Thank you. Can I describe in more detail how and where to set it up?
on the Wyse with the media attached go to:
â+ Add new Driveâ
Volumio will scan the network, net click on the device that has the disk attached:
Writes ânetwork drives not foundâ
All three devices are on the same network with the same mask 255.255.255.0?
Please post the logs from these devices here on the forum:
Sorry for the delay in responding. The router was rebooting.
both computers are connected to the same hub
478a7f5c67089b1783056cfc6eca478a
fe772a8293bfdb7a0e2866bdd984e33e
you need to paste the url, otherwise we canât read it ![]()
These ones?
http://192.168.1.83/dev/
http://192.168.1.78/dev/
Oh, I get it)
http://logs.volumio.org/volumio/X5zny0t.html
http://logs.volumio.org/volumio/43rIAca.html
a bit confused, I see in both logs a connected USB device with audio.
You stated that you want one device with Audio and share it with the 2 others?
The disk is connected to only one computer
I wanted two devices with sound and one device with a music library. Two computers are physically available to me now, the third is in another room, it is now closed, I cannot get into it. I need the second computer to have access to the SSD drive of the first computer from one computer with an SSD drive
I reset both computers to factory settings and installed the latest updates. SSD drive on only one computer http://192.168.1.83/
I reset both computers to factory settings and installed the latest updates. SSD drive is only on one computer. Made new log files
http://logs.volumio.org/volumio/CkZtnTE.html
http://logs.volumio.org/volumio/LMrTiFm.html
So 192.168.1.83 holds your USB disk.
You should be able now to connect 192.168.1.78 to the library on 192.168.1.83.
like:
Guys, I moved the Wyse support issue to this x86 support thread
Itâs working! Super! Thanks! Low bow! It turned out to be so simple)
Yeah Volumio did their best to make it as easy as possible.
So now enjoy your music.
Volumio! You are the best!
Ho recuperato x pochi euro un nas che non eseguiva il booting, riparato , e installato Volumio v3, in quanto ha a bordo una scheda madre x86 64 bit, un display 16x2, e 2 giga di ram. Tutto ok, il sistema funziona, ma non riesco a vedere gli altri dischi interni. Qualcuno ha provato questa soluzione?
[mod=Wheaten, Google translate]
I recovered for a few euros a NAS that wasnât booting, repaired it, and installed Volumio v3, as it has an x86 64 bit motherboard on board, a 16x2 display, and 2 gigabytes of RAM. Everything ok, the system works, but I canât see the other internal disks. Has anyone tried this solution?
Avrebbe anche a bordo dei pulsanti. e un display display, credo sia i2c, sarebbe bello configurarlo con volumio
It would also have on-board buttons. and a display display, I think itâs i2c, it would be nice to configure it with volumio
