I pick up Pi5 and conected. Is really faster than Pi4 4gb. From power on to start sound from speaker Pi4 need 1 minut 40 sec. Pi5 done it in 50 sec.
But I haven’t LCD screen. My 11.9 Waveshare shows nothing on HDMI0 and HDMI1 ports.
Some tips?
I use the same config in Pi3 and Pi4 without problems.
As far as I know, the tested versions by Volumio had no issues, mine did from the start. It’s always possible that a unit fails. I don’t think it’s a common thing.
I’ve connected the RPi5 sample to my Samsung TV using the HDMI-0 port, no problem in my case (I forgot to test this use-case before)
It means that the problem is the combination of the Waveshare display with the RPi5, @eMCZe looking at the problems on the Raspberry Pi forum I think it’s a general problem, not strictly related to Volumio
My suggestion is try to make the Waveshare display working on RaspiOS first, and then try the very same settings on the Volumio image
PS: what tool are you using to edit the cmdline.txt file? If you use notepad on Windows, it will change the line-ending of the file and create problems
