Keep checking ricardo.ch! At the moment there aren’t any. Usually sold in lots of 5, around 50-60 CHF each. Ebay sometimes lists them as well.
Hi, gkkpck,
I am ready to submit a patch. I have no previous experience. How do I get in contact with you
Hi, I want to solve the problem with the HP t510 terminal PC, the wired network does not work, I see that you tried to solve the problem with the user tepiloxtl, but it seems he quit, as for the sound, I will use the usb audio that is detected and works, I upload dmesg debian 11, if you need something else, I’m ready to experiment, I can switch hard drives volumio >> debian.
debian11-dmesg
root@radio:/home/radio# dmesg
[ 0.000000] Linux version 5.10.0-18-amd64 (debian-kernel@lists.debian.org) (g cc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2 ) #1 SMP Debian 5.10.140-1 (2022-09-02)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-18-amd64 root=UUID= 2bbcd638-c7cc-4537-adf0-380891400dac ro quiet
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000dffcffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dffd0000-0x00000000dffddfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000dffde000-0x00000000dffeffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dfff0000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fecc0000-0x00000000fecc0fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000117ffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: Hewlett-Packard HP t5570e Thin Client/158Ch, BIOS 786R9 v1.0 4 11/10/2011
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 997.503 MHz processor
[ 0.018153] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.018181] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.018221] last_pfn = 0x118000 max_arch_pfn = 0x400000000
[ 0.018236] MTRR default type: uncachable
[ 0.018244] MTRR fixed ranges enabled:
[ 0.018253] 00000-9FFFF write-back
[ 0.018262] A0000-DFFFF uncachable
[ 0.018270] E0000-EFFFF write-through
[ 0.018277] F0000-FFFFF write-protect
[ 0.018284] MTRR variable ranges enabled:
[ 0.018294] 0 base 000000000 mask F00000000 write-back
[ 0.018303] 1 base 100000000 mask FE0000000 write-back
[ 0.018312] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.018321] 3 base 0E0000000 mask FF8000000 uncachable
[ 0.018327] 4 disabled
[ 0.018334] 5 disabled
[ 0.018340] 6 disabled
[ 0.018347] 7 disabled
[ 0.018754] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.019114] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.019151] last_pfn = 0xdffd0 max_arch_pfn = 0x400000000
[ 0.095007] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.103561] RAMDISK: [mem 0x348a9000-0x3644bfff]
[ 0.103577] ACPI: Early table checksum verification disabled
[ 0.103593] ACPI: RSDP 0x00000000000FA170 000024 (v02 ACPIAM)
[ 0.103623] ACPI: XSDT 0x00000000DFFD0100 000054 (v01 111011 XSDT1519 2011111 0 MSFT 00000097)
[ 0.103663] ACPI: FACP 0x00000000DFFD0290 0000F4 (v04 111011 FACP1519 2011111 0 MSFT 00000097)
[ 0.103705] ACPI: DSDT 0x00000000DFFD0430 00499F (v02 786R9 786R9104 0000010 4 INTL 20051117)
[ 0.103739] ACPI: FACS 0x00000000DFFDE000 000040
[ 0.103767] ACPI: FACS 0x00000000DFFDE000 000040
[ 0.103796] ACPI: APIC 0x00000000DFFD0390 000060 (v02 111011 APIC1519 2011111 0 MSFT 00000097)
[ 0.103828] ACPI: MCFG 0x00000000DFFD03F0 00003C (v01 111011 OEMMCFG 2011111 0 MSFT 00000097)
[ 0.103860] ACPI: OEMB 0x00000000DFFDE040 000082 (v01 111011 OEMB1519 2011111 0 MSFT 00000097)
[ 0.103892] ACPI: HPET 0x00000000DFFDA430 000038 (v01 111011 VIA HPET 2011111 0 MSFT 00000097)
[ 0.103924] ACPI: SSDT 0x00000000DFFDE0D0 00023A (v01 AMI P001PM 0000000 1 INTL 20051117)
[ 0.103953] ACPI: Reserving FACP table memory at [mem 0xdffd0290-0xdffd0383]
[ 0.103962] ACPI: Reserving DSDT table memory at [mem 0xdffd0430-0xdffd4dce]
[ 0.103970] ACPI: Reserving FACS table memory at [mem 0xdffde000-0xdffde03f]
[ 0.103977] ACPI: Reserving FACS table memory at [mem 0xdffde000-0xdffde03f]
[ 0.103985] ACPI: Reserving APIC table memory at [mem 0xdffd0390-0xdffd03ef]
[ 0.103992] ACPI: Reserving MCFG table memory at [mem 0xdffd03f0-0xdffd042b]
[ 0.104000] ACPI: Reserving OEMB table memory at [mem 0xdffde040-0xdffde0c1]
[ 0.104008] ACPI: Reserving HPET table memory at [mem 0xdffda430-0xdffda467]
[ 0.104016] ACPI: Reserving SSDT table memory at [mem 0xdffde0d0-0xdffde309]
[ 0.104069] ACPI: Local APIC address 0xfee00000
[ 0.104241] No NUMA configuration found
[ 0.104249] Faking a node at [mem 0x0000000000000000-0x0000000117ffffff]
[ 0.104303] NODE_DATA(0) allocated [mem 0x117fd4000-0x117ffdfff]
[ 0.107736] Zone ranges:
[ 0.107743] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.107756] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.107769] Normal [mem 0x0000000100000000-0x0000000117ffffff]
[ 0.107781] Device empty
[ 0.107792] Movable zone start for each node
[ 0.107807] Early memory node ranges
[ 0.107815] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.107823] node 0: [mem 0x0000000000100000-0x00000000dffcffff]
[ 0.107834] node 0: [mem 0x0000000100000000-0x0000000117ffffff]
[ 0.107843] Initmem setup node 0 [mem 0x0000000000001000-0x0000000117ffffff]
[ 0.107854] On node 0 totalpages: 1015662
[ 0.107862] DMA zone: 64 pages used for memmap
[ 0.107869] DMA zone: 21 pages reserved
[ 0.107876] DMA zone: 3998 pages, LIFO batch:0
[ 0.107884] DMA32 zone: 14272 pages used for memmap
[ 0.107891] DMA32 zone: 913360 pages, LIFO batch:63
[ 0.107898] Normal zone: 1536 pages used for memmap
[ 0.107905] Normal zone: 98304 pages, LIFO batch:31
[ 0.107926] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.108197] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.170857] On node 0, zone Normal: 48 pages in unavailable ranges
[ 0.170908] Looks like a VIA chipset. Disabling IOMMU. Override with iommu=al lowed
[ 0.171117] ACPI: PM-Timer IO Port: 0x808
[ 0.171132] ACPI: Local APIC address 0xfee00000
[ 0.171192] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
[ 0.171211] IOAPIC[1]: apic_id 2, version 3, address 0xfecc0000, GSI 24-47
[ 0.171228] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.171238] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.171250] ACPI: IRQ0 used by override.
[ 0.171259] ACPI: IRQ9 used by override.
[ 0.171275] Using ACPI (MADT) for SMP configuration information
[ 0.171288] ACPI: HPET id: 0x11068201 base: 0xfed00000
[ 0.171309] smpboot: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.171396] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x0000 0fff]
[ 0.171408] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009 ffff]
[ 0.171416] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000d ffff]
[ 0.171422] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000f ffff]
[ 0.171435] PM: hibernation: Registered nosave memory: [mem 0xdffd0000-0xdffd dfff]
[ 0.171442] PM: hibernation: Registered nosave memory: [mem 0xdffde000-0xdffe ffff]
[ 0.171448] PM: hibernation: Registered nosave memory: [mem 0xdfff0000-0xdfff ffff]
[ 0.171455] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xfebf ffff]
[ 0.171462] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec0 0fff]
[ 0.171469] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecb ffff]
[ 0.171476] PM: hibernation: Registered nosave memory: [mem 0xfecc0000-0xfecc 0fff]
[ 0.171483] PM: hibernation: Registered nosave memory: [mem 0xfecc1000-0xfedf ffff]
[ 0.171490] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee0 0fff]
[ 0.171496] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffef ffff]
[ 0.171503] PM: hibernation: Registered nosave memory: [mem 0xfff00000-0xffff ffff]
[ 0.171514] [mem 0xe0000000-0xfebfffff] available for PCI devices
[ 0.171521] Booting paravirtualized kernel on bare hardware
[ 0.171536] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffff ffff, max_idle_ns: 7645519600211568 ns
[ 0.190854] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:1 nr_cpu_ids:1 nr_node _ids:1
[ 0.192093] percpu: Embedded 58 pages/cpu s200664 r8192 d28712 u2097152
[ 0.192130] pcpu-alloc: s200664 r8192 d28712 u2097152 alloc=1*2097152
[ 0.192141] pcpu-alloc: [0] 0
[ 0.192303] Built 1 zonelists, mobility grouping on. Total pages: 999769
[ 0.192310] Policy zone: Normal
[ 0.192320] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-18-amd64 roo t=UUID=2bbcd638-c7cc-4537-adf0-380891400dac ro quiet
[ 0.194762] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes , linear)
[ 0.195897] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.196003] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.304410] Memory: 3671456K/4062648K available (12295K kernel code, 2536K rw data, 7576K rodata, 2648K init, 3444K bss, 199284K reserved, 0K cma-reserved)
[ 0.305799] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.305902] Kernel/User page tables isolation: enabled
[ 0.305998] ftrace: allocating 36478 entries in 143 pages
[ 0.400216] ftrace: allocated 143 pages with 5 groups
[ 0.400854] rcu: Hierarchical RCU implementation.
[ 0.400862] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=1.
[ 0.400868] Rude variant of Tasks RCU enabled.
[ 0.400873] Tracing variant of Tasks RCU enabled.
[ 0.400879] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.400885] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.434130] NR_IRQS: 524544, nr_irqs: 256, preallocated irqs: 16
[ 0.436609] Console: colour VGA+ 80x25
[ 0.436684] printk: console [tty0] enabled
[ 0.436772] ACPI: Core revision 20200925
[ 0.437101] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_i dle_ns: 133484882848 ns
[ 0.437134] APIC: Switch to symmetric I/O mode setup
[ 0.438140] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.457140] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1c c1c09636a, max_idle_ns: 881590567670 ns
[ 0.457158] Calibrating delay loop (skipped), value calculated using timer fr equency.. 1995.00 BogoMIPS (lpj=3990012)
[ 0.457174] pid_max: default: 32768 minimum: 301
[ 0.457518] LSM: Security Framework initializing
[ 0.457583] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.457783] AppArmor: AppArmor initialized
[ 0.457793] TOMOYO Linux initialized
[ 0.457968] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line ar)
[ 0.458012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.459361] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.459369] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.459383] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user poin ter sanitization
[ 0.459391] Spectre V2 : Mitigation: Retpolines
[ 0.459397] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on c ontext switch
[ 0.459402] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.459408] Speculative Store Bypass: Vulnerable
[ 0.459419] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.459424] MMIO Stale Data: Unknown: No mitigations
[ 0.549543] Freeing SMP alternatives memory: 32K
[ 0.666096] smpboot: CPU0: Centaur VIA Nano U3500@1000MHz (family: 0x6, model : 0xf, stepping: 0xa)
[ 0.667024] Performance Events:
[ 0.667027] core: Welcome to zhaoxin pmu!
[ 0.667032] core: Version check pass!
[ 0.667035] ZXC events, zhaoxin PMU driver.
[ 0.667047] ... version: 2
[ 0.667051] ... bit width: 40
[ 0.667054] ... generic registers: 2
[ 0.667058] ... value mask: 000000ffffffffff
[ 0.667062] ... max period: 0000007fffffffff
[ 0.667065] ... fixed-purpose events: 3
[ 0.667069] ... event mask: 0000000700000003
[ 0.667492] rcu: Hierarchical SRCU implementation.
[ 0.669149] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.669149] smp: Bringing up secondary CPUs ...
[ 0.669149] smp: Brought up 1 node, 1 CPU
[ 0.669149] smpboot: Max logical packages: 1
[ 0.669149] smpboot: Total of 1 processors activated (1995.00 BogoMIPS)
[ 0.673619] node 0 deferred pages initialised in 8ms
[ 0.674808] devtmpfs: initialized
[ 0.675046] x86/mm: Memory block size: 128MB
[ 0.677912] PM: Registering ACPI NVS region [mem 0xdffde000-0xdffeffff] (7372 8 bytes)
[ 0.678183] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.678204] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.678407] pinctrl core: initialized pinctrl subsystem
[ 0.679725] NET: Registered protocol family 16
[ 0.680210] audit: initializing netlink subsys (disabled)
[ 0.680933] thermal_sys: Registered thermal governor 'fair_share'
[ 0.680938] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.680943] thermal_sys: Registered thermal governor 'step_wise'
[ 0.680947] thermal_sys: Registered thermal governor 'user_space'
[ 0.680951] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.680966] cpuidle: using governor ladder
[ 0.680971] cpuidle: using governor menu
[ 0.681105] ACPI: bus type PCI registered
[ 0.681112] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.681499] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xef ffffff] (base 0xe0000000)
[ 0.681508] PCI: not using MMCONFIG
[ 0.681524] PCI: Using configuration type 1 for base access
[ 0.685203] audit: type=2000 audit(1665914784.240:1): state=initialized audit _enabled=0 res=1
[ 0.687103] Kprobes globally optimized
[ 0.687721] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.509789] ACPI: Added _OSI(Module Device)
[ 1.509796] ACPI: Added _OSI(Processor Device)
[ 1.509801] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 1.509806] ACPI: Added _OSI(Processor Aggregator Device)
[ 1.509812] ACPI: Added _OSI(Linux-Dell-Video)
[ 1.509819] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 1.509825] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 1.527434] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 1.533498] ACPI: Interpreter enabled
[ 1.533557] ACPI: (supports S0 S5)
[ 1.533563] ACPI: Using IOAPIC for interrupt routing
[ 1.533691] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xef ffffff] (base 0xe0000000)
[ 1.533834] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI mot herboard resources
[ 1.533858] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a h uge-page mapping due to MTRR override.
[ 1.536822] PCI: Using host bridge windows from ACPI; if necessary, use "pci= nocrs" and report a bug
[ 1.537729] ACPI: Enabled 7 GPEs in block 00 to 0F
[ 1.537745] ACPI: Enabled 1 GPEs in block 10 to 1F
[ 1.559852] ACPI: Power Resource [URP1] (off)
[ 1.560038] ACPI: Power Resource [URP2] (off)
[ 1.560220] ACPI: Power Resource [FDDP] (off)
[ 1.560400] ACPI: Power Resource [LPTP] (off)
[ 1.575877] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.575898] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM S egments MSI HPX-Type3]
[ 1.577146] acpi PNP0A03:00: ignoring host bridge window [mem 0x000d0000-0x00 0dffff window] (conflicts with Adapter ROM [mem 0x000ce800-0x000d07ff])
[ 1.578146] PCI host bridge to bus 0000:00
[ 1.578157] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 1.578164] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.578171] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff win dow]
[ 1.578178] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff win dow]
[ 1.578185] pci_bus 0000:00: root bus resource [mem 0x400000000-0xfffffffff w indow]
[ 1.578192] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.578236] pci 0000:00:00.0: [1106:0410] type 00 class 0x060000
[ 1.578690] pci 0000:00:00.1: [1106:1410] type 00 class 0x060000
[ 1.579209] pci 0000:00:00.2: [1106:2410] type 00 class 0x060000
[ 1.579704] pci 0000:00:00.3: [1106:3410] type 00 class 0x060000
[ 1.580253] pci 0000:00:00.4: [1106:4410] type 00 class 0x060000
[ 1.580764] pci 0000:00:00.5: [1106:5410] type 00 class 0x060000
[ 1.581313] pci 0000:00:00.6: [1106:6410] type 00 class 0x060000
[ 1.581810] pci 0000:00:00.7: [1106:7410] type 00 class 0x060000
[ 1.582318] pci 0000:00:01.0: [1106:7122] type 00 class 0x030000
[ 1.582339] pci 0000:00:01.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 1.582352] pci 0000:00:01.0: reg 0x14: [mem 0xfc000000-0xfcffffff]
[ 1.582365] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf7ffffff pref]
[ 1.582394] pci 0000:00:01.0: reg 0x30: [mem 0xfbff0000-0xfbffffff pref]
[ 1.582444] pci 0000:00:01.0: supports D1 D2
[ 1.582886] pci 0000:00:01.1: [1106:9170] type 00 class 0x040300
[ 1.582906] pci 0000:00:01.1: reg 0x10: [mem 0xfbfec000-0xfbfeffff]
[ 1.582988] pci 0000:00:01.1: supports D1 D2
[ 1.583432] pci 0000:00:03.0: [1106:a410] type 01 class 0x060400
[ 1.583566] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 1.584141] pci 0000:00:03.1: [1106:b410] type 01 class 0x060400
[ 1.584270] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 1.584822] pci 0000:00:03.2: [1106:c410] type 01 class 0x060400
[ 1.584957] pci 0000:00:03.2: PME# supported from D0 D3hot D3cold
[ 1.585518] pci 0000:00:03.3: [1106:d410] type 01 class 0x060400
[ 1.585656] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[ 1.586189] pci 0000:00:03.4: [1106:e410] type 00 class 0x060000
[ 1.586640] pci 0000:00:0f.0: [1106:9001] type 00 class 0x01018a
[ 1.586694] pci 0000:00:0f.0: reg 0x20: [io 0xfc00-0xfc0f]
[ 1.586720] pci 0000:00:0f.0: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 1.586725] pci 0000:00:0f.0: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 1.586731] pci 0000:00:0f.0: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 1.586737] pci 0000:00:0f.0: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 1.587238] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 1.587290] pci 0000:00:10.0: reg 0x20: [io 0xdc00-0xdc1f]
[ 1.587353] pci 0000:00:10.0: supports D1 D2
[ 1.587359] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.587840] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 1.587892] pci 0000:00:10.1: reg 0x20: [io 0xd880-0xd89f]
[ 1.587954] pci 0000:00:10.1: supports D1 D2
[ 1.587960] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.588429] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 1.588481] pci 0000:00:10.2: reg 0x20: [io 0xd800-0xd81f]
[ 1.588542] pci 0000:00:10.2: supports D1 D2
[ 1.588548] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.589018] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 1.589041] pci 0000:00:10.4: reg 0x10: [mem 0xfbfebc00-0xfbfebcff]
[ 1.589138] pci 0000:00:10.4: supports D1 D2
[ 1.589144] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.589680] pci 0000:00:11.0: [1106:8410] type 00 class 0x060100
[ 1.590260] pci 0000:00:11.7: [1106:a353] type 00 class 0x060000
[ 1.590756] pci 0000:00:13.0: [1106:b353] type 01 class 0x060401
[ 1.591302] pci 0000:00:14.0: [1106:3288] type 00 class 0x040300
[ 1.591327] pci 0000:00:14.0: reg 0x10: [mem 0xfbfe4000-0xfbfe7fff 64bit]
[ 1.591426] pci 0000:00:14.0: PME# supported from D0 D3hot D3cold
[ 1.592058] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 1.592246] pci 0000:00:03.1: PCI bridge to [bus 02]
[ 1.592418] pci 0000:00:03.2: PCI bridge to [bus 03-04]
[ 1.592428] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 1.592437] pci 0000:00:03.2: bridge window [mem 0xfe000000-0xfeafffff]
[ 1.592448] pci 0000:00:03.2: bridge window [mem 0xf8000000-0xfaffffff 64bi t pref]
[ 1.592623] pci 0000:05:00.0: [14e4:1692] type 00 class 0x020000
[ 1.592657] pci 0000:05:00.0: reg 0x10: [mem 0xfebf0000-0xfebfffff 64bit]
[ 1.592725] pci 0000:05:00.0: enabling Extended Tags
[ 1.592862] pci 0000:05:00.0: PME# supported from D3hot D3cold
[ 1.593241] pci 0000:00:03.3: ASPM: current common clock configuration is inc onsistent, reconfiguring
[ 1.605207] pci 0000:00:03.3: PCI bridge to [bus 05]
[ 1.605220] pci 0000:00:03.3: bridge window [mem 0xfeb00000-0xfebfffff]
[ 1.605255] pci_bus 0000:06: extended config space not accessible
[ 1.605653] pci 0000:00:13.0: PCI bridge to [bus 06] (subtractive decode)
[ 1.605670] pci 0000:00:13.0: bridge window [io 0x0000-0x0cf7 window] (sub tractive decode)
[ 1.605677] pci 0000:00:13.0: bridge window [io 0x0d00-0xffff window] (sub tractive decode)
[ 1.605684] pci 0000:00:13.0: bridge window [mem 0x000a0000-0x000bffff wind ow] (subtractive decode)
[ 1.605691] pci 0000:00:13.0: bridge window [mem 0xf0000000-0xfebfffff wind ow] (subtractive decode)
[ 1.605697] pci 0000:00:13.0: bridge window [mem 0x400000000-0xfffffffff wi ndow] (subtractive decode)
[ 1.608829] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 14 15)
[ 1.609111] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 14 15)
[ 1.609405] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 14 *15)
[ 1.609680] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 14 15)
[ 1.609954] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.610233] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.610509] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.610783] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 1.611358] iommu: Default domain type: Translated
[ 1.611517] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[ 1.611526] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=i o+mem,locks=none
[ 1.611543] pci 0000:00:01.0: vgaarb: bridge control possible
[ 1.611547] vgaarb: loaded
[ 1.611931] EDAC MC: Ver: 3.0.0
[ 1.613236] NetLabel: Initializing
[ 1.613242] NetLabel: domain hash size = 128
[ 1.613246] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.613325] NetLabel: unlabeled traffic allowed by default
[ 1.613329] PCI: Using ACPI for IRQ routing
[ 1.620160] PCI: pci_cache_line_size set to 64 bytes
[ 1.620265] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 1.620272] e820: reserve RAM buffer [mem 0xdffd0000-0xdfffffff]
[ 1.620424] hpet: 3 channels of 0 reserved for per-cpu timers
[ 1.620433] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.620452] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 1.622220] clocksource: Switched to clocksource tsc-early
[ 1.688627] VFS: Disk quotas dquot_6.6.0
[ 1.688708] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.689453] AppArmor: AppArmor Filesystem Enabled
[ 1.689532] pnp: PnP ACPI init
[ 1.689945] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.689971] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.690519] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.691603] system 00:02: [io 0x0680-0x068f] has been reserved
[ 1.691613] system 00:02: [io 0x1000-0x100f] has been reserved
[ 1.691621] system 00:02: [io 0x0a00-0x0a2f] has been reserved
[ 1.691629] system 00:02: [io 0x1100-0x117f] has been reserved
[ 1.691636] system 00:02: [io 0x1200-0x123f] has been reserved
[ 1.691657] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.692670] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 1.692679] system 00:03: [io 0x0800-0x087f] has been reserved
[ 1.692687] system 00:03: [io 0x0400-0x041f] has been reserved
[ 1.692696] system 00:03: [mem 0xfed01000-0xfed013ff] has been reserved
[ 1.692704] system 00:03: [mem 0xfed02000-0xfed02fff] has been reserved
[ 1.692712] system 00:03: [mem 0xfed03000-0xfed03fff] has been reserved
[ 1.692720] system 00:03: [mem 0xfed05000-0xfed05fff] has been reserved
[ 1.692727] system 00:03: [mem 0xfff00000-0xffffffff] has been reserved
[ 1.692736] system 00:03: [mem 0xfecc0000-0xfecc0fff] could not be reserved
[ 1.692756] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.693578] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 1.693588] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 1.693609] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.694869] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.694890] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.695685] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved
[ 1.695695] system 00:06: [mem 0x000c0000-0x000cffff] could not be reserved
[ 1.695703] system 00:06: [mem 0x000e0000-0x000fffff] could not be reserved
[ 1.695712] system 00:06: [mem 0x00100000-0xdfffffff] could not be reserved
[ 1.695720] system 00:06: [mem 0xfec00000-0xffffffff] could not be reserved
[ 1.695740] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.696346] pnp: PnP ACPI: found 7 devices
[ 1.708607] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_id le_ns: 2085701024 ns
[ 1.708993] NET: Registered protocol family 2
[ 1.709357] IP idents hash table entries: 65536 (order: 7, 524288 bytes, line ar)
[ 1.715261] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276 8 bytes, linear)
[ 1.715583] TCP established hash table entries: 32768 (order: 6, 262144 bytes , linear)
[ 1.716012] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linea r)
[ 1.716289] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.716484] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.716564] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.716814] NET: Registered protocol family 1
[ 1.716852] NET: Registered protocol family 44
[ 1.716921] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 1.716943] pci 0000:00:03.1: PCI bridge to [bus 02]
[ 1.716960] pci 0000:00:03.2: PCI bridge to [bus 03-04]
[ 1.716968] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 1.716979] pci 0000:00:03.2: bridge window [mem 0xfe000000-0xfeafffff]
[ 1.716988] pci 0000:00:03.2: bridge window [mem 0xf8000000-0xfaffffff 64bi t pref]
[ 1.717000] pci 0000:00:03.3: PCI bridge to [bus 05]
[ 1.717009] pci 0000:00:03.3: bridge window [mem 0xfeb00000-0xfebfffff]
[ 1.717025] pci 0000:00:13.0: PCI bridge to [bus 06]
[ 1.717043] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 1.717050] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 1.717056] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.717063] pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfebfffff window]
[ 1.717069] pci_bus 0000:00: resource 8 [mem 0x400000000-0xfffffffff window]
[ 1.717077] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 1.717083] pci_bus 0000:03: resource 1 [mem 0xfe000000-0xfeafffff]
[ 1.717090] pci_bus 0000:03: resource 2 [mem 0xf8000000-0xfaffffff 64bit pref ]
[ 1.717096] pci_bus 0000:05: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 1.717104] pci_bus 0000:06: resource 4 [io 0x0000-0x0cf7 window]
[ 1.717110] pci_bus 0000:06: resource 5 [io 0x0d00-0xffff window]
[ 1.717117] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.717123] pci_bus 0000:06: resource 7 [mem 0xf0000000-0xfebfffff window]
[ 1.717130] pci_bus 0000:06: resource 8 [mem 0x400000000-0xfffffffff window]
[ 1.717530] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c00 00-0x000dffff]
[ 1.717546] pci 0000:00:03.0: disabling DAC on VIA PCI bridge
[ 1.717558] pci 0000:00:03.1: disabling DAC on VIA PCI bridge
[ 1.717571] pci 0000:00:03.2: disabling DAC on VIA PCI bridge
[ 1.717582] pci 0000:00:03.3: disabling DAC on VIA PCI bridge
[ 1.719718] pci 0000:00:13.0: disabling DAC on VIA PCI bridge
[ 1.719744] PCI: CLS 32 bytes, default 64
[ 1.719927] Trying to unpack rootfs image as initramfs...
[ 3.531264] Freeing initrd memory: 28300K
[ 3.531312] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 3.531319] software IO TLB: mapped [mem 0x00000000dbfd0000-0x00000000dffd000 0] (64MB)
[ 3.533045] Initialise system trusted keyrings
[ 3.533103] Key type blacklist registered
[ 3.533356] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 3.541631] zbud: loaded
[ 3.542510] integrity: Platform Keyring initialized
[ 3.542520] Key type asymmetric registered
[ 3.542525] Asymmetric key parser 'x509' registered
[ 3.542559] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 51)
[ 3.542739] io scheduler mq-deadline registered
[ 3.547753] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.548063] tsc: Marking TSC unstable due to TSC halts in idle
[ 3.548848] clocksource: Switched to clocksource hpet
[ 3.549528] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.551633] Linux agpgart interface v0.103
[ 3.551824] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 3.552129] i8042: PNP: No PS/2 controller found.
[ 3.552133] i8042: Probing ports directly.
[ 3.552772] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.552790] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.553411] mousedev: PS/2 mouse device common for all mice
[ 3.553560] rtc_cmos 00:01: RTC can wake from S4
[ 3.554179] rtc_cmos 00:01: registered as rtc0
[ 3.554237] rtc_cmos 00:01: setting system clock to 2022-10-16T10:06:28 UTC ( 1665914788)
[ 3.554311] rtc_cmos 00:01: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 3.554382] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.555984] NET: Registered protocol family 10
[ 3.594515] Segment Routing with IPv6
[ 3.594650] mip6: Mobile IPv6
[ 3.594658] NET: Registered protocol family 17
[ 3.594811] mpls_gso: MPLS GSO support
[ 3.595217] IPI shorthand broadcast: enabled
[ 3.595469] registered taskstats version 1
[ 3.595481] Loading compiled-in X.509 certificates
[ 3.785337] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3d d27dfcc5cbb419ea1'
[ 3.785420] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 140112 49c2675ea8e5148542202005810584b25f'
[ 3.785487] zswap: loaded using pool lzo/zbud
[ 3.786030] Key type ._fscrypt registered
[ 3.786035] Key type .fscrypt registered
[ 3.786040] Key type fscrypt-provisioning registered
[ 3.786309] AppArmor: AppArmor sha1 policy hashing enabled
[ 3.788374] Unstable clock detected, switching default tracing clock to "glob al"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 3.795364] Freeing unused kernel image (initmem) memory: 2648K
[ 3.801190] Write protecting the kernel read-only data: 22528k
[ 3.803810] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 3.804592] Freeing unused kernel image (rodata/data gap) memory: 616K
[ 4.049543] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 4.049590] x86/mm: Checking user space page tables
[ 4.272810] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 4.272830] Run /init as init process
[ 4.272835] with arguments:
[ 4.272839] /init
[ 4.272843] with environment:
[ 4.272847] HOME=/
[ 4.272851] TERM=linux
[ 4.272855] BOOT_IMAGE=/boot/vmlinuz-5.10.0-18-amd64
[ 4.915509] pps_core: LinuxPPS API ver. 1 registered
[ 4.915517] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 4.974706] PTP clock support registered
[ 5.259435] SCSI subsystem initialized
[ 5.332834] ACPI: bus type USB registered
[ 5.332935] usbcore: registered new interface driver usbfs
[ 5.332977] usbcore: registered new interface driver hub
[ 5.333025] usbcore: registered new device driver usb
[ 5.442046] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.465978] ehci-pci: EHCI PCI platform driver
[ 5.466495] ehci-pci 0000:00:10.4: EHCI Host Controller
[ 5.466521] ehci-pci 0000:00:10.4: new USB bus registered, assigned bus numbe r 1
[ 5.466545] ehci-pci 0000:00:10.4: debug port 1
[ 5.466678] ehci-pci 0000:00:10.4: irq 23, io mem 0xfbfebc00
[ 5.481215] ehci-pci 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 5.481457] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 5.10
[ 5.481466] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.481472] usb usb1: Product: EHCI Host Controller
[ 5.481478] usb usb1: Manufacturer: Linux 5.10.0-18-amd64 ehci_hcd
[ 5.481484] usb usb1: SerialNumber: 0000:00:10.4
[ 5.482013] hub 1-0:1.0: USB hub found
[ 5.482050] hub 1-0:1.0: 6 ports detected
[ 5.491514] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.492021] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 5.492060] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus numbe r 2
[ 5.492077] uhci_hcd 0000:00:10.0: detected 2 ports
[ 5.492136] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000dc00
[ 5.498890] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 5.10
[ 5.498901] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.498907] usb usb2: Product: UHCI Host Controller
[ 5.498913] usb usb2: Manufacturer: Linux 5.10.0-18-amd64 uhci_hcd
[ 5.498919] usb usb2: SerialNumber: 0000:00:10.0
[ 5.505783] hub 2-0:1.0: USB hub found
[ 5.505819] hub 2-0:1.0: 2 ports detected
[ 5.509654] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 5.509677] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus numbe r 3
[ 5.509716] uhci_hcd 0000:00:10.1: detected 2 ports
[ 5.509790] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000d880
[ 5.512402] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 5.10
[ 5.512411] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.512418] usb usb3: Product: UHCI Host Controller
[ 5.512423] usb usb3: Manufacturer: Linux 5.10.0-18-amd64 uhci_hcd
[ 5.512429] usb usb3: SerialNumber: 0000:00:10.1
[ 5.512925] hub 3-0:1.0: USB hub found
[ 5.513346] hub 3-0:1.0: 2 ports detected
[ 5.514975] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 5.514996] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus numbe r 4
[ 5.515011] uhci_hcd 0000:00:10.2: detected 2 ports
[ 5.515067] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 5.516634] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 5.10
[ 5.516642] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.516649] usb usb4: Product: UHCI Host Controller
[ 5.516654] usb usb4: Manufacturer: Linux 5.10.0-18-amd64 uhci_hcd
[ 5.516660] usb usb4: SerialNumber: 0000:00:10.2
[ 5.517345] hub 4-0:1.0: USB hub found
[ 5.517625] hub 4-0:1.0: 2 ports detected
[ 5.588918] Broadcom BCM57780 500:01: attached PHY driver [Broadcom BCM57780] (mii_bus:phy_addr=500:01, irq=POLL)
[ 5.592376] tg3 0000:05:00.0 eth0: Tigon3 [partno(BCM57780) rev 57780001] (PC I Express) MAC address 9c:8e:99:d8:bb:12
[ 5.592386] tg3 0000:05:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] T SOcap[1]
[ 5.592394] tg3 0000:05:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 5.607117] tg3 0000:05:00.0 enp5s0: renamed from eth0
[ 5.616847] libata version 3.00 loaded.
[ 5.626427] pata_via 0000:00:0f.0: version 0.3.4
[ 5.633454] scsi host0: pata_via
[ 5.635427] scsi host1: pata_via
[ 5.635641] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 5.635646] ata2: DUMMY
[ 5.842952] ata1.01: HPA detected: current 625076911, native 625142448
[ 5.842968] ata1.01: ATA-8: ST9320328CS, SC1A, max UDMA/133
[ 5.842975] ata1.01: 625076911 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 5.842992] ata1.01: limited to UDMA/33 due to 40-wire cable
[ 5.848384] scsi 0:0:1:0: Direct-Access ATA ST9320328CS SC1A PQ : 0 ANSI: 5
[ 5.895357] sd 0:0:1:0: [sda] 625076911 512-byte logical blocks: (320 GB/298 GiB)
[ 5.895409] sd 0:0:1:0: [sda] Write Protect is off
[ 5.895418] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 5.895490] sd 0:0:1:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 5.897208] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 5.960383] sda: sda1 sda2 < sda5 >
[ 5.973633] sd 0:0:1:0: [sda] Attached SCSI disk
[ 6.093889] usb 3-1: New USB device found, idVendor=10c4, idProduct=8108, bcd Device= 0.00
[ 6.093901] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.093907] usb 3-1: Product: USB OPTICAL MOUSE
[ 6.093913] usb 3-1: Manufacturer: YSPRINGTECH
[ 6.132982] hid: raw HID events driver (C) Jiri Kosina
[ 6.176278] usbcore: registered new interface driver usbhid
[ 6.176285] usbhid: USB HID core driver
[ 6.192741] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/pci0000:00/0000: 00:10.1/usb3/3-1/3-1:1.0/0003:10C4:8108.0001/input/input3
[ 6.193592] hid-generic 0003:10C4:8108.0001: input,hidraw0: USB HID v1.11 Mou se [YSPRINGTECH USB OPTICAL MOUSE] on usb-0000:00:10.1-1/input0
[ 6.543360] PM: Image not found (code -22)
[ 6.817198] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 7.105888] usb 3-2: New USB device found, idVendor=04f2, idProduct=1228, bcd Device= 1.11
[ 7.105900] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.105907] usb 3-2: Product: USB KEYBOARD
[ 7.105913] usb 3-2: Manufacturer: CHICONY
[ 7.126139] input: CHICONY USB KEYBOARD as /devices/pci0000:00/0000:00:10.1/u sb3/3-2/3-2:1.0/0003:04F2:1228.0002/input/input4
[ 7.186752] hid-generic 0003:04F2:1228.0002: input,hidraw1: USB HID v1.11 Key board [CHICONY USB KEYBOARD] on usb-0000:00:10.1-2/input0
[ 7.195764] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.211087] input: CHICONY USB KEYBOARD Consumer Control as /devices/pci0000: 00/0000:00:10.1/usb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input5
[ 7.269726] input: CHICONY USB KEYBOARD System Control as /devices/pci0000:00 /0000:00:10.1/usb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input6
[ 7.270197] input: CHICONY USB KEYBOARD as /devices/pci0000:00/0000:00:10.1/u sb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input7
[ 7.271623] hid-generic 0003:04F2:1228.0003: input,hiddev0,hidraw2: USB HID v 1.11 Device [CHICONY USB KEYBOARD] on usb-0000:00:10.1-2/input1
[ 7.645516] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 9.142681] systemd[1]: Inserted module 'autofs4'
[ 9.513814] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +G NUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 defa ult-hierarchy=unified)
[ 9.514468] systemd[1]: Detected architecture x86-64.
[ 9.550571] systemd[1]: Set hostname to <radio>.
[ 10.357927] random: crng init done
[ 11.328153] systemd[1]: Queued start job for default target Graphical Interfa ce.
[ 11.355116] systemd[1]: Created slice system-getty.slice.
[ 11.356643] systemd[1]: Created slice system-modprobe.slice.
[ 11.358155] systemd[1]: Created slice User and Session Slice.
[ 11.358550] systemd[1]: Started Dispatch Password Requests to Console Directo ry Watch.
[ 11.358887] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ 11.359747] systemd[1]: Set up automount Arbitrary Executable File Formats Fi le System Automount Point.
[ 11.359994] systemd[1]: Reached target Local Encrypted Volumes.
[ 11.360191] systemd[1]: Reached target Paths.
[ 11.360313] systemd[1]: Reached target Remote File Systems.
[ 11.360416] systemd[1]: Reached target Slices.
[ 11.361116] systemd[1]: Listening on Syslog Socket.
[ 11.361878] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.362226] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.363185] systemd[1]: Listening on Journal Audit Socket.
[ 11.363772] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.364456] systemd[1]: Listening on Journal Socket.
[ 11.365337] systemd[1]: Listening on udev Control Socket.
[ 11.365963] systemd[1]: Listening on udev Kernel Socket.
[ 11.370164] systemd[1]: Mounting Huge Pages File System...
[ 11.377077] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.384220] systemd[1]: Mounting Kernel Debug File System...
[ 11.390182] systemd[1]: Mounting Kernel Trace File System...
[ 11.432017] systemd[1]: Starting Set the console keyboard layout...
[ 11.441684] systemd[1]: Starting Create list of static device nodes for the c urrent kernel...
[ 11.447642] systemd[1]: Starting Load Kernel Module configfs...
[ 11.467039] systemd[1]: Starting Load Kernel Module drm...
[ 11.482699] systemd[1]: Starting Load Kernel Module fuse...
[ 11.629356] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.629623] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.638464] systemd[1]: Starting Journal Service...
[ 11.854390] systemd[1]: Starting Load Kernel Modules...
[ 11.859851] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.867724] systemd[1]: Starting Coldplug All udev Devices...
[ 11.882910] systemd[1]: Mounted Huge Pages File System.
[ 11.883484] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.884002] systemd[1]: Mounted Kernel Debug File System.
[ 11.884545] systemd[1]: Mounted Kernel Trace File System.
[ 11.886315] systemd[1]: Finished Create list of static device nodes for the c urrent kernel.
[ 11.887908] systemd[1]: modprobe@configfs.service: Succeeded.
[ 11.889144] systemd[1]: Finished Load Kernel Module configfs.
[ 11.894660] systemd[1]: Mounting Kernel Configuration File System...
[ 11.919513] systemd[1]: Mounted Kernel Configuration File System.
[ 11.998758] fuse: init (API version 7.32)
[ 12.002245] systemd[1]: modprobe@fuse.service: Succeeded.
[ 12.003506] systemd[1]: Finished Load Kernel Module fuse.
[ 12.018908] systemd[1]: Mounting FUSE Control File System...
[ 12.084783] systemd[1]: Mounted FUSE Control File System.
[ 12.109278] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.117838] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 12.216710] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 12.216964] systemd[1]: Condition check resulted in Platform Persistent Stora ge Archival being skipped.
[ 12.220892] systemd[1]: Starting Load/Save Random Seed...
[ 12.226115] systemd[1]: Starting Create System Users...
[ 12.228671] systemd[1]: modprobe@drm.service: Succeeded.
[ 12.233409] systemd[1]: Finished Load Kernel Module drm.
[ 12.258654] systemd[1]: Finished Load Kernel Modules.
[ 12.263016] systemd[1]: Starting Apply Kernel Variables...
[ 12.578339] systemd[1]: Finished Apply Kernel Variables.
[ 13.021501] systemd[1]: Finished Load/Save Random Seed.
[ 13.022156] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 13.062627] systemd[1]: Finished Coldplug All udev Devices.
[ 13.096023] systemd[1]: Starting Helper to synchronize boot up for ifupdown.. .
[ 13.099017] systemd[1]: Started Journal Service.
[ 13.245700] systemd-journald[177]: Received client request to flush runtime j ournal.
[ 15.996587] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:0 0/input/input8
[ 15.996712] ACPI: Sleep Button [SLPB]
[ 16.018839] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:0 0/input/input9
[ 16.018966] ACPI: Power Button [PWRB]
[ 16.022213] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/inp ut10
[ 16.022388] ACPI: Power Button [PWRF]
[ 16.034295] acpi_cpufreq: acpi_cpufreq: failed to register hotplug callbacks
[ 16.547792] sd 0:0:1:0: Attached scsi generic sg0 type 0
[ 17.124702] audit: type=1400 audit(1665914802.064:2): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="lsb_release" pid=217 comm="apparm or_parser"
[ 17.172124] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 17.805476] audit: type=1400 audit(1665914802.748:3): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="nvidia_modprobe" pid=245 comm="ap parmor_parser"
[ 17.810987] audit: type=1400 audit(1665914802.752:4): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=245 co mm="apparmor_parser"
[ 18.757855] audit: type=1400 audit(1665914803.700:5): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="/usr/bin/man" pid=252 comm="appar mor_parser"
[ 18.771024] audit: type=1400 audit(1665914803.712:6): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="man_filter" pid=252 comm="apparmo r_parser"
[ 18.776059] audit: type=1400 audit(1665914803.716:7): apparmor="STATUS" opera tion="profile_load" profile="unconfined" name="man_groff" pid=252 comm="apparmor _parser"
[ 18.846148] VIA RNG detected
[ 19.767282] via_cputemp via_cputemp.0: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 20.337244] Adding 999420k swap on /dev/sda5. Priority:-2 extents:1 across:9 99420k FS
[ 20.390045] padlock_aes: Using VIA PadLock ACE for AES algorithm.
[ 20.473977] padlock_sha: Using VIA PadLock ACE for SHA1/SHA256 algorithms.
[ 20.712702] snd_hda_intel 0000:00:01.1: CORB reset timeout#1, CORBRP = 0
[ 20.712760] snd_hda_intel 0000:00:01.1: no codecs found!
[ 20.717740] snd_hda_intel 0000:00:14.0: Force to non-snoop mode
[ 21.653452] snd_hda_codec_via hdaudioC1D0: autoconfig for VT1708S: line_outs= 1 (0x1c/0x0/0x0/0x0/0x0) type:line
[ 21.653467] snd_hda_codec_via hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0 /0x0)
[ 21.653477] snd_hda_codec_via hdaudioC1D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 21.653484] snd_hda_codec_via hdaudioC1D0: mono: mono_out=0x0
[ 21.653490] snd_hda_codec_via hdaudioC1D0: inputs:
[ 21.653499] snd_hda_codec_via hdaudioC1D0: Mic=0x1a
[ 22.956896] tg3 0000:05:00.0 enp5s0: Link is down
[ 24.982710] tg3 0000:05:00.0 enp5s0: Link is up at 100 Mbps, full duplex
[ 24.982722] tg3 0000:05:00.0 enp5s0: Flow control is on for TX and on for RX
[ 24.982750] IPv6: ADDRCONF(NETDEV_CHANGE): enp5s0: link becomes ready</p>
</details>
volumio-dmesg
bash-5.0# dmesg
[ 0.000000] Linux version 5.10.139-volumio (gkkpch@busteros) (gcc (Debian 8.3.0-6) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP Tue Aug 30 15:09 :12 CEST 2022
[ 0.000000] Command line: BOOT_IMAGE=vmlinuz biosdevname=0 splash plymouth.ignore-serial-consoles quiet ro rootwait imgpart=UUID=2301fe0c-07cd-4a6d-bfb4-1 780dbe18679 bootpart=UUID=6B3C-7633 datapart=UUID=32081f10-452e-41fb-9815-f6d3c7a1d598 imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_default=0 a cpi_backlight=vendor use_kmsg=yes net.ifnames=0 loglevel=0 initrd=volumio.initrd
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] DMI: Hewlett-Packard HP t5570e Thin Client/158Ch, BIOS 786R9 v1.04 11/10/2011
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] last_pfn = 0x118000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 100000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 base 0E0000000 mask FF8000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] last_pfn = 0xdffd0 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.000000] RAMDISK: [mem 0x7ccde000-0x7fffffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FA170 000024 (v02 ACPIAM)
[ 0.000000] ACPI: XSDT 0x00000000DFFD0100 000054 (v01 111011 XSDT1519 20111110 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x00000000DFFD0290 0000F4 (v04 111011 FACP1519 20111110 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x00000000DFFD0430 00499F (v02 786R9 786R9104 00000104 INTL 20051117)
[ 0.000000] ACPI: FACS 0x00000000DFFDE000 000040
[ 0.000000] ACPI: APIC 0x00000000DFFD0390 000060 (v02 111011 APIC1519 20111110 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x00000000DFFD03F0 00003C (v01 111011 OEMMCFG 20111110 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x00000000DFFDE040 000082 (v01 111011 OEMB1519 20111110 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000DFFDA430 000038 (v01 111011 VIA HPET 20111110 MSFT 00000097)
[ 0.000000] ACPI: SSDT 0x00000000DFFDE0D0 00023A (v01 AMI P001PM 00000001 INTL 20051117)
[ 0.000000] ACPI: Reserving FACP table memory at [mem 0xdffd0290-0xdffd0383]
[ 0.000000] ACPI: Reserving DSDT table memory at [mem 0xdffd0430-0xdffd4dce]
[ 0.000000] ACPI: Reserving FACS table memory at [mem 0xdffde000-0xdffde03f]
[ 0.000000] ACPI: Reserving APIC table memory at [mem 0xdffd0390-0xdffd03ef]
[ 0.000000] ACPI: Reserving MCFG table memory at [mem 0xdffd03f0-0xdffd042b]
[ 0.000000] ACPI: Reserving OEMB table memory at [mem 0xdffde040-0xdffde0c1]
[ 0.000000] ACPI: Reserving HPET table memory at [mem 0xdffda430-0xdffda467]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdffde0d0-0xdffde309]
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000117ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000dffcffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000117ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x0000000117ffffff]
[ 0.000000] On node 0 totalpages: 1015662
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14272 pages used for memmap
[ 0.000000] DMA32 zone: 913360 pages, LIFO batch:63
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 98304 pages, LIFO batch:31
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 48 pages in unavailable ranges
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 2, version 3, address 0xfecc0000, GSI 24-47
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x11068201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdffd0000-0xdffddfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdffde000-0xdffeffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdfff0000-0xdfffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xfebfffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecbffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfecc0000-0xfecc0fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfecc1000-0xfedfffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffefffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[ 0.000000] [mem 0xe0000000-0xfebfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] percpu: Embedded 57 pages/cpu s194328 r8192 d30952 u2097152
[ 0.000000] pcpu-alloc: s194328 r8192 d30952 u2097152 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999769
[ 0.000000] Kernel command line: BOOT_IMAGE=vmlinuz biosdevname=0 splash plymouth.ignore-serial-consoles quiet ro rootwait imgpart=UUID=2301fe0c-07cd-4a6d -bfb4-1780dbe18679 bootpart=UUID=6B3C-7633 datapart=UUID=32081f10-452e-41fb-9815-f6d3c7a1d598 imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_defa ult=0 acpi_backlight=vendor use_kmsg=yes net.ifnames=0 loglevel=0 initrd=volumio.initrd
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 3849500K/4062648K available (12296K kernel code, 1776K rwdata, 3076K rodata, 1828K init, 2428K bss, 212892K reserved, 0K cma-reserved)
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] ftrace: allocating 37242 entries in 146 pages
[ 0.000000] ftrace: allocated 146 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 4352, nr_irqs: 256, preallocated irqs: 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] printk: console [tty0] enabled
[ 0.000000] ACPI: Core revision 20200925
[ 0.000000] hpet: Global config: Unknown bits 0x10
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.024000] tsc: PIT calibration matches HPET. 1 loops
[ 0.024000] tsc: Detected 997.499 MHz processor
[ 0.000016] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1cc1b8ea335, max_idle_ns: 881590512489 ns
[ 0.000028] Calibrating delay loop (skipped), value calculated using timer frequency.. 1994.99 BogoMIPS (lpj=3989996)
[ 0.000041] pid_max: default: 32768 minimum: 301
[ 0.000253] LSM: Security Framework initializing
[ 0.000268] Yama: becoming mindful.
[ 0.000412] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000453] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001396] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.001403] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.001416] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.001427] Spectre V2 : Mitigation: Retpolines
[ 0.001430] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.001434] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.001440] Speculative Store Bypass: Vulnerable
[ 0.001451] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.096182] Freeing SMP alternatives memory: 32K
[ 0.211212] smpboot: CPU0: Centaur VIA Nano U3500@1000MHz (family: 0x6, model: 0xf, stepping: 0xa)
[ 0.211976] Performance Events:
[ 0.211980] core: Welcome to zhaoxin pmu!
[ 0.211985] core: Version check pass!
[ 0.211988] ZXC events, zhaoxin PMU driver.
[ 0.212000] ... version: 2
[ 0.212004] ... bit width: 40
[ 0.212008] ... generic registers: 2
[ 0.212012] ... value mask: 000000ffffffffff
[ 0.212016] ... max period: 0000007fffffffff
[ 0.212020] ... fixed-purpose events: 3
[ 0.212022] ... event mask: 0000000700000003
[ 0.212022] rcu: Hierarchical SRCU implementation.
[ 0.212022] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.212022] smp: Bringing up secondary CPUs ...
[ 0.212022] smp: Brought up 1 node, 1 CPU
[ 0.212022] smpboot: Max logical packages: 1
[ 0.212022] smpboot: Total of 1 processors activated (1994.99 BogoMIPS)
[ 0.212022] devtmpfs: initialized
[ 0.212224] x86/mm: Memory block size: 128MB
[ 0.215337] PM: Registering ACPI NVS region [mem 0xdffde000-0xdffeffff] (73728 bytes)
[ 0.215544] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.215557] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.215765] pinctrl core: initialized pinctrl subsystem
[ 0.216644] NET: Registered protocol family 16
[ 0.217553] audit: initializing netlink subsys (disabled)
[ 0.218131] thermal_sys: Registered thermal governor 'fair_share'
[ 0.218136] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.218141] thermal_sys: Registered thermal governor 'step_wise'
[ 0.218145] thermal_sys: Registered thermal governor 'user_space'
[ 0.218184] EISA bus registered
[ 0.218191] cpuidle: using governor ladder
[ 0.218196] cpuidle: using governor menu
[ 0.218760] ACPI: bus type PCI registered
[ 0.218766] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.219043] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.219052] PCI: not using MMCONFIG
[ 0.219068] PCI: Using configuration type 1 for base access
[ 0.224055] audit: type=2000 audit(1665929226.240:1): state=initialized audit_enabled=0 res=1
[ 0.225711] Kprobes globally optimized
[ 0.226159] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.698746] ACPI: Added _OSI(Module Device)
[ 1.698752] ACPI: Added _OSI(Processor Device)
[ 1.698758] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 1.698764] ACPI: Added _OSI(Processor Aggregator Device)
[ 1.698771] ACPI: Added _OSI(Linux-Dell-Video)
[ 1.698777] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 1.698784] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 1.715476] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 1.721472] ACPI: Interpreter enabled
[ 1.721529] ACPI: (supports S0 S5)
[ 1.721535] ACPI: Using IOAPIC for interrupt routing
[ 1.721666] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 1.721811] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 1.721834] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[ 1.722742] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.723621] ACPI: Enabled 7 GPEs in block 00 to 0F
[ 1.723637] ACPI: Enabled 1 GPEs in block 10 to 1F
[ 1.745191] ACPI: Power Resource [URP1] (off)
[ 1.745352] ACPI: Power Resource [URP2] (off)
[ 1.745514] ACPI: Power Resource [FDDP] (off)
[ 1.745671] ACPI: Power Resource [LPTP] (off)
[ 1.760170] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.760193] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.761413] acpi PNP0A03:00: ignoring host bridge window [mem 0x000d0000-0x000dffff window] (conflicts with Adapter ROM [mem 0x000ce800-0x000d07ff])
[ 1.762313] PCI host bridge to bus 0000:00
[ 1.762323] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 1.762331] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.762339] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 1.762347] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff window]
[ 1.762354] pci_bus 0000:00: root bus resource [mem 0x400000000-0xfffffffff window]
[ 1.762362] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.762406] pci 0000:00:00.0: [1106:0410] type 00 class 0x060000
[ 1.762839] pci 0000:00:00.1: [1106:1410] type 00 class 0x060000
[ 1.763328] pci 0000:00:00.2: [1106:2410] type 00 class 0x060000
[ 1.763814] pci 0000:00:00.3: [1106:3410] type 00 class 0x060000
[ 1.764310] pci 0000:00:00.4: [1106:4410] type 00 class 0x060000
[ 1.764789] pci 0000:00:00.5: [1106:5410] type 00 class 0x060000
[ 1.765263] pci 0000:00:00.6: [1106:6410] type 00 class 0x060000
[ 1.765740] pci 0000:00:00.7: [1106:7410] type 00 class 0x060000
[ 1.766217] pci 0000:00:01.0: [1106:7122] type 00 class 0x030000
[ 1.766239] pci 0000:00:01.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 1.766254] pci 0000:00:01.0: reg 0x14: [mem 0xfc000000-0xfcffffff]
[ 1.766268] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf7ffffff pref]
[ 1.766301] pci 0000:00:01.0: reg 0x30: [mem 0xfbff0000-0xfbffffff pref]
[ 1.766352] pci 0000:00:01.0: supports D1 D2
[ 1.766763] pci 0000:00:01.1: [1106:9170] type 00 class 0x040300
[ 1.766784] pci 0000:00:01.1: reg 0x10: [mem 0xfbfec000-0xfbfeffff]
[ 1.766871] pci 0000:00:01.1: supports D1 D2
[ 1.767296] pci 0000:00:03.0: [1106:a410] type 01 class 0x060400
[ 1.767435] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 1.767937] pci 0000:00:03.1: [1106:b410] type 01 class 0x060400
[ 1.768125] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 1.768637] pci 0000:00:03.2: [1106:c410] type 01 class 0x060400
[ 1.768781] pci 0000:00:03.2: PME# supported from D0 D3hot D3cold
[ 1.769282] pci 0000:00:03.3: [1106:d410] type 01 class 0x060400
[ 1.769425] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[ 1.769915] pci 0000:00:03.4: [1106:e410] type 00 class 0x060000
[ 1.770353] pci 0000:00:0f.0: [1106:9001] type 00 class 0x01018a
[ 1.770411] pci 0000:00:0f.0: reg 0x20: [io 0xfc00-0xfc0f]
[ 1.770438] pci 0000:00:0f.0: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 1.770445] pci 0000:00:0f.0: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 1.770451] pci 0000:00:0f.0: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 1.770458] pci 0000:00:0f.0: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 1.770911] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 1.770968] pci 0000:00:10.0: reg 0x20: [io 0xdc00-0xdc1f]
[ 1.771031] pci 0000:00:10.0: supports D1 D2
[ 1.771038] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.771479] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 1.771535] pci 0000:00:10.1: reg 0x20: [io 0xd880-0xd89f]
[ 1.771599] pci 0000:00:10.1: supports D1 D2
[ 1.771606] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.772056] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 1.772112] pci 0000:00:10.2: reg 0x20: [io 0xd800-0xd81f]
[ 1.772182] pci 0000:00:10.2: supports D1 D2
[ 1.772189] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.772634] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 1.772659] pci 0000:00:10.4: reg 0x10: [mem 0xfbfebc00-0xfbfebcff]
[ 1.772760] pci 0000:00:10.4: supports D1 D2
[ 1.772767] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.773217] pci 0000:00:11.0: [1106:8410] type 00 class 0x060100
[ 1.773774] pci 0000:00:11.7: [1106:a353] type 00 class 0x060000
[ 1.774241] pci 0000:00:13.0: [1106:b353] type 01 class 0x060401
[ 1.774747] pci 0000:00:14.0: [1106:3288] type 00 class 0x040300
[ 1.774774] pci 0000:00:14.0: reg 0x10: [mem 0xfbfe4000-0xfbfe7fff 64bit]
[ 1.774880] pci 0000:00:14.0: PME# supported from D0 D3hot D3cold
[ 1.775485] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 1.775640] pci 0000:00:03.1: PCI bridge to [bus 02]
[ 1.775799] pci 0000:00:03.2: PCI bridge to [bus 03-04]
[ 1.775809] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 1.775819] pci 0000:00:03.2: bridge window [mem 0xfe000000-0xfeafffff]
[ 1.775831] pci 0000:00:03.2: bridge window [mem 0xf8000000-0xfaffffff 64bit pref]
[ 1.776006] pci 0000:05:00.0: [14e4:1692] type 00 class 0x020000
[ 1.776055] pci 0000:05:00.0: reg 0x10: [mem 0xfebf0000-0xfebfffff 64bit]
[ 1.776126] pci 0000:05:00.0: enabling Extended Tags
[ 1.776251] pci 0000:05:00.0: PME# supported from D3hot D3cold
[ 1.776574] pci 0000:00:03.3: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 1.788076] pci 0000:00:03.3: PCI bridge to [bus 05]
[ 1.788090] pci 0000:00:03.3: bridge window [mem 0xfeb00000-0xfebfffff]
[ 1.788130] pci_bus 0000:06: extended config space not accessible
[ 1.788500] pci 0000:00:13.0: PCI bridge to [bus 06] (subtractive decode)
[ 1.788517] pci 0000:00:13.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 1.788525] pci 0000:00:13.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 1.788533] pci 0000:00:13.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 1.788540] pci 0000:00:13.0: bridge window [mem 0xf0000000-0xfebfffff window] (subtractive decode)
[ 1.788548] pci 0000:00:13.0: bridge window [mem 0x400000000-0xfffffffff window] (subtractive decode)
[ 1.788590] pci_bus 0000:00: on NUMA node 0
[ 1.791349] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 14 15)
[ 1.791626] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 14 15)
[ 1.791896] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 14 *15)
[ 1.792178] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 14 15)
[ 1.792450] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.792724] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.792997] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 1.793267] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 1.793706] iommu: Default domain type: Translated
[ 1.793844] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[ 1.793853] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 1.793875] pci 0000:00:01.0: vgaarb: bridge control possible
[ 1.793879] vgaarb: loaded
[ 1.794374] SCSI subsystem initialized
[ 1.794558] libata version 3.00 loaded.
[ 1.794581] ACPI: bus type USB registered
[ 1.794662] usbcore: registered new interface driver usbfs
[ 1.794699] usbcore: registered new interface driver hub
[ 1.794736] usbcore: registered new device driver usb
[ 1.795904] PCI: Using ACPI for IRQ routing
[ 1.803007] PCI: pci_cache_line_size set to 64 bytes
[ 1.803121] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 1.803128] e820: reserve RAM buffer [mem 0xdffd0000-0xdfffffff]
[ 1.803716] hpet: 3 channels of 0 reserved for per-cpu timers
[ 1.803726] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.803745] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 1.805087] clocksource: Switched to clocksource tsc-early
[ 1.858130] VFS: Disk quotas dquot_6.6.0
[ 1.858203] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.858451] pnp: PnP ACPI init
[ 1.858835] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.858865] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.859411] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.860476] system 00:02: [io 0x0680-0x068f] has been reserved
[ 1.860487] system 00:02: [io 0x1000-0x100f] has been reserved
[ 1.860496] system 00:02: [io 0x0a00-0x0a2f] has been reserved
[ 1.860505] system 00:02: [io 0x1100-0x117f] has been reserved
[ 1.860514] system 00:02: [io 0x1200-0x123f] has been reserved
[ 1.860536] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.861521] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 1.861533] system 00:03: [io 0x0800-0x087f] has been reserved
[ 1.861542] system 00:03: [io 0x0400-0x041f] has been reserved
[ 1.861551] system 00:03: [mem 0xfed01000-0xfed013ff] has been reserved
[ 1.861560] system 00:03: [mem 0xfed02000-0xfed02fff] has been reserved
[ 1.861569] system 00:03: [mem 0xfed03000-0xfed03fff] has been reserved
[ 1.861577] system 00:03: [mem 0xfed05000-0xfed05fff] has been reserved
[ 1.861586] system 00:03: [mem 0xfff00000-0xffffffff] has been reserved
[ 1.861595] system 00:03: [mem 0xfecc0000-0xfecc0fff] could not be reserved
[ 1.861617] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.862414] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 1.862425] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 1.862447] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.863049] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.863071] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.863834] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved
[ 1.863845] system 00:06: [mem 0x000c0000-0x000cffff] could not be reserved
[ 1.863854] system 00:06: [mem 0x000e0000-0x000fffff] could not be reserved
[ 1.863863] system 00:06: [mem 0x00100000-0xdfffffff] could not be reserved
[ 1.863872] system 00:06: [mem 0xfec00000-0xffffffff] could not be reserved
[ 1.863893] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.864511] pnp: PnP ACPI: found 7 devices
[ 1.874637] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.874980] NET: Registered protocol family 2
[ 1.875306] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.877603] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 1.877649] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.877830] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.878152] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.878267] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.878322] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.878551] NET: Registered protocol family 1
[ 1.878637] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 1.878660] pci 0000:00:03.1: PCI bridge to [bus 02]
[ 1.878680] pci 0000:00:03.2: PCI bridge to [bus 03-04]
[ 1.878690] pci 0000:00:03.2: bridge window [io 0xe000-0xefff]
[ 1.878701] pci 0000:00:03.2: bridge window [mem 0xfe000000-0xfeafffff]
[ 1.878711] pci 0000:00:03.2: bridge window [mem 0xf8000000-0xfaffffff 64bit pref]
[ 1.878724] pci 0000:00:03.3: PCI bridge to [bus 05]
[ 1.878735] pci 0000:00:03.3: bridge window [mem 0xfeb00000-0xfebfffff]
[ 1.878753] pci 0000:00:13.0: PCI bridge to [bus 06]
[ 1.878772] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 1.878780] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 1.878788] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.878795] pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfebfffff window]
[ 1.878802] pci_bus 0000:00: resource 8 [mem 0x400000000-0xfffffffff window]
[ 1.878811] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 1.878819] pci_bus 0000:03: resource 1 [mem 0xfe000000-0xfeafffff]
[ 1.878826] pci_bus 0000:03: resource 2 [mem 0xf8000000-0xfaffffff 64bit pref]
[ 1.878834] pci_bus 0000:05: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 1.878842] pci_bus 0000:06: resource 4 [io 0x0000-0x0cf7 window]
[ 1.878850] pci_bus 0000:06: resource 5 [io 0x0d00-0xffff window]
[ 1.878857] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.878865] pci_bus 0000:06: resource 7 [mem 0xf0000000-0xfebfffff window]
[ 1.878872] pci_bus 0000:06: resource 8 [mem 0x400000000-0xfffffffff window]
[ 1.879180] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.879195] pci 0000:00:03.0: disabling DAC on VIA PCI bridge
[ 1.879207] pci 0000:00:03.1: disabling DAC on VIA PCI bridge
[ 1.879218] pci 0000:00:03.2: disabling DAC on VIA PCI bridge
[ 1.879229] pci 0000:00:03.3: disabling DAC on VIA PCI bridge
[ 1.881528] pci 0000:00:13.0: disabling DAC on VIA PCI bridge
[ 1.881551] PCI: CLS 32 bytes, default 64
[ 1.881709] Trying to unpack rootfs image as initramfs...
[ 4.851372] Freeing initrd memory: 52360K
[ 4.851449] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 4.851457] software IO TLB: mapped [mem 0x00000000dbfd0000-0x00000000dffd0000] (64MB)
[ 4.853318] Initialise system trusted keyrings
[ 4.853502] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 4.853564] zbud: loaded
[ 4.853927] Key type asymmetric registered
[ 4.853933] Asymmetric key parser 'x509' registered
[ 4.853964] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 4.854095] io scheduler mq-deadline registered
[ 4.854101] io scheduler kyber registered
[ 4.858770] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 4.859391] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 4.859501] ACPI: Sleep Button [SLPB]
[ 4.859660] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 4.859754] ACPI: Power Button [PWRB]
[ 4.859911] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 4.860091] ACPI: Power Button [PWRF]
[ 4.860404] tsc: Marking TSC unstable due to TSC halts in idle
[ 4.861075] clocksource: Switched to clocksource hpet
[ 4.861524] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 4.869557] Linux agpgart interface v0.103
[ 4.869964] Uniform Multi-Platform E-IDE driver
[ 4.870013] ide-gd driver 1.18
[ 4.870358] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.870376] ehci-pci: EHCI PCI platform driver
[ 4.870822] ehci-pci 0000:00:10.4: EHCI Host Controller
[ 4.870847] ehci-pci 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 4.870870] ehci-pci 0000:00:10.4: debug port 1
[ 4.870976] ehci-pci 0000:00:10.4: irq 23, io mem 0xfbfebc00
[ 4.884104] ehci-pci 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 4.884284] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 4.884292] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.884300] usb usb1: Product: EHCI Host Controller
[ 4.884307] usb usb1: Manufacturer: Linux 5.10.139-volumio ehci_hcd
[ 4.884313] usb usb1: SerialNumber: 0000:00:10.4
[ 4.884713] hub 1-0:1.0: USB hub found
[ 4.884742] hub 1-0:1.0: 6 ports detected
[ 4.885398] ehci-platform: EHCI generic platform driver
[ 4.885434] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.885447] ohci-pci: OHCI PCI platform driver
[ 4.885493] ohci-platform: OHCI generic platform driver
[ 4.885521] uhci_hcd: USB Universal Host Controller Interface driver
[ 4.885881] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 4.885904] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 4.885919] uhci_hcd 0000:00:10.0: detected 2 ports
[ 4.885971] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000dc00
[ 4.886123] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 4.886132] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.886139] usb usb2: Product: UHCI Host Controller
[ 4.886146] usb usb2: Manufacturer: Linux 5.10.139-volumio uhci_hcd
[ 4.886152] usb usb2: SerialNumber: 0000:00:10.0
[ 4.886516] hub 2-0:1.0: USB hub found
[ 4.886544] hub 2-0:1.0: 2 ports detected
[ 4.887266] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 4.887289] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 4.887304] uhci_hcd 0000:00:10.1: detected 2 ports
[ 4.887353] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000d880
[ 4.887508] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 4.887516] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.887523] usb usb3: Product: UHCI Host Controller
[ 4.887530] usb usb3: Manufacturer: Linux 5.10.139-volumio uhci_hcd
[ 4.887536] usb usb3: SerialNumber: 0000:00:10.1
[ 4.887899] hub 3-0:1.0: USB hub found
[ 4.887926] hub 3-0:1.0: 2 ports detected
[ 4.888697] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 4.888719] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 4.888734] uhci_hcd 0000:00:10.2: detected 2 ports
[ 4.888784] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 4.888938] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 4.888946] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.888953] usb usb4: Product: UHCI Host Controller
[ 4.888960] usb usb4: Manufacturer: Linux 5.10.139-volumio uhci_hcd
[ 4.888966] usb usb4: SerialNumber: 0000:00:10.2
[ 4.889331] hub 4-0:1.0: USB hub found
[ 4.889359] hub 4-0:1.0: 2 ports detected
[ 4.889941] i8042: PNP: No PS/2 controller found.
[ 4.889945] i8042: Probing ports directly.
[ 4.890491] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 4.890510] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 4.890978] mousedev: PS/2 mouse device common for all mice
[ 4.891472] rtc_cmos 00:01: RTC can wake from S4
[ 4.892201] rtc_cmos 00:01: registered as rtc0
[ 4.892261] rtc_cmos 00:01: setting system clock to 2022-10-16T14:07:11 UTC (1665929231)
[ 4.892336] rtc_cmos 00:01: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 4.892369] i2c /dev entries driver
[ 4.892461] platform eisa.0: Probing EISA bus 0
[ 4.892470] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 4.892556] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.893081] NET: Registered protocol family 10
[ 4.893918] Segment Routing with IPv6
[ 4.893988] mip6: Mobile IPv6
[ 4.893995] NET: Registered protocol family 17
[ 4.894118] mpls_gso: MPLS GSO support
[ 4.894878] IPI shorthand broadcast: enabled
[ 4.895089] registered taskstats version 1
[ 4.895098] Loading compiled-in X.509 certificates
[ 4.895142] zswap: loaded using pool lzo/zbud
[ 4.897259] acpi_cpufreq: acpi_cpufreq: failed to register hotplug callbacks
[ 4.898133] Unstable clock detected, switching default tracing clock to "global"
"trace_clock=local"
[ 4.904881] Freeing unused kernel image (initmem) memory: 1828K
[ 4.905023] Write protecting the kernel read-only data: 18432k
[ 4.907447] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 4.908535] Freeing unused kernel image (rodata/data gap) memory: 1020K
[ 4.908836] Run /init as init process
[ 4.908842] with arguments:
[ 4.908847] /init
[ 4.908852] splash
[ 4.908856] with environment:
[ 4.908861] HOME=/
[ 4.908865] TERM=linux
[ 4.908870] BOOT_IMAGE=vmlinuz
[ 4.908874] biosdevname=0
[ 4.908879] imgpart=UUID=2301fe0c-07cd-4a6d-bfb4-1780dbe18679
[ 4.908883] bootpart=UUID=6B3C-7633
[ 4.908888] datapart=UUID=32081f10-452e-41fb-9815-f6d3c7a1d598
[ 4.908892] imgfile=/volumio_current.sqsh
[ 4.908897] use_kmsg=yes
[ 4.934072] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.965356] fuse: init (API version 7.32)
[ 5.094001] sdhci: Secure Digital Host Controller Interface driver
[ 5.094008] sdhci: Copyright(c) Pierre Ossman
[ 5.128220] hid: raw HID events driver (C) Jiri Kosina
[ 5.139608] usbcore: registered new interface driver usbhid
[ 5.139615] usbhid: USB HID core driver
[ 5.140094] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 5.176268] loop: module loaded
[ 5.207579] usbcore: registered new interface driver usb-storage
[ 5.288490] pata_via 0000:00:0f.0: version 0.3.4
[ 5.293145] scsi host0: pata_via
[ 5.293598] scsi host1: pata_via
[ 5.293773] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 5.293779] ata2: DUMMY
[ 5.297833] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176, bcdDevice= 2.00
[ 5.297843] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.297851] usb 1-1: Product: 802.11n WLAN Adapter
[ 5.297857] usb 1-1: Manufacturer: Realtek
[ 5.297864] usb 1-1: SerialNumber: 00e04c000001
[ 5.463228] ata1.01: ATA-9: Netac SSD 128GB, HPS1A30F, max UDMA/133
[ 5.463239] ata1.01: 250069680 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 5.463257] ata1.01: limited to UDMA/33 due to 40-wire cable
[ 5.466305] scsi 0:0:1:0: Direct-Access ATA Netac SSD 128GB A30F PQ: 0 ANSI: 5
[ 5.467368] sd 0:0:1:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 5.467406] sd 0:0:1:0: [sda] Write Protect is off
[ 5.467415] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 5.467471] sd 0:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.475341] sda: sda1 sda2 sda3
[ 5.476640] sd 0:0:1:0: [sda] Attached SCSI disk
[ 5.560113] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 5.757147] usb 3-1: New USB device found, idVendor=10c4, idProduct=8108, bcdDevice= 0.00
[ 5.757159] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.757168] usb 3-1: Product: USB OPTICAL MOUSE
[ 5.757177] usb 3-1: Manufacturer: YSPRINGTECH
[ 5.776944] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:10.1/usb3/3-1/3-1:1.0/0003:10C4:8108.0001/input/input5
[ 5.777332] hid-generic 0003:10C4:8108.0001: input,hidraw0: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-0000:00:10.1-1/input0
[ 6.356092] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 6.554149] usb 3-2: New USB device found, idVendor=04f2, idProduct=1228, bcdDevice= 1.11
[ 6.554160] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.554170] usb 3-2: Product: USB KEYBOARD
[ 6.554178] usb 3-2: Manufacturer: CHICONY
[ 6.574810] input: CHICONY USB KEYBOARD as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.0/0003:04F2:1228.0002/input/input6
[ 6.632362] hid-generic 0003:04F2:1228.0002: input,hidraw1: USB HID v1.11 Keyboard [CHICONY USB KEYBOARD] on usb-0000:00:10.1-2/input0
[ 6.656472] input: CHICONY USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input7
[ 6.716380] input: CHICONY USB KEYBOARD System Control as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input8
[ 6.716649] input: CHICONY USB KEYBOARD as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.1/0003:04F2:1228.0003/input/input9
[ 6.717044] hid-generic 0003:04F2:1228.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [CHICONY USB KEYBOARD] on usb-0000:00:10.1-2/input1
[ 10.728925] [i] initramfs: IMGPART=/dev/sda2
[ 10.729093] [i] initramfs: IMGFILE=/volumio_current.sqsh
[ 10.729230] [i] initramfs: BOOTPART=/dev/sda1
[ 10.729363] [i] initramfs: DATAPART=/dev/sda3
[ 10.814358] EXT4-fs (sda2): recovery complete
[ 10.817996] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.853144] [i] initramfs: GPTSIZEMISMATCH:
[ 10.853406] [i] initramfs: Doing a 5 second delay here to give kernel load a headstart
[ 15.857110] [i] initramfs: Checking for a volumio rootfs update on a USB device
[ 15.873694] [i] initramfs: Checking for factory reset on a USB device
[ 15.890197] [i] initramfs: Checking for factory or user-data reset on boot device
[ 15.912232] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 15.929295] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 23.197497] [i] initramfs: Volumio version 3.378
[ 23.348838] EXT4-fs (sda3): recovery complete
[ 23.352592] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 23.395813] [i] initramfs: Checking if fstab needs to be updated..
[ 23.395971] [i] initramfs: Current /dev/sda1 - UUID=6B3C-7633
[ 23.396155] [i] initramfs: Current fstb \boot
[ 23.401914] [i] initramfs: Volumio: 3.378
[ 23.402076] [i] initramfs: Finishing initramfs, switching rootfs and starting the boot process...
[ 24.236952] systemd[1]: Inserted module 'autofs4'
[ 24.306250] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +AC L +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 24.306766] systemd[1]: Detected architecture x86-64.
[ 24.315583] systemd[1]: Set hostname to <volumio>.
[ 24.996576] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 24.996594] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 25.109130] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd .pid \xe2\x86\x92 /run/samba/winbindd.pid; please update the unit file accordingly.
[ 25.239777] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.239859] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.247969] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.248370] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 25.248930] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 25.250795] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 25.252223] systemd[1]: Listening on Journal Audit Socket.
[ 26.170472] RPC: Registered named UNIX socket transport module.
[ 26.170480] RPC: Registered udp transport module.
[ 26.170484] RPC: Registered tcp transport module.
[ 26.170488] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 26.277650] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 26.331696] random: systemd: uninitialized urandom read (16 bytes read)
[ 26.508493] random: systemd: uninitialized urandom read (16 bytes read)
[ 27.502898] random: systemd: uninitialized urandom read (16 bytes read)
[ 27.529342] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 27.542415] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 27.632353] systemd-journald[213]: Received request to flush runtime journal from PID 1
[ 28.499466] VIA Graphics Integration Chipset framebuffer 2.4 initializing
[ 28.557906] viafb: Probing I2C bus 0x26
[ 28.788461] sd 0:0:1:0: Attached scsi generic sg0 type 0
[ 29.023111] usbcore: registered new interface driver usbkbd
[ 29.089631] random: systemd: uninitialized urandom read (16 bytes read)
[ 29.227932] viafb: Probing I2C bus 0x31
[ 29.623252] usbcore: registered new interface driver usbmouse
[ 29.892161] EDID: NEC NEC LCD1550VM
[ 29.998439] tg3 0000:05:00.0: No PHY devices
[ 29.998874] tg3 0000:05:00.0: Problem fetching invariants of chip, aborting
[ 30.620033] snd_hda_intel 0000:00:01.1: CORB reset timeout#1, CORBRP = 0
[ 30.621391] snd_hda_intel 0000:00:01.1: no codecs found!
[ 30.656841] snd_hda_intel 0000:00:14.0: Force to non-snoop mode
[ 30.772876] snd_hda_codec_via hdaudioC1D0: autoconfig for VT1708S: line_outs=1 (0x1c/0x0/0x0/0x0/0x0) type:line
[ 30.772889] snd_hda_codec_via hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 30.772898] snd_hda_codec_via hdaudioC1D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 30.772905] snd_hda_codec_via hdaudioC1D0: mono: mono_out=0x0
[ 30.772910] snd_hda_codec_via hdaudioC1D0: inputs:
[ 30.772918] snd_hda_codec_via hdaudioC1D0: Mic=0x1a
[ 30.901974] viafb: Probing I2C bus 0x2C
[ 31.939164] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 32.391614] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 32.696605] padlock_sha: Using VIA PadLock ACE for SHA1/SHA256 algorithms.
[ 35.046634] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 35.832277] 8021q: 802.1Q VLAN Support v1.8
[ 41.744489] VIA RNG detected
[ 42.120501] via_cputemp via_cputemp.0: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 42.636896] padlock_aes: Using VIA PadLock ACE for AES algorithm.
[ 44.867915] random: crng init done
[ 44.867927] random: 271 urandom warning(s) missed due to ratelimiting
[ 47.368056] viafb: Finished I2C bus probing
[ 48.796308] fbcon: Via (fb0) is primary device
[ 48.824693] Console: switching to colour frame buffer device 80x30
[ 49.141802] rtl8192cu: Chip version 0x10
[ 49.384973] rtl8192cu: Board Type 0
[ 49.385200] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 49.385267] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 49.385330] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 49.430591] usbcore: registered new interface driver rtl8192cu
[ 49.510207] usbcore: registered new interface driver rtl8xxxu
[ 49.710017] rtl8192cu: MAC auto ON okay!
[ 49.762033] rtl8192cu: Tx queue select: 0x05
[ 51.704017] rtl8192cu: MAC auto ON okay!
[ 51.737295] rtl8192cu: Tx queue select: 0x05
[ 54.166718] rtl8192cu: MAC auto ON okay!
[ 54.211750] rtl8192cu: Tx queue select: 0x05
[ 55.801887] wlan0: authenticate with 50:ff:20:66:b3:c4
[ 55.826494] wlan0: send auth to 50:ff:20:66:b3:c4 (try 1/3)
[ 55.828450] wlan0: authenticated
[ 55.832081] wlan0: associate with 50:ff:20:66:b3:c4 (try 1/3)
[ 55.854738] wlan0: RX AssocResp from 50:ff:20:66:b3:c4 (capab=0x1811 status=0 aid=2)
[ 55.956356] wlan0: associated
[ 55.956474] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 50:ff:20:66:b3:c4
[ 95.010212] Bluetooth: Core ver 2.22
[ 95.010311] NET: Registered protocol family 31
[ 95.010316] Bluetooth: HCI device and connection manager initialized
[ 95.016203] Bluetooth: HCI socket layer initialized
[ 95.016215] Bluetooth: L2CAP socket layer initialized
[ 95.016247] Bluetooth: SCO socket layer initialized
[ 95.149088] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 95.149098] Bluetooth: BNEP filters: protocol multicast
[ 95.149112] Bluetooth: BNEP socket layer initialized
[ 132.801102] snd_hda_intel 0000:00:14.0: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
Please add
before your log
I just checked, alsamixer and card 1: VT82xx [HDA VIA VT82xx], device 0: VT1708S Analog [VT1708S Analog] works, I do not know why the user tepiloxtl failed.
Test
Sorry I didn’t figure it out
Simple: a 10-year old terminal device, when it works, fine. When it doesn’t, bad luck, for me not worth putting any effort in.
Sometimes it is obvious why some ones fail and can be easily solved by adding missing firmware. Not in this case, sorry
think I am going to buy this one: Nuc worked for me before (now using that as desktop pc);
If you already have it at home, i would just test it first and order later.
To be sure that it works. Just use the boot from usb option in bios and run it from there.
I get it tomorrow. Thanks for the advice. I will test it first from usb. When that works I can migrate to minipc.
I ordered the 64gb rom version. 4GB ram should be enough.
To be sure you can disconnect the hdd so it can’t be wiped during testing.
Sounds strange 64gb rom, it should be a micro sd of 64gb i guess.
I hope tested it all before you bought anything.
If you do not have the device you can not test it. Other versions in this range have a SSD drive. Other brand with same looks says it is a 64Gb eMMC.
Do you think it is better to buy a ssd with it?
I think that ssd should be faster than any eMMC
For volumio it doesn’t matter. most of the system runs from memory, with eMMC or SSD it boots faster. that’s about it.
If you plan to use the HW for other purposes, then go for a SSD as this is faster (most of the times) in overal performance.
thx, I ordered a kingston ssd to be sure . Not to expensive. Will update how the eperience will be.
I do not get it boot from SSD when installed volumio on it. Bios I set to legacy. Volumio sees ssd but can not figure out the boot priority.
did you install it to the SSD? There is an option in System to do so.
