Got it, gkkpch.
Thanks for your support
Hello all! This is my first post! I recently subscribed to volumio premium. I downloaded and flashed the image using balena. I booted my PC from external USB drive. Initial setup started normally.When I went to network tab no availabilie wifi appeared and of course my home wifi. In volumio app for Android ,volumio appearears, connects as access point but again I canāt connect to internet,am I doing something wrong. My wifi works perfectpy. My router is an Asus RT AX 88 U which is considered as very capable. Thank you.
I guess your running the x86 version.
Please disable Hotspot, refresh your screen after a minute or so and see if the wireless SSIDās come up.
Sorry for my lack of experience but how can I do that ? Thank you
Thank you so much for your help. Now wifi networks appear but I still canāt connect to my wifi although the password is correct!
please read opening post and supply info:
Reporting**
I will upgrade it today. I canāt find the Display touch plugin to rotate my screen horizontally. Please help.
Please read the opening post and provide what is mentioned in the opening post:
Reporting**
There is no plugin for the screen with an x86 device. To be honest if you want to use PeppyMeterBasic, rotation isnāt helpful as there are no templates available. All templates are in landscape mode.
You can use a script.
ssh to your device;
cd ~
mkdir scripts && cd scripts && nano rotate.sh
Copy + paste
#!/bin/bash
set -e
export DISPLAY=:0.0
# Check for input
if [ -z "$1" ]; then
echo "Usage: $0 [left|right|inverted|normal]"
exit 1
fi
# Choose the desired rotation
case "$1" in
left|right|inverted|normal)
# Find the primary display
display=$(xrandr | grep " connected" | awk '{ print $1 }' | head -n 1)
xrandr --output "$display" --rotate "$1"
echo "Screen rotated to $1"
echo "Invalid option: $1"
exit 1
esac
ctrl+o, ctrl+x
chmod +x rotate.sh
sudo bash rotate.sh right
When will volumio linux build support the intel ax2xx chipset?
Yes, Intel ax200, ax201, ax210 and ax211 are supported with the X86 version.
Ive tried many bords and cards and they dont work. Do i need to do anything?
@Jersinger You should not have to do anything special, the chipsets are supported since kernel version 5.14.
Volumio is already on kernel 6.6.y (Volumio 4 beta on 6.12.y), so it āshouldā work out of the box.
I tested Volumio 3 and Volumio 4 (beta) on a Lenovo Thinkpad T15v with an Intel Wi-Fi 6E AX211 802.11ax without any issues.
To enable us to help you, please read the first post in this thread and supply the required information.
With the hardware information we should get a clearer picture of your setup and the log may show us a possible issue.
Hi!
I installed Volumio 4 latest beta version, on PC. Every thing functions quite good, even youtube music, but not to HDMI.
I have two sound card, HDMI over my Marantz AVR surround receiver and Maverick Tubemagic DAC 2. For the record, I had turned of motherboard build in soundcard in bios settings.
Sound functions out from the Maverick, but not from HDMI. I got this message:
Volumio failed to open alsa (alsa). Failed to open ALSA device on āvolumioā. No such file or directory.
I had tried to flip flop controls and al combinations of configuration. I have tested restart. Also tested adding;
options snd_hda_intel index=0
options snd-usb-audio index=5
in new file;
/etc/modprobe.d/sound.conf
(then a restart)
I have tested sound out from console, there is sound, tested by;
speaker-test -Dhw:0,3 -c 6
**This is my aplay -l;**
evi* List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [marantz-AVR]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdces: 1/1
card 5: TE7022 [Maverick Audio TE7022], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 5: TE7022 [Maverick Audio TE7022], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
This is my aplay -L:
hw:CARD=NVidia,DEV=3
HDA NVidia, marantz-AVR
Direct hardware device without any conversions
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
hw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
plughw:CARD=NVidia,DEV=3
Hardware device with all software conversions
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
plughw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
hdmi:CARD=NVidia,DEV=0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
Direct sample mixing device
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
dmix:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
hw:CARD=TE7022,DEV=0
Maverick Audio TE7022, USB Audio
hw:CARD=TE7022,DEV=1
Maverick Audio TE7022, USB Audio #1
plughw:CARD=TE7022,DEV=0
plughw:CARD=TE7022,DEV=1
sysdefault:CARD=TE7022
Default Audio Device
front:CARD=TE7022,DEV=0
Front output / input
surround21:CARD=TE7022,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=TE7022,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=TE7022,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=TE7022,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=TE7022,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=TE7022,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=TE7022,DEV=0
IEC958 (S/PDIF) Digital Audio Output
iec958:CARD=TE7022,DEV=1
dmix:CARD=TE7022,DEV=0
dmix:CARD=TE7022,DEV=1
usbstream:CARD=TE7022
USB Stream Output
any help appreciated.
@Klasw
Probably this is the first time you run Volumio on that PC as it appears that Volumio needs an additional device profile for this particular Nvidia soundcard configuration.
In case you want to test this, could you add this line to /volumio/app/plugins/audio_interface/alsa_controller/cards.json, just after the line with āHDA ATI HDMIā?
{"name": "HDA NVidia", "multidevice": true, "devices":[{"number":3, "prettyname": "HDMI 0", "defaultmixer": ""},{"number":7, "prettyname": "HDMI 1", "defaultmixer": ""},{"number":8, "prettyname": "HDMI 2", "defaultmixer": ""},{"number":9, "prettyname": "HDMI 3", "defaultmixer": ""}],"type":"integrated"},
Please let me know whether this solves your issue.
Thank you very much, that functioned!
I modified code a bit, there is no sound on HDMI 1 to 3 (same in Kodi), so I just added this line:
{"name": "HDA NVidia", "multidevice": true, "devices":[{"number":3, "prettyname": "HDMI-0 Marantz NR1509", "defaultmixer": ""}],"type":"integrated"},
(at first i copied your code before āHDA ATI HDMIā, so guess order does not matter)
Thanks again, I got good sound from hdmi now, I can even turn off Volume mixer and get sound directly, do not know if it count as pass through, though?
Hi @klasw, unfortunately we canāt do your āpretty nameā, as we need to keep the NVidia profile generic, not linked to a specific (in this case your) device attached to it.
It must stay HDMI-0 in our standard image and for 1-2-3 for that reason. Keeps your version standard for potential other users.
I will do a change request to this for the next weekly release. Many thanks for taking the time to test this.
Yes I understand that, the generic name is;
marantz-AVR
I surpose, what you read from;
aplay -L.
(I know some programming, a web developer, and also think Kodi put that string in, on HDMI 0, last)
Thanks again, I am very happy, but do not know what sounds best now, Maverick or Marantz, he!
I have installed last free version of Volumio. It works good with ethernet lan cable. How can I use the wireless lan instead of the cable one?
The hardware is a Nuc i5 with wifi and bluetooth. How can link my iPhone via bluetooth to Volumio? Is it possibile?
Last question: I use the free version of Volumio. My system shows me the sample rate and it is always 44.1Khz. Can Volumio play music with more than 44.1khz sample rate?
System Information
OS info
Version of Volumio: 3.819
Hostname: volumio
Kernel: 6.6.32-volumio
Governor: performance
Uptime: 4 days, 3 Hrs, 59 Minutes, 28 Seconds
Network info
Interface: eth0
IP Address: 192.168.254.106
MAC Address: ec:a8:6b:fb:9f:31
Type: wired
Speed: 100Mb/s
Audio info
Hw audio configured: A12 Classic
Mixer type: Hardware
Number of channels: 2
Supported sample rate: 44100 48000 88200 96000 176400 192000 384000
Board info
Manufacturer: Intel
Model: D53427RKE / G87971-403 /
Version: 1 / G87971-403
Firmware Version: Available only for RPI
CPU info
Brand: Core⢠i5-3427U
Speed: 1.8 GHz
Family: 6
Model: 58
Number of cores: 4
Physical cores: 2
Average load: 27%
Temperature: 28°C
Memory info
Memory: 7839628 Ko
Free: 4791224 Ko
Used: 3048404 Ko
Software info
Mpd version: Music Player Daemon 0.23.15 (0.23.15)
Storage info
INTERNAL storage - Size: 56224Mo
Used: 4952Mo
Available for storage: 48384Mo (86%)
From where are you playing your music, local storage or via the iPhone using airplay. if the latter this is due to airplay.
If you canāt setup Wifi in the network menu, your wifi adapter might not have been identified. Please provide the information as requested in the opening post under: **
Reporting**
