Plugin submitted to Volumio 3 plugin store. If you do not see it there, enable “Plugins Test Mode” in http://<volumio_address>/dev. If you still do not see it, that means the plugin has not yet been accepted and you are advised to wait.
Volumio 2.x
The plugin requires manual installation, instructions for which you can find in the volumio-2.x branch of the Github repo:
And no, this plugin does not support user login, so it will only give you publicly-accessible stuff. It doesn’t support Live shows as well – haven’t figured out how to do that
You can report issues here and suggestions are welcome.
it’s not 1 point in 10 minutes you will have it … if i go back to a spot without sound and start
from there again i have sound again… but cuts off again … the cuts seem to be random.
i had it from 1.35 till 7.28 between that i have seen the cutt off of the sound stream still
running but no sound… 3.015 …ash …Music Player Daemon 0.21.5
creating live log at the moment for you : it’s saying a lot of:
Starting Live Log...
info: [youtube2-auth] Access token not obtained. Will try again in 6s
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
info: CoreCommandRouter::volumioSeek
info: CoreStateMachine::seek
info: TRACKBLOCK {"service":"mixcloud","uri":"mixcloud/cloudcast@cloudcastId=Q2xvdWRjYXN0OjIxNTI1MDE2MzE%3D@owner=tombauminista","type":"track","albumart":"https://thumbnailer.mixcloud.com/unsafe/600x600/extaudio/3/1/0/c/61c8-76c5-4c98-af5b-3afab66e7277","artist":"Tom Bauminista","album":"","name":"Dub Conference #295 (2021/02/28) never sell out","title":"Dub Conference #295 (2021/02/28) never sell out"}
info: CoreStateMachine::startPlaybackTimer
info: CoreStateMachine::setConsumeUpdateService mpd
info: ControllerMpd::seek
error: null
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info: ControllerMpd::pushState
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus play
info: Received an update from plugin. extracting info from payload
info: ------------------------------ 28ms
info: [youtube2-auth] Starting auth flow...
info: [youtube2-auth] Start polling for access token...
$ mpc
Tom Bauminista - Dub Conference #295 (2021/02/28) never sell out
[playing] #1/1 9:33/127:33 (7%)
volume: 40% repeat: off random: off single: off consume: off
Do this a few times. See if there’s an error and whether the time / percentage increases. As you can see, I’m now at 9:33 minutes into the show and it’s still playing.
nope it stays like this:
volumio@volumio:~$ mpc
[playing] #1/1 4:10/127:33 (3%)
volume: 78% repeat: off random: off single: off consume: off
volumio@volumio:~$
it stopped at 4.10 and repeating mpc makes no changes…
volumio@volumio:~$
player still running at 9 min now no sound...mpc doesn't show that...
oke we will keep the versions of ash to test and skip the new beta release
@patrickkfkan
still testing that song :
if i put seek past 10 min and start playing it…it will play it full ( 127.33 min ) without any cuts.
could this be the preview playing? instead of the full session.
it looks like some ( prev ) timer is triggered in the first 10 min…
i tested it twice with a reboot in the middle trigger seems to be there
after 10min i can play it till the end. it looks like a trigger in the first 10 min. that is what i could say…
