Were you successful with the official raspberry screen? With the official Pi builds it shines right away, no display in volumio. I did not try other configurations on the dac though, probably i should do that.
I could not try the official DSI display because I don’t have one…
I still fighting with Pi5 Volumio issues. On Raspberry forum, Software Engineer at Raspberry Pi Ltd. said that on official system can be some problems with display because of drivers and still are added. Maybe here too, but Linux, Debian and other systems are outside my percepion.
Yes, it’s reason why I use older HV Pi4. Last HV1.5 dasn’t works with HifiBerry DIGI and few more.
I bought Pi5 because I use very good USB/Spdif module( I2S in Pi is software not hardware like my XMOS and CPLD / FPGA. Sound quality is on higher level) and I thought that if I haven’t problems with DIGI hat I can use Pi5… and now it is wrong decision - HDMI issue.
Good thing is, that I have few offer to sell it 2 x expensive than I bought it (it is because if you order it now, you must wait 3 months). I give Pi5 chance to start LCD. I will wait. I think that it is “Childhood disease”
Please try adding
dtoverlay=rpi-ft5406
to your “boot/userconfig.txt”.
If that should not work you would probably instead have to add
dtoverlay=vc4-kms-v3d-pi5
dtoverlay=vc4-kms-dsi-7inch,dsi0
for a display connected to “CAM/DISP 0” or
for a display connected to “CAM/DISP 1” to “/boot/userconfig.txt”.
Display rotation set on the Touch Display’s config page will probably not work when using “dtoverlay=vc4-kms-…”.
thanks, i will try that.
I have a Pi 5 with Voumio 3.569 that did not show any screen.
the
worked fine, display slot 1
Thanks alot #gvolt ![]()
Good morning,
when I try to update my library it stops and the following error is reported:
error: MPD error: Error: This socket has been terminated by the other party
error: This socket has been terminated by the other party {“code”:“EPIPE”}
Any advice?
I migrated from rpi4 to rpi5 (new install). The booting time is much shorted and the audio quality is much better.
Problem my Volumio on rpi5 doens’t work with waveshare 7.9" LCD HDMI display 400x1280. I have spent tons of hours - still dark.
The only progress I have made is only with the following line in (user)config.txt:
After boot screen starts to work but:
- LCD can not be rotated via command in config.txt
- Volumio starts but Touch Display not. There is error: Error connecting to Xserver
Hi, nie jesteś sam ![]()
Here is thread about this problem:
but still not solve.
It is problem with all Waveshare, all with not standard resolution.
That is expected, see post #89:
Please post the output of
cat /var/log/Xorg.0.log
Thank you.
I will post the log when I get home ![]()
Just to be clear: Touch display starts when I remove line: dtoverlay=vc4-kms-… from config.txt
When line is active - Error connecting to Xserver
So for sure it is not a problem with Touch display addon itself.
For some reason the Xserver seems to fail to start with that option.
If you are back home please also post the output of
ls -al /dev/fb*
Here you are:
ls -al /dev/fb*
volumio@volumio2:~$ ls -al /dev/fb*
crw-rw---- 1 root video 29, 0 Dec 4 22:38 /dev/fb0
volumio@volumio2:~$
volumio@volumio2:~$ cat /var/log/Xorg.0.log
[ 17.876]
xorg X Server 1.20.4
[ 17.876] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 17.876] Current Operating System: Linux volumio2 6.1.58-v8+ #1690 SMP PREEMPT Tue Oct 17 15:37:08 BST 2023 aarch64
[ 17.876] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:A8:99:0F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 17.876] Build Date: 04 April 2023 07:50:56AM
[ 17.877] xorg-server 2:1.20.4-1+rpt4+deb10u9
[ 17.877] Current version of pixman: 0.36.0
[ 17.877] Before reporting problems, check
[ 17.877] Markers: (--) probed, (**) from config file, (==) default setting,
[ 17.877] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 4 22:38:58 2023
[ 17.880] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 17.880] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 17.884] (==) No Layout section. Using the first Screen section.
[ 17.884] (==) No screen section available. Using defaults.
[ 17.884] (**) |-->Screen "Default Screen Section" (0)
[ 17.884] (**) | |-->Monitor "<default monitor>"
[ 17.886] (==) No monitor specified for screen "Default Screen Section".
[ 17.886] (==) Automatically adding devices
[ 17.886] (==) Automatically enabling devices
[ 17.886] (==) Automatically adding GPU devices
[ 17.888] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 17.888] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 17.888] Entry deleted from font path.
[ 17.891] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 17.891] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 17.891] (II) The server relies on udev to provide the list of input devices.
[ 17.891] (II) Loader magic: 0x1fdf80
[ 17.891] (II) Module ABI versions:
[ 17.891] xorg ANSI C Emulation: 0.4
[ 17.891] xorg Video Driver: 24.0
[ 17.891] xorg XInput driver : 24.1
[ 17.891] xorg Server Extension : 10.0
[ 17.892] (--) using VT number 2
[ 17.892] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 17.893] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 17.893] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 17.895] (II) no primary bus or device found
[ 17.895] falling back to /sys/devices/platform/axi/1002000000.v3d/drm/card0
[ 17.895] (II) LoadModule: "glx"
[ 17.898] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 17.913] (II) Module glx: vendor="xorg Foundation"
[ 17.913] compiled for 1.20.4, module version = 1.0.0
[ 17.913] ABI class: xorg Server Extension, version 10.0
[ 17.913] (==) Matched modesetting as autoconfigured driver 0
[ 17.913] (==) Matched fbdev as autoconfigured driver 1
[ 17.913] (==) Assigned the driver to the xf86ConfigLayout
[ 17.913] (II) LoadModule: "modesetting"
[ 17.913] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 17.916] (II) Module modesetting: vendor="xorg Foundation"
[ 17.916] compiled for 1.20.4, module version = 1.20.4
[ 17.916] Module class: xorg Video Driver
[ 17.916] ABI class: xorg Video Driver, version 24.0
[ 17.916] (II) LoadModule: "fbdev"
[ 17.916] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 17.917] (II) Module fbdev: vendor="xorg Foundation"
[ 17.917] compiled for 1.20.3, module version = 0.5.0
[ 17.917] Module class: xorg Video Driver
[ 17.917] ABI class: xorg Video Driver, version 24.0
[ 17.917] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 17.917] (II) FBDEV: driver for framebuffer: fbdev
[ 17.928] (WW) Falling back to old probe method for modesetting
[ 17.928] (WW) Falling back to old probe method for fbdev
[ 17.928] (II) Loading sub module "fbdevhw"
[ 17.928] (II) LoadModule: "fbdevhw"
[ 17.928] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 17.930] (II) Module fbdevhw: vendor="xorg Foundation"
[ 17.930] compiled for 1.20.4, module version = 0.0.2
[ 17.930] ABI class: xorg Video Driver, version 24.0
[ 17.930] (II) FBDEV(0): using default device
[ 17.944] (II) modeset(G0): using drv /dev/dri/card1
[ 17.944] (EE)
Fatal server error:
[ 17.944] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[ 17.944] (EE)
[ 17.944] (EE)
Please consult the The xorg Foundation support
at http://wiki.xorg
for help.
[ 17.944] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 17.944] (EE)
[ 18.011] (EE) Server terminated with error (1). Closing log file.
[Wheaten] Formatted the code to make it more readable
Please try the following:
Stop the Touch Display plugin.
As root execute
cat >> /etc/X11/xorg.conf.d/99-vc4.conf <<EOL
Section "OutputClass"
Identifier "vc4"
MatchDriver "vc4"
Driver "modesetting"
Option "PrimaryGPU" "true"
EndSection
EOL
Start the Touch Display plugin.
It works
but the question is how to rotate the screen?
Many, many thanks!!!
/usr/bin/xrandr --display :0 --query
Here you are ![]()
volumio@volumio2:~$ /usr/bin/xrandr --display :0 --query
Screen 0: minimum 320 x 200, current 400 x 1280, maximum 8192 x 8192
HDMI-1 connected primary 400x1280+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
400x1280 60.23*+
1280x720 100.00
320x1480 59.32
HDMI-2 disconnected (normal left inverted right x axis y axis)
thank you!
Try to manually rotate the display clockwise by running
xrandr --output HDMI-1 --rotate right
no luck this time:
volumio@volumio2:~$ xrandr --output HDMI-1 --rotate right
Can’t open display
volumio@volumio2:~$ sudo xrandr --output HDMI-1 --rotate right
[sudo] password for volumio:
Can’t open display
