The PeppySpectrum plugin was create by @balbuze, who also created FusionDSP. Both work together.
deleted by the author
HI I have installed peppyspectrum, and inactivated peppymeter.
This is what I have
I have the squar (backround od spectrum, but no bars)
Any idea ?
save settings in peppyspectrum
Save has been done.
when peppyspectrum is active no sound , the dac that is external get nothing.
If I inactive the peppyspectrum, sound back
@balbuze HI, have you any idea to fix this issue ?
HI
I tried many changes, inactive DSP, touchplay Active, Peppymeter Incative.
When PeppySpectrum active, I see the background of the pluging without bars and no sound .
IF i inactive the plugin, sound is played.
Can you help me in the reolution ?
Your helep will be appreciated.
Georges
Can you try with Now playing plugin disabled
ok i will do tomorrow ![]()
Nothing changed Even when inactive all other pluggins eexcept touch display. As soon spectrum activated sound stops.
Have you tried to disable peppyspectrum and re enable it?
Can you send log?
yes I did. Can you remember me how to get the log ?
I found how to.produce log. I am preparing two logs
First is without spectrum activated.
http://logs.volumio.org/volumio/BPScv9s.html
This one is with spectrum on, the sound stops,
http://logs.volumio.org/volumio/8qxs7kY.html
This one is after reboot, spectrum active, tracks are listed, but cannot start any of them, so no sound
http://logs.volumio.org/volumio/hj5eXFF.html
I see several reasons…
FusionDsp is enabled
Multi room is enabled
Software volume is enabled…
Disable themone by one to see if better
ok I will.
1-Must Have I to reboot each time ?
2-Where multiroom actived ?
No need to reboot.
Multi room is enabled in source menu
In order
Stopped multiroom, no change
Stopped DSP, no change
Stopped software volume, spectrum started then run 5 seconds then stops
when stop the now playing, spectrum is displayed 5 seconds then switches to now playing, spectrum deseappers
When start the now playing, spectrum is displayed 5 seconds then switches to the normal screen, spectrum deseappers
the log and video
http://logs.volumio.org/volumio/tRDYgiA.html
additional test:
1- I activated DSP then the background of spectrum displayed, no song.
2- DSP off, Software volume, spectrum on, the background of spectrum displayed, no sound.
Hope this will help
Hi everyone ![]()
I have the vu with peppymeter on one display, and the user interface on the other
here is a short video about my DiY Dac & Streamer…which runs like a power tank completely on LifePO4 batteries…
And everything packed in two cases ![]()
Still under construction; and I still have to finalise a few things .
