gkkpch
November 27, 2025, 5:14pm
1368
No, we do our own kernel compilation, based on the LTS sources released by kernel.org .
We try to keep as close as possible to Ubuntu and Debian kernel configurations, but, as written the other day, we have not changed the sound configurations between 6.6 and 6.12, nothing except for wireless drivers and some extra sensor support.
You have a PM.
Im using Volumio X86 v4.0.73 with usb wifi dongle RTL8188FTV and i canāt connect to router from volumio GUI settingsā¦
In network settings i can found available wifi network, put the password but no connection successfullā¦
from ssh running
sudo wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
the connection start and goes ok, he got ip from router and its visible in GUI interface network settings as active connection⦠i guess hardware driver is working.
This mean that volumio create wpa_suplicant file with wifi detail but is not operate from volumio settings GUI.
Any others have this bug?
Iād tryed another dongle also, old RT5370 and same issueā¦
Log is visible at : Log file here
Lshw here :
volumio
description: Desktop Computer
product: ESPRIMO Q957
vendor: FUJITSU
serial: YMDD058048
width: 64 bits
capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
configuration: administrator_password=disabled boot=normal chassis=desktop family=ESPRIMO-FTS power-on_password=disabled uuid=d240a367-e7dd-11e8-9d9f-4c52621de137
*-core
description: Motherboard
product: D3513-A1
vendor: FUJITSU
physical id: 0
version: S26361-D3513-A1
serial: 58062254
*-firmware
description: BIOS
vendor: FUJITSU // American Megatrends Inc.
physical id: 0
version: V5.0.0.12 R1.35.0 for D3513-A1x
date: 10/17/2024
capacity: 16MiB
capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: e
slot: System board or motherboard
*-bank:0
description: SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2667 MHz (0.4 ns)
product: RMSA3270ME86H9F-2666
vendor: Fujitsu
physical id: 0
serial: 1184C2A8
slot: DIMM CHA3
width: 64 bits
clock: 2667MHz (0.4ns)
*-bank:1
vendor: Fujitsu
physical id: 1
serial: 11421724
slot: DIMM CHB4
width: 64 bits
*-cache:0
description: L1 cache
physical id: 12
slot: L1 Cache
capacity: 128KiB
capabilities: synchronous internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 13
slot: L2 Cache
capacity: 512KiB
configuration: level=2
*-cache:2
description: L3 cache
physical id: 14
slot: L3 Cache
capacity: 4MiB
configuration: level=3
*-cpu
description: CPU
product: Intel(R) Core(TM) i3-6300T CPU @ 3.30GHz
vendor: Intel Corp.
physical id: 15
bus info: cpu@0
version: 6.94.3
serial: To Be Filled By O.E.M.
slot: CPU1
capacity: 4005MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb pti ssbd ibrs ibpb stibp tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp vnmi md_clear flush_l1d arch_capabilities cpufreq
configuration: cores=2 enabledcores=2 microcode=240 threads=4
*-pci
description: Host bridge
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 07
width: 32 bits
clock: 33MHz
configuration: driver=skl_uncore
resources: irq:0
*-display
description: VGA compatible controller
product: HD Graphics 530
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:129 memory:ee000000-eeffffff memory:d0000000-dfffffff ioport:f000(size=64) memory:c0000-dffff
*-usb
description: USB controller
product: 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:121 memory:ef130000-ef13ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 6.12.57-volumio xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 6.12
capabilities: usb-2.00
configuration: driver=hub slots=16 speed=480Mbit/s
*-usb
description: Generic USB device
product: 802.11n
vendor: Realtek
physical id: 3
bus info: usb@1:3
version: 0.00
serial: 00E0254FD3C5
configuration: driver=rtl8xxxu maxpower=500mA speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 6.12
capabilities: usb-3.00
configuration: driver=hub slots=10 speed=5000Mbit/s
*-generic UNCLAIMED
description: Signal processing controller
product: 200 Series PCH Thermal Subsystem
physical id: 14.2
bus info: pci@0000:00:14.2
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: latency=0
resources: memory:ef14f000-ef14ffff
*-communication:0
description: Communication controller
product: 200 Series PCH CSME HECI #1
physical id: 16
bus info: pci@0000:00:16.0
version: 00
width: 64 bits
clock: 33MHz
configuration: driver=mei_me latency=0
resources: irq:131 memory:ef14e000-ef14efff
*-communication:1
description: Serial controller
product: Intel Corporation
physical id: 16.3
bus info: pci@0000:00:16.3
version: 00
width: 32 bits
clock: 66MHz
capabilities: msi pm 16550 bus_master cap_list
configuration: driver=serial latency=0
resources: irq:19 ioport:f0a0(size=8) memory:ef14d000-ef14dfff
*-sata
description: SATA controller
product: 200 Series PCH SATA controller [AHCI mode]
physical id: 17
bus info: pci@0000:00:17.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:123 memory:ef148000-ef149fff memory:ef14c000-ef14c0ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:ef14b000-ef14b7ff
*-pci
description: PCI bridge
product: 200 Series PCH PCI Express Root Port #9
physical id: 1d
bus info: pci@0000:00:1d.0
version: f0
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:120 memory:ef000000-ef0fffff
*-nvme
description: NVMe device
product: LENSE20256GMSP34MEAT2TA
vendor: Lenovo
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/nvme0
version: 2.3.8341
serial: 1188050101780
width: 64 bits
clock: 33MHz
capabilities: nvme pm pciexpress msix nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.2014.08.org.nvmexpress:17aa17aa1188050101780 state=live
resources: irq:16 memory:ef000000-ef003fff
*-namespace:0
description: NVMe disk
physical id: 0
logical name: /dev/ng0n1
*-namespace:1
physical id: 1
bus info: nvme@0:1
logical name: /dev/nvme0n1
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: guid=700b9cfd-87c2-4da4-9de0-1eb3e537e29e logicalsectorsize=512 sectorsize=512 wwid=eui.a0329915a7051780
*-volume:0
description: Windows FAT volume
vendor: SYSLINUX
physical id: 1
bus info: nvme@0:1,1
logical name: /dev/nvme0n1p1
logical name: /boot
version: FAT32
serial: e45b-88be
capacity: 365MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat label=boot mount.fstype=vfat mount.options=rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=utf8,shortname=mixed,utf8,errors=remount-ro name=primary state=mounted
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: nvme@0:1,2
logical name: /dev/nvme0n1p2
logical name: /imgpart
version: 1.0
serial: 91e5944e-b0c1-437d-aa36-649214fd2370
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2025-12-08 18:43:33 filesystem=ext4 label=volumio lastmountpoint=/mnt/imgpart modified=2025-12-09 23:01:13 mount.fstype=ext4 mount.options=rw,relatime mounted=2025-12-09 23:01:13 name=primary state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: nvme@0:1,3
logical name: /dev/nvme0n1p3
version: 1.0
serial: 4ca5396e-84e2-4830-95d4-914e8829db8b
configuration: created=2025-12-08 18:43:34 filesystem=ext4 label=volumio_data lastmountpoint=/ modified=2025-12-09 02:16:16 mounted=2025-12-09 01:16:09 name=primary state=clean
*-isa
description: ISA bridge
product: 200 Series PCH LPC Controller (Q270)
physical id: 1f
bus info: pci@0000:00:1f.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-pnp00:00
product: PnP device PNP0c02
physical id: 0
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0501
physical id: 1
capabilities: pnp
*-pnp00:02
physical id: 2
capabilities: pnp
*-pnp00:03
physical id: 3
capabilities: pnp
*-pnp00:04
product: PnP device PNP0b00
physical id: 4
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:05
physical id: 5
capabilities: pnp
*-pnp00:06
physical id: 6
capabilities: pnp
*-pnp00:07
physical id: 7
capabilities: pnp
*-pnp00:08
physical id: 8
capabilities: pnp
*-pnp00:09
product: PnP device FXY0815
physical id: 9
capabilities: pnp
*-memory UNCLAIMED
description: Memory controller
product: 200 Series/Z370 Chipset Family Power Management Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 00
width: 32 bits
clock: 33MHz (30.3ns)
capabilities: bus_master
resources: memory:ef144000-ef147fff
*-multimedia
description: Audio device
product: 200 Series PCH HD Audio
physical id: 1f.3
bus info: pci@0000:00:1f.3
logical name: card0
logical name: /dev/snd/controlC0
logical name: /dev/snd/hwC0D0
logical name: /dev/snd/hwC0D2
logical name: /dev/snd/pcmC0D0c
logical name: /dev/snd/pcmC0D0p
logical name: /dev/snd/pcmC0D3p
logical name: /dev/snd/pcmC0D7p
logical name: /dev/snd/pcmC0D8p
version: 00
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: irq:130 memory:ef140000-ef143fff memory:ef120000-ef12ffff
*-input:0
product: HDA Intel PCH Mic
physical id: 0
logical name: input4
logical name: /dev/input/event4
*-input:1
product: HDA Intel PCH Line Out
physical id: 1
logical name: input5
logical name: /dev/input/event5
*-input:2
product: HDA Intel PCH Front Headphone
physical id: 2
logical name: input6
logical name: /dev/input/event6
*-input:3
product: HDA Intel PCH HDMI/DP,pcm=3
physical id: 3
logical name: input7
logical name: /dev/input/event7
*-input:4
product: HDA Intel PCH HDMI/DP,pcm=7
physical id: 4
logical name: input8
logical name: /dev/input/event8
*-input:5
product: HDA Intel PCH HDMI/DP,pcm=8
physical id: 5
logical name: input9
logical name: /dev/input/event9
*-serial
description: SMBus
product: 200 Series/Z370 Chipset Family SMBus Controller
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 00
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:16 memory:ef14a000-ef14a0ff ioport:f040(size=32)
*-network
description: Ethernet interface
product: Ethernet Connection (2) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: eth0
version: 00
serial: 4c:52:62:1d:e1:37
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.12.57-volumio duplex=full firmware=0.8-4 ip=192.168.1.28 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:124 memory:ef100000-ef11ffff
*-power UNCLAIMED
description: To Be Filled By O.E.M.
product: To Be Filled By O.E.M.
vendor: To Be Filled By O.E.M.
physical id: 1
version: To Be Filled By O.E.M.
capacity: 32768mWh
*-input:0
product: Sleep Button
physical id: 2
logical name: input0
logical name: /dev/input/event0
capabilities: platform
*-input:1
product: Power Button
physical id: 3
logical name: input1
logical name: /dev/input/event1
*-input:2
product: Fujitsu FUJ02E3
physical id: 4
logical name: input10
logical name: /dev/input/event10
*-input:3
physical id: 5
logical name: input2
logical name: /dev/input/event2
*-input:4
product: Video Bus
physical id: 6
logical name: input3
logical name: /dev/input/event3
*-network
description: Wireless interface
physical id: 7
bus info: usb@1:3
logical name: wlan0
serial: 00:e0:25:4f:d3:c5
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8xxxu driverversion=6.12.57-volumio firmware=N/A link=no multicast=yes wireless=IEEE 802.11
Wheaten
December 9, 2025, 10:11pm
1371
Please read the opening post and provide the information, so we can help you.
About
Please use this thread to post issues you encounter with typical X86 issues, like missing support for WiFi devices (onboard or dongles), onboard sound and DAC devices, disk devices etc.
Also if you encounter boot issues or other problems of which you assume they are x86-related, post them here first.
Issues which do not fit this thread will be redirected as a general help section post section.
We have a dedicated guide for Tips and guidelines to get faster help which will proviā¦
** Reporting**
Im momentary fix wifi issue with this method.
Edit wpa configuration
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
this is the code
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="Put your Wifi_ssid"
psk="Put your wifi password"
key_mgmt=WPA-PSK
Create a service for Wlan0
sudo nano /etc/systemd/system/wpa_supplicant@wlan0.service
this is the code
[Unit]
Description=WPA supplicant for %i
After=network.target
[Service]
ExecStart=/sbin/wpa_supplicant -i %i -c /etc/wpa_supplicant/wpa_supplicant.conf
Restart=always
[Install]
WantedBy=multi-user.target
Enable the Service and start it
sudo systemctl enable wpa_supplicant@wlan0.service
sudo systemctl start wpa_supplicant@wlan0.service
gkkpch
December 13, 2025, 12:04am
1373
Unfortunately we cannot accept a fix without more info. Wireless concerns all Volumio platforms, it is not x86-specific.
In order to help you, the Volumio team and community devs need all information as requested in the very first post of this thread.
youāre right, thread purpose is for x86, iād shared log and lshw response, thatās all they need. wireless issue still here and volumio developer is not fixing it.
gkkpch
December 13, 2025, 12:17am
1375
Sorry that you did not get my point. To be more precise, without you delivering the data as tequested, it is impossible to help you here.
what youāre talking about? iād shared the log required. sorry
gkkpch
December 13, 2025, 12:21am
1377
Iām really sorry, missed that
Wheaten
December 13, 2025, 12:22am
1378
Please avoid making assumptions here, thereās some background youāre missing.
The RTL8188FTV simply canāt run hotspot and WiāFi client at the same time.
The correct procedure is:
boot the device with eth0 connected
disable the hotspot
configure your WiāFi normally
unplug eth0 and reboot
After that, WiāFi will connect as expected. If it is still failing we need to take a closer look.
nope, sorry but your trick is not working.
when i put wifi password popup ānetwork card correctly rebootedā but no connection show.
also rebooting without lan and put again wireless password, still the same.
This happens also with RT5370 usb adapter
Wheaten
December 13, 2025, 12:34am
1380
Please upgrade to the latest version 4.080. We have spend a lot of hours on this subject.
Make sure to not manipulate any files.
If it is still failing post the following outputs:
systemctl status hostapd.service > /tmp/hostapd_service.txt
journalctl -u hostapd.service --no-pager > /tmp/journalctl_hostapd_service.txt
cat /etc/hostapd/hostapd.conf > /tmp/hostapd_conf.txt
/tmp/wireless.log
Just upgraded to 4.080, booted without Lan and wifi connected perfectly.
Im using RT5370 usb adapter.
Thanks for support Wheaten.
gurusto
December 15, 2025, 9:51pm
1382
I canāt enable WiFi in Volume 4. It only accepts wired network connection.
Error: Command failed:
sudo /bin/systemnctl restart
wireless.service Job for
wireless.service failed because the
service did not take the steps required
by its unit configuration. See
āsystemctl status wireless.serviceā and
ājournalctl -xeu wireless.serviceā for
details.
Can anyone offer me help? Can it be a bug? a driver?
My computer is based on an Intel X86 PC board
Greetings
Wheaten
December 15, 2025, 9:56pm
1383
Hi @gurusto
Could you please drop the details as mentioned in the openings post under:
Reporting
Without that info, weāre basically trying to solve a mystery with a thousand different x86 boards and fifty WiFi chips . Thatās less ātech supportā and more ālottery of doom."
Help us help you, otherwise weāll be stuck playing hardware bingo forever!
gurusto
December 15, 2025, 10:58pm
1384
Thank you for responding.
The hardware worked well with V3. There was an error when installing the new V4 version.
As soon as I can, Iāll give you the full hardware relationship. Reinstall V3 and add system information to extract the device ratio.
dewen
December 17, 2025, 7:26am
1385
CPU : i5-6500
GPU : NVIDIA GTX 1660 Ti, HDMI connect to FHD TV
16G RAM
USB dongle ( 128G and 32G )
use diskpart clean the dongle then write image by win32img or rufus or etcher
Volumio-3.884 -2025-12-10-x86_amd64 : boot and install without problem
Volumio-4.073 -2025-12-05-x86_amd64
I can see
SYSLINUX 6.04ā¦
Booting Volumio Audiophile Music Playerā¦
then the screen was black ( sometimes pause with the above line )
I have to reset PC to restart but the same result.
Tried onboard HDMI the same result.
Is it PC hardware compatibility issue ?
Any suggestion ? I tried several USB dongle but the same result.
Thank you.
gurusto
December 17, 2025, 12:10pm
1386
My Hardware for Volumio:
OS info
Version of Volumio: 4.073
Hostname: volumio
Kernel: 6.12.57-volumio
Governor: performance
Uptime: 0 days, 4 Hrs, 15 Minutes, 15 Seconds
Network info
Interface: eth0
IP Address: 192.168.1.43
MAC Address: bc:5f:f4:3a:fd:f2
Type: wired
Speed: 1Gb/s
Audio info
Hw audio configured: Analog Out
Mixer type: Hardware
Number of channels: 6
Supported sample rate: 44100 48000 96000 192000
Board info
Manufacturer: To Be Filled By O.E.M.
Model: To Be Filled By O.E.M.
CPU info
Brand: Core⢠i3-2120
Model name: Intel(R) Core⢠i3-2120 CPU @ 3.30GHz
Speed: 3.3 GHz
Family: 6
Model: 42
Number of cores: 4
Physical cores: 2
Average load: 6%
Temperature: 55°C
Memory info
Memory: 15309668 Ko
Free: 12929504 Ko
Used: 2380164 Ko
Software info
MPD version: Music Player Daemon 0.24.6 (b6f106b+)
Bluetooth capabilities version: 5.83
AirPlay version: AirPlay 2
UPnP renderer: upmpdcli 1.9.7-1~ppa1~bookworm
Storage info
INTERNAL storage - Size: 443849MB
Used: 576MB
Available: 420655MB (95%)
Iāve currently chosen the network connection since the Wi-Fi isnāt working. The chip in the Wi-Fi USB dongle is: Realtek RTL8811AU.
Regards
Wheaten
December 17, 2025, 12:31pm
1387
@gurusto , try this sequence for reliable WiāFi setup:
Update to the latest test build. (V4.080)
Connect via Ethernet and complete the initial setup.
While still on Ethernet, configure your WiāFi network.
Shut down the device.
Disconnect the Ethernet cable.
Power it back on ā WiāFi should come up normally.
gkkpch
December 17, 2025, 9:39pm
1388
The information you supplied does not give us anything to work with.
Please reply to the very first post in this topic with what we require.
