sure, anything else, sir?
volumio@volumio:~$ cat /var/log/Xorg.0.log
[ 410.458]
X.Org X Server 1.20.4
[ 410.458] Build Operating System: Linux 5.10.0-10-amd64 x86_64 Debian
[ 410.458] Current Operating System: Linux volumio 6.6.29-volumio #2 SMP PREEMPT_DYNAMIC Wed May 1 21:05:45 CEST 2024 x86_64
[ 410.458] Kernel command line: BOOT_IMAGE=/vmlinuz initramfs.clear splash plymouth.ignore-serial-consoles quiet loglevel=0 biosdevname=0 imgpart=UUID=215c22ec-0d91-428d-bdaa-2623fe31c27e bootpart=UUID=74C4-DAE0 datapart=UUID=c8c476dc-7b1b-4948-a64d-d8c475478624 hwdevice=x86 uuidconfig=syslinux.cfg,efi/BOOT/grub.cfg imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_default=0 acpi_backlight=vendor net.ifnames=0 use_kmsg=no
[ 410.458] Build Date: 18 December 2021 09:05:36AM
[ 410.458] xorg-server 2:1.20.4-1+deb10u4 (Debian -- User Support)
[ 410.458] Current version of pixman: 0.36.0
[ 410.458] Before reporting problems, check http://wiki.x.org
[ 410.458] Markers: (â) probed, () from config file, (==) default setting,
[ 410.459] (==) Log file: â/var/log/Xorg.0.logâ, Time: Tue May 7 18:25:35 2024
[ 410.474] (==) Using system config directory â/usr/share/X11/xorg.conf.dâ
[ 410.476] (==) No Layout section. Using the first Screen section.
[ 410.476] (==) No screen section available. Using defaults.
[ 410.476] () |â>Screen âDefault Screen Sectionâ (0)
[ 410.476] (**) | |â>Monitor ââ
[ 410.476] (==) No monitor specified for screen âDefault Screen Sectionâ.
[ 410.476] (==) Automatically adding devices
[ 410.476] (==) Automatically enabling devices
[ 410.476] (==) Automatically adding GPU devices
[ 410.493] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 410.495] (WW) The directory â/usr/share/fonts/X11/cyrillicâ does not exist.
[ 410.495] Entry deleted from font path.
[ 410.513] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 410.513] (==) ModulePath set to â/usr/lib/xorg/modulesâ
[ 410.513] (II) The server relies on udev to provide the list of input devices.
[ 410.513] (II) Loader magic: 0x55ec4851ae20
[ 410.513] (II) Module ABI versions:
[ 410.513] X.Org ANSI C Emulation: 0.4
[ 410.513] X.Org Video Driver: 24.0
[ 410.513] X.Org XInput driver : 24.1
[ 410.513] X.Org Server Extension : 10.0
[ 410.514] (â) using VT number 2
[ 410.515] (EE) systemd-logind: failed to get session: PID 1090 does not belong to any known session
[ 410.516] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 410.534] (â) PCI:*(0@0:2:0) 8086:5a85:1849:5a85 rev 11, Mem @ 0x90000000/16777216, 0x80000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 410.534] (II) LoadModule: âglxâ
[ 410.536] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 410.606] (II) Module glx: vendor=âX.Org Foundationâ
[ 410.606] compiled for 1.20.4, module version = 1.0.0
[ 410.606] ABI class: X.Org Server Extension, version 10.0
[ 410.606] (==) Matched modesetting as autoconfigured driver 0
[ 410.606] (==) Matched fbdev as autoconfigured driver 1
[ 410.606] (==) Matched vesa as autoconfigured driver 2
[ 410.606] (==) Assigned the driver to the xf86ConfigLayout
[ 410.606] (II) LoadModule: âmodesettingâ
[ 410.611] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 410.617] (II) Module modesetting: vendor=âX.Org Foundationâ
[ 410.617] compiled for 1.20.4, module version = 1.20.4
[ 410.617] Module class: X.Org Video Driver
[ 410.617] ABI class: X.Org Video Driver, version 24.0
[ 410.617] (II) LoadModule: âfbdevâ
[ 410.617] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 410.622] (II) Module fbdev: vendor=âX.Org Foundationâ
[ 410.622] compiled for 1.20.0, module version = 0.5.0
[ 410.622] Module class: X.Org Video Driver
[ 410.622] ABI class: X.Org Video Driver, version 24.0
[ 410.622] (II) LoadModule: âvesaâ
[ 410.623] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 410.627] (II) Module vesa: vendor=âX.Org Foundationâ
[ 410.627] compiled for 1.20.1, module version = 2.4.0
[ 410.627] Module class: X.Org Video Driver
[ 410.628] ABI class: X.Org Video Driver, version 24.0
[ 410.628] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 410.628] (II) FBDEV: driver for framebuffer: fbdev
[ 410.628] (II) VESA: driver for VESA chipsets: vesa
[ 410.647] (II) modeset(0): using drv /dev/dri/card0
[ 410.647] (WW) Falling back to old probe method for fbdev
[ 410.647] (II) Loading sub module âfbdevhwâ
[ 410.647] (II) LoadModule: âfbdevhwâ
[ 410.648] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 410.652] (II) Module fbdevhw: vendor=âX.Org Foundationâ
[ 410.652] compiled for 1.20.4, module version = 0.0.2
[ 410.652] ABI class: X.Org Video Driver, version 24.0
[ 410.653] (II) modeset(0): Creating default Display subsection in Screen section
âDefault Screen Sectionâ for depth/fbbpp 24/32
[ 410.653] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 410.653] (==) modeset(0): RGB weight 888
[ 410.653] (==) modeset(0): Default visual is TrueColor
[ 410.653] (II) Loading sub module âglamoreglâ
[ 410.653] (II) LoadModule: âglamoreglâ
[ 410.658] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 410.703] (II) Module glamoregl: vendor=âX.Org Foundationâ
[ 410.703] compiled for 1.20.4, module version = 1.0.1
[ 410.703] ABI class: X.Org ANSI C Emulation, version 0.4
[ 411.071] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 500 (Broxton 2x6)
[ 411.071] (II) modeset(0): glamor initialized
[ 411.139] (II) modeset(0): Output DP-1 has no monitor section
[ 411.140] (II) modeset(0): Output HDMI-1 has no monitor section
[ 411.140] (II) modeset(0): Output DP-2 has no monitor section
[ 411.204] (II) modeset(0): EDID for output DP-1
[ 411.204] (II) modeset(0): Manufacturer: SAM Model: 1018 Serial#: 1129861170
[ 411.204] (II) modeset(0): Year: 2021 Week: 13
[ 411.204] (II) modeset(0): EDID Version: 1.3
[ 411.204] (II) modeset(0): Digital Display Input
[ 411.204] (II) modeset(0): Max Image Size [cm]: horiz.: 63 vert.: 36
[ 411.204] (II) modeset(0): Gamma: 2.20
[ 411.204] (II) modeset(0): DPMS capabilities: Off
[ 411.204] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 411.204] (II) modeset(0): First detailed timing is preferred mode
[ 411.204] (II) modeset(0): redX: 0.679 redY: 0.312 greenX: 0.268 greenY: 0.617
[ 411.204] (II) modeset(0): blueX: 0.146 blueY: 0.062 whiteX: 0.313 whiteY: 0.329
[ 411.204] (II) modeset(0): Supported established timings:
[ 411.204] (II) modeset(0): 720x400@70Hz
[ 411.204] (II) modeset(0): 640x480@60Hz
[ 411.204] (II) modeset(0): 640x480@67Hz
[ 411.204] (II) modeset(0): 640x480@72Hz
[ 411.204] (II) modeset(0): 640x480@75Hz
[ 411.204] (II) modeset(0): 800x600@56Hz
[ 411.204] (II) modeset(0): 800x600@60Hz
[ 411.204] (II) modeset(0): 800x600@72Hz
[ 411.204] (II) modeset(0): 800x600@75Hz
[ 411.204] (II) modeset(0): 832x624@75Hz
[ 411.204] (II) modeset(0): 1024x768@60Hz
[ 411.204] (II) modeset(0): 1024x768@70Hz
[ 411.204] (II) modeset(0): 1024x768@75Hz
[ 411.204] (II) modeset(0): 1280x1024@75Hz
[ 411.204] (II) modeset(0): 1152x864@75Hz
[ 411.204] (II) modeset(0): Manufacturerâs mask: 0
[ 411.204] (II) modeset(0): Supported standard timings:
[ 411.204] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 411.204] (II) modeset(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 411.204] (II) modeset(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 411.204] (II) modeset(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 411.204] (II) modeset(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 411.204] (II) modeset(0): #5: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 411.204] (II) modeset(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 411.204] (II) modeset(0): Supported detailed timing:
[ 411.204] (II) modeset(0): clock: 594.0 MHz Image Size: 632 x 360 mm
[ 411.204] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 411.204] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 411.204] (II) modeset(0): Ranges: V min: 40 V max: 60 Hz, H min: 30 H max: 135 kHz, PixClock max 605 MHz
[ 411.204] (II) modeset(0): Monitor name: LU28R55
[ 411.204] (II) modeset(0): Serial No: H4ZR307172
[ 411.204] (II) modeset(0): clock: 148.5 MHz Image Size: 632 x 360 mm
[ 411.204] (II) modeset(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 411.204] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 411.204] (II) modeset(0): clock: 241.5 MHz Image Size: 632 x 360 mm
[ 411.204] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 411.204] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 411.204] (II) modeset(0): clock: 297.0 MHz Image Size: 632 x 360 mm
[ 411.204] (II) modeset(0): Number of EDID sections to follow: 1
[ 411.204] (II) modeset(0): EDID (in hex):
[ 411.204] (II) modeset(0): 00ffffffffffff004c2d181032505843
[ 411.204] (II) modeset(0): 0d1f0103803f24782ac8b5ad50449e25
[ 411.204] (II) modeset(0): 0f5054bfef80714f810081c081809500
[ 411.204] (II) modeset(0): a9c0b300010108e80030f2705a80b058
[ 411.204] (II) modeset(0): 8a0078682100001e000000fd00283c1e
[ 411.205] (II) modeset(0): 873c000a202020202020000000fc004c
[ 411.205] (II) modeset(0): 5532385235350a2020202020000000ff
[ 411.205] (II) modeset(0): 0048345a523330373137320a202001cf
[ 411.205] (II) modeset(0): 02033ef04961120313041f10605f2309
[ 411.205] (II) modeset(0): 070783010000e305c0006b030c001000
[ 411.205] (II) modeset(0): b83c2000200167d85dc401788003e20f
[ 411.205] (II) modeset(0): 81681a00000101283c00e3060501023a
[ 411.205] (II) modeset(0): 80d072382d40102c458078682100001e
[ 411.205] (II) modeset(0): 565e00a0a0a029503020350078682100
[ 411.205] (II) modeset(0): 001a04740030f2705a80b0588a007868
[ 411.205] (II) modeset(0): 2100001e00000000000000000000003a
[ 411.205] (â) modeset(0): HDMI max TMDS frequency 300000KHz
[ 411.205] (II) modeset(0): Printing probed modes for output DP-1
[ 411.205] (II) modeset(0): Modeline "3840x2160"x60.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz eP)
[ 411.205] (II) modeset(0): Modeline "3840x2160"x50.0 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "3840x2160"x59.9 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[ 411.205] (II) modeset(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 411.205] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 411.205] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 411.205] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 411.205] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 411.205] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 411.205] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 411.205] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 411.205] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 411.205] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 411.205] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 411.205] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 411.205] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 411.205] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 411.205] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 411.205] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 411.205] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 411.206] (II) modeset(0): EDID for output HDMI-1
[ 411.206] (II) modeset(0): EDID for output DP-2
[ 411.206] (II) modeset(0): Output DP-1 connected
[ 411.206] (II) modeset(0): Output HDMI-1 disconnected
[ 411.206] (II) modeset(0): Output DP-2 disconnected
[ 411.206] (II) modeset(0): Using exact sizes for initial modes
[ 411.206] (II) modeset(0): Output DP-1 using initial mode 3840x2160 +0+0
[ 411.206] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 411.206] (==) modeset(0): DPI set to (96, 96)
[ 411.206] (II) Loading sub module âfbâ
[ 411.206] (II) LoadModule: âfbâ
[ 411.210] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 411.212] (II) Module fb: vendor=âX.Org Foundationâ
[ 411.212] compiled for 1.20.4, module version = 1.0.0
[ 411.212] ABI class: X.Org ANSI C Emulation, version 0.4
[ 411.212] (II) UnloadModule: âfbdevâ
[ 411.212] (II) Unloading fbdev
[ 411.212] (II) UnloadSubModule: âfbdevhwâ
[ 411.212] (II) Unloading fbdevhw
[ 411.212] (II) UnloadModule: âvesaâ
[ 411.212] (II) Unloading vesa
[ 411.411] (==) modeset(0): Backing store enabled
[ 411.411] (==) modeset(0): Silken mouse enabled
[ 411.514] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 411.514] (==) modeset(0): DPMS enabled
[ 411.515] (II) modeset(0): [DRI2] Setup complete
[ 411.515] (II) modeset(0): [DRI2] DRI driver: i965
[ 411.515] (II) modeset(0): [DRI2] VDPAU driver: i965
[ 411.515] (II) Initializing extension Generic Event Extension
[ 411.515] (II) Initializing extension SHAPE
[ 411.516] (II) Initializing extension MIT-SHM
[ 411.516] (II) Initializing extension XInputExtension
[ 411.516] (II) Initializing extension XTEST
[ 411.516] (II) Initializing extension BIG-REQUESTS
[ 411.517] (II) Initializing extension SYNC
[ 411.517] (II) Initializing extension XKEYBOARD
[ 411.517] (II) Initializing extension XC-MISC
[ 411.517] (II) Initializing extension SECURITY
[ 411.517] (II) Initializing extension XFIXES
[ 411.518] (II) Initializing extension RENDER
[ 411.518] (II) Initializing extension RANDR
[ 411.518] (II) Initializing extension COMPOSITE
[ 411.519] (II) Initializing extension DAMAGE
[ 411.519] (II) Initializing extension MIT-SCREEN-SAVER
[ 411.519] (II) Initializing extension DOUBLE-BUFFER
[ 411.519] (II) Initializing extension RECORD
[ 411.519] (II) Initializing extension DPMS
[ 411.520] (II) Initializing extension Present
[ 411.520] (II) Initializing extension DRI3
[ 411.520] (II) Initializing extension X-Resource
[ 411.520] (II) Initializing extension XVideo
[ 411.521] (II) Initializing extension XVideo-MotionCompensation
[ 411.521] (II) Initializing extension SELinux
[ 411.521] (II) SELinux: Disabled on system
[ 411.521] (II) Initializing extension GLX
[ 412.650] (II) AIGLX: Loaded and initialized i965
[ 412.650] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 412.650] (II) Initializing extension XFree86-VidModeExtension
[ 412.650] (II) Initializing extension XFree86-DGA
[ 412.651] (II) Initializing extension XFree86-DRI
[ 412.651] (II) Initializing extension DRI2
[ 412.668] (II) modeset(0): Damage tracking initialized
[ 412.668] (II) modeset(0): Setting screen physical size to 1016 x 571
[ 413.097] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 413.097] () Video Bus: Applying InputClass âlibinput keyboard catchallâ
[ 413.097] (II) LoadModule: âlibinputâ
[ 413.098] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 413.123] (II) Module libinput: vendor=âX.Org Foundationâ
[ 413.123] compiled for 1.20.4, module version = 0.28.2
[ 413.123] Module class: X.Org XInput Driver
[ 413.123] ABI class: X.Org XInput driver, version 24.1
[ 413.123] (II) Using input driver âlibinputâ for âVideo Busâ
[ 413.123] () Video Bus: always reports core events
[ 413.123] () Option âDeviceâ â/dev/input/event5â
[ 413.123] () Option â_sourceâ âserver/udevâ
[ 413.142] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 413.142] (II) event5 - Video Bus: device is a keyboard
[ 413.143] (II) event5 - Video Bus: device removed
[ 413.160] () Option âconfig_infoâ âudev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event5â
[ 413.160] (II) XINPUT: Adding extended input device âVideo Busâ (type: KEYBOARD, id 6)
[ 413.160] () Option âxkb_modelâ âpc105â
[ 413.160] () Option âxkb_layoutâ âusâ
[ 413.162] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 413.162] (II) event5 - Video Bus: device is a keyboard
[ 413.163] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 413.163] () Power Button: Applying InputClass âlibinput keyboard catchallâ
[ 413.163] (II) Using input driver âlibinputâ for âPower Buttonâ
[ 413.163] () Power Button: always reports core events
[ 413.163] () Option âDeviceâ â/dev/input/event0â
[ 413.163] () Option â_sourceâ âserver/udevâ
[ 413.165] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 413.165] (II) event0 - Power Button: device is a keyboard
[ 413.165] (II) event0 - Power Button: device removed
[ 413.180] () Option âconfig_infoâ âudev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0â
[ 413.180] (II) XINPUT: Adding extended input device âPower Buttonâ (type: KEYBOARD, id 7)
[ 413.180] () Option âxkb_modelâ âpc105â
[ 413.180] () Option âxkb_layoutâ âusâ
[ 413.181] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 413.181] (II) event0 - Power Button: device is a keyboard
[ 413.183] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event10)
[ 413.183] (II) No input driver specified, ignoring this device.
[ 413.183] (II) This device may have been added with another device file.
[ 413.183] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 413.184] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[ 413.184] (II) No input driver specified, ignoring this device.
[ 413.184] (II) This device may have been added with another device file.
[ 413.185] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event13)
[ 413.185] (II) No input driver specified, ignoring this device.
[ 413.185] (II) This device may have been added with another device file.
[ 413.186] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[ 413.186] (II) No input driver specified, ignoring this device.
[ 413.186] (II) This device may have been added with another device file.
[ 413.186] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 413.187] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event8)
[ 413.187] (II) No input driver specified, ignoring this device.
[ 413.187] (II) This device may have been added with another device file.
[ 413.188] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event9)
[ 413.188] (II) No input driver specified, ignoring this device.
[ 413.188] (II) This device may have been added with another device file.
[ 413.189] (II) config/udev: Adding input device CHESEN PS2 to USB Converter (/dev/input/event1)
[ 413.189] () CHESEN PS2 to USB Converter: Applying InputClass âlibinput keyboard catchallâ
[ 413.189] (II) Using input driver âlibinputâ for âCHESEN PS2 to USB Converterâ
[ 413.189] () CHESEN PS2 to USB Converter: always reports core events
[ 413.189] () Option âDeviceâ â/dev/input/event1â
[ 413.189] () Option â_sourceâ âserver/udevâ
[ 413.192] (II) event1 - CHESEN PS2 to USB Converter: is tagged by udev as: Keyboard
[ 413.192] (II) event1 - CHESEN PS2 to USB Converter: device is a keyboard
[ 413.192] (II) event1 - CHESEN PS2 to USB Converter: device removed
[ 413.212] () Option âconfig_infoâ âudev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.0/0003:0A81:0205.0001/input/input1/event1â
[ 413.212] (II) XINPUT: Adding extended input device âCHESEN PS2 to USB Converterâ (type: KEYBOARD, id 8)
[ 413.212] () Option âxkb_modelâ âpc105â
[ 413.212] () Option âxkb_layoutâ âusâ
[ 413.214] (II) event1 - CHESEN PS2 to USB Converter: is tagged by udev as: Keyboard
[ 413.214] (II) event1 - CHESEN PS2 to USB Converter: device is a keyboard
[ 413.216] (II) config/udev: Adding input device CHESEN PS2 to USB Converter Mouse (/dev/input/event2)
[ 413.216] () CHESEN PS2 to USB Converter Mouse: Applying InputClass âlibinput pointer catchallâ
[ 413.216] (II) Using input driver âlibinputâ for âCHESEN PS2 to USB Converter Mouseâ
[ 413.216] () CHESEN PS2 to USB Converter Mouse: always reports core events
[ 413.216] () Option âDeviceâ â/dev/input/event2â
[ 413.216] () Option â_sourceâ âserver/udevâ
[ 413.219] (II) event2 - CHESEN PS2 to USB Converter Mouse: is tagged by udev as: Mouse
[ 413.219] (II) event2 - CHESEN PS2 to USB Converter Mouse: device is a pointer
[ 413.219] (II) event2 - CHESEN PS2 to USB Converter Mouse: device removed
[ 413.236] () Option âconfig_infoâ âudev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.1/0003:0A81:0205.0002/input/input2/event2â
[ 413.236] (II) XINPUT: Adding extended input device âCHESEN PS2 to USB Converter Mouseâ (type: MOUSE, id 9)
[ 413.236] () Option âAccelerationSchemeâ ânoneâ
[ 413.236] () CHESEN PS2 to USB Converter Mouse: (accel) selected scheme none/0
[ 413.236] () CHESEN PS2 to USB Converter Mouse: (accel) acceleration factor: 2.000
[ 413.236] () CHESEN PS2 to USB Converter Mouse: (accel) acceleration threshold: 4
[ 413.239] (II) event2 - CHESEN PS2 to USB Converter Mouse: is tagged by udev as: Mouse
[ 413.239] (II) event2 - CHESEN PS2 to USB Converter Mouse: device is a pointer
[ 413.241] (II) config/udev: Adding input device CHESEN PS2 to USB Converter Mouse (/dev/input/mouse0)
[ 413.241] (II) No input driver specified, ignoring this device.
[ 413.241] (II) This device may have been added with another device file.
[ 413.242] (II) config/udev: Adding input device CHESEN PS2 to USB Converter System Control (/dev/input/event3)
[ 413.242] () CHESEN PS2 to USB Converter System Control: Applying InputClass âlibinput keyboard catchallâ
[ 413.242] (II) Using input driver âlibinputâ for âCHESEN PS2 to USB Converter System Controlâ
[ 413.242] () CHESEN PS2 to USB Converter System Control: always reports core events
[ 413.242] () Option âDeviceâ â/dev/input/event3â
[ 413.242] () Option â_sourceâ âserver/udevâ
[ 413.245] (II) event3 - CHESEN PS2 to USB Converter System Control: is tagged by udev as: Keyboard
[ 413.245] (II) event3 - CHESEN PS2 to USB Converter System Control: device is a keyboard
[ 413.245] (II) event3 - CHESEN PS2 to USB Converter System Control: device removed
[ 413.272] () Option âconfig_infoâ âudev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.1/0003:0A81:0205.0002/input/input3/event3â
[ 413.272] (II) XINPUT: Adding extended input device âCHESEN PS2 to USB Converter System Controlâ (type: KEYBOARD, id 10)
[ 413.272] () Option âxkb_modelâ âpc105â
[ 413.272] () Option âxkb_layoutâ âusâ
[ 413.274] (II) event3 - CHESEN PS2 to USB Converter System Control: is tagged by udev as: Keyboard
[ 413.274] (II) event3 - CHESEN PS2 to USB Converter System Control: device is a keyboard
[ 413.276] (II) config/udev: Adding input device CHESEN PS2 to USB Converter Consumer Control (/dev/input/event4)
[ 413.276] () CHESEN PS2 to USB Converter Consumer Control: Applying InputClass âlibinput keyboard catchallâ
[ 413.276] (II) Using input driver âlibinputâ for âCHESEN PS2 to USB Converter Consumer Controlâ
[ 413.276] () CHESEN PS2 to USB Converter Consumer Control: always reports core events
[ 413.276] () Option âDeviceâ â/dev/input/event4â
[ 413.276] () Option â_sourceâ âserver/udevâ
[ 413.278] (II) event4 - CHESEN PS2 to USB Converter Consumer Control: is tagged by udev as: Keyboard
[ 413.278] (II) event4 - CHESEN PS2 to USB Converter Consumer Control: device is a keyboard
[ 413.278] (II) event4 - CHESEN PS2 to USB Converter Consumer Control: device removed
[ 413.292] () Option âconfig_infoâ âudev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.1/0003:0A81:0205.0002/input/input4/event4â
[ 413.292] (II) XINPUT: Adding extended input device âCHESEN PS2 to USB Converter Consumer Controlâ (type: KEYBOARD, id 11)
[ 413.292] () Option âxkb_modelâ âpc105â
[ 413.292] () Option âxkb_layoutâ âusâ
[ 413.294] (II) event4 - CHESEN PS2 to USB Converter Consumer Control: is tagged by udev as: Keyboard
[ 413.295] (II) event4 - CHESEN PS2 to USB Converter Consumer Control: device is a keyboard
volumio@volumio:~$
