HI @balbuze is ther any chance to have spectrum working on my setting. I sent you the video to show what happends. At this moment I inactived it as it stay display one second.
Hope I would be able to test it.
Regards Georges
Regards Georges
Hello!
New version for the plugin!
Now support custom folder and resolution.
Put your skins in the shared folder
/data/INTERNAL/PeppySpectrum/Templates
With the naming convention for folders:
myspectrum(widthxheiight)
ex wood(800x480)
size will be automatically set.
@Gelo5 already created nice spectrum!
Enjoy
800x480_9skin.zip (4,7 Mo)
peppyspectrum.zip (216,3 Ko)
Spectrum works great! Good job!
Let me @balbuze add better photos and 1 additional skin (800x480).
Unpack. Copy the entire folder to:
HI Balbuze
I installed the plugin, see above the sequence of the process, then reboot volumio.
Here is the setting screen I have. the spectrum is not displayed.
ssh volumio@volumio.local
password volumio
data/INTERNAL
cd /data/INTERNAL
mkdir peppyspectrum
cd peppyspectrum
mkdir templates
exit
on the pc, cd to the directory where files to copy are (temp)
scp c:/temp/peppyspectrum.zip volumio@volumio.local:/data/INTERNAL/peppyspectrum.zip
scp c:/temp/800x480_9skin.zip volumio@volumio.local:/data/INTERNAL/800x480_9skin.zip
Remove old plugin.
Download the last version in /data/INTERNAL
then
mkdir ps
miniunzip peppyspectrum.zip -d ./ps
cd ps
volumio plugin install
cd ..
rm -Rf ps
reboot
You donât have to create the Templates folder. Just drop spectrum unzipped folder in it like
/Templates/myspectrum(800x600)
HI
got the error message during installation.
volumio@volumio:/data/INTERNAL$ cd ps
volumio@volumio:/data/INTERNAL/ps$ volumio plugin install
This command will install the plugin on your device
================================ WARNING ====================================
This plugin is not verified by Volumio. Installing it is UNSAFE and can make your system UNSTABLE!
You are STRONGLY advised not to install plugins manually, better wait they are officially available.
? Do you want to install this plugin anyway? Yes
Compressing the plugin
Plugin succesfully compressed
Progress: 10
Status :Downloading plugin
nloading plugin at http://127.0.0.1:3000/plugin-serve/peppyspectrum.zip
Progress: 30
Status :Creating install location
Progress: 40
Status :Unpacking plugin
Unpacking plugin
Progress: 45
Status :Checking that the plugin is suitable for this version of Volumio The plugin can be used with this version of Volumio
Progress: 50
Status :Checking for duplicate plugin
Progress: 60
Status :Copying plugin to location
Progress: 70
Status :Installing necessary utilities
Progress: 70
Installing peppyalsa plugin dependencies
Progress: 70
etc/systemd/system/peppyspectrum.service
Progress: 70
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Progress: 70
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Progress: 70
Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
Progress: 70
Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Progress: 70
Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
Progress: 70
Get:6 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [110 kB]
Progress: 70
Fetched 13.6 MB in 11s (1211 kB/s)
Progress: 70
Reading package lists...
Progress: 70
cloning peppyspectrum repo
Progress: 70
installing apt packages
Progress: 70
Progress: 70
Building dependency tree...
Progress: 70
Reading state information...
Progress: 70
python3 is already the newest version (3.7.3-1).
Progress: 70
python3-pygame is already the newest version (1.9.4.post1+dfsg-3).
Progress: 70
0 upgraded, 0 newly installed, 0 to remove and 79 not upgraded.
Progress: 0
**Status :An error occurred while installing the plugin Error**
**An error occurred while installing the plugin Error**
**Failed to Install Plugin**
[Wheaten] Cleaned the layout to keep it readable.
did you change default password in volumio?
no, no !
did you remove folders you created in /data/INTERNAL?
Another method - use e.g. Fillezilla
Now unzip the skins folder (on your computer) and move the entire folder to: /data/INTERNAL/PeppySpectrum/Templates
cannot delete the directory
volumio@volumio:/data/INTERNAL$ rm -r PeppySpectrum
rm: descend into write-protected directory âPeppySpectrumâ? y
rm: cannot remove âPeppySpectrum/Templatesâ: Permission denied
Then delete the contents or chnage name
sudo rm..
point 1 done
point 3 name is Peppyspectrum or PeppySpectrum ?
It doesnât matter what itâs called.I have PeppySpectrum
@balbuze - PW
same issue
volumio@volumio:~/PeppySpectrum$ volumio plugin install
No modules found, running "npm install"
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN peppyspectrum@0.0.8 No repository field.
Progress: 10
Progress: 30
Progress: 40
Unpacking plugin
Progress: 45
Progress: 50
Progress: 60
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Progress: 70
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Fetched 4584 B in 1s (3588 B/s)
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 70
Progress: 0
Impossible, what version of volumio do you have?
Only @balbuze can help here
can you check internet connectivity
volumio endpointstest
Hello!
PeppySpectrum is now available in the plugin store (beta).
Whatâs in ?
In a very easy way. Just drop the folder with your custom Spectrum in the shared folder
/INTERNAL/PeppySpectrum/Templates/
with the naming convention :
myspectrum(weightxhighxnnumberofbars) ex : metal(800x600x30)
Number of bars can be omitted, then default is 30.
As it is always pleasant to have ready to use nice Spectrums, our best creator, @Gelo5 did it!
Warning : itâs beta
Known issue : does not work with software volume mixer!
Gelo5 (1920x1080x13).zip (5.1 MB)
Gelo5 (1920x1080x30).zip (6.8 MB)
Gelo5 (1920x1080x55).zip (8.7 MB)
Gelo5 (800x480x30).zip (5.5 MB)
Gelo5 (1280x400x30).zip (6.9 MB)
