good for you!
I will wait for stable version.
Now I can’t rotate and Touch Screen not working. Only this I have few sec.
and restart without Touch Screen.
Touch Screen try to start only first time after “Active On”
I will wait and ask for help on stable 3.584.
Please post the ouput of
ls -al /dev/fb*
and with the Touch Display plugin being started of
cat /var/log/Xorg.0.log
I need to add it to userconfig.txt or on command line after start ??
and this ??
Sorry if it is stupid question.
Not “userconfig.txt”. After connecting to Volumio via SSH paste each command to the command line (one after the other of course
) and hit enter. Copy the output and paste it into your next post in this thread.
volumio@volumio:~$ ls -al /dev/fb*
crw-rw---- 1 root video 29, 0 Dec 12 20:52 /dev/fb0
volumio@volumio:~$ cat /var/log/Xorg.0.log
[ 364.434]
X.Org X Server 1.20.4
[ 364.434] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 364.434] Current Operating System: Linux volumio 6.1.64-v8+ #1702 SMP PREEMPT Wed Nov 29 14:23:01 GMT 2023 aarch64
[ 364.434] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:CB:30:4C vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 364.434] Build Date: 04 April 2023 07:50:56AM
[ 364.434] xorg-server 2:1.20.4-1+rpt4+deb10u9 (Debian -- User Support)
[ 364.434] Current version of pixman: 0.36.0
[ 364.434] Before reporting problems, check http://wiki.x.org
[ 364.434] Markers: (–) probed, () from config file, (==) default setting,
[ 364.434] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Dec 12 20:57:58 2023
[ 364.434] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 364.434] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 364.435] (==) No Layout section. Using the first Screen section.
[ 364.435] (==) No screen section available. Using defaults.
[ 364.435] () |–>Screen “Default Screen Section” (0)
[ 364.435] (**) | |–>Monitor “”
[ 364.435] (==) No monitor specified for screen “Default Screen Section”.
[ 364.435] (==) Automatically adding devices
[ 364.435] (==) Automatically enabling devices
[ 364.435] (==) Automatically adding GPU devices
[ 364.435] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 364.435] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 364.435] Entry deleted from font path.
[ 364.435] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 364.435] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 364.435] (II) The server relies on udev to provide the list of input devices.
[ 364.435] (II) Loader magic: 0x1fdf80
[ 364.435] (II) Module ABI versions:
[ 364.435] X.Org ANSI C Emulation: 0.4
[ 364.435] X.Org Video Driver: 24.0
[ 364.435] X.Org XInput driver : 24.1
[ 364.435] X.Org Server Extension : 10.0
[ 364.436] (–) using VT number 2
[ 364.436] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 364.437] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 364.437] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 364.445] (II) no primary bus or device found
[ 364.445] falling back to /sys/devices/platform/axi/1002000000.v3d/drm/card0
[ 364.445] (II) LoadModule: “glx”
[ 364.446] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 364.447] (II) Module glx: vendor=“X.Org Foundation”
[ 364.447] compiled for 1.20.4, module version = 1.0.0
[ 364.447] ABI class: X.Org Server Extension, version 10.0
[ 364.447] (==) Matched modesetting as autoconfigured driver 0
[ 364.447] (==) Matched fbdev as autoconfigured driver 1
[ 364.447] (==) Assigned the driver to the xf86ConfigLayout
[ 364.447] (II) LoadModule: “modesetting”
[ 364.447] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 364.447] (II) Module modesetting: vendor=“X.Org Foundation”
[ 364.447] compiled for 1.20.4, module version = 1.20.4
[ 364.447] Module class: X.Org Video Driver
[ 364.447] ABI class: X.Org Video Driver, version 24.0
[ 364.447] (II) LoadModule: “fbdev”
[ 364.447] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 364.447] (II) Module fbdev: vendor=“X.Org Foundation”
[ 364.447] compiled for 1.20.3, module version = 0.5.0
[ 364.447] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 364.447] (II) FBDEV: driver for framebuffer: fbdev
[ 364.462] (WW) Falling back to old probe method for modesetting
[ 364.462] (WW) Falling back to old probe method for fbdev
[ 364.462] (II) Loading sub module “fbdevhw”
[ 364.462] (II) LoadModule: “fbdevhw”
[ 364.462] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 364.462] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 364.462] compiled for 1.20.4, module version = 0.0.2
[ 364.462] ABI class: X.Org Video Driver, version 24.0
[ 364.462] (II) FBDEV(0): using default device
[ 364.478] (II) modeset(G0): using drv /dev/dri/card1
[ 364.478] (EE)
Fatal server error:
[ 364.478] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[ 364.478] (EE)
[ 364.478] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 364.478] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 364.478] (EE)
[ 364.545] (EE) Server terminated with error (1). Closing log file.
volumio@volumio:~$
It is without modifications of userconfig.txt
Stop the Touch Display plugin.
On Volumio’s command line become root by excuting
su
(root’s password is “volumio”, too).
Then execute
cat >> /etc/X11/xorg.conf.d/99-vc4.conf <<EOL
Section "OutputClass"
Identifier "vc4"
MatchDriver "vc4"
Driver "modesetting"
Option "PrimaryGPU" "true"
EndSection
EOL
Start the Touch Display plugin again.
It is my first time
Should I put it line by line ??
no just copy the complete block at once and run it.
I have Volumio Touch Screen but rotate right.
If you are still root type
exit
and hit “Enter”.
Then execute
mkdir /home/volumio/.config/openbox
and
cat >> /home/volumio/.config/openbox/autostart <<EOL
xrandr --output HDMI-1 --rotate left
EOL
Stop and start the Touch Display plugin.
Works !!!
I have to do it all time after restart ??
EDIT:
after restart still ok ![]()
No.
Thank you very much !!!
Do you know why I dont have HDMI signal on 3.569 but on 3.584 have it ??
Can I use 3.584 till finall version ?? Play music from my USB converter.
Probably kernel related.
I guess so.
Do you know if this modification will be included in the next firmware upgrade?
Which one ??
If you asked about working Waveshare 11.9" - my started to work on next firmware 3.584 ( but now it is Beta ver. ). I use it because it was my problem solution.
It would be nice to have a brief sum up of what’s been modified to get it to work. I’ve just picked up the 7.9" display; effectively the same albeit smaller.
I’ve grabbed the beta (3.584) and the display seems to work. Only issue is the touch mapping is off/still orientated for a portrait layout, and I don’t see where that particular tweak is in this thread after a few up and down skims.
TIA
Here was solved 7.9" Pi5 issue .
and here is source by @gvolt :
Please try the following: Stop the Touch Display plugin. As root execute cat >> /etc/X11/xorg.conf.d/99-vc4.conf <<EOL Section "OutputClass" Identifier "vc4" MatchDriver "vc4" Driver "modesetting" Option "PrimaryGPU" "true" EndSection EOL Start the Touch Display plugin.
