Volumio Plugins Collection
Volusonic
Plugin that allows any subsonic API (<1.13.0) capable server ( subsonic / airsonic / etc…) to be used as backend for Volumio.
Main menu provide:
  • Randoms albums
  • Newest albums
  • Genres
  • Artists
  • Playlists
  • Podcasts
Albums special feature
  • LastFM infos when available
Artists Specials Features:
  • Radio mode: generate a playlist of similar tracks present on the backend
  • Top songs as defined on lastFM
  • Links to similar artists present on the backend
Platform:
Raspberry Pi; tested on 3. It should be platform agnostic though.
Author: foobarjo
Status: released
subsonic: subsonic.org
airsonic: airsonic.github.io/
Pandora Plugin
Plugin that connects to the Pandora service.
Users can listen to their existing Pandora stations. Users can skip tracks they don’t like.
Thumbs up / Thumbs down is currently not supported. If elements can be added somehow to the GUI, this may change in the future.
Cover art and song information is displayed in the playback window.
The code is currently available here. Instructions for installation are on that page.
A pull request has been made and has been awaiting approval for a few months now. I think it’s ready for production, but of course that’s not up to me.
The plugin is powered by the Anesidora Node JS library (uses the Unofficial Pandora API).
@lostmyshape helped me with coding suggestions, and @srhamil added a fix that helps with an intermittent connectivity issue.
Thanks to the Volumio developers for making the project open and allowing for outside developers like myself to join in. I have learned a lot about Javascript and Node JS while doing this project. I hope to try another plugin in the future.
You can reach me here on the forum, my username is truckershitch. All messages are welcome. I will try to answer them in a timely fashion. For some reason, I do not get instant notifications when I get a message or on the forums, so I have to check manually.
Systeminfos
This plugin gives informations about your system (cpu, mem, kernel)
source : github.com/balbuze/volumio-plug … Systeminfo
File to download : github.com/balbuze/volumio-plug … p?raw=true
Author : Balbuze
Status : beta
Another last.fm scrobbler - I can’t get the lastfm one to work consistently.
This only scrobbles, there’s no last.fm user interface. I might look into adding that as a separat plugin later.
I know very little javascript and node, so I’m learning as i walk.
It’s pretty stable, so I will share.
github: github.com/oisteink/volumio-plu … fmscrobble
file: github.com/oisteink/volumio-plu … p?raw=true
Roon Bridge
Stream music from Roon to Volumio.
Author: Christopher Rieke
Version: 1.0.0
Source: from the Volumio UI.
Nanosound CD
Nanosound CD playback and extraction plugin by Nanomesher.
Author: Nanomesher
Version: 1.1.7
Allo Relay Volume Attenuator
This plugin enables Allo’s relay volume attenuator.
Author: The Volumio Team
Version: 1.3.0
Source: From the Volumio UI.
FritzCallMute
Mute on phone calls via FritzBox router.
Author: clmtrapp
Version: 1.0.1
Amplifier Switch
Status based power management of external amplifier.
Author: Tim Lange
Version: 0.1.1
Tradfri
Switch Tradfri devices on/off based on the Volumio player state.
Author: Rene Schuenemann
Version: 1.0.0
GPIO Control
GPIO output control plugin for Volumio.
Author: supercrab
Version: 0.0.1
Radio Nowy Swiat Plugin
The Radio Nowy Swiat plugin allows to play their stream within volumio. nowyswiat.online.
Features:
  • listening to normal streams in mp3 quality
  • metadata (cover, artist, title)
Platform:
Raspberry Pi; tested on 1B and 4. It should be platform agnostic though.
Installable through volumio plugins menu.
Author: DJack
Status: stable
Github project : https://github.com/djack2017/volumio-plugins-1/tree/master/plugins/music_service/nowyswiat
SWARM Station Plugin
The SWARM Station plugin allows to play their stream within volumio.
http://swarmstation.fm/ This station is independent and non-commercial.
This internet radio station tries to immerse you in a certain feeling.
To let you escape for a moment, hear relaxing music and enjoy this feeling.
Features:
listening to normal streams in 320kbps quality
Platform:
Author: DJack
Status: stable
Github project : https://github.com/djack2017/volumio-plugins-1/tree/master/plugins/music_service/swarmstation
Radio 357 Plugin
The Radio 357 plugin allows to play their stream within volumio. radio357.pl .
Features:
Platform:
Author: DJack
Status: stable
Github project : https://github.com/djack2017/volumio-plugins-1/tree/master/plugins/music_service/radio357
Pirateaudio Plugin
A plugin that allows the user to use the 1.3" display and the 4 buttons on the pimoroni pirate audio dac.
Works with Pirate Audio:
  • Headphone Amp
  • 3W Stereo Amp
  • Line-out
Author: AxLED
Version: 0.0.4
Source and installation: From the Volumio UI.
Features:
  • use your pi and pirate audio standalone
  • show coverart and button icons
  • show text for title, album, artist and remaining time
  • show volumebar and progressbar
  • play / pause
  • volume up/down
  • browse music sources
  • seek +/-
  • prev/next song
  • Sleeptimer
  • shutdown/restart pi
Platform:
Raspberry Pi; tested on Raspberry Pi Zero W (should work on other pi’s as well).
suggested volumio settings:
  • Output device: “HiFiBerry DAC”
  • Volume setting -> type of mixer: “Software”
Supported musicservices:
  • basic volumio services
  • Podcast plugin
  • Spotify plugin
Forum post: [Plugin] pirate audio
mpd_oled Plugin
Here’s a plugin that provides an easy way to install and configure the popular mpd_oled project! The mpd_oled application drives an OLED screen and displays Volumio status information and a real time spectrum analyser.
Platform: Raspberry Pi
Instructions/ & ource: volumio-plugins/plugins/miscellanea/mpd_oled at master · supercrab/volumio-plugins · GitHub
Author: supercrab
Status: stable
Forum post: [PLUGIN] MPD OLED - installation & configuration plugin
Cisco DUO 2FA plugin
Volumio 2 plugin to enable 2FA for SSH with Cisco DUO (free for personal use). Because changing the volumio password could break updates and plugin installation. This method hardens SSH security without breaking functionality; also you can determine whether or not it should fail-open or fail-close (e.g. when DUO can’t be reached).
Platform: Raspberry Pi & x86/x64
Depends on source code by Cisco DUO, build instructions can be found on GitHub
Github project: GitHub - Saiyato/volumio-duo-plugin: A DUO plugin compiled for Volumio (Debian Jessie) on 32-bit ARM platforms
File to download : https://github.com/Saiyato/volumio-duo-plugin/raw/master/volumio-duo-plugin.zip
Author: Saiyato
Status: stable
Forum post: [PLUGIN] Cisco DUO 2FA for SSH
Status2mqtt
Volumio plugin that sends volumio status to a given mqtt server.
Platform: any
Depends on Node JS mqtt
Infos:
The volumio state is sent as soon as it changes and provides a JSON payload that include the state, the album, the author and the title.
The plugin allows the use of mqtts, and login/password authentication (optional).
Author: jit
Installation: from the Plugins section in the Volumio UI.
Status: stable
ledstatus
Volumio plugin that blink a gpio led while playing.
Platform: any that have a GPIO kernel interface
Depends on Node JS onoff
Infos:
The delay between on and off can be customized
Author: jit
Status: stable
gpiorandom
Play a randomized playlist, play a web radio or toggle play / pause uppon single, double and / or triple click on a GPIO wired button
Infos:
By wiring a button to a GPIO pin that support interrupt (eg: gpio 3 on rpi), this plugins detect single, double and triple click. It is possible to assign an action to each.
The timing used to detect the number of clicks can be customized
Author: jit
Status: stable
