Volumio Plugins Collection
Virtual Keyboard
The plugin uses “matchbox-keyboard” along with the “matchbox-window-manager” to provide an onscreen keyboard which can be useful especially when the only input device is a touchscreen. It requires the Touch Display plugin to be installed.
From the configuration page of the plugin a keyboard layout can be chosen. The plugin currently provides keyboard layouts only for some languages but custom keyboards can be built. To be accessible by the plugin keyboard layout files need to be saved in “/data/plugins/miscellanea/virtual_keyboard/layouts/name of the language/keyboard.xml”. “name of the language” should be descriptive like “English - UK” as this will appear as an entry in the list box on the configuration page of the plugin. If multiple keyboard variants for the same language are desired each variants’ “keyboard.xml” needs its separate folder.
How to obtain: Volumio plugin store
Author: gvolt
Volumio version: 2
Status: stable on Raspberry Pi
Disussion: [PLUGIN] Virtual Keyboard
Jellyfin
Plugin for playing audio from one or more Jellyfin media servers
Source: https://github.com/patrickkfkan/volumio-jellyfin
Installation: Volumio UI → Plugins → Music Services
Author: patrickkfkan
Volumio version: 2 and 3
Plugin status: Stable on Rpi/x86
Discussion: [PLUGIN] Jellyfin
YouTube2
Plugin for browsing YouTube videos and playing audio streams
Source: https://github.com/patrickkfkan/volumio-youtube2
Installation:
Volumio 3: Volumio UI → Plugins → Music Services
Volumio 2: GitHub - patrickkfkan/volumio-youtube2 at volumio-2.x
Volumio version: 2* and 3
Discussion: [PLUGIN] YouTube2
*Volumio 2.x ships with an outdated version of MPD. This has implications on playback of YouTube streams. Check the Installation and Discussion links for more information (and fix).
SoundCloud
Plugin for playing SoundCloud tracks
Source: https://github.com/patrickkfkan/volumio-soundcloud
Installation:
Volumio 3 : Volumio UI → Plugins → Music Services
Volumio 2 : GitHub - patrickkfkan/volumio-soundcloud at volumio-2.x
Discussion: [PLUGIN] SoundCloud
*Volumio 2.x ships with an outdated version of MPD. This has implications on playback of some SoundCloud tracks. Check the Installation link for more information (and fix).
Bandcamp Discover
Plugin for discovering Bandcamp music
Source: https://github.com/patrickkfkan/volumio-bandcamp
Installation:
Volumio 3 : Plugin submitted to plugin store; pending review.
Volumio 2 : Volumio UI → Plugins → Music Services
Plugin status: Stable on RPi/x86
Discussion: [PLUGIN] Bandcamp Discover
Mixcloud
Plugin for playing Mixcloud shows
Source: https://github.com/patrickkfkan/volumio-mixcloud
Installation:
Volumio 2 : GitHub - patrickkfkan/volumio-mixcloud at volumio-2.x
Discussion: [PLUGIN] Mixcloud
YouTube Cast Receiver
Plugin that enables Volumio to act as a cast device for the YouTube mobile app or website
Source: https://github.com/patrickkfkan/volumio-ytcr
Installation:
Volumio 2 : GitHub - patrickkfkan/volumio-ytcr at volumio-2.x
Discussion: [PLUGIN] YouTube Cast Receiver
Randomizer
This plugin provides three user buttons. One button will browse your music library and select a number of random tracks, place them in the queue and start playing them. The second will load and play a random album. The third will load and play the album of the currently playing track.
Source: Volumio UI - Search Plugins: Miscellanea
Author: Redlawd
Volumio 2 & 3
Status Stable RPi3
More Info: [PLUGIN] Randomizer Plugin
Philips AmbX
Basic control of the AmbX LEDs
How to obtain the plugin: Volumio UI
Author name: @Xerusial
Volumio version: 2 & 3
Plugin status: stable on RPi3
Further discussion: here
RotaryEncoder II (Version 1.0.12)
Alternative implementation of Rotary Encoder controls using the Linux Kernel driver for Rotaries. It also offers additional features compared to the original RotaryEncoder Plugin.
Documentation including tips for hardware debouncing is available on the Volumio Documentation for this plugin.
Plugin is available on the Plugin-Store for Volumio 2 (1.0.7) and for Volumio 3.
Latest development version on Github.
The compatibility with Volumio 2 is no longer tested since I am only using Volumio 3.
Author: 7h0mas-R
Tested with Volumio3
Stable on RPi3
For discussion use this topic: [PLUGIN] RotaryEncoder II
Music Services Shield (Version 1.2.0)
This plugin separates Volumio music processes from other processes. It allows you to select the CPUs and the process priority for selected music services.
Source: Volumio UI - Search Plugins: Miscellanea. Also Releases · petecallaghan/volumio-plugins · GitHub
Author: Pete Callaghan
Status: stable
Volumio version: 2*
More info : [PLUGIN] Music Services Shield
Notes: Works with MPD and Spotify Connect
Open issues here: Issues · petecallaghan/volumio-plugins · GitHub
A post was split to a new topic: Podcasts Plugin
[PLUGIN] SerialAmpController
Control Amplifiers with Serial Interface from Volumio (e.g. ROTEL A12/A11/A14)
The plugin allows to control amplifiers that support control via Serial Interface from Volumio.
Supported functions are volume and mute from the Volumio GUI and some additional features like:
  • defining max volume
  • defining startup volume
  • map to 100
  • pausing and resuming when amp is muted
  • pausing and resuming when input source of amp is changed
  • switching to the correct source when play is pressed on volumio
  • start playback when Amp is powered up
The configuration of the serial interface and the commands to send to the amps are stored in a json file that can easily be extended to support other models and brands.
ROTEL A12 is included and tested. ROTEL A14 and A11 are included (since the documentation was available to me) but have not been tested, since I only have an A12 (I did some simulation with the A12, however).
On request, I recently added a Meridian DSP420 implementation, but I did not hear yet, if it works.
A pull request is pending. If you are not risk averse, you can download a zipped archive for manual install in Volumio3 here
Sources are in my repo.
  • Author: 7h0mas-R
  • Volumio version: Tested with
    • 3.139, 3.213, 3.251
    • Volumio 2 will no longer be supported since I do not use any Volumio 2 system anymore
  • Supported Amplifiers:
    • tested
      • ROTEL – A12
    • untested
      • ROTEL – A11/A14 (partly simulated with A12)
      • MERIDIAN – DSP420
  • Plugin status: stable on RPi3 with ROTEL A12 and GooBay USB2Serial Adapter with Prolific Chipset
  • Discussions and feedback here
  • Version History:
    • 1.0.0: Initial version developed for Volumio 2. Used spawn to implement the interface communication using bash shell
    • 2.0.0: Complete remake for Volumio 3, replacing the spawn solution by use of SerialPort.io package and restructuring the RegEx implementation of the Amp-Message responses
    • 2.0.2: After the PR was stale for quite some time - I submitted a new one on a separate branch to disentangle it from my other plugin and tidied up the history. No other changes.
Now Playing
Provides a ‘Now Playing’ screen for Volumio devices with connected displays
Source: https://github.com/patrickkfkan/volumio-now-playing
Installation:
Volumio 3 : Volumio UI → Plugins → User Interface
Volumio 2 : Volumio UI → Plugins → Miscellaneous
Discussion: [PLUGIN] Now Playing
m3u_importer
This is a m3u playlist importer plugin for Volumio which makes it easy to import simple or extended M3U playlists.
Install file download: https://github.com/skiphansen/volumio-plugins
Source: volumio-plugins/plugins/miscellanea/m3u_importer at master · skiphansen/volumio-plugins · GitHub
Author: Skip Hansen
Status: beta
Discussion: [PLUGIN] m3u_importer
So far only tested by the author on a Rpi4, but since it’s 100% Javascript and
has no hardware dependencies it is expected it to run on other platforms
without a problem.
Nanosound One
Platform: Raspberry Pi
Author: Nanomesher
Status: stable
Github project : https://github.com/nanomesher/volumio-plugins/tree/master/plugins/miscellanea/nanosoundone
Touch Display Lite
Touch Display Lite is a clean and fast user interface for Volumio 3. It works with the official 7-inch touch screen and other touch screens.
Source: Releases · zf3/volumio_touch_display_lite · GitHub
File to download: touch_display_lite.zip
Author: fenzo
Status: Beta
Volumio version: 3
Discussion: [Plugin] Touch Display Lite
Hello, I am interested in using your plugin. How do I access it? It does not appear on the list of plugins. Thanks in advance.
Dan
Thank You for your speedy response. Have a great day!
Dan
