I used your image version 0.005 with kernel 4.19.97-v7l+ armv7l what is the same kernel version which runs on the current Raspbian Buster where I could started Kodi from the command line without any problem.
Actually I donât know anything about a minimum supported kernel version in terms of Kodi. Does it matter if the kernal you have used in the Volumio image 0.005 is the same as in the working Raspbian image?
If I compare the Kodi logs on the Raspbian with those on the Volumio image they look quite similar. But maybe somebody understand the stack trace in the attached crashlog.
It might be a problem with the ALSA device because thatâs the point where the Kodi crashed (last log lines).
(unfortunately attachment with logs or txt extension were not allowed on this forum)
[code]############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Apr 25 19:18:00 UTC 2020
Kodi Options:
Arch: armv7l
Kernel: Linux 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020
Release: Raspbian GNU/Linux 10 (buster)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /core (2020-04-25 19:18:00.000000000 +0000)
[New LWP 1300]
[New LWP 1301]
[New LWP 1302]
[New LWP 1294]
[New LWP 1296]
[New LWP 1298]
[New LWP 1297]
[Thread debugging using libthread_db enabled]
Using host libthread_db library â/lib/arm-linux-gnueabihf/libthread_db.so.1â.
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8 --lircdev /var/run/lirc/lircd --sâ.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0xb6e59904 in snd_config_get_type () from /usr/lib/arm-linux-gnueabihf/libasound.so.2
[Current thread is 1 (Thread 0xaf5ff0d0 (LWP 1300))]
Thread 7 (Thread 0xb09ff0d0 (LWP 1297)):
#0 futex_abstimed_wait_cancelable (private=, abstime=0xb09fe948, expected=0, futex_word=0x37beb10) at âŠ/sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0xb09fe948, mutex=0x0, cond=0x37beae8) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x37beae8, mutex=0x0, abstime=0xb09fe948) at pthread_cond_wait.c:667
#3 0x005a2564 in std::cv_status std::_V2::condition_variable_any::wait_until<XbmcThreads::CRecursiveMutex, std::chrono::_V2::system_clock, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> > >(XbmcThreads::CRecursiveMutex&, std::chrono::time_point<std::chrono::_V2::system_clock, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> > > const&) ()
#4 0x005a262c in XbmcThreads::ConditionVariable::wait(CCriticalSection&, unsigned long) ()
#5 0x005a271c in CEvent::WaitMSec(unsigned int) ()
#6 0x006a9fc0 in CLirc::Process() ()
#7 0x00873018 in CThread::Action() ()
#8 0x00873f18 in CThread::staticThread(void*) ()
#9 0xb6f21494 in start_thread (arg=0xb09ff0d0) at pthread_create.c:486
#10 0xb53e5578 in ?? () at âŠ/sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 6 (Thread 0xaffff0d0 (LWP 1298)):
#0 0xb53e59d0 in epoll_wait (epfd=, events=0xafffe9d0, maxevents=1, timeout=200) at âŠ/sysdeps/unix/sysv/linux/epoll_wait.c:30
#1 0x006aae24 in CLibInputHandler::Process() ()
#2 0x00873018 in CThread::Action() ()
#3 0x00873f18 in CThread::staticThread(void*) ()
#4 0xb6f21494 in start_thread (arg=0xaffff0d0) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x180
Thread 5 (Thread 0xb13540d0 (LWP 1296)):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x3866e98) at âŠ/sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x3866e70) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x3866e70, mutex=0x0) at pthread_cond_wait.c:655
#3 0xb54f3c94 in std::condition_variable::wait(std::unique_lockstd::mutex&) () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
#4 0x00872b18 in void std::_V2::condition_variable_any::waitXbmcThreads::CRecursiveMutex(XbmcThreads::CRecursiveMutex&) ()
#5 0x00c47654 in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#6 0x00873018 in CThread::Action() ()
#7 0x00873f18 in CThread::staticThread(void*) ()
#8 0xb6f21494 in start_thread (arg=0xb13540d0) at pthread_create.c:486
#9 0xb53e5578 in ?? () at âŠ/sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 4 (Thread 0xb1357c60 (LWP 1294)):
#0 futex_abstimed_wait_cancelable (private=, abstime=0xbebb58f8, expected=0, futex_word=0x37e8278) at âŠ/sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0xbebb58f8, mutex=0x0, cond=0x37e8250) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x37e8250, mutex=0x0, abstime=0xbebb58f8) at pthread_cond_wait.c:667
#6 0x0080bd00 in Actor::Protocol::SendOutMessageSync(int, Actor::Message**, int, void*, unsigned int) ()
#7 0x00ce853c in ActiveAE::CActiveAE::Start() ()
#8 0x00a09a64 in CApplication::Create(CAppParamParser const&) ()
#9 0x0088f830 in XBMC_Run ()
#10 0x00519c3c in main ()
Thread 3 (Thread 0xae3ff0d0 (LWP 1302)):
#0 __GI___poll (timeout=-1, nfds=2, fds=0xae400708) at âŠ/sysdeps/unix/sysv/linux/poll.c:29
#1 __GI___poll (fds=0xae400708, nfds=2, timeout=-1) at âŠ/sysdeps/unix/sysv/linux/poll.c:26
#2 0x006b3d00 in CFDEventMonitor::Process() ()
#3 0x00873018 in CThread::Action() ()
#4 0x00873f18 in CThread::staticThread(void*) ()
#5 0xb6f21494 in start_thread (arg=0xae3ff0d0) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x30ec7ff8
Thread 2 (Thread 0xaedfe0d0 (LWP 1301)):
#0 futex_abstimed_wait_cancelable (private=, abstime=0xaedfd958, expected=0, futex_word=0x38e61e8) at âŠ/sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0xaedfd958, mutex=0x0, cond=0x38e61c0) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x38e61c0, mutex=0x0, abstime=0xaedfd958) at pthread_cond_wait.c:667
#6 0x00cf21c0 in ActiveAE::CActiveAESink::Process() ()
#9 0xb6f21494 in start_thread (arg=0xaedfe0d0) at pthread_create.c:486
Thread 1 (Thread 0xaf5ff0d0 (LWP 1300)):
#1 0xb6e5c6a0 in ?? () from /usr/lib/arm-linux-gnueabihf/libasound.so.2
############# END STACK TRACE ###############
################# LOG FILE ##################
2020-04-25 19:17:59.845 T:2973072480 NOTICE: -----------------------------------------------------------------------
2020-04-25 19:17:59.845 T:2973072480 NOTICE: Starting Kodi (18.6 Git:20200310-283bece277). Platform: Linux ARM 32-bit
2020-04-25 19:17:59.845 T:2973072480 NOTICE: Using Release Kodi x32 build
2020-04-25 19:17:59.845 T:2973072480 NOTICE: Kodi compiled 2020-03-22 by GCC 8.3.0 for Linux ARM 32-bit version 4.18.20 (266772)
2020-04-25 19:17:59.845 T:2973072480 NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 4.19.97-v7l+
2020-04-25 19:17:59.852 T:2973072480 NOTICE: FFmpeg version/source: 4.0.4-Kodi
2020-04-25 19:17:59.853 T:2973072480 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
2020-04-25 19:17:59.853 T:2973072480 NOTICE: ARM Features: Neon enabled
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://envhome/ is mapped to: /home/kodi
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://home/ is mapped to: /home/kodi/.kodi
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp
2020-04-25 19:17:59.853 T:2973072480 NOTICE: special://logpath/ is mapped to: /home/kodi/.kodi/temp
2020-04-25 19:17:59.853 T:2973072480 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8
2020-04-25 19:17:59.853 T:2973072480 NOTICE: Local hostname: volumio
2020-04-25 19:17:59.853 T:2973072480 NOTICE: Log File is located: /home/kodi/.kodi/temp/kodi.log
2020-04-25 19:17:59.853 T:2973072480 NOTICE: -----------------------------------------------------------------------
2020-04-25 19:17:59.864 T:2973072480 INFO: loading settings
2020-04-25 19:17:59.865 T:2973072480 NOTICE: special://profile/ is mapped to: special://masterprofile/
2020-04-25 19:17:59.865 T:2973072480 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
2020-04-25 19:17:59.883 T:2973072480 DEBUG: CSkinSettings: no tag found
2020-04-25 19:17:59.884 T:2973072480 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2020-04-25 19:17:59.885 T:2973072480 NOTICE: Contents of special://xbmc/system/advancedsettings.xml areâŠ
<?xml version="1.0" encoding="UTF-8" ?>
720
540
30
31457280
2020-04-25 19:17:59.885 T:2973072480 WARNING: CSettingsManager: missing version attribute
2020-04-25 19:17:59.886 T:2973072480 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2020-04-25 19:17:59.886 T:2973072480 NOTICE: Default Video Player: VideoPlayer
2020-04-25 19:17:59.886 T:2973072480 NOTICE: Default Audio Player: paplayer
2020-04-25 19:17:59.886 T:2973072480 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2020-04-25 19:17:59.886 T:2973072480 NOTICE: Log level changed to âLOG_LEVEL_NORMALâ
2020-04-25 19:18:00.004 T:2973072480 NOTICE: PulseAudio: Server not running
2020-04-25 19:18:00.241 T:2973072480 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: game.controller.default v1.0.8 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: kodi.resource v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.local v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2020-04-25 19:18:00.242 T:2973072480 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: script.module.pil v1.1.7 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: skin.estouchy v2.0.28 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: skin.estuary v2.0.27 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.addon v18.6.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.core v0.1.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.json v10.3.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.python v2.26.0 installed
2020-04-25 19:18:00.243 T:2973072480 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2020-04-25 19:18:00.312 T:2973072480 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
[/code]
Kodi logs on Raspbia Buster:
2020-04-27 19:37:40.541 T:2973203552 NOTICE: -----------------------------------------------------------------------
2020-04-27 19:37:40.541 T:2973203552 NOTICE: Starting Kodi (18.6 Git:20200310-283bece277). Platform: Linux ARM 32-bit
2020-04-27 19:37:40.541 T:2973203552 NOTICE: Using Release Kodi x32 build
2020-04-27 19:37:40.541 T:2973203552 NOTICE: Kodi compiled 2020-03-22 by GCC 8.3.0 for Linux ARM 32-bit version 4.18.20 (266772)
2020-04-27 19:37:40.541 T:2973203552 NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 4.19.97-v7l+
2020-04-27 19:37:40.542 T:2973203552 NOTICE: FFmpeg version/source: 4.0.4-Kodi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
2020-04-27 19:37:40.542 T:2973203552 NOTICE: ARM Features: Neon enabled
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://envhome/ is mapped to: /home/pi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://home/ is mapped to: /home/pi/.kodi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2020-04-27 19:37:40.542 T:2973203552 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2020-04-27 19:37:40.542 T:2973203552 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8
2020-04-27 19:37:40.542 T:2973203552 NOTICE: Local hostname: raspberrypi
2020-04-27 19:37:40.542 T:2973203552 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2020-04-27 19:37:40.545 T:2973203552 NOTICE: -----------------------------------------------------------------------
2020-04-27 19:37:40.546 T:2973203552 INFO: loading settings
2020-04-27 19:37:40.546 T:2973203552 NOTICE: special://profile/ is mapped to: special://masterprofile/
2020-04-27 19:37:40.547 T:2973203552 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
2020-04-27 19:37:40.564 T:2973203552 DEBUG: CSkinSettings: no <skinsettings> tag found
2020-04-27 19:37:40.564 T:2973203552 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2020-04-27 19:37:40.564 T:2973203552 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
2020-04-27 19:37:40.564 T:2973203552 WARNING: CSettingsManager: missing version attribute
2020-04-27 19:37:40.565 T:2973203552 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2020-04-27 19:37:40.565 T:2973203552 NOTICE: Default Video Player: VideoPlayer
2020-04-27 19:37:40.565 T:2973203552 NOTICE: Default Audio Player: paplayer
2020-04-27 19:37:40.565 T:2973203552 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2020-04-27 19:37:40.565 T:2973203552 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2020-04-27 19:37:40.664 T:2973203552 NOTICE: PulseAudio: Server not running
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: game.controller.default v1.0.8 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2020-04-27 19:37:41.439 T:2973203552 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: kodi.resource v1.0.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.local v1.0.0 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2020-04-27 19:37:41.440 T:2973203552 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: script.module.pil v1.1.7 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: skin.estouchy v2.0.28 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: skin.estuary v2.0.27 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.addon v18.6.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.core v0.1.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.json v10.3.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2020-04-27 19:37:41.441 T:2973203552 NOTICE: ADDON: xbmc.python v2.26.0 installed
2020-04-27 19:37:41.442 T:2973203552 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2020-04-27 19:37:41.523 T:2973203552 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2020-04-27 19:37:41.632 T:2942300368 NOTICE: Found 2 Lists of Devices
2020-04-27 19:37:41.632 T:2942300368 NOTICE: Enumerated ALSA devices:
2020-04-27 19:37:41.632 T:2942300368 NOTICE: Device 1
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceName : @
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayNameExtra:
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_channels : FL, FR
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_streamTypes : No passthrough capabilities
2020-04-27 19:37:41.633 T:2942300368 NOTICE: Device 2
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceName : sysdefault:CARD=ALSA
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayName : bcm2835 ALSA
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayNameExtra: bcm2835 ALSA
2020-04-27 19:37:41.633 T:2942300368 NOTICE: Enumerated PI devices:
2020-04-27 19:37:41.633 T:2942300368 NOTICE: Device 1
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceName : HDMI
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayName : HDMI
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_deviceName : Analogue
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_displayName : Analogue
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_sampleRates : 48000
2020-04-27 19:37:41.633 T:2942300368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2020-04-27 19:37:41.633 T:2942300368 NOTICE: Device 3
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_deviceName : Both
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_displayName : HDMI and Analogue
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_displayNameExtra:
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_channels : FL, FR
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_sampleRates : 48000
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2020-04-27 19:37:41.634 T:2942300368 NOTICE: m_streamTypes : No passthrough capabilities
2020-04-27 19:37:42.047 T:2973203552 NOTICE: Raspberry PI firmware version: Feb 12 2020 12:36:21
Copyright (c) 2012 Broadcom
version c3c8dbdf147686fb0c3f32aece709d0653368810 (clean) (release) (start)
2020-04-27 19:37:42.047 T:2973203552 NOTICE: ARM mem: 948MB GPU mem: 76MB MPG2:0 WVC1:0
2020-04-27 19:37:42.047 T:2973203552 NOTICE: Config:
arm_freq=1500
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
hdmi_channel_map=8
init_uart_clock=0x2dc6c00
lcd_framerate=60
mask_gpu_interrupt0=1024
mask_gpu_interrupt1=0x10000
max_framebuffers=2
over_voltage_avs=1250
pause_burst_frames=1
program_serial_random=1
total_mem=4096
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
device_tree=-
overlay_prefix=overlays/
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
2020-04-27 19:37:42.816 T:2973203552 WARNING: CDRMUtils::FindPlane - could not find plane
2020-04-27 19:37:42.817 T:2973203552 WARNING: CDRMUtils::InitDrm - failed to set drm master, will try to authorize instead: Permission denied
2020-04-27 19:37:42.817 T:2973203552 NOTICE: CDRMUtils::InitDrm - successfully authorized drm magic
2020-04-27 19:37:44.424 T:2973203552 NOTICE: Found resolution 2560x1080 with 2560x1080 @ 60.000000 Hz
2020-04-27 19:37:44.424 T:2973203552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 60.000000 Hz
2020-04-27 19:37:44.424 T:2973203552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 59.940063 Hz
2020-04-27 19:37:44.424 T:2973203552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 50.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 30.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 29.970032 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1680x1050 with 1680x1050 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1600x900 with 1600x900 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1280x1024 with 1280x1024 @ 75.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1280x1024 with 1280x1024 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1152x864 with 1152x864 @ 75.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1280x720 with 1280x720 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1280x720 with 1280x720 @ 59.940063 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1024x768 with 1024x768 @ 75.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 800x600 with 800x600 @ 75.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 720x480 with 720x480 @ 59.940063 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 720x480 with 720x480 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 640x480 with 640x480 @ 75.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Previous line repeats 1 times.
2020-04-27 19:37:44.425 T:2973203552 NOTICE: Found resolution 720x400 with 720x400 @ 70.000000 Hz
2020-04-27 19:37:44.427 T:2973203552 NOTICE: EGL_VERSION = 1.4
2020-04-27 19:37:44.427 T:2973203552 NOTICE: EGL_VENDOR = Mesa Project
2020-04-27 19:37:44.427 T:2973203552 NOTICE: EGL_EXTENSIONS = EGL_ANDROID_blob_cache EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display
2020-04-27 19:37:44.427 T:2973203552 NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_wayland EGL_EXT_platform_x11 EGL_MESA_platform_gbm EGL_MESA_platform_surfaceless EGL_EXT_platform_device
2020-04-27 19:37:44.476 T:2973203552 NOTICE: Checking resolution 16
2020-04-27 19:37:44.617 T:2973203552 WARNING: CGBMUtils::DestroySurface - surface already destroyed
2020-04-27 19:37:44.679 T:2973203552 NOTICE: GL_VENDOR = Broadcom
2020-04-27 19:37:44.679 T:2973203552 NOTICE: GL_RENDERER = V3D 4.2
2020-04-27 19:37:44.679 T:2973203552 NOTICE: GL_VERSION = OpenGL ES 3.1 Mesa 19.3.2
2020-04-27 19:37:44.679 T:2973203552 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.10
2020-04-27 19:37:44.679 T:2973203552 NOTICE: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT_primitive_bounding_box GL_EXT_shader_io_blocks GL_EXT_texture_border_clamp GL_EXT_texture_norm16 GL_KHR_context_flush_control GL_NV_image_formats GL_OES_draw_elements_base_vertex GL_OES_primitive_bounding_box GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_EXT_buffer_storage GL_EXT_float_blend GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_OES_shader_image_atomic GL_MESA_shader_integer_functions GL_KHR_parallel_shader_compile GL_MESA_framebuffer_flip_y GL_EXT_texture_query_lod
2020-04-27 19:37:45.279 T:2764468432 NOTICE: Running database version Addons27
2020-04-27 19:37:45.939 T:2973203552 NOTICE: start dvd mediatype detection
2020-04-27 19:37:45.973 T:2973203552 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2020-04-27 19:37:46.246 T:2973203552 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2020-04-27 19:37:46.293 T:2973203552 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2020-04-27 19:37:46.293 T:2973203552 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2020-04-27 19:37:46.294 T:2973203552 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2020-04-27 19:37:46.295 T:2973203552 NOTICE: Loaded playercorefactory configuration
2020-04-27 19:37:46.295 T:2973203552 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2020-04-27 19:37:46.295 T:2973203552 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2020-04-27 19:37:46.310 T:2973203552 NOTICE: initialize done
2020-04-27 19:37:46.310 T:2973203552 NOTICE: Running the application...
2020-04-27 19:37:46.315 T:2973203552 NOTICE: starting zeroconf publishing
2020-04-27 19:37:46.316 T:2657923280 NOTICE: ES: Starting UDP Event server on port 9777
2020-04-27 19:37:46.316 T:2657923280 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2020-04-27 19:37:46.331 T:2973203552 NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2020-04-27 19:37:46.333 T:2622980304 NOTICE: Creating InputStream
2020-04-27 19:37:46.333 T:2622980304 ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2020-04-27 19:37:46.333 T:2622980304 NOTICE: CVideoPlayer::OnExit()
2020-04-27 19:37:46.541 T:2708279504 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2020-04-27 19:37:46.791 T:2973203552 NOTICE: CVideoPlayer::CloseFile()
2020-04-27 19:37:46.791 T:2973203552 NOTICE: VideoPlayer: waiting for threads to exit
2020-04-27 19:37:46.791 T:2973203552 NOTICE: VideoPlayer: finished waiting
2020-04-27 19:37:53.343 T:2973203552 NOTICE: Stopping player
2020-04-27 19:37:53.343 T:2973203552 NOTICE: Storing total System Uptime
2020-04-27 19:37:53.343 T:2973203552 NOTICE: Saving settings
2020-04-27 19:37:53.349 T:2973203552 NOTICE: Saving skin settings
2020-04-27 19:37:53.350 T:2973203552 NOTICE: Stopping all
2020-04-27 19:37:54.040 T:2973203552 NOTICE: ES: Stopping event server
2020-04-27 19:37:54.041 T:2973203552 NOTICE: stopping zeroconf publishing
2020-04-27 19:37:54.324 T:2657923280 NOTICE: ES: UDP Event server stopped
2020-04-27 19:37:54.328 T:2973203552 NOTICE: stop dvd detect media
2020-04-27 19:37:54.471 T:2973203552 NOTICE: Application stopped
2020-04-27 19:37:54.671 T:2973203552 NOTICE: XBApplicationEx: destroying...
2020-04-27 19:37:56.284 T:2973203552 NOTICE: unload skin
2020-04-27 19:37:56.343 T:2973203552 NOTICE: unload sections
2020-04-27 19:37:56.700 T:2973203552 NOTICE: XBApplicationEx: application stopped!
