Volumio 3 RC1 Beta Testing - Odroid images
Please use this topic to discuss errors, missing components or improvement suggestions during the Volumio 3 RC1 beta test phase for Odroid devices.
In this opening and first following post I will keep a list of beta versions, fixes, known problems and important updates.
Before reporting issues, please also refer to volumio-3-rc1-open-beta-testing for known general issues.
Current version
Odroid C0/C1/C1+/ C2/ C4/ N2/ N2+ and XU4
Feel free to try them, most things should work now.
C4 users: please refer to the “Note on DAC Usage” in this thread
C0/C1/C1+ (RC1)
Volumiobuster-3.136-2021-11-05-odroidc1
C2 (RC1)
Volumiobuster-3.136-2021-11-05-odroidc2
C4 (RC1)
Volumiobuster-3.136-2021-11-05-odroidc4
N2/N2+ (RC1)
Volumiobuster-3.136-2021-11-05-odroidn2
XU4 (RC1)
Volumiobuster-3.136-2021-11-05-odroidxu4
Previous versions
C0/C1/C1+
Volumiobuster-3.066-2021-04-16-odroidc1
Volumiobuster-3.063-2021-04-14-odroidc1
C2
Volumiobuster-3.066-2021-04-16-odroidc2
Volumiobuster-3.063-2021-04-14-odroidc2
C4
Volumiobuster-3.066-2021-04-16-odroidc4
Volumiobuster-3.063-2021-04-14-odroidc4
N2/N2+
Volumiobuster-3.066-2021-04-16-odroidn2
Volumiobuster-3.063-2021-04-14-odroidn2
Volumiobuster-3.039-2021-02-22-odroidn2
XU4
No history
3.063 Odroid C4
Not indexing NAS … log full of repeated attempts to start hostapd/hotspot even though no wireless connected.
systemlog.txt (277.7 KB)
this is standard Volumio behavior at the moment, this is an issue on x86 as well. Makes log analysis not easier :wink:
I’ll look into the indexing problems, we seem to have general issues with MPD, so this may be related.
  1. Added USB wifi dongle to get rid of hostapd rubbish in system log. mpd service running ok.
volumio@volumiostudy:~$ sudo systemctl status mpd
● mpd.service - Music Player Daemon
   Loaded: loaded (/lib/systemd/system/mpd.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2021-04-15 10:32:06 UTC; 23min ago
     Docs: man:mpd(1)
           man:mpd.conf(5)
  Process: 5448 ExecStartPre=/usr/bin/touch /var/log/mpd.log (code=exited, status=0/SUCCESS)
  Process: 5471 ExecStartPre=/bin/chown volumio /var/log/mpd.log (code=exited, status=0/SUCCESS)
 Main PID: 5476 (mpd)
    Tasks: 3 (limit: 3843)
   Memory: 6.3M
   CGroup: /system.slice/mpd.service
           └─5476 /usr/bin/mpd --no-daemon
  1. Nothing in /var/log/mpd.log.
  2. Nothing in journalctl -u mpd
volumio@volumiostudy:~$ date
Thu Apr 15 10:58:24 UTC 2021
volumio@volumiostudy:~$ sudo journalctl -u mpd
-- Logs begin at Thu 2021-04-15 10:31:13 UTC, end at Thu 2021-04-15 10:58:32 UTC. --
Apr 15 10:31:15 volumiostudy systemd[1]: Starting Music Player Daemon...
Apr 15 10:31:17 volumiostudy mpd[4377]: Apr 15 10:31 : exception: Decoder plugin 'wildmidi' is unavailable: configuration file does not
Apr 15 10:31:17 volumiostudy systemd[1]: Started Music Player Daemon.
Apr 15 10:31:32 volumiostudy systemd[1]: Stopping Music Player Daemon...
Apr 15 10:31:32 volumiostudy systemd[1]: mpd.service: Succeeded.
Apr 15 10:31:32 volumiostudy systemd[1]: Stopped Music Player Daemon.
Apr 15 10:31:32 volumiostudy systemd[1]: Starting Music Player Daemon...
Apr 15 10:31:33 volumiostudy mpd[4961]: Apr 15 10:31 : exception: Decoder plugin 'wildmidi' is unavailable: configuration file does not
Apr 15 10:31:33 volumiostudy systemd[1]: Started Music Player Daemon.
Apr 15 10:31:35 volumiostudy systemd[1]: Stopping Music Player Daemon...
Apr 15 10:31:35 volumiostudy systemd[1]: mpd.service: Succeeded.
Apr 15 10:31:35 volumiostudy systemd[1]: Stopped Music Player Daemon.
Apr 15 10:31:35 volumiostudy systemd[1]: Starting Music Player Daemon...
Apr 15 10:31:52 volumiostudy mpd[5197]: Apr 15 10:31 : exception: Decoder plugin 'wildmidi' is unavailable: configuration file does not
Apr 15 10:31:52 volumiostudy systemd[1]: Started Music Player Daemon.
Apr 15 10:32:05 volumiostudy systemd[1]: Stopping Music Player Daemon...
Apr 15 10:32:05 volumiostudy systemd[1]: mpd.service: Succeeded.
Apr 15 10:32:05 volumiostudy systemd[1]: Stopped Music Player Daemon.
Apr 15 10:32:05 volumiostudy systemd[1]: Starting Music Player Daemon...
Apr 15 10:32:06 volumiostudy mpd[5476]: Apr 15 10:32 : exception: Decoder plugin 'wildmidi' is unavailable: configuration file does not
Apr 15 10:32:06 volumiostudy systemd[1]: Started Music Player Daemon.
lines 1-22/22 (END)
  1. System log looks as though mpd is scanning ok, but no tracks appearing indexed.
systemlog2.txt (129.4 KB)
On my Odroid-N2 is the same problem.
Updated versions published, see OP.
Indexing fine now thank you. Music library in UI disappears & returns occasionally (I’ve seen someone else report this in one of the other beta tests).
hostapd & BT complaints no longer present in log.
Edit: Music library in UI is (possibly) stable … only saw the changes a couple of times in the first period after updating.
interesting, I was not aware of this fix.
XU4 now also added
Now. With Volumiobuster-3.066 it can scan and indexing NAS fully on my Odroid-N2.
Thank for gkkpch very much.
Thank you for providing this. Although I have raspberry pi 4 also, Odroid XU4 is always my favorite…
Running 3.066-2021-04-16 on a C1+.
Not seeing any PlugIns available. I need my RadioParadise fix. :slight_smile:
*** Update *** Just found the “invite” thread, which mentions not to install PlugIns. Guess I need to be patient.
A post was split to a new topic: DACS for Odroid C2
Would it be possible to have an image for 3.101 for a clean flash please?
3.101 will be announced today for RPi, x86 and Tinkerboard.
However, I have not done any alpha testing yet on Odroid devices since 3.066
Perhaps there is time next week, but no promises.
What the improvements of version 3 over version 2?
You don’t really expect to get an answer to that, do you???
Check the forum and read for yourself😉
Please notice we have moved to the Volumio 3 RC1 beta testing for all Odroid devices, see OP.
C0/C1/C1+ (RC1)
C2 (RC1)
C4 (RC1)
N2/N2+ (RC1)
XU4 (RC1)
Great stuff :+1:
Can you upgrade using system upgrade in the settings?
