rpi5 needs a 5V/5A power supply, the cooling not mandatory for Volumio, you need to test it for your situation. There is also passive cooling. But I would advise to cool it.
A library target comparison table is in this post.
can you please share the link where to buy the screen ? thanks
The original link is missing, you can search “1920x480 LCD” in Amazon, or any other on-line shopping.
Good luck !
Hi everyone, first off, big thanks @Gelo5 and @2aCD for this amazing plugin and visuals - volumio looks kinda boring without it! :stuck_out_tongue_winking_eye:
I finally got round to updating my main player from 3.6 to the latest 3.785 and now have a wierd issue where PeepyMeter seems to draw itself twice, resulting in flickering bars and/or needles. It’s really obvious if the start animation is on as you can see the wipe draw itself twice.
I’m using a Pi4 with an 800x480 7" DSI touchscreen (can’t remember where it came from, but probably AliExpress).
I’ve tried playing with userconfig.txt but to no avail.
Any help/pointers would be greatly appreciated.
Cheers Simon
What version?:
*Peppymeter
*pygame
pygame ver. via SSH (write):
python3
Click ENTER
import pygame
Click ENTER
Asking a favor if you can make peppy meter 1366 x 768 resolution. Marantz , Naim or any other design.
Thanks in advance.
I’ll have some free time so I’ll do something.
Now I make 3840x2160 skins
Here are some skins 1366 x 768
to templates.zip (3.9 MB)
so quick. Thank you so much!
You’re welcome. 3.000$ :stuck_out_tongue_winking_eye:
you gave a discount? :rofl:
Yes, 4000$ with discount= 3.000$ :innocent:
Probably should have mentioned that as well:
Peppymeter 2.2.1
pygame 2.6.0.dev1 (SDL 2.0.9, Python 3.7.3)
cheers /S
can you take pictures? It’s hard to imagine. PM and pygame are the latest, everything should work fine.
Please don’t judge my ghetto player! :joy: There always seems to be something else that needs doing instead of putting this in a proper case…
record 30s of music playing. What plugins do you have installed?
Crappy iphone large files! Sorry i have to link it this way: playing and nothing crazy with plugins:
and thanks for looking at this :grinning:
Try to set it up like in the picture (end of post). I don’t know what’s the reason?? :grimacing:
Project with PeppyMeter/PeppySpectrum Screensaver Plugin for VOLUMIO - #741 by Gelo5?
Annoyingly that’s exactly how it’s set up except for my smooth needle is 4 :thinking:
Perhaps when the weather is bad again i’ll sit down and do a ground up rebuild and see if that makes any difference.
Cheers for the help though :grinning:
Just taken the SD card from the “main” system to the spare Pi i have but using an HDMI screen - no problems :rage: :hot_face:
