I am running my Rivo for quite a while with a Samsung 870 QVO ssd 1TB as music source, formatted ext4. Today I changed to a 2TB disk, same type. The disk is not recognized and mounted. Worse, the old disk is now not recognized either! Tried several cold starts, no avail.
Right, I recall that issue now. But it seems not enough, the disk is still not recognized. When I searched for “issd” in the forum threads, some people mention that it also must be formatted in a certain manner.
The disk works just fine on my laptop, btw.
It would be good if someone from Volumio could clarify what the issue is with 2TB SSD’s-
Yesterday, I revived an Rpi4 with the latest volumio. Same result
I will try to create a dedicated entry in the fstab, this helped in the past, when there were problems with ssd disks in general.
I am not sure whether it is a power issue. After all, I got the 2TB disk to work on my Rpi4 with an explicit entry in /etc/fstab that contains the uuid of the disk. I can try the same with the Rivo, but I am a bit reluctant to tamper with it.
Unfortunately, I don’t a have a powered USB hub at hand. And the Rivo has only one USB port for input, right?
