please try to use Raspberry Pi Imager for burning the USB drive, after uncompressing the .zip file to obtain the .img file.
Please also format the USB drive in FAT32, before buring the image (please use Raspberry Pi Imager too)
Which USB drive/stick are you using?
Even if Iâm going for x86?
Generic 4.04 Gb
can you try another flash drive? Some rare memory controllers are known not to play well with linux. Also, donât forget to âejectâ the usb drive after flashing it.
yes, the Raspberry Pi Imager tool can be used with all platforms, to burn the .img file in the SD-card/USB-drive
Thank you very much! Will try and let you know of the results
I just install the Volumio-3.512-2023-06-25-x86_amd64 to fitlet3 and I am not able to link network.
So I use Apple USB Ehternet adapter.
Is there way for use LAN( Marvel 88E1512) or WLAN(AX210)?
Fitlet3 Specifications
$ sudo lshw
volumio
description: Desktop Computer
product: Default string (Default string)
vendor: Default string
version: Default string
serial: 1230310-02112
width: 64 bits
capabilities: smbios-3.3.0 dmi-3.3.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=Default string sku=Default string uuid=02719A51-534C-EB11-AC2A-601858881700
*-core
description: Motherboard
physical id: 0
version: 1.1
serial: 1221120-02147
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends International, LLC.
physical id: 0
version: 5.19
date: 12/28/2022
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd acpi biosbootspecification uefi
*-memory
description: System Memory
physical id: 39
slot: System board or motherboard
*-bank:0
description: SODIMM DDR4 Synchronous 3200 MHz (0.3 ns)
product: CT32G4SFD832A.M16FF
vendor: Crucial Technology
physical id: 0
serial: E768DF71
slot: Controller0-ChannelA
width: 64 bits
clock: 3200MHz (0.3ns)
*-bank:1
description: [empty]
physical id: 1
slot: Controller0-ChannelB-DIMM0
*-cache:0
description: L1 cache
physical id: 42
slot: L1 Cache
capacity: 256KiB
capabilities: synchronous internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 43
slot: L2 Cache
capacity: 1536KiB
configuration: level=2
*-cache:2
description: L3 cache
physical id: 44
slot: L3 Cache
capacity: 4MiB
configuration: level=3
*-cpu
description: CPU
product: Intel(R) Celeron(R) J6413 @ 1.80GHz
vendor: Intel Corp.
physical id: 45
bus info: cpu@0
version: Intel(R) Celeron(R) J6413 @ 1.80GHz
serial: To Be Filled By O.E.M.
slot: U3E1
capacity: 3GHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch cpuid_fault epb cat_l2 cdp_l2 ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust smep erms rdt_a rdseed smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req umip waitpkg gfni rdpid movdiri movdir64b md_clear flush_l1d arch_capabilities cpufreq
configuration: cores=4 enabledcores=4 threads=4
*-pci
description: Host bridge
product: Intel Corporation
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 01
width: 32 bits
clock: 33MHz
*-display UNCLAIMED
description: VGA compatible controller
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:400-3ff memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff
*-generic:0 UNCLAIMED
description: System peripheral
physical id: 8
bus info: pci@0000:00:08.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: msi pm cap_list
resources: iomemory:600-5ff memory:60013a2000-60013a2fff
*-usb
description: USB controller
physical id: 14
bus info: pci@0000:00:14.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: iomemory:600-5ff irq:123 memory:6001380000-600138ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.10.176-volumio xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 5.10
capabilities: usb-2.00
configuration: driver=hub slots=10 speed=480Mbit/s
*-usb:0
description: Audio device
product: EarMen Angel
vendor: XMOS
physical id: 3
bus info: usb@1:3
version: 1.01
capabilities: usb-2.00 audio-control
configuration: driver=usbhid speed=480Mbit/s
*-usb:1
description: Generic USB device
product: Apple USB Ethernet Adapter
vendor: Apple Inc.
physical id: 4
bus info: usb@1:4
version: 0.01
serial: 31FCE8
configuration: driver=asix maxpower=250mA speed=480Mbit/s
*-usb:2
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 5
bus info: usb@1:5
version: 0.00
capabilities: bluetooth usb-2.01
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.10
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-memory UNCLAIMED
description: RAM memory
physical id: 14.2
bus info: pci@0000:00:14.2
version: 11
width: 64 bits
clock: 33MHz (30.3ns)
capabilities: pm cap_list
resources: iomemory:600-5ff iomemory:600-5ff memory:6001394000-6001397fff memory:60013a1000-60013a1fff
*-serial:0
description: Serial bus controller
physical id: 15
bus info: pci@0000:00:15.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=intel-lpss latency=0
resources: irq:27 memory:4010000000-4010000fff
*-serial:1
physical id: 15.2
bus info: pci@0000:00:15.2
version: 11
width: 64 bits
clock: 33MHz
resources: irq:29 memory:4010001000-4010001fff
*-serial:2
physical id: 15.3
bus info: pci@0000:00:15.3
version: 11
width: 64 bits
clock: 33MHz
resources: irq:30 memory:4010002000-4010002fff
*-communication:0
description: Communication controller
physical id: 16
bus info: pci@0000:00:16.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: iomemory:600-5ff irq:130 memory:600139d000-600139dfff
*-sata
description: SATA controller
physical id: 17
bus info: pci@0000:00:17.0
version: 11
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:129 memory:7fe00000-7fe01fff memory:7fe03000-7fe030ff ioport:3090(size=8) ioport:3080(size=4) ioport:3060(size=32) memory:7fe02000-7fe027ff
*-serial:3
physical id: 19
bus info: pci@0000:00:19.0
version: 11
width: 64 bits
clock: 33MHz
resources: irq:31 memory:4010003000-4010003fff
*-communication:1
physical id: 19.2
bus info: pci@0000:00:19.2
version: 11
width: 64 bits
clock: 33MHz
resources: irq:33 memory:4010004000-4010004fff
*-pci:0
description: PCI bridge
physical id: 1c
bus info: pci@0000:00:1c.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:120 memory:7fd00000-7fdfffff
*-storage
description: Non-Volatile memory controller
product: Sandisk Corp
vendor: Sandisk Corp
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: storage pm msi msix pciexpress nvm_express bus_master cap_list
configuration: driver=nvme latency=0
resources: irq:16 memory:7fd00000-7fd03fff memory:7fd04000-7fd040ff
*-pci:1
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: 11
width: 32 bits
clock: 33MHz
resources: irq:121
*-pci:2
physical id: 1c.6
bus info: pci@0000:00:1c.6
version: 11
width: 32 bits
clock: 33MHz
resources: irq:122 memory:7fc00000-7fcfffff
*-network
description: Network controller
physical id: 0
bus info: pci@0000:03:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:18 memory:7fc00000-7fc03fff
*-generic:1 UNCLAIMED
physical id: 1d
bus info: pci@0000:00:1d.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi cap_list
resources: iomemory:600-5ff memory:6001000000-60011fffff
*-network:0 UNCLAIMED
description: Ethernet controller
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 11
width: 64 bits
clock: 33MHz
resources: iomemory:600-5ff memory:6001340000-600137ffff
*-network:1 UNCLAIMED
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 11
width: 64 bits
clock: 33MHz
resources: iomemory:600-5ff memory:6001300000-600133ffff
*-communication:2
physical id: 1e
bus info: pci@0000:00:1e.0
version: 11
width: 64 bits
clock: 33MHz
resources: irq:16 memory:4010005000-4010005fff
*-communication:3
physical id: 1e.1
bus info: pci@0000:00:1e.1
version: 11
width: 64 bits
clock: 33MHz
resources: irq:17 memory:4010006000-4010006fff
*-isa
description: ISA bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-multimedia
description: Multimedia audio controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 11
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: iomemory:600-5ff iomemory:600-5ff irq:16 memory:6001390000-6001393fff memory:6001200000-60012fffff
*-serial:4
description: SMBus
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 11
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: iomemory:600-5ff irq:16 memory:6001398000-60013980ff ioport:efa0(size=32)
*-serial:5 UNCLAIMED
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 11
width: 32 bits
clock: 33MHz
resources: memory:7fe04000-7fe04fff
*-pnp00:00
product: PnP device PNP0c02
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device INT3f0d
physical id: 2
capabilities: pnp
*-pnp00:02
physical id: 3
capabilities: pnp
*-pnp00:03
physical id: 4
capabilities: pnp
*-pnp00:04
physical id: 5
capabilities: pnp
*-pnp00:05
physical id: 6
capabilities: pnp
*-pnp00:06
physical id: 7
capabilities: pnp
*-battery:0
description: Nickel Cadmium Battery
product: Battery 1 Name
vendor: Battery 1 Manufacturer
physical id: 1
version: 01/01/2012
serial: Battery 1 Serial Number
slot: Battery 1 Location
*-battery:1
product: Battery 2 Name
vendor: Battery 2 Manufacturer
physical id: 2
version: 01/01/2012
serial: Battery 2 Serial Number
slot: Battery 2 Location
*-battery:2
product: Battery 3 Name
vendor: Battery 3 Manufacturer
physical id: 3
version: 01/01/2012
serial: Battery 3 Serial Number
slot: Battery 3 Location
*-battery:3
product: Battery 4 Name
vendor: Battery 4 Manufacturer
physical id: 4
version: 01/01/2012
serial: Battery 4 Serial Number
slot: Battery 4 Location
*-power:0 UNCLAIMED
description: Default string
physical id: 5
serial: Default string
capacity: 32768mWh
*-power:1 UNCLAIMED
physical id: 6
capacity: 32768mWh
*-power:2 UNCLAIMED
physical id: 7
capacity: 32768mWh
*-network
description: Ethernet interface
physical id: 8
bus info: usb@1:4
logical name: eth0
serial: d0:a6:37:e3:8a:b4
capacity: 100Mbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=asix driverversion=22-Dec-2011 duplex=full firmware=ASIX AX88772 USB 2.0 Ethernet ip=192.168.100.20 link=yes multicast=yes port=MII speed=100Mbit/s
$ inxi -Fxxxz
System: Host: volumio Kernel: 5.10.176-volumio x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop Mobo: N/A model: N/A v: 1.1 serial: <filter> UEFI: American Megatrends LLC. v: 5.19
date: 12/28/2022
CPU: Topology: Quad Core model: Intel Celeron J6413 bits: 64 type: MCP arch: N/A L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14438
Speed: 1578 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1573 2: 2808 3: 2417 4: 2807
Graphics: Device-1: Intel driver: N/A bus ID: 00:02.0 chip ID: 8086:4555
Display: tty server: X.org 1.20.4 driver: vesa unloaded: fbdev,modesetting tty: 120x30
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:4b58
Device-2: XMOS type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:75 chip ID: 20b1:30de
Sound Server: ALSA v: k5.10.176-volumio
Network: Device-1: Intel driver: N/A port: 3060 bus ID: 00:1d.1 chip ID: 8086:4ba1
Device-2: Intel driver: N/A port: 3060 bus ID: 00:1d.2 chip ID: 8086:4bb1
Device-3: Intel driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:2725
Device-4: Apple Ethernet Adapter [A1277] type: USB driver: asix bus ID: 1-4:3 chip ID: 05ac:1402
serial: <filter>
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 923.9 MiB (0.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 500GB size: 465.76 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 234110WD scheme: GPT
Partition: ID-1: / size: 453.90 GiB used: 16.4 MiB (0.0%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 61.2 MiB (36.3%) fs: vfat dev: /dev/nvme0n1p1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 181 Uptime: 41m Memory: 31.19 GiB used: 373.8 MiB (1.2%) Init: systemd v: 241 runlevel: 5
default: 2 Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
$ lspci
00:00.0 Host bridge: Intel Corporation Device 4522 (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Device 4555 (rev 01)
00:08.0 System peripheral: Intel Corporation Device 4511 (rev 01)
00:14.0 USB controller: Intel Corporation Device 4b7d (rev 11)
00:14.2 RAM memory: Intel Corporation Device 4b7f (rev 11)
00:15.0 Serial bus controller [0c80]: Intel Corporation Device 4b78 (rev 11)
00:15.2 Serial bus controller [0c80]: Intel Corporation Device 4b7a (rev 11)
00:15.3 Serial bus controller [0c80]: Intel Corporation Device 4b7b (rev 11)
00:16.0 Communication controller: Intel Corporation Device 4b70 (rev 11)
00:17.0 SATA controller: Intel Corporation Device 4b63 (rev 11)
00:19.0 Serial bus controller [0c80]: Intel Corporation Device 4b4b (rev 11)
00:19.2 Communication controller: Intel Corporation Device 4b4d (rev 11)
00:1c.0 PCI bridge: Intel Corporation Device 4b38 (rev 11)
00:1c.4 PCI bridge: Intel Corporation Device 4b3c (rev 11)
00:1c.6 PCI bridge: Intel Corporation Device 4b3e (rev 11)
00:1d.0 System peripheral: Intel Corporation Device 4bb3 (rev 11)
00:1d.1 Ethernet controller: Intel Corporation Device 4ba1 (rev 11)
00:1d.2 Ethernet controller: Intel Corporation Device 4bb1 (rev 11)
00:1e.0 Communication controller: Intel Corporation Device 4b28 (rev 11)
00:1e.1 Communication controller: Intel Corporation Device 4b29 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Device 4b00 (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Device 4b58 (rev 11)
00:1f.4 SMBus: Intel Corporation Device 4b23 (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device 4b24 (rev 11)
01:00.0 Non-Volatile memory controller: Sandisk Corp Device 501a
03:00.0 Network controller: Intel Corporation Device 2725 (rev 1a)
Well, this is one of the reasons why I have started a beta program for x86, using the lastest 6.1.y LTS kernel version and corresponding firmware.
There are several compatibility issues with your setup, due to new or updated versions of hardware components.
Starting with your Bluetooth interface, this is a serious problem, it is obviously not supported in kernel 5.10, but worse: it completely clogs up your log. Is this a usb module? Which one? There is much better BT support in kernel 6.1.y
Wifi 6E is the next issue, support for it was only introduced in kernel 5.11 (or was it 5.12?), our current x86 images are built on kernel 5.10, there is nothing I can do about it. See further below.
As for the Marvell ethernet controller, same story, kernel 5.10 does not recognize the device.
Same for the graphics card, Intel 5555 is not fully supported by the Intel i915 driver in kernel 5.10.
But this does not necessarily have to be an issue for Volumio, did it display the UI?
Current Volumio versions wonât run on your hardware without workarounds and I cannot do anything to solve it for you with the current kernel.
If you can, remove the BT module. In case you canât remove BT, then you have a system which attempts to load the BT driver/firmware 2 times a second, no idea what impact that will have on your performance.
For wireless you could use a usb dongle, for eth you already have the Apple (asix) module as a workaround.
But there is something else you can try and help us at the same time.
There is a thread about the beta versions with kernel 6.1.y
In my last post I included a link to the version I built last week.
Try it please, so we can see how far you get with that.
Thank you gkkpch.
I will try Volumiobuster-3.538-2023-08-07-x86_amd64 and let you know of the results.
Should I post logs to the beta thread or this thread?
This is m.2 module.
I want to say it displays the CLI.
Best to do that in the beta thread to keep things nicely separated.
I was afraid so.
Letâs wait for the beta results. In case you wish to continue with the current (5.10 based) version, in case that is an option, I would remove it.
I canât install Volumio-3.512-2023-06-25-x86_amd64 version on my Intel N5105 16GB 512GB. Iâm still stuck on the volumio login screen
Please could you help me?
Thanks a lot,
You did install, but the UI does not appear, right?
What machine are you referring to? Brand, model?
Is the network connection working? Did you try with a browser from another device?
We need more information, see X86 Hardware issues (WiFi, DAC, Disks, Boot etc.)
Please reply in that thread, most important is the log, in case this is not possible, then at least supply the other data as requested in the first post in that thread.
Is this still an issue? I have not received any feedback.
I have used volumio 2.0 without any problem before on dedicated Lenovo S10 netbook. Recently I installed 3.0 on it. The installation is working fine and I can access it as a blackbox from volumio app and web UI. The only issue is I am not getting default screen on laptop when I boot it. It just stops at volumio login. Is there any configuration I need to do to get the default screen which I used to get on Volumio 2.0. I am not very technical person but if there is specific script configuration I need to do, please direct me to specific thread. I couldnât find any. Then all talk about touch plugin but none about default screen. Thanks
Could you try the version from this post?
It is a beta (coming up for release soon) and could resolve some driver and firmware issues.
In case it does not work, then there is not much I can help with.
Please supply a log link, this explains how to produce a log
These netbooks are > 13 years old, unfortunately it happens that newer kernels fail with some devices. We experienced that recently again with a Toshiba device.
Thanks gkkpch for the quick reply. Here is the log I extracted.
http://logs.volumio.org/volumio/sumouJ7.html
Thanks again
Also, itâs working fine in headless mode. Identifies USB DAC and rest of the connectivity from Laptop and Mobile app. I was even able to move files to internal storage etc.
Hardware Setup:
OS info
Version of Volumio: 3.512
Hostname: jedimaster3
Governor: performance
Uptime: 0 days, 8 Hrs, 23 Minutes, 37 Seconds
Audio info
Hw audio configured: Bravo-X USB Audio
Mixer type: Hardware
Number of channels:
Supported sample rate:
Board info
Manufacturer: LENOVO
Model: S10-3
Version: Lenovo
Firmware Version: -
CPU info
Brand: Atom⢠N455
Speed: 1.66Ghz
Number of cores: 2
Physical cores: 1
Average load: 34%
Temperature: 70°C
Memory info
Memory: 999516 Ko
Free: 90184 Ko
Used: 909332 Ko
Storage info
INTERNAL storage - Size: 230081Mo
Used: 69000Mo
Available for storage: 149324Mo (65%)
Close
Had a quick look at your log, quite a number of acpi errors, meaning parts of hardware components were not recognized/ initialised and the Xorg display manager failed to start. You only have a terminal interface at the moment. I will have a closer look tomorrow, but as said, there is not much I can do.
It would be extremely interesting to know whether the beta version, as pointed to in my previous post, makes a difference.
@wheaten: could you please move this conversation to the proper place? Thanks.
