Volumio 2 + Airplay 2
I have been able to update shairport-sync on Volumio 2 (System Version: 2.917, RP 4), so that I can use Airplay 2 (multi-room support).
I thought I’d share the process.
There is only one problem at the moment: the ui on Volumio does not show artwork/album when using Airplay 2. I am not sure if that worked with Airplay 1.
Maybe someone out there can help with that.
Plugins I have installed (that are still working after the update)
  • Nanosound CD
  • Volumio Spotify Connect2
Process
Login
ssh volumio@volumio.local
Turn off WiFi power management
sudo iwconfig wlan0 power off
Update Dependencies
sudo apt-get update
sudo apt-get install --only-upgrade dhcpcd5 e2fslibs e2fsprogs libblas-common libblas3 libbluray1 libcairo2 libcomerr2 libdrm2 libfreetype6 liblapack3 liborc-0.4-0 libpam-modules libpam-modules-bin libpam-runtime libpam0g libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libss2 libva-drm1 libva-x11-1 libva1 x11-common
NOTE: I have here skipped updating dependencies firmware-ralink and libsdl1.2debian because they broke the OS for me.
Remove old version
# backup
mv /usr/local/bin/shairport-sync /usr/local/bin/shairport-sync.old
# remove services (see https://github.com/mikebrady/shairport-sync/blob/master/BUILD.md#1-prepare)
sudo rm /lib/systemd/system/shairport-sync.service
sudo rm /etc/dbus-1/system.d/shairport-sync-dbus.conf
Install build-essential
  1. Edit file /etc/apt/sources.list
  2. Add a new line at the bottom with the following deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
  3. Save
  4. Then:
sudo apt-get update
sudo apt-get -y install binutils
sudo apt-get -y install libstdc++-4.9-dev
sudo apt-get -y install gcc-4.9 gcc g++-4.9 g++ dpkg-dev
  1. Remove line from /etc/apt/sources.list
  2. Then:
sudo apt-get update
NOTE For reference on this step, check out 2aCD’s post.
Install Airplay 2 Dependencies
sudo apt install --no-install-recommends git xxd xmltoman autoconf automake libtool
sudo apt install --no-install-recommends libpopt-dev libconfig-dev
sudo apt install --no-install-recommends avahi-daemon libavahi-client-dev libssl-dev libsoxr-dev
sudo apt install --no-install-recommends libplist-dev libsodium-dev libavutil-dev libavcodec-dev libavformat-dev uuid-dev libgcrypt-dev
NOTE I skipped installing dependecies libasound2-dev because it broke the OS and build-essential because we have already installed it on previous step.
Install NQPTP
NQPTP Is needed for Airplay 2 functionality. More info here.
# Make a temporary folder
mkdir temp
cd temp
# Clone nqptp repository
git clone https://github.com/mikebrady/nqptp.git
cd nqptp
# Install
autoreconf -fi
./configure --with-systemd-startup
make
sudo make install
# Enable service
sudo systemctl enable nqptp
sudo systemctl start nqptp
cd ..
NOTE: For NQPTP to work properly, port 319 and 320 should be open.
Check with netstat --listen that the ports are open.
Update libplist-dev
Shairport sync uses libplist-dev version 2.2.0-6.
In order to update it:
  2. Add new line at the bottom deb http://deb.debian.org/debian bullseye main contrib non-free
  3. Save
  4. Then:
sudo apt-get update
sudo apt-get install libplist-dev=2.2.0-6
  1. Remove line from file /etc/apt/sources.list
  2. Then:
sudo apt-get update
Install Shairport-sync
# Clone repo
git clone https://github.com/mikebrady/shairport-sync.git
cd shairport-sync
git checkout tags/4.1-rc2
NOTE : The previous command is checking out tag 4.1-rc2 which is were Airplay 2 support is at the moment. Be sure to checkout the right tag/branch for your case. Hopefully it will just be released on main soon.
# Install
autoreconf -fi
./configure --sysconfdir=/etc --with-alsa --with-soxr --with-avahi --with-ssl=openssl --with-metadata  --with-systemd --with-airplay-2
make -j
sudo make install
# Enable service
sudo systemctl enable shairport-sync
NOTE: The ./configure command has many options. Be sure to apply the correct flags for your specific system (more info here)
Configuration of output device
  1. Launch command shairport-sync -h to list all system’s output devices.
  2. Edit configuration file /etc/shairport-sync.conf and add the correct output_device.
  3. Reboot
You will notice Airplay 2 is working because of the different icon (tick within a circle) displayed closed to device name when streaming to Volumio from iOS or MacOS.
This seems to be broken now, are these instructions still the same?
I haven’t touched the install since I have posted this.
Not sure if it is still valid today.
What’s the error you get?
One point where it might get wrong is this:
Ah, it may be because im using Volumio 3, not Volumio 2. Looks like its built on Buster, and breaks a heap of dependencies in the installed packages…
I successfully installed installed Shairport Sync 4.1.1 to use Airplay 2 on Volumio 3 using following steps:
sudo apt update
sudo apt install --no-install-recommends build-essential git autoconf automake libtool \
    libpopt-dev libconfig-dev libasound2-dev avahi-daemon libavahi-client-dev libssl-dev libsoxr-dev \
    libplist-dev libsodium-dev libavutil-dev libavcodec-dev libavformat-dev uuid-dev libgcrypt-dev xxd
cd nqptp
autoreconf -fi
make
sudo make install
cd ..
cd shairport-sync/
git checkout 4.1.1
autoreconf -i -f
./configure --sysconfdir=/etc --with-alsa --with-pa --with-pipe --with-avahi --with-ssl=openssl --with-metadata --with-soxr --with-systemd --with-airplay-2
make
sudo make install
sudo systemctl stop shairport-sync
cd ..
mv /usr/bin/shairport-sync /usr/bin/shairport-sync-orig
sudo mv /usr/local/bin/shairport-sync /usr/bin/shairport-sync
sudo systemctl restart shairport-sync
systemctl status shairport-sync
Album art on the external volumio display works just fine.
Stange, fresh install and I get the following error when trying to install the packages. Can’t seem to resolve the issue…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libavcodec-dev : Depends: libavcodec58 (= 7:4.1.10-0+deb10u1+rpt1)
libavformat-dev : Depends: libavformat58 (= 7:4.1.10-0+deb10u1+rpt1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I get the same thing here on my end had me puzzled all day
Does Airplay 2 allow for high-res streamming to the device? (more than 16 44.1 I mean)
Does it? I really need to know too… please someone help. tnx.
Volumio 2 is no longer supported since the arrival of Volumio 3. Volumio 2 did not support Airplay 2.
Anyone have any luck getting Shairport Sync updated to allow Airplay 2? I followed the steps and got the same error as @mvn and @rocco
Fresh install of volumio distro solve the problem for me - i was trying to get rid of that issue for a few hours with no luck. Windows version of Apple Music client doesn’t work with --with-airplay-2 → AmpLibraryAgent is displaying version mismatch error … Streaming from iPhone device is working fine → you can find an information here shairport-sync/CONFIGURATION FLAGS.md at master · mikebrady/shairport-sync · GitHub
AirPlay 2 or AirPlay – leaving for your consideration :smiley:
Thanks. Jun/2025 and this still works. Only things I’ve done differently are:
  • I didn’t checkout 4.1.1, just used the master branch;
  • had to sudo the renaming of the binary to shairport-sync-orig.
Cheers!
Is there a way to get album art and other metadata? Streaming via MacOS Music app, no metadata is getting over to Volumio. Do I need to change config file?
