ 44.249910] initramfs: Creating archive for factory kernel...
[ 62.640973] initramfs: Checking for USB updates
[ 62.732618] initramfs: No USB device detected (when incorrect, try adding 'bootdelay=5' to your boot cmdline)
[ 63.041743] initramfs: Re-sizing Volumio data partition
[ 74.662338] initramfs: Volumio data partition succesfully resized
[ 74.969199] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 75.001138] initramfs: With Option:
[ 75.189050] initramfs:
[ 75.194630] initramfs: Finish initramfs, continue booting Volumio
[ 75.837462] systemd[1]: System time before build time, advancing clock.
[ 75.940288] NET: Registered protocol family 10
[ 75.948991] Segment Routing with IPv6
[ 75.983305] systemd[1]: systemd 244-3~bpo10+1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 76.012783] systemd[1]: Detected architecture arm.
[ 76.062422] systemd[1]: Set hostname to <volumio>.
[ 76.226425] uart-pl011 fe201000.serial: no DMA platform data
[ 76.762251] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 76.793305] systemd[1]: /lib/systemd/system/winbind.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[ 76.890107] systemd[1]: /lib/systemd/system/smbd.service:10: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 76.965925] systemd[1]: /lib/systemd/system/nmbd.service:10: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 77.158377] random: systemd: uninitialized urandom read (16 bytes read)
[ 77.174472] systemd[1]: Created slice system-getty.slice.
[ 77.188842] random: systemd: uninitialized urandom read (16 bytes read)
[ 77.200803] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 77.215607] random: systemd: uninitialized urandom read (16 bytes read)
[ 77.227282] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 77.243939] systemd[1]: Created slice User and Session Slice.
[ 77.257980] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 77.274301] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 77.292500] systemd[1]: Reached target Slices.
[ 77.304832] systemd[1]: Reached target System Time Set.
[ 77.317948] systemd[1]: Reached target System Time Synchronized.
[ 77.363020] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 77.379433] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 77.394741] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 77.434615] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 77.448007] systemd[1]: Listening on Journal Socket (/dev/log).
[ 77.462908] systemd[1]: Listening on Journal Socket.
[ 77.477166] systemd[1]: Listening on udev Control Socket.
[ 77.491308] systemd[1]: Listening on udev Kernel Socket.
[ 77.505631] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 77.523446] systemd[1]: Mounting POSIX Message Queue File System...
[ 77.544842] systemd[1]: Mounting RPC Pipe File System...
[ 77.565685] systemd[1]: Mounting Kernel Debug File System...
[ 77.581024] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 77.600402] systemd[1]: Started dynamicswap service.
[ 77.629291] systemd[1]: Reached target Swap.
[ 77.659283] systemd[1]: Starting Restore / save the current clock...
[ 77.684011] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 77.705381] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 77.728090] systemd[1]: Starting Journal Service...
[ 77.750222] systemd[1]: Starting Load Kernel Modules...
[ 77.770362] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 77.792018] systemd[1]: Starting udev Coldplug all Devices...
[ 77.825406] systemd[1]: Mounted POSIX Message Queue File System.
[ 77.844909] systemd[1]: Mounted RPC Pipe File System.
[ 77.848851] i2c /dev entries driver
[ 77.871404] systemd[1]: Mounted Kernel Debug File System.
[ 77.886564] systemd[1]: dynamicswap.service: Succeeded.
[ 77.901584] systemd[1]: Started Restore / save the current clock.
[ 77.919091] systemd[1]: Started Create list of static device nodes for the current kernel.
[ 77.938535] systemd[1]: Started Load Kernel Modules.
[ 77.956465] systemd[1]: Started Remount Root and Kernel File Systems.
[ 77.972334] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 77.989795] systemd[1]: Mounting Kernel Configuration File System...
[ 78.005190] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 78.022790] systemd[1]: Starting Load/Save Random Seed...
[ 78.042158] systemd[1]: Starting Apply Kernel Variables...
[ 78.061626] systemd[1]: Starting Create System Users...
[ 78.093774] systemd[1]: Mounted Kernel Configuration File System.
[ 78.118616] systemd[1]: Started Apply Kernel Variables.
[ 78.148278] systemd[1]: Started Journal Service.
[ 78.647014] systemd-journald[210]: Received client request to flush runtime journal.
[ 78.953345] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 78.953813] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 78.954266] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 78.954698] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 78.959406] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 78.961345] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 78.961360] [vc_sm_connected_init]: start
[ 78.982374] [vc_sm_connected_init]: installed successfully
[ 78.987151] media: Linux media interface: v0.10
[ 79.158773] videodev: Linux video capture interface: v2.00
[ 79.273618] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 79.297754] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 79.348635] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 79.404796] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 79.431302] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 79.431337] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 79.448386] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 79.448417] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 79.455644] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 79.455677] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 79.483609] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 79.555746] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 79.591509] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 79.594006] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 79.594022] cfg80211: failed to load regulatory.db
[ 79.597148] bcm2835_audio soc:audio: card created with 8 channels
[ 79.599126] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 79.662615] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 79.768599] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 79.769935] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 79.782691] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 79.783674] usbcore: registered new interface driver brcmfmac
[ 79.785320] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 80.100411] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 80.140424] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 80.257374] brcmfmac: power management disabled
[ 80.425499] 8021q: 802.1Q VLAN Support v1.8
[ 80.433325] pcm512x 1-004d: 1-004d supply AVDD not found, using dummy regulator
[ 80.433410] pcm512x 1-004d: Linked as a consumer to regulator.0
[ 80.433433] pcm512x 1-004d: 1-004d supply DVDD not found, using dummy regulator
[ 80.433512] pcm512x 1-004d: 1-004d supply CPVDD not found, using dummy regulator
[ 80.557526] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> fe203000.i2s mapping ok
[ 80.566609] bcmgenet: Skipping UMAC reset
[ 80.672788] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 80.785048] random: crng init done
[ 80.785060] random: 7 urandom warning(s) missed due to ratelimiting
[ 80.789056] brcmfmac: power management disabled
[ 81.764280] bcmgenet fd580000.genet eth0: Link is Down
[ 85.912034] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[ 87.870156] Bluetooth: Core ver 2.22
[ 87.870207] NET: Registered protocol family 31
[ 87.870211] Bluetooth: HCI device and connection manager initialized
[ 87.870222] Bluetooth: HCI socket layer initialized
[ 87.870230] Bluetooth: L2CAP socket layer initialized
[ 87.870250] Bluetooth: SCO socket layer initialized
[ 87.882204] Bluetooth: HCI UART driver ver 2.3
[ 87.882211] Bluetooth: HCI UART protocol H4 registered
[ 87.882271] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 87.882397] Bluetooth: HCI UART protocol Broadcom registered
[ 88.046271] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 88.046278] Bluetooth: BNEP filters: protocol multicast
[ 88.046289] Bluetooth: BNEP socket layer initialized
bash-5.0#
Some CPU, model info:
[code]bash-5.0# uname -a
Linux volumio 4.19.86-v7l+ #1283 SMP Fri Nov 29 18:37:40 GMT 2019 armv7l GNU/Linux
bash-5.0# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 270.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03112
Serial : 1000000007debc00
Model : Raspberry Pi 4 Model B Rev 1.2
bash-5.0# cat /proc/device-tree/model
Raspberry Pi 4 Model B Rev 1.2bash-5.0#
[/code]
After reboot as boot doesn’t complete and no IP address is assigned I cannot SSH into the Pi. I mounted the SD card on another linux device but I cannot see anything saved about last boot and why it failed.
If you have any idea what I should check I’ll take a look.
