Volumio Version:4.096
Hardware: mac mini 2010 (macmini 4,1)
Issue: no sound output, and there is only “HDMI 0” & “HDMI 1” in output devices
I can see the card seems to be correctly recognize by the system but just doesn’t have sound, I’ve also checked in alsamixer to make sure all of the output are not muted.
Below are some logs of the system hope can get some help. Thanks
Internal card name: HDA NVidia
Internal codec name: Cirrus Logic Generic
amixer -c 0
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 127
Mono: Playback 95 [75%] [-16.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback 115 [91%] [0.00dB] [on]
Front Right: Playback 115 [91%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Simple mixer control 'Line Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 2 [67%] [20.00dB]
Front Right: 2 [67%] [20.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined cswitch cswitch-joined
Capture channels: Mono
Mono: Playback [on] Capture [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',16
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [12.00dB] [on]
Front Right: Capture 63 [100%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'SoftMaster',0
Limits: 0 - 99
Front Left: 70 [71%]
Front Right: 69 [70%]
aplay -l
card 0: NVidia [HDA NVidia], device 0: Generic Analog [Generic Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: Generic Digital [Generic Digital]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
bluealsa
Bluetooth Audio
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
volumio
volumioOutput
hw:CARD=NVidia,DEV=0
HDA NVidia, Generic Analog
Direct hardware device without any conversions
hw:CARD=NVidia,DEV=1
HDA NVidia, Generic Digital
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=0
Hardware device with all software conversions
plughw:CARD=NVidia,DEV=1
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
sysdefault:CARD=NVidia
Default Audio Device
front:CARD=NVidia,DEV=0
Front output / input
surround21:CARD=NVidia,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=NVidia,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=NVidia,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=NVidia,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=NVidia,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=NVidia,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=NVidia,DEV=0
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 0
HDMI Audio Output
dmix:CARD=NVidia,DEV=0
Direct sample mixing device
dmix:CARD=NVidia,DEV=1
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
