Volumio Version: 2.882, 2.878
Cannot install build-essential package on fresh install of Volumio
volumio@volumio15:~$ sudo apt install build-essential
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: gcc (>= 4:4.9.1) but it is not going to be installed
Depends: g++ (>= 4:4.9.1) but it is not going to be installed
Depends: dpkg-dev (>= 1.17.11) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Initial report to mpd_oled: Volumio 2.878, 2.882 - installation from source fail · Issue #66 · antiprism/mpd_oled · GitHub
This probably also affects other software instrallation from source such as the mpd_oled Volumio plugin and instructions for installing PeppyMeter.
Adrian.
