Gentlemen, the same thing happens when UPNP is turned off and on
I have x86 Lenovo ThinkCentre
What processor is the Thinkcentre?
As all slower hardware seems to reveal the DNLA servers after boot (Rpi/Wyse 3040/Toshiba Click/Booting from USB).
(No clue if itā€™s related, just mentioning it)
HW.txt (10.3 KB)
I wrote about how to run from USB itā€™s ok, servers are missing how to install on disk and run from nvme2
HW1.txt (12.8 KB)
volumio@volumio:~$ inxi -Fxxxz
System: Host: volumio Kernel: 5.10.139-volumio x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Mini-pc System: LENOVO product: 10MUS05G00 v: ThinkCentre M910q serial: Chassis: type: 35
serial:
Mobo: LENOVO model: 310B v: SDK0J40697 WIN 3305056580087 serial: UEFI [Legacy]: LENOVO v: M1AKT53A
date: 03/18/2022
CPU: Topology: Dual Core model: Intel Core i3-7100T bits: 64 type: MT MCP arch: Kaby Lake rev: 9
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27199
Speed: 3400 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3400 2: 3401 3: 3400 4: 3403
Graphics: Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5912
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 123x37
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Sound Server: ALSA v: k5.10.139-volumio
Network: Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel port: f040 bus ID: 00:1f.6
chip ID: 8086:15b7
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Drives: Local Storage: total: 238.47 GiB used: 1.40 GiB (0.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000L7 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
serial: rev: 5L7QCXB7 scheme: GPT
Partition: ID-1: / size: 230.19 GiB used: 520.5 MiB (0.2%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 61.2 MiB (36.3%) fs: vfat dev: /dev/nvme0n1p1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 162 Uptime: 6h 29m Memory: 7.52 GiB used: 574.0 MiB (7.5%) Init: systemd v: 241 runlevel: 5
default: 2 Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
volumio@volumio:~$
Iā€™m testing it on an old Acer Laptop, and it works well, but I was trying to get audio from HDMI, but it didnā€™t work.
Is there anything that can be done?
did it work with the current released version?
You can do something yourself by properly reading the first post and supply the information we are asking for. If that is not possible, then a beta is not for you.
Hi It didnā€™t work on the stable version
Follows the Information:
Logs http://logs.volumio.org/volumiobuster/J0TSLBc.html
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.3 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation 82801I (ICH9 Family) Thermal Subsystem (rev 03)
01:00.0 VGA compatible controller: NVIDIA Corporation G96M [GeForce 9600M GT] (rev a1)
02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0)
05:00.0 Network controller: Intel Corporation WiFi Link 5100
Battery:   ID-1: BAT0 charge: 31.9 Wh condition: 31.9/53.3 Wh (60%) volts: 11.8/11.1 model: SONY AS07B41
           type: Li-ion serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core2 Duo T5900 bits: 64 type: MCP arch: Core Merom rev: D
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 8778
           Speed: 2200 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2200 2: 1197
Graphics:  Device-1: NVIDIA G96M [GeForce 9600M GT] vendor: Acer Incorporated ALI G96CM driver: nouveau v: kernel
           bus ID: 01:00.0 chip ID: 10de:0649
           Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 120x30
Audio:     Device-1: Intel 82801I HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:293e
           Device-2: Thesycon System & Consulting type: USB driver: snd-usb-audio bus ID: 2-2:6 chip ID: 152a:85dd
           Sound Server: ALSA v: k6.1.6-volumio
Network:   Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet vendor: Acer Incorporated ALI
           driver: ATL1E v: N/A port: 4000 bus ID: 02:00.0 chip ID: 1969:1026
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Intel WiFi Link 5100 driver: iwlwifi v: kernel port: 4000 bus ID: 05:00.0 chip ID: 8086:4232
           IF: wlan0 state: up mac: <filter>
Drives:    Local Storage: total: 326.96 GiB used: 1.82 GiB (0.6%)
           ID-1: /dev/sda vendor: Seagate model: ST9320320AS size: 298.09 GiB speed: 3.0 Gb/s serial: <filter>
           rev: 0303 scheme: MBR
           ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.87 GiB speed: 3.0 Gb/s
           serial: <filter> rev: 0000 scheme: GPT
Partition: ID-1: / size: 24.55 GiB used: 68.4 MiB (0.3%) fs: overlay source: ERR-102
           ID-2: /boot size: 170.8 MiB used: 69.9 MiB (40.9%) fs: vfat dev: /dev/sdb1
Info:      Processes: 150 Uptime: 23h 16m Memory: 3.84 GiB used: 1018.7 MiB (25.9%) Init: systemd v: 241 runlevel: 5
Thank you for that.
Iā€™ve seen the issue, but need help with this from you. Presuming you are OK with SSH, I have a few amixer commands for you to test.
Is using nano for editing a script also fine?
Nothing big, Iā€™ll send a PM with instructions sometime in the next few days, OK?
Thatā€™s OK, I can handle it.
Hello, the computer on which the system is installed does not output an HDMI interface. Only the terminal is visible. Changing the interface display setting for HDMI via WebUI does not work.
Is it possible to display the image on an HDMI screen?
The system is installed on x86 PC. Version Volumio 3.423 Intel JasperLake n5095 processor
http://logs.volumio.org/volumio/AnM6U4A.html log
Please read the start of this topic and post the information requested.
Feb 05 16:23:05 amaron-renoir kernel: i915 0000:00:02.0: Your graphics device 4e55 is not properly supported by the driver in this kernel version.
This is unfortunate, the current x86 kernel does not support your AZW Mini S graphics component.
This is why we are beta testing with a new kernel at the moment.
Please try Beta kernel 6.1.y
I tried the version you sent, (Volumiobuster-3.424-2023-01-11-x86_amd64) the volumio logo graphic appeared for a second before launch. But right after the terminal appears. Settings in webUI also did not affect.
This is not a big problem, but I still hope that in future versions support for my graphical component will be added
Hi
I just installed 3.423 on an Acer Revo RL70 and couldnā€™t get sound out of either HDMI or SPDIF optical so I plugged in an old USB Soundcard and that worked.
The soundcard is connected via USB to the Acer then the soundcard is connected to my Denon AVR via Optical.
When I play a DSD file it shows as 2.82 MHz 1 Bit in volumio but shows on the receiver as PCM 48kHz
Why would this be?
Not sure, but make sure your Volumio volume is set to 100%.
Best thing you can do just now is to share a link to a log file.
Perhaps HDMI and toslink are only muted, but for checking that we need a log file.
Boot up, wait until the UI shows up and then produce the log.
https://help.volumio.com/help/how-to-send-a-log-link-for-a-bug-report
@Wheaten could you move this to the x86 thread please?
Thanks for the reply
Hereā€™s the link to the log
logs.volumio.org/volumio/6BZgASw.html
Try this for S/PDIF:
/usr/bin/amixer -c 1 set IEC958,16 unmute
for HDMI:
/usr/bin/amixer -c 0 set Master unmute"
When this fixes it, I will add it to Volumioā€™s HD Audio tweaks.
I get the message
amixer: Unable to find simple control ā€˜IEC958ā€™,16 for the optical and nothing in response to the HDMI
Still no HDMI sound
Please do
amixer -c 0 scontrols
amixer -c 1 scontrols
This should give us a list of the controls they do have.
I need to check the HD Audio documentation for more info, the log did not give enough.
And I need to know what the exact error message of the spdif unmute was :wink:
