This topic is about x86, not Tinkerboard
Thank you so much!
Intel Broadwell.
I have trouble making audio over HDMI work.
In Settings → playback options → output device there are two option, “HDA Intel HDMI” and “Analog Out”.
I want HDMI audio playback, so I select the first option, but no sound comes out.
‘speaker-test -D hw:0,3 -c 2’ works fine.
System version: 3.251 released: Thu 31 Mar 2022 03:20:44 PM CEST
Link to log:
http://logs.volumio.org/volumio/lQ1PWRB.html
volumio@stue:~$ aplay -l
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
Subdevices: 1/1
volumio@stue:~$ lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.1 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation Wildcat Point-LP Thermal Management Controller (rev 03)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
02:00.0 Network controller: Intel Corporation Wireless 7260 (rev bb)
volumio@stue:~$ inxi -Fxxxz
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = “da_DK.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
System: Host: stue Kernel: 5.10.95-volumio x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop Mobo: GOOGLE model: Guado v: 1.0 serial: UEFI: coreboot v: MrChromebox-4.16 date: 04/09/2022
CPU: Topology: Dual Core model: Intel Celeron 3215U bits: 64 type: MCP arch: Broadwell rev: 4 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6783
Speed: 1696 MHz min/max: 500/1700 MHz Core speeds (MHz): 1: 1696 2: 1696
Graphics: Device-1: Intel HD Graphics driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1606
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 190x52
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel Broadwell-U Audio driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9ca0
Sound Server: ALSA v: k5.10.95-volumio
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: 2000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: 2000 bus ID: 02:00.0 chip ID: 8086:08b1
IF: wlan0 state: down mac:
Drives: Local Storage: total: 22.12 GiB used: 1.40 GiB (6.3%)
ID-1: /dev/sda vendor: Transcend model: TS16GMTS400 size: 14.91 GiB speed: 6.0 Gb/s serial: rev: 5O1
scheme: GPT
ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0 size: 7.20 GiB serial: scheme: GPT
Partition: ID-1: / size: 3.55 GiB used: 543.5 MiB (15.0%) fs: overlay source: ERR-102
ID-2: /boot size: 170.8 MiB used: 60.2 MiB (35.2%) fs: vfat dev: /dev/sdb1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 142 Uptime: 13m Memory: 7.65 GiB used: 461.9 MiB (5.9%) Init: systemd v: 241 runlevel: 5 default: 2
Compilers: gcc: 8.3.0 alt: 8 Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
Regards
Søren
Your HDMI sound interface is called “HDA Intel HDMI”, which is missing from the list of card profiles (so far nobody asked for it).
This will need a patch in the Volumio backend.
Meanwhile, if you know how to use an editor in a terminal session,
modify “/volumio/app/plugins/audio_interface/alsa_controller/cards.json”
- copy the line with “Intel HDMI/DP LPE Audio”
- in the copied line, replace “Intel HDMI/DP LPE Audio” by “HDA Intel HDMI”
- reboot
Then let me know how that went.
Hi gkkpch
Thank you for your help. It doesn’t quite work yet. Now the option to select “HDA Intel HDMI” is completely missing from the UI.
This is what it looks like:
{“name”: “Intel HDMI/DP LPE Audio”, “multidevice”: true, “devices”:[{“number”:0, “prettyname”: “HDMI 0”, “defaultmixer”: “”},{“number”:1, “prettyname”: “HDMI 1”, “defaultmixer”: “”},{“number”:2, “prettyname”: “HDMI 2”, “defaultmixer”: “”}],“type”:“integrated”},
{“name”: “HDA Intel HDMI”, “multidevice”: true, “devices”:[{“number”:0, “prettyname”: “HDMI 0”, “defaultmixer”: “”},{“number”:1, “prettyname”: “HDMI 1”, “defaultmixer”: “”},{“number”:2, “prettyname”: “HDMI 2”, “defaultmixer”: “”}],“type”:“integrated”},
yes, but you ‘should’ have HDMI 0, HDMI 1 and HDMI 2 instead.
Try each one of them.
In case that does not work, change the profile to look like this:
{“name”: “HDA Intel HDMI”, “multidevice”: true, “devices”:[{“number”:3, “prettyname”: “HDMI”, “defaultmixer”: “”}],“type”:“integrated”},
This should reflect the speakertest “hw” parameters which you said were working
Thank you, that worked.
The software mixer does not seem to work - could there be some kind of mixer issue? But I don’t want it anyways.
regards
Søren
I presume the last one worked, not the first?
Indeed, the last one:
{“name”: “HDA Intel HDMI”, “multidevice”: true, “devices”:[{“number”:3, “prettyname”: “HDMI 0”, “defaultmixer”: “”},{“number”:7, “prettyname”: “HDMI 1”, “defaultmixer”: “”},{“number”:8, “prettyname”: “HDMI 2”, “defaultmixer”: “”},{“number”:9, “prettyname”: “HDMI 3”, “defaultmixer”: “”},{“number”:10, “prettyname”: “HDMI 4”, “defaultmixer”: “”}],“type”:“integrated”},
perfect addition, please submit this as a patch.
I’ll help via PM when needed😀
Is the new Spotify plugin not available for x86? I can’t seem to find it.
Hi, I Installed Volumio X86 on a Chuwi Herobook Air.
My problem is that the screen is always on and I couldn’t manage to set screen timeout.
Please can you help me?
The log is here http://logs.volumio.org/volumio/aScBQKT.html
I append outputs of lspci and inxi -Fxxxz here.
Thank you
volumio@volumio:~$ inxi -Fxxxz
System: Host: volumio Kernel: 5.10.112-volumio x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Machine: Type: Laptop System: CHUWI Innovation And (ShenZhen) product: HeroBook Air v: N/A serial: <filter>
Mobo: N/A model: N/A serial: <filter> UEFI: American Megatrends v: 0.5.0_P8S4M1E0F0L2B0T7P2G00A0U0D605_ENE
date: 03/17/2022
Battery: ID-1: BAT0 charge: 32.1 Wh condition: 36.5/36.5 Wh (100%) volts: 7.6/N/A model: Emdoor Li-ion Battery type: Li-ion
serial: <filter> status: Discharging
CPU: Topology: Dual Core model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus rev: 8 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4377
Speed: 1517 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 1549 2: 1271
Graphics: Device-1: Intel vendor: Ncipher Corp driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3185
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 133x36
Audio: Device-1: Intel driver: snd_hda_intel v: kernel bus ID: 00:0e.0 chip ID: 8086:3198
Sound Server: ALSA v: k5.10.112-volumio
Network: Message: No Device data found.
IF-ID-1: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 119.24 GiB used: 1.17 GiB (1.0%)
ID-1: /dev/sda vendor: BIWIN model: SSD size: 119.24 GiB speed: 6.0 Gb/s serial: <filter> rev: 2M0 scheme: GPT
Partition: ID-1: / size: 113.39 GiB used: 312.1 MiB (0.3%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 60.2 MiB (35.8%) fs: vfat dev: /dev/sda1
Info: Processes: 143 Uptime: 23m Memory: 3.68 GiB used: 422.5 MiB (11.2%) Init: systemd v: 241 runlevel: 5 default: 2
Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
volumio@volumio:~$ lspci
00:00.0 Host bridge: Intel Corporation Device 31f0 (rev 06)
00:00.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Dynamic Platform and Thermal Framework Processor Participant (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Device 3185 (rev 06)
00:0e.0 Multimedia audio controller: Intel Corporation Device 3198 (rev 06)
00:0f.0 Communication controller: Intel Corporation Celeron/Pentium Silver Processor Trusted Execution Engine Interface (rev 06)
00:12.0 SATA controller: Intel Corporation Device 31e3 (rev 06)
00:14.0 PCI bridge: Intel Corporation Device 31d7 (rev f6)
00:15.0 USB controller: Intel Corporation Device 31a8 (rev 06)
00:16.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO I2C Host Controller (rev 06)
00:16.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO I2C Host Controller (rev 06)
00:16.2 Signal processing controller: Intel Corporation Device 31b0 (rev 06)
00:16.3 Signal processing controller: Intel Corporation Device 31b2 (rev 06)
00:17.0 Signal processing controller: Intel Corporation Device 31b4 (rev 06)
00:17.1 Signal processing controller: Intel Corporation Device 31b6 (rev 06)
00:17.2 Signal processing controller: Intel Corporation Device 31b8 (rev 06)
00:17.3 Signal processing controller: Intel Corporation Device 31ba (rev 06)
00:18.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.2 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.3 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:19.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO SPI Host Controller (rev 06)
00:19.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO SPI Host Controller (rev 06)
00:19.2 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO SPI Host Controller (rev 06)
00:1c.0 SD Host controller: Intel Corporation Celeron/Pentium Silver Processor SDA Standard Compliant SD Host Controller (rev 06)
00:1e.0 SD Host controller: Intel Corporation Device 31d0 (rev 06)
00:1f.0 ISA bridge: Intel Corporation Device 31e8 (rev 06)
00:1f.1 SMBus: Intel Corporation Celeron/Pentium Silver Processor Gaussian Mixture Model (rev 06)
Screen blanking is not supported on x86 as kiosk mode is fixed and unlike touch screen plugin, has no UI settings.
Hi. I came on this forum to find this information. It’s a quite a search to find this. My device did not auto-update (of course, because of the CPU issue), but I only found out about this because Spotify stopped working. Would be nice to add a very small line of text at the downloads to indicate that V3 does not support 32-bit devices anymore. I couldn’t find any “minimum requirements” or something like that.
I’ll try to find a new thin Client, now that my 25-year old thin-client is -at last- obsolete.
what is not clear about "Volumio Audiophile Music Player for PC (X86/X64) on the download page
Btw. plenty of 64-bit thin clients on the 2nd hand market, e.g. Dell/ HP for a price lower than an RPi 4.
Maybe it’s a definition question, but I read it as X86 and/or X64. Could be me, but I think there might be others who don’t have the definitions / nomenclature clear. Just thought that it could be nice to add a short explanation, that’s all.
I was already looking for a nice X64 ThinClient, prices do seem to have gone up lately. But I’ll find something
Bijvoorbeeld Dell Wyse 3040, is een Intel Atom x5-z8350 met genoeg memory en eMMC
mm kenden wij maar iemand… Deze zijn momenteel rond de 200-250 euro.
