I got messages from Waveshare:
Rain (Waveshare)
Dec 7, 2023, 18:50 GMT+8
Hello
I will test the Volumio system for you
Best regards
Rain
Raspi ??
Rain (Waveshare)
Hello
Best regards
Rain
Raspi ??
yes, RaspiOS 32-bit
Prepared, running, Works the same like on RaspiOS 64bit :
Dispolay but not rotate.
EDIT:
I changed orientation used mouse and select Screen Configuration from the Preferences menu. Right-click on the HDMI-A-1 display rectangle in the layout editor, select Orientation
My observation is that the screen can’t be rotated after applied this:
dtoverlay=vc4-kms-v3d-pi5
that’s why, of course thanks to @gvolt I use this command:
xrandr --output HDMI-1 --rotate right
My observation is that my 11.9 not start ![]()
well, my screen looks very similar to your. And it started to work.
My best guess it is because of PEBKAC ![]()
ofc it is a joke ![]()
I don’t need this command on Raspi. Mr. Rain from Waveshare wrote me that in Pi5 I should rotate with Screen Config.
He still monitoring situation.
It may be truth, but for now my Wavashare 7.9" works becuase of this.
edit:
When I activated it, my screen started to live - I could see booting message /disturbed but it was first live symptome/ and finally login screen to volumio - in wrong rotation.
Problem was the Touch Display coudn’t start due to Error connecting to Xserver.
Above error has been fixed by @gvolt by creating missing: 99-vc4.conf file
My is blank at start
Maybe you had some ideas overnight, in your sleep
Maybe I prepare second one set Pi5/Waveshare 11.9" and send to one of you
EDIT: It’s not a joke.
Now I have problem but I think that maybe near future somebody else want change Pi to newer in system with 11.9"
Hi sent mi userconfig.txt:
"# Add your custom config.txt options to this file, which will be preserved during updates
max_framebuffer_height=1480
hdmi_group=2
hdmi_mode=87
hdmi_timings=320 0 80 16 32 1480 0 16 4 12 0 0 0 60 0 42000000 3
but still the same. If I use command: dtoverlay=vc4-kms-v3d screen powered off backlight.
What the …
what port are you using? HDMI0 or HDMI1?
the same like on photo above from Waveshare. HDMI near USB PowerSupply
To sum up:
RaspiOs 32 at first start:
RaspiOs 32 after config in Screen Configuration
I don’t need to change any command in config.txt.
After changed SD Card to Volumio:
nothing.
If I started Volumio in original config backlight is still on. If I only add “dtoverlay=vc4-kms-v3d” or “dtoverlay=vc4-kms-v3d-pi5” I have backlight on after start and backlight off and " no HDMI signal" LED.
I tried :
disable_fw_kms_setup=1
hdmi_group=2
hdmi_mode=87
and
hdmi_group=2
hdmi_mode=87
and
hdmi_group=2
hdmi_mode=87
and
hdmi_group=2
hdmi_mode=87
still nothing.
I edited userconfig via Notepad ++ and via Putty “sudo nano /boot/userconfig.txt”
I upgraded Pi5 firmware to newest.
I checked 6 HDMI cables
I tried with two Pi5
How did you do that?
My firmware checked via SystemInfo Plugin was:
Firmware Version: 2023/10/30 16:45:10 Copyright (c) - (embedded)
Now is:
Firmware Version: 2023/11/20 19:40:17 Copyright (c) - (embedded)
OK, you did with RaspiOS
Yes. You told me that with Volumio it destroy system. You are specialist and I listen what you said.
But new firmware nothing change. Raspi works, Volumio not.
I ask Waveshare what they done because I still have no hdmi signal LED.
I use command boost with higher value but without result.
I enabled TEST MODE and upgrade to 3.584 ( I know, is unstable, unchecked, untested ) and restart system.
and connected to the Waveshare 11.9 witout any change in userconfig and config line and…
JUPI !!!
Now I will try to configure screen after that install TouchDisplay and check LCD
Yes I know 3.584 is unstable version, I will wait for official but with sure that LCD working.
