I would like to thanks @Wheaten and @gkkpch for the help. I am building something like a case and I ll post the result. I also decided to go for a pico psu to minimize the thing
Help me solve the problem: booting the system, library 0 (empty). Autostart shows the last song, but it doesnāt start. I reboot (turn off the power and turn on) and the library appears, and autostart works as it should. Sometimes you have to turn it off and on several times.
Ver. 3.779 x86_amd64, Now playing, AutoStart
@jimmy210967 Please help US to solve your problem by giving us a little bit more information.
Please read the first post of this thread and supply the information we need.
Weāll gladly analyse it and help determine next steps.
Beelink T4 Pro Intel Celeron N3350 4 ŠŠ DDR RAM + 64 ŠŠ emmc
http://logs.volumio.org/volumio/nVhcg5g.html
sudo lshw
permitted by applicable law.
Welcome to Volumio for x86_64 (6.6.32-volumio x86_64)
volumio@volumiocomp:~$ sudo lshw
[sudo] password for volumio:
volumiocomp
description: Desktop Computer
product: T4 PRO (Default string)
vendor: AZW
version: Default string
serial: Default string
width: 64 bits
capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=Default string sku=Default string uuid=00020003-0004-0005-0006-000700080009
*-core
description: Motherboard
product: T4 PRO
vendor: AZW
physical id: 0
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: TMINI105
date: 11/30/2021
capacity: 5MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17 printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: 30
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: 123456789012345678
vendor: ABCD
physical id: 0
serial: 1234
slot: ChannelA-DIMM0
width: 16 bits
clock: 1600MHz (0.6ns)
*-bank:1
vendor: ABCD
physical id: 1
serial: 1234
slot: ChannelB-DIMM0
width: 16 bits
*-bank:2
vendor: ABCD
physical id: 2
serial: 1234
slot: ChannelC-DIMM0
width: 16 bits
*-bank:3
vendor: ABCD
physical id: 3
serial: 1234
slot: ChannelD-DIMM0
width: 16 bits
*-cache:0
description: L1 cache
physical id: 36
slot: CPU Internal L1
capacity: 112KiB
capabilities: synchronous internal write-back
configuration: level=1
*-cache:1
description: L2 cache
physical id: 37
slot: CPU Internal L2
capacity: 2MiB
capabilities: synchronous internal write-back unified
configuration: level=2
*-cpu
description: CPU
product: Intel(R) Celeron(R) CPU N3350 @ 1.10GHz
vendor: Intel Corp.
physical id: 38
bus info: cpu@0
version: Intel(R) Celeron(R) CPU N3350 @ 1.10GHz
slot: SOCKET 0
capacity: 2400MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 a pic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_ good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds _cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc _deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch cpuid_fault cat_l2 pti tp r_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust smep erms mpx rdt_a rd seed smap clflushopt intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves dtherm ida a rat pln pts vnmi cpufreq
configuration: cores=2 enabledcores=2 threads=2
*-pci
description: Host bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 0d
width: 32 bits
clock: 33MHz
*-display
description: VGA compatible controller
product: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 0d
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:127 memory:90000000-90ffffff memory:80000000-8ffffff f ioport:f000(size=64) memory:c0000-dffff
*-multimedia
description: Audio device
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Au dio Cluster
physical id: e
bus info: pci@0000:00:0e.0
version: 0d
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:130 memory:91310000-91313fff memory:91000000-910ffff f
*-communication
description: Communication controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Tr usted Execution Engine
physical id: f
bus info: pci@0000:00:0f.0
version: 0d
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:128 memory:9131d000-9131dfff
*-sata
description: SATA controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SA TA AHCI Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 0d
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:125 memory:91314000-91315fff memory:9131a000-9131a0f f ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:91319000-9 13197ff
*-pci:0
description: PCI bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PC I Express Port A #1
physical id: 13
bus info: pci@0000:00:13.0
version: fd
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_li st
configuration: driver=pcieport
resources: irq:120 ioport:e000(size=4096) memory:91200000-912fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controll er
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 15
serial: 7c:83:34:b8:f3:5a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list etherne t physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 dri verversion=6.6.32-volumio firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no m ulticast=yes port=twisted pair
resources: irq:22 ioport:e000(size=256) memory:91204000-91204fff memory:91200000-91203fff
*-pci:1
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PC I Express Port A #2
physical id: 13.1
bus info: pci@0000:00:13.1
version: fd
width: 32 bits
clock: 33MHz
resources: irq:121 memory:91100000-911fffff
*-network
description: Wireless interface
product: Wireless 3165
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlan0
version: 81
serial: 50:2f:9b:6b:d7:71
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet phy sical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=6.6.32 -volumio firmware=29.4063824552.0 7265D-29.ucode ip=192.168.1.122 latency=0 link =yes multicast=yes wireless=IEEE 802.11
resources: irq:129 memory:91100000-91101fff
*-pci:2
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PC I Express Port A #3
physical id: 13.2
bus info: pci@0000:00:13.2
version: fd
width: 32 bits
clock: 33MHz
resources: irq:122
*-pci:3
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PC I Express Port A #4
physical id: 13.3
bus info: pci@0000:00:13.3
version: fd
width: 32 bits
clock: 33MHz
resources: irq:123
*-usb
description: USB controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series US B xHCI
physical id: 15
bus info: pci@0000:00:15.0
version: 0d
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:124 memory:91300000-9130ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 6.6.32-volumio xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 6.06
capabilities: usb-2.00
configuration: driver=hub slots=8 speed=480Mbit/s
*-usb:0
product: FIIO KA17
vendor: GuangZhou FIIO Electronics Co.,Ltd
physical id: 3
bus info: usb@1:3
version: 2.02
capabilities: usb-2.00 audio-control
configuration: driver=usbhid speed=480Mbit/s
*-usb:1
description: Human interface device
product: USB2IIC_CTP_CONTROL
vendor: wch.cn
physical id: 4
bus info: usb@1:4
version: 0.00
capabilities: usb-0.01
configuration: driver=usbhid maxpower=64mA speed=12Mbit/s
*-usb:2
product: KT_USB_AUDIO
vendor: KTMicro
physical id: 5
bus info: usb@1:5
version: 1.00
serial: 214b206000000178
capabilities: usb-1.10 audio-control
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:3
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 6
bus info: usb@1:6
version: 0.01
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 6.06
capabilities: usb-3.00
configuration: driver=hub slots=7 speed=5000Mbit/s
*-generic
description: SD Host controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series eM MC Controller
physical id: 1c
bus info: pci@0000:00:1c.0
version: 0d
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=sdhci-pci latency=0
resources: irq:39 memory:91318000-91318fff memory:91317000-91317fff
*-isa
description: ISA bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Lo w Pin Count Interface
physical id: 1f
bus info: pci@0000:00:1f.0
version: 0d
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
configuration: latency=0
*-serial
description: SMBus
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SM Bus Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
version: 0d
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:-2147483648 memory:91316000-913160ff ioport:f040(siz e=32)
*-pnp00:00
product: PnP device PNP0c02
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
physical id: 2
capabilities: pnp
*-pnp00:02
product: PnP device PNP0b00
physical id: 3
capabilities: pnp
configuration: driver=rtc_cmos
inxi -Fxxxz
System: Host: volumiocomp Kernel: 6.6.32-volumio x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop Mobo: AZW model: T4 PRO serial: UEFI: American Megatrends v: TMINI105 date: 11/30/2021
CPU: Topology: Dual Core model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont rev: A L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4377
Speed: 2400 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 2021 2: 800
Graphics: Device-1: Intel driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5a85
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 189x55
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster driver: snd_hda_intel
v: kernel bus ID: 00:0e.0 chip ID: 8086:5a98
Device-2: N/A type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5:4 chip ID: 31b2:8001 serial:
Device-3: N/A type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2 chip ID: 2972:0093
Sound Server: ALSA v: k6.6.32-volumio
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: eth0 state: down mac:
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:3165
IF: wlan0 state: up mac:
Drives: Local Storage: total: 57.62 GiB used: 1.74 GiB (3.0%)
ID-1: /dev/mmcblk0 type: Removable model: 58A441 size: 57.62 GiB serial: rev: 0x8 scheme: GPT
Partition: ID-1: / size: 52.93 GiB used: 779.4 MiB (1.4%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 77.9 MiB (46.3%) fs: vfat dev: /dev/mmcblk0p1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 159 Uptime: 54m Memory: 3.69 GiB used: 553.3 MiB (14.6%) Init: systemd v: 241 runlevel: 5 default: 2
Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
Maybe itās related
@jimmy210967
Do you also have the library issue without autostart and now playing, just the plain x86 image install?
Did you try with a wired connection?
i upgraded the system to ssd, will i be able via ssh to format the new disk / clone the old hdd?
I d be trying the āinstall toā in settings, but i feel not confortableā¦
āInstall toā will work perfectly if you boot from hdd (or USB) with the ssd installed.
Just make sure you pick the ssd drive, after deciding you do not need any of it, as your ssd choice will be re-partitioned and re-formatted according to volumioās requirements. So all data on the target disk will be lost.
As long as you keep the hdd (or USB), you will still be able to boot from it when unsure.
Refer to the BIOS settings to select the proper boot device and boot order.
I would advice against using commandline calls, theoretically you could use āddā but that would be a sector-by-sector copy, which can take a lot of time depending on the size of the hdd.
Plus, in case of dd copy, the ssd MUST be larger than the hdd, with āInstall toā you may get away with a smaller ssd depending on much data you stored on /data/INTERNAL
@gkkpch thanks for your reply.
I will want to use the SSD instead of the HDD.
So i will remain with only the SSD, both for system and data.
perhaps can i go with the āinstallā , and filezilla to have the flac back again, this time on the SSD ?
I was thinking to copy / clone to avoid new settings
Unfortunately you will have to re-configure Volumio and re-install the flacs when using āinstall to diskā.
However, it is a safer and MUCH faster way than trying a sector-by-sector copy. In case you do want a copy, you need to ssh into Volumio and do a sudo fdisk -l and post the output here.
I can then prepare a copy command for you, but as I said, I do not recommend it.
@gkkpch ok i did install, make the config steps, ssh on and flac on ssd. It works, thanks again.
Last step will be a pico psu, while i am working on the case ![]()
Thanks again!
i should not touch⦠i tried a theme (classic) now itās all white. No anything ![]()
What is the output of:
ls -als /data/
volumio@volumio:~$ ls .-als /data/
ls: cannot access '.-als': No such file or directory
/data/:
INTERNAL backgrounds playerstate updatesHistoryFile
active_volumio_ui configuration playlist volumio-update.tmp
albumart favourites plugins volumiokiosk
volumio@volumio:~$ volumio@volumio:~$ ls .-als /data/
/data/:
-bash: volumio@volumio:~$: command not found
volumio@volumio:~$ ls: cannot access '.-als': No such file or directory
volumio@volumio:~$
-bash: ls:: command not found
volumio@volumio:~$ /data/:
-bash: /data/:: No such file or directory
volumio@volumio:~$ INTERNAL backgrounds playerstate updatesHistoryFile
-bash: INTERNAL: command not found
volumio@volumio:~$ active_volumio_ui configuration playlist volumio-update.tmp
-bash: active_volumio_ui: command not found
volumio@volumio:~$ albumart favourites plugins volumiokiosk
-bash: albumart: command not found
volumio@volumio:~$
please use the command @Wheaten gaveā¦;
You added a . before -als!
volumio@volumio:~$ ls -als /data/
total 60
8 drwxr-xr-x 1 volumio volumio 4096 Jan 10 18:48 .
4 drwxrwxrwx 1 root root 4096 Jan 10 17:42 ..
4 drwxrwxrwx 1 root root 4096 Jan 10 19:57 INTERNAL
4 -rwxrwxrwx 1 volumio volumio 75 Jan 10 19:36 active_volumio_ui
4 drwxr-xr-x 6 volumio volumio 4096 Jan 10 17:43 albumart
4 drwxr-xr-x 2 volumio volumio 4096 Jan 10 17:43 backgrounds
4 drwxr-xr-x 7 volumio volumio 4096 Jan 10 18:24 configuration
4 drwxr-xr-x 2 volumio volumio 4096 Jan 10 17:43 favourites
4 drwxr-xr-x 2 volumio volumio 4096 Jan 10 17:43 playerstate
4 drwxr-xr-x 2 volumio volumio 4096 Jan 10 17:43 playlist
4 drwxr-xr-x 5 volumio volumio 4096 Jan 10 18:45 plugins
4 -rw-r--r-- 1 volumio volumio 185 Jan 10 17:43 updatesHistoryFile
4 -rw-r--r-- 1 volumio volumio 22 Jan 11 12:13 volumio-update.tmp
4 drwxr-xr-x 1 root root 4096 Jan 11 12:14 volumiokiosk
volumio@volumio:~$
i write āvolumio.localā, it does appear, shortly, the page for playback, and it goes to white
final one, what is the output of:
cat /data/active_volumio_ui
volumio@volumio:~$ cat /data/active_volumio_ui
{āuiPrettyNameā:āClassicā,āuiNameā:āclassicā,āuiPathā:ā/volumio/http/wwwā}
Run the following commands:
rm /data/active_volumio_ui
cat <<EOF >>/active_volumio_ui
{"uiPrettyName":"Manifest","uiName":"manifest","uiPath":"/volumio/http/www4"}
EOF
sudo reboot
oh wow.
It worked.
I suppose you made me change the theme by string
thanks!!
