Volumio 3.x download links?
Volumio 3 Issues?
I have just tried Volumio 4 on a Raspberry Pi 1 and it doesn’t work.
Where can I get the last version of the Volumio 3 img file?
Correct the Raspberry Pi 1 is not compatible to run V4, you can only run V3
Thank you for the download link
Thank you for the download link as well.
Hi, I just want Volumio 3.x download links for Raspberry Pi 1 and Raspberry Pi Zero and x86 old pcs, and also, because I want to archive them.
As of today 3.874 (14-11-2025) is the latest version. Thanks
Welcome, @Mat84.
https://updates.volumio.org/pi/volumio/3.832/Volumio-3.832-2025-07-26-pi.zip
Thanks. Its not the latest version though. Its good to have it anyway.
I’m not sure if it’s not. Anyway if it’s not is just an OTA update away :slight_smile:
https://updates.volumio.org/pi/volumio/3.874/Volumio-3.874-2025-11-12-pi.zip
For PC:
https://updates.volumio.org/x86_amd64/volumio/3.874/Volumio-3.874-2025-11-12-x86_amd64.zip
For RPi:
Now with Tidal low res fix - only for those who cannot upgrade to v4 for any reason
For i386:
https://updates.volumio.org/x86_amd64/volumio/3.884/Volumio-3.884-2025-12-10-x86_amd64.zip
For RPI:
https://updates.volumio.org/pi/volumio/3.884/Volumio-3.884-2025-12-10-pi.zip
@Josh2000
Hi. What’s this “Tidal low res fix” thing about? I currently have software version 3.874 on my Usbridge Sig, and everything seems fine. Should I “manually” update to 3.884? This version of Volumio isn’t available via OTA.
I’m asking because I haven’t installed Volume 4 on my Usbridge Sig yet. I don’t know if it’ll be supported. So I’m currently running on 3.874.
I dont know and no official changelog nor upgrade is available to 3.884. So I maked the solution to 3.874.
Hi, with 3,874 when AAC file is on playlist by Tidal connect it will stop. Then you must disable and enable tidal connect in volumio sources or restart. Final version is ok.
3.886 has been released. any links?
(there is a type on the version…)
3.866 (18-12-2025) Hotfix release [Rivo, RivoPlus, Integro, Primo v2, PrimoPlus, Motivo, ThinkerBoard, Raspberry Pi, x86-64]
FIXES
Fix TIDAL low quality (AAC) playback
Fix for DLNA Server discovery
Fix for Plugins installation
NEW ADDITIONS
BLE-based onboarding setup
Update TIDAL SDK
Download links for v3.887
For I386:
https://updates.volumio.org/x86_amd64/volumio/3.887/Volumio-3.887-2025-12-19-x86_amd64.zip
For RPI:
https://updates.volumio.org/pi/volumio/3.887/Volumio-3.887-2025-12-19-pi.zip
Download link for v3.905 BETA - RPI only
This one includes the Tidal Connect fix.
https://updates.volumio.org/pi/volumio/3.905/Volumio-3.905-2026-01-28-pi.zip
Download link for v3.907 BETA - RPI only.
https://updates.volumio.org/pi/volumio/3.907/Volumio-3.907-2026-01-30-pi.zip
Thanks! v3.908 got released, any links?
This post should not become a side mirror with V3 downloads.
You can download the latest version that was posted 12d ago by Josh2000 and run an OTA.
i want to mention that these links are only for beta versions ! and it only makes sense in rare cases and test scenarios to flash these.
