@gkkpch
Hi GĂ©, a nice one for you.
Trying to install Volumio V3.349 on Dell Latitude 3189.
Also tried with other version, same problem (V0.620, V3.224).
For some reason I am unable to get WiFi ( Dual Band Wireless-AC 7265) working. After installation Itâs shows the hot spot, so WiFi card seems to be detected, but in no way it will display the access point.
If I use the installation from a different laptop, it connect to WiFi once, but after reboot the available access points wonât show.
Same if I use a dongle like the TP-LINK, it wonât dispaly any access point, while the dongle works on other installations.
Since this laptop has no eth0, not sure how to debug
sudo lshw
volumiorc
description: Notebook
product: Latitude 3189 (07B3)
vendor: Dell Inc.
serial: GJHGSN2
width: 64 bits
capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
configuration: boot=normal chassis=notebook family=Latitude sku=07B3 uuid=44454C4C-4A00-1048-8047-C7C04F534E32
*-core
description: Motherboard
product: 0VG3TM
vendor: Dell Inc.
physical id: 0
version: A00
serial: /GJHGSN2/CNCMK0085C017A/
*-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: 1.18.0
date: 03/23/2022
capacity: 16MiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppynec int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi
*-memory
description: System Memory
physical id: 37
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 Synchronous 1866 MHz (0.5 ns)
product: 0
vendor: 0
physical id: 0
serial: 0
slot: ChannelA-DIMM0
width: 64 bits
clock: 1866MHz (0.5ns)
*-bank:1
product: 0
vendor: 0
physical id: 1
serial: 0
slot: ChannelB-DIMM0
width: 64 bits
*-bank:2
product: 0
vendor: 0
physical id: 2
serial: 0
slot: ChannelC-DIMM0
width: 64 bits
*-bank:3
product: 0
vendor: 0
physical id: 3
serial: 0
slot: ChannelD-DIMM0
width: 64 bits
*-cache:0
description: L1 cache
physical id: 3d
slot: CPU Internal L1
capacity: 224KiB
capabilities: synchronous internal write-back
configuration: level=1
*-cache:1
description: L2 cache
physical id: 3e
slot: CPU Internal L2
capacity: 2MiB
capabilities: synchronous internal write-back unified
configuration: level=2
*-cpu
description: CPU
product: Intel(R) Pentium(R) CPU N4200 @ 1.10GHz
vendor: Intel Corp.
physical id: 3f
bus info: cpu@0
version: Intel(R) Pentium(R) CPU N4200 @ 1.10GHz
slot: SOCKET 0
capacity: 2500MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch cpuid_fault cat_l2 ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust smep erms mpx rdt_a rdseed smap clflushopt intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts md_clear arch_capabilities cpufreq
configuration: cores=4 enabledcores=4 threads=4
*-pci
description: Host bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 0b
width: 32 bits
clock: 33MHz
*-generic:0
description: Signal processing controller
product: Intel Corporation
physical id: 0.1
bus info: pci@0000:00:00.1
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=proc_thermal latency=0
resources: irq:24 memory:92210000-92217fff
*-display
description: VGA compatible controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Integrated Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:125 memory:91000000-91ffffff memory:80000000-8fffffff ioport:f000(size=64) memory:c0000-dffff
*-multimedia:0 UNCLAIMED
description: Multimedia controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Imaging Unit
physical id: 3
bus info: pci@0000:00:03.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm cap_list
configuration: latency=0
resources: memory:90000000-90ffffff
*-multimedia:1
description: Audio device
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster
physical id: e
bus info: pci@0000:00:0e.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:127 memory:92218000-9221bfff memory:92000000-920fffff
*-communication
description: Communication controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Trusted Execution Engine
physical id: f
bus info: pci@0000:00:0f.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:124 memory:92248000-92248fff
*-generic:1 UNCLAIMED
description: Unclassified device
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Integrated Sensor Hub
physical id: 11
bus info: pci@0000:00:11.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm cap_list
resources: memory:9221e000-9221ffff memory:92245000-92245fff
*-sata
description: SATA controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SATA AHCI Controller
physical id: 12
bus info: pci@0000:00:12.0
logical name: scsi0
version: 0b
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list emulated
configuration: driver=ahci latency=0
resources: irq:122 memory:9221c000-9221dfff memory:92244000-922440ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:92243000-922437ff
*-disk
description: ATA Disk
product: SanDisk X600 M.2
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 3012
serial: 180650802400
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=f6aeca72-59e5-4aa0-9e9b-46b782d12df4 logicalsectorsize=512 sectorsize=512
*-volume:0
description: Windows FAT volume
vendor: SYSLINUX
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /boot
version: FAT32
serial: 6e69-9864
capacity: 170MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat label=boot mount.fstype=vfat mount.options=rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=utf8,shortname=mixed,utf8,errors=remount-ro name=primary state=mounted
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /imgpart
version: 1.0
serial: cd97bbbd-aff7-48df-96c8-c68801f91c5d
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2023-04-03 21:36:38 filesystem=ext4 label=volumio lastmountpoint=/mnt/imgpart modified=2023-04-04 16:22:45 mount.fstype=ext4 mount.options=rw,relatime mounted=2023-04-04 16:22:45 name=primary state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
version: 1.0
serial: dca6d9f6-0d87-4e88-9b62-45a16170a4ac
configuration: created=2023-04-03 21:36:38 filesystem=ext4 label=volumio_data lastmountpoint=/mnt/ext/union modified=2023-04-03 21:52:25 mounted=2023-04-03 21:52:25 name=primary state=clean
*-pci
description: PCI bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #1
physical id: 13
bus info: pci@0000:00:13.0
version: fb
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:120 memory:92100000-921fffff
*-network
description: Wireless interface
product: Wireless 7265
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlan0
version: 61
serial: 7c:76:35:75:65:52
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.10.165-volumio firmware=29.4063824552.0 7265D-29.ucode ip=192.168.211.1 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:126 memory:92100000-92101fff
*-usb
description: USB controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series USB xHCI
physical id: 15
bus info: pci@0000:00:15.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:121 memory:92200000-9220ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.10.165-volumio xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 5.10
capabilities: usb-2.00
configuration: driver=hub slots=8 speed=480Mbit/s
*-usb:0 UNCLAIMED
description: Video
product: Integrated Webcam
vendor: CNFFH36O14141006FBA2
physical id: 4
bus info: usb@1:4
version: 65.10
serial: 0x0001
configuration: maxpower=500mA speed=480Mbit/s
*-usb:1
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 6
bus info: usb@1:6
version: 0.03
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usb:2
description: Human interface device
product: Pen and multitouch sensor
vendor: Wacom Co.,Ltd.
physical id: 7
bus info: usb@1:7
version: 61.04
configuration: driver=usbhid maxpower=400mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.10
capabilities: usb-3.00
configuration: driver=hub slots=7 speed=5000Mbit/s
*-generic:2
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #1
physical id: 16
bus info: pci@0000:00:16.0
version: 0b
width: 64 bits
clock: 33MHz
configuration: driver=intel-lpss latency=0
resources: irq:27 memory:92242000-92242fff memory:92241000-92241fff
*-generic:3
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #2
physical id: 16.1
bus info: pci@0000:00:16.1
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:28 memory:92240000-92240fff memory:9223f000-9223ffff
*-generic:4
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #3
physical id: 16.2
bus info: pci@0000:00:16.2
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:29 memory:9223e000-9223efff memory:9223d000-9223dfff
*-generic:5
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #4
physical id: 16.3
bus info: pci@0000:00:16.3
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:30 memory:9223c000-9223cfff memory:9223b000-9223bfff
*-generic:6
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #5
physical id: 17
bus info: pci@0000:00:17.0
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:31 memory:9223a000-9223afff memory:92239000-92239fff
*-generic:7
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #6
physical id: 17.1
bus info: pci@0000:00:17.1
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:32 memory:92238000-92238fff memory:92237000-92237fff
*-generic:8
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #7
physical id: 17.2
bus info: pci@0000:00:17.2
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:33 memory:92236000-92236fff memory:92235000-92235fff
*-generic:9
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #8
physical id: 17.3
bus info: pci@0000:00:17.3
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:34 memory:92234000-92234fff memory:92233000-92233fff
*-generic:10
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #1
physical id: 18
bus info: pci@0000:00:18.0
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:4 memory:92232000-92232fff memory:92231000-92231fff
*-generic:11
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #2
physical id: 18.1
bus info: pci@0000:00:18.1
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:5 memory:92230000-92230fff memory:9222f000-9222ffff
*-generic:12 UNCLAIMED
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #3
physical id: 18.2
bus info: pci@0000:00:18.2
version: 0b
width: 64 bits
clock: 33MHz
resources: memory:92246000-92246fff memory:92247000-92247fff
*-generic:13
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #4
physical id: 18.3
bus info: pci@0000:00:18.3
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:7 memory:9222e000-9222efff memory:9222d000-9222dfff
*-generic:14
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #1
physical id: 19
bus info: pci@0000:00:19.0
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:35 memory:9222c000-9222cfff memory:9222b000-9222bfff
*-generic:15
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #2
physical id: 19.1
bus info: pci@0000:00:19.1
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:36 memory:9222a000-9222afff memory:92229000-92229fff
*-generic:16
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #3
physical id: 19.2
bus info: pci@0000:00:19.2
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:37 memory:92228000-92228fff memory:92227000-92227fff
*-generic:17
description: SD Host controller
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SDXC/MMC Host Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 0b
width: 64 bits
clock: 33MHz
configuration: driver=sdhci-pci latency=0
resources: irq:3 memory:92226000-92226fff memory:92225000-92225fff
*-generic:18
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series eMMC Controller
physical id: 1c
bus info: pci@0000:00:1c.0
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:39 memory:92224000-92224fff memory:92223000-92223fff
*-generic:19
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SDIO Controller
physical id: 1e
bus info: pci@0000:00:1e.0
version: 0b
width: 64 bits
clock: 33MHz
resources: irq:42 memory:92222000-92222fff memory:92221000-92221fff
*-isa
description: ISA bridge
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Low Pin Count Interface
physical id: 1f
bus info: pci@0000:00:1f.0
version: 0b
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
configuration: driver=lpc_ich latency=0
resources: irq:0
*-serial
description: SMBus
product: Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SMBus Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
version: 0b
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:-2147483648 memory:92220000-922200ff ioport:f040(size=32)
*-pnp00:00
product: PnP device PNP0c02
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0303
physical id: 2
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:02
product: PnP device DLL07b3
physical id: 3
capabilities: pnp
configuration: driver=i8042 aux
*-pnp00:03
physical id: 4
capabilities: pnp
*-pnp00:04
product: PnP device PNP0b00
physical id: 5
capabilities: pnp
configuration: driver=rtc_cmos
*-battery
product: DELL CYMGM84
vendor: Samsung SDI
physical id: 1
version: 04/06/2018
serial: E980
slot: Sys. Battery Bay
capacity: 41990mWh
configuration: voltage=11.4V
inxi -Fxxxz
System:
Host: volumiorc Kernel: 5.10.165-volumio x86_64 bits: 64 compiler: N/A
Console: tty 0 dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine:
Type: Laptop System: Dell product: Latitude 3189 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VG3TM v: A00 serial: <filter> UEFI: Dell v: 1.18.0
date: 03/23/2022
Battery:
ID-1: BAT0 charge: 17.9 Wh condition: 22.8/42.0 Wh (54%) volts: 12.0/11.4
model: Samsung SDI DELL CYMGM84 type: Li-ion serial: <filter>
status: Discharging
CPU:
Topology: Quad Core model: Intel Pentium N4200 bits: 64 type: MCP
arch: Goldmont rev: 9 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8755
Speed: 1048 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 1492 2: 953
3: 2388 4: 2410
Graphics:
Device-1: Intel Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series
Integrated Graphics
vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5a84
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa
tty: 80x59
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
Imaging Unit
vendor: Dell driver: N/A bus ID: 00:03.0 chip ID: 8086:5a88
Device-2: Intel Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series
Audio Cluster
vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:0e.0
chip ID: 8086:5a98
Sound Server: ALSA v: k5.10.165-volumio
Network:
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040
bus ID: 01:00.0 chip ID: 8086:095a
IF: wlan0 state: up mac: <filter>
Drives:
Local Storage: total: 119.24 GiB used: 945.4 MiB (0.8%)
ID-1: /dev/sda vendor: SanDisk model: X600 M.2 2280 SATA 128GB
size: 119.24 GiB speed: 6.0 Gb/s serial: <filter> rev: 3012 scheme: GPT
Partition:
ID-1: / size: 113.33 GiB used: 39.7 MiB (0.0%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 61.2 MiB (36.3%) fs: vfat dev: /dev/sda1
Sensors:
Missing: Required tool sensors not installed. Check --recommends
Info:
Processes: 156 Uptime: 1h 22m Memory: 3.68 GiB used: 479.3 MiB (12.7%)
Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A
Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge (rev 0b)
00:00.1 Signal processing controller: Intel Corporation Device 5a8c (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Integrated Graphics Controller (rev 0b)
00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Imaging Unit (rev 0b)
00:0e.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster (rev 0b)
00:0f.0 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Trusted Execution Engine (rev 0b)
00:11.0 Unclassified device [0050]: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Integrated Sensor Hub (rev 0b)
00:12.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SATA AHCI Controller (rev 0b)
00:13.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #1 (rev fb)
00:15.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series USB xHCI (rev 0b)
00:16.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #1 (rev 0b)
00:16.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #2 (rev 0b)
00:16.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #3 (rev 0b)
00:16.3 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #4 (rev 0b)
00:17.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #5 (rev 0b)
00:17.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #6 (rev 0b)
00:17.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #7 (rev 0b)
00:17.3 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #8 (rev 0b)
00:18.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #1 (rev 0b)
00:18.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #2 (rev 0b)
00:18.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #3 (rev 0b)
00:18.3 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #4 (rev 0b)
00:19.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #1 (rev 0b)
00:19.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #2 (rev 0b)
00:19.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #3 (rev 0b)
00:1b.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SDXC/MMC Host Controller (rev 0b)
00:1c.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series eMMC Controller (rev 0b)
00:1e.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SDIO Controller (rev 0b)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Low Pin Count Interface (rev 0b)
00:1f.1 SMBus: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SMBus Controller (rev 0b)
01:00.0 Network controller: Intel Corporation Wireless 7265 (rev 61)
Log file with connected TP-LINK:
http://logs.volumio.org/volumio/iX33PMq.html
Unable to generate a log file after reboot as it wonât connect to te network anymoreâŠ
