Please post in English, so people can read your posting.
label the hdd as issd
tried to label it issd, formatted fat32, but they are not seen anyway, other options? Thank you
You can take a look at topic DEV: [PLUGIN] MPD_OLED for x86 based systems
here we played around to get i2c running on a x86 for mdp_oled.
one of these should do the trick:
What are the minimum CPU and memory requirements for volumio?One of my tablets has 2 GB memories and a CPU Z3740, but it seems that there is a lag in the operation, which affects the sound quality of the treble part. However, the same DAC will not have such a problem when placed on a laptop with I5 5200 8G memory.
How did you install volumio on a tablet? ![]()
The new version of volumio generally supports it, but some functions don’t work. In my case, I can’t shut down or restart it, I can only force it to shut down. I think the power driver is wrong.Tablets have advantages and disadvantages. They perfectly support touch screens. However, tablets generally only have one Android USB port. Charging and connecting to the DAC are both in the same USB port, making it inconvenient to use.
In addition to this and the above mentioned, there will be lags during use, which affects the sound quality. I don’t know if it is because the CPU Z3740 and 2GB memory are not enough.
I expect that when you turn off spectrum, the sound will be better. A tablet with the a 3740 has about the performance of a rpi3, without almost no video support.
For some reason I cannot create a proper boot usbstick that works on my older mainboard. The mainboard does not recognise the usbstick as een boot device. Tried Belena, Rufus and other utilities, no luck.
Is there another way to install Volumio on the SSD, maybe copy directly to the SSD?
you can indeed take the SSD out and flash it like it’s an USB device.
I tried that but I does not see it as a bootable device?
Please read the opening post from this topic and provide requested information.
I have installed Volumio on a 2009 Mac Mini. All is working well except playing from the internal CD drive. I insert the disk and it spins, but never starts playing. I also do not see CD in the sources list. Any help would be appreciated.
http://logs.volumio.org/volumio/eH3G46v.html
description: Lunch Box Computer
product: Macmini3,1 (System SKU#)
vendor: Apple Inc.
version: 1.0
serial: YM937AM69G6
width: 64 bits
capabilities: smbios-2.4 dmi-2.4 smp vsyscall32
configuration: boot=normal chassis=lunchbox family=Macmini sku=System SKU# uuid=978369DC-54FA-F24C-82C8-B1B5307A6A7F
*-core
description: Motherboard
product: Mac-F22C86C8
vendor: Apple Inc.
physical id: 0
serial: Base Board Serial#
slot: Part Component
*-cpu:0
description: CPU
product: Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz
vendor: Intel Corp.
physical id: 0
bus info: cpu@0
version: Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz
slot: U2E1
capacity: 2530MHz
width: 64 bits
clock: 266MHz
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl cpuid aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm pti tpr_shadow flexpriority vpid dtherm vnmi cpufreq
*-cache
description: L1 cache
physical id: 2
slot: Unknown
capacity: 32KiB
capabilities: asynchronous internal write-back data
configuration: level=1
*-cache:0
physical id: 1
slot: Unknown
capacity: 32KiB
capabilities: asynchronous internal write-back instruction
*-cpu:1
description: CPU
vendor: Intel(R) Corporation
physical id: 3
bus info: cpu@1
slot: U2E1
capacity: 2530MHz
clock: 266MHz
capabilities: cpufreq
*-cache
physical id: 5
slot: Unknown
capacity: 32KiB
*-cache:1
physical id: 4
slot: Unknown
capacity: 32KiB
*-memory
description: System Memory
physical id: 6
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1067 MHz (0.9 ns)
product: M471B5673EH1-CF8
vendor: Samsung
physical id: 0
serial: 0x84D1AC8C
slot: DIMM0
clock: 1067MHz (0.9ns)
*-bank:1
vendor: Samsung
physical id: 1
serial: 0x84D1ABB2
slot: DIMM0
*-firmware
description: BIOS
vendor: Apple Inc.
physical id: e
version: MM31.88Z.00AD.B00.0907171535
date: 07/17/09
capacity: 4MiB
capabilities: pci upgrade shadowing cdboot bootselect acpi ieee1394boot smartbattery netboot
*-pci
description: Host bridge
product: MCP79 Host Bridge
vendor: NVIDIA Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: b1
width: 32 bits
clock: 66MHz
*-memory:0 UNCLAIMED
description: RAM memory
product: MCP79 Memory Controller
physical id: 0.1
bus info: pci@0000:00:00.1
version: b1
width: 32 bits
clock: 66MHz (15.2ns)
capabilities: bus_master
configuration: latency=0
*-isa
description: ISA bridge
product: MCP79 LPC Bridge
physical id: 3
bus info: pci@0000:00:03.0
version: b3
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
resources: ioport:2000(size=256)
*-memory:1 UNCLAIMED
physical id: 3.1
bus info: pci@0000:00:03.1
version: b1
width: 32 bits
*-serial
description: SMBus
product: MCP79 SMBus
physical id: 3.2
bus info: pci@0000:00:03.2
version: b1
width: 32 bits
clock: 66MHz
capabilities: pm cap_list
configuration: driver=nForce2_smbus latency=0
resources: irq:0 ioport:2180(size=64) ioport:2140(size=64) ioport:2100(size=64)
*-memory:2 UNCLAIMED
physical id: 3.3
bus info: pci@0000:00:03.3
version: b1
width: 32 bits
*-memory:3 UNCLAIMED
physical id: 3.4
bus info: pci@0000:00:03.4
version: b1
width: 32 bits
*-processor UNCLAIMED
description: Co-processor
product: MCP79 Co-processor
physical id: 3.5
bus info: pci@0000:00:03.5
version: b1
width: 32 bits
clock: 66MHz
configuration: latency=0 maxlatency=1 mingnt=3
resources: memory:d3400000-d347ffff
*-usb:0
description: USB controller
product: MCP79 OHCI USB 1.1 Controller
physical id: 4
bus info: pci@0000:00:04.0
version: b1
width: 32 bits
clock: 66MHz
capabilities: pm ohci bus_master cap_list
configuration: driver=ohci-pci latency=0 maxlatency=1 mingnt=3
resources: irq:20 memory:d3488000-d3488fff
*-usbhost
product: OHCI PCI host controller
vendor: Linux 6.6.25-volumio ohci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 6.06
capabilities: usb-1.10
configuration: driver=hub slots=7 speed=12Mbit/s
*-usb
description: Human interface device
product: IR Receiver
vendor: Apple Computer, Inc.
physical id: 5
bus info: usb@1:5
version: 0.16
capabilities: usb-2.00
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:1
product: MCP79 EHCI USB 2.0 Controller
physical id: 4.1
bus info: pci@0000:00:04.1
version: b1
width: 32 bits
clock: 66MHz
capabilities: debug pm ehci bus_master cap_list
configuration: driver=ehci-pci latency=0 maxlatency=1 mingnt=3
resources: irq:17 memory:d3489200-d34892ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 6.6.25-volumio ehci_hcd
physical id: 1
bus info: usb@3
logical name: usb3
version: 6.06
configuration: driver=hub slots=7 speed=480Mbit/s
*-usb:2
physical id: 6
bus info: pci@0000:00:06.0
version: b1
width: 32 bits
clock: 66MHz
resources: irq:22 memory:d3487000-d3487fff
*-usbhost
physical id: 1
bus info: usb@2
logical name: usb2
version: 6.06
configuration: driver=hub slots=5 speed=12Mbit/s
*-usb:0
description: USB hub
product: BRCM2046 Hub
vendor: Apple Inc.
physical id: 1
bus info: usb@2:1
version: 1.00
configuration: driver=hub slots=3 speed=12Mbit/s
*-usb
description: Bluetooth wireless interface
product: Bluetooth USB Host Controller
vendor: Apple Inc.
physical id: 1
bus info: usb@2:1.1
version: 2.08
serial: 0026B0F5695A
capabilities: bluetooth usb-2.00
configuration: driver=btusb speed=12Mbit/s
*-usb:1
description: Keyboard
product: Keychron K1
vendor: Keychron
physical id: 2
bus info: usb@2:2
version: 1.05
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:2
product: USB Receiver
vendor: Logitech
physical id: 4
bus info: usb@2:4
version: 24.11
configuration: driver=usbhid maxpower=98mA speed=12Mbit/s
*-usb:3
physical id: 6.1
bus info: pci@0000:00:06.1
version: b1
width: 32 bits
clock: 66MHz
resources: irq:22 memory:d3489100-d34891ff
*-usbhost
physical id: 1
bus info: usb@4
logical name: usb4
version: 6.06
configuration: driver=hub slots=5 speed=480Mbit/s
*-multimedia
description: Audio device
product: MCP79 High Definition Audio
physical id: 8
bus info: pci@0000:00:08.0
version: b1
width: 32 bits
clock: 66MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=0 maxlatency=5 mingnt=2
resources: irq:20 memory:d3480000-d3483fff
*-pci:0
description: PCI bridge
product: MCP79 PCI Bridge
physical id: 9
bus info: pci@0000:00:09.0
version: b1
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode cap_list
resources: memory:d3300000-d33fffff
*-network
description: Ethernet interface
product: MCP79 Ethernet
physical id: a
bus info: pci@0000:00:0a.0
logical name: eth0
version: b1
serial: 00:26:b0:e9:a8:b8
capacity: 1Gbit/s
width: 32 bits
clock: 66MHz
capabilities: pm msi bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=forcedeth driverversion=0.64 duplex=full ip=192.168.20.186 latency=0 link=yes maxlatency=20 mingnt=1 multicast=yes port=MII speed=1Gbit/s
resources: irq:29 memory:d3486000-d3486fff ioport:21e0(size=8) memory:d3489000-d34890ff memory:d3489300-d348930f
*-sata
description: SATA controller
product: MCP79 AHCI Controller
physical id: b
bus info: pci@0000:00:0b.0
logical name: scsi0
logical name: scsi1
version: b1
width: 32 bits
clock: 66MHz
capabilities: sata pm msi ahci_1.0 bus_master cap_list emulated
configuration: driver=ahci latency=0 maxlatency=1 mingnt=3
resources: irq:26 ioport:21d8(size=8) ioport:21ec(size=4) ioport:21d0(size=8) ioport:21e8(size=4) ioport:21c0(size=16) memory:d3484000-d3485fff
*-disk
description: ATA Disk
product: Hitachi HTS54323
vendor: Hitachi
physical id: 0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: C52F
serial: 090901FBE400CEHPA97F
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=512
*-volume:0 UNCLAIMED
description: EFI GPT partition
physical id: 1
bus info: scsi@0:0.0.0,1
capacity: 171MiB
capabilities: primary nofs
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /imgpart
version: 1.0
serial: f5ea4fcf-a842-4d8c-81a5-8fe07ebdd8d9
capacity: 3452MiB
capabilities: primary bootable nofs journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2024-05-31 09:15:58 filesystem=ext4 label=volumio lastmountpoint=/mnt/imgpart modified=2024-06-01 09:44:34 mount.fstype=ext4 mount.options=rw,relatime mounted=2024-06-01 09:44:34 state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
version: 1.0
serial: 85462bfd-f034-41f7-8079-8d6d3bc61663
capacity: 294GiB
capabilities: primary nofs journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2024-05-31 09:16:00 filesystem=ext4 label=volumio_data lastmountpoint=/ modified=2024-05-31 16:33:58 mounted=2024-05-31 16:33:58 state=clean
*-cdrom
description: DVD writer
product: DVD-RW DVRTS08
vendor: PIONEER
physical id: 1
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: Q81F
capabilities: removable audio cd-r cd-rw dvd dvd-r
configuration: ansiversion=5 status=open
*-pci:1
product: MCP79 PCI Express Bridge
physical id: 10
bus info: pci@0000:00:10.0
version: b1
width: 32 bits
clock: 33MHz
capabilities: pci pm msi normal_decode bus_master cap_list
resources: ioport:1000(size=4096) memory:d2000000-d30fffff ioport:c0000000(size=301989888)
*-display
description: VGA compatible controller
product: C79 [GeForce 9400]
physical id: 0
bus info: pci@0000:02:00.0
version: b1
width: 64 bits
clock: 33MHz
capabilities: pm msi vga_controller bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:28 memory:d2000000-d2ffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:1000(size=128) memory:d3000000-d301ffff
*-pci:2
physical id: 15
bus info: pci@0000:00:15.0
version: b1
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 memory:d3200000-d32fffff
*-network DISABLED
description: Wireless interface
product: BCM4321 802.11a/b/g/n
vendor: Broadcom Limited
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 05
serial: 00:26:b0:f5:6c:26
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=b43 driverversion=6.6.25-volumio firmware=666.2 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:20 memory:d3200000-d3203fff
*-pci:3
physical id: 16
bus info: pci@0000:00:16.0
version: b1
width: 32 bits
clock: 33MHz
resources: irq:25 memory:d3100000-d31fffff
*-firewire
description: FireWire (IEEE 1394)
product: FW643 [TrueFire] PCIe 1394b Controller
vendor: LSI Corporation
physical id: 0
bus info: pci@0000:04:00.0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress ohci bus_master cap_list
configuration: driver=firewire_ohci latency=0
resources: irq:27 memory:d3100000-d3100fff
*-pnp00:00
product: PnP device PNP0c02
physical id: 2
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0103
physical id: 5
capabilities: pnp
*-pnp00:02
physical id: 7
capabilities: pnp
*-pnp00:03
product: PnP device PNP0b00
physical id: 8
capabilities: pnp
configuration: driver=rtc_cmos
(edited by @gkkpch for readability)
Prob. just asking the obvious, you have a paid subscription?
I presume (I dare not ask) you flashed the unzipped image file, not the zip file itself.
With older main boards you may have to go into the BIOS and enable USB Legacy boot.
As for the SSD, without more info about the main board it is very difficult to just guess what your problem could be. I expect a BIOS setup issue in case the image was flashed correctly.
I do
Display not working Intel 82945G/GZ Integrated Graphics driver: i915
volumio@tity:~$ inxi -Fxz
System:
Host: tity Kernel: 6.6.25-volumio x86_64 bits: 64 compiler: N/A
Console: tty 0 Distro: Debian GNU/Linux 10 (buster)
Machine:
Type: Desktop Mobo: N/A model: LakePort serial: <filter> BIOS: Phoenix
v: 6.00 PG date: 08/05/2008
CPU:
Topology: Single Core model: Intel Atom 230 bits: 64 type: MT
arch: Bonnell rev: 2 L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 6383
Speed: 1596 MHz min/max: N/A Core speeds (MHz): 1: 1596 2: 1596
Graphics:
Device-1: Intel 82945G/GZ Integrated Graphics driver: i915 v: kernel
bus ID: 00:02.0
Display: tty server: X.org 1.20.4 driver: i915 tty: 80x24
Message: Advanced graphics data unavailable in console. Try -G --display
Audio:
Device-1: Intel NM10/ICH7 Family High Definition Audio
vendor: Jetway Information driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k6.6.25-volumio
Network:
Device-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet
driver: r8169 v: kernel port: ee00 bus ID: 02:00.0
IF: eth0 state: down mac: <filter>
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
bus ID: 5-2:2
IF: wlan0 state: up mac: <filter>
Drives:
Local Storage: total: 14.91 GiB used: 1.29 GiB (8.7%)
ID-1: /dev/sda model: SQF-S25M4-16G-S8E size: 14.91 GiB
Partition:
ID-1: / size: 11.02 GiB used: 331.4 MiB (2.9%) fs: overlay source: ERR-102
ID-2: /boot size: 170.8 MiB used: 77.3 MiB (45.2%) fs: vfat dev: /dev/sda1
Sensors:
Missing: Required tool sensors not installed. Check --recommends
Info:
Processes: 116 Uptime: 4h 34m Memory: 1.93 GiB used: 329.1 MiB (16.6%)
Init: systemd runlevel: 5 Compilers: gcc: N/A Shell: bash v: 5.0.3
inxi: 3.0.32
(re-formatted by moderator for readability purposes)
@tity67a Please provide a log so we can see what happens when loading the driver.
Remember, this is 16-year old hardware according to the BIOS, if we can help with supplying additional firmware, then there is hope.
In case of a driver issue, you will be out of luck I’m afraid.
@gkkpch Done! Thanks for info!
