Volumio version: “2.917”
HW: Raspberry Pi 3 Model B Plus Rev 1.3
OS: “Raspbian GNU/Linux 8 (jessie)”
Could the problem be related to what the journal reports hereafter
volumio@volumio:~$ sudo journalctl -p 3
-- Logs begin at Sat 2021-11-20 10:41:07 UTC, end at Sat 2021-11-20 10:54:33 UTC. --
Nov 20 10:41:08 volumio kernel: snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
Nov 20 10:41:08 volumio kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Nov 20 10:41:08 volumio kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
Nov 20 10:41:09 volumio kernel: Under-voltage detected! (0x00050005)
Nov 20 10:41:11 volumio kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
Nov 20 10:41:13 volumio systemd-udevd[778]: failed to execute '/usr/bin/hciconfig' '/usr/bin/hciconfig hci0 up': No such file or directory
Nov 20 10:41:17 volumio ntpd_intres[835]: host name not found: 0.debian.pool.ntp.org
Nov 20 10:41:17 volumio ntpd_intres[835]: host name not found: 1.debian.pool.ntp.org
Nov 20 10:41:17 volumio ntpd_intres[835]: host name not found: 2.debian.pool.ntp.org
Nov 20 10:41:17 volumio ntpd_intres[835]: host name not found: 3.debian.pool.ntp.org
Nov 20 10:41:19 volumio winbindd[882]: [2021/11/20 10:41:19.345611, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 20 10:41:19 volumio winbindd[882]: Unable to open new log file '/var/log/samba/log.winbindd': No such file or directory
Nov 20 10:41:19 volumio winbindd[882]: [2021/11/20 10:41:19.347309, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 20 10:41:19 volumio winbindd[891]: [2021/11/20 10:41:19.414095, 0] ../source3/winbindd/winbindd_cache.c:3235(initialize_winbindd_cache)
Nov 20 10:41:19 volumio winbindd[891]: initialize_winbindd_cache: clearing cache and re-creating with version number 2
Nov 20 10:41:19 volumio nmbd[885]: [2021/11/20 10:41:19.425773, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 20 10:41:19 volumio nmbd[885]: Unable to open new log file '/var/log/samba/log.nmbd': No such file or directory
Nov 20 10:41:19 volumio nmbd[885]: [2021/11/20 10:41:19.428716, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 20 10:41:19 volumio nmbd[894]: [2021/11/20 10:41:19.434394, 0] ../source3/nmbd/asyncdns.c:157(start_async_dns)
Nov 20 10:41:19 volumio nmbd[894]: started asyncdns process 895
Nov 20 10:41:19 volumio nmbd[894]: [2021/11/20 10:41:19.439800, 0] ../lib/util/become_daemon.c:135(daemon_status)
Nov 20 10:41:19 volumio nmbd[894]: STATUS=daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...NOTE: NetBIOS name resolutio
Nov 20 10:41:19 volumio winbindd[891]: [2021/11/20 10:41:19.468574, 0] ../lib/util/become_daemon.c:124(daemon_ready)
Nov 20 10:41:19 volumio winbindd[891]: STATUS=daemon 'winbindd' finished starting up and ready to serve connections
`WARNING!!! Some remote endpoints cannot be reached!
Failing endpoints:
https://oauth-performer.dfs.volumio.org, 5235 ms
https://browsing-performer.dfs.volumio.org, 5235 ms
https://radio-directory.firebaseapp.com, 5235 ms`
I dont see any message from mpd that decoder is too slow
here is the output of the command
cat /home/volumio/mpd_radio_fix.sh
#!/bin/bash
while :
do
OUT=$(tail -n 1 /var/log/mpd.log)
if [[ $OUT == *"Decoder is too slow"* ]]; then
/usr/bin/mpc stop
fi
sleep 1
done
Please can you be careful with quotes … your last post doesn’t make sense.
You might not think that “mpd_radio_fix.sh” isn’t causing your problems, but surely it would be sensible to remove or disable the script to test. You have introduced a non-standard script into Volumio, which makes debugging problematical. Try:
Are you sure you are running a stock Volumio image?
Perhaps, list out all the mods you have carried out aswell so we can trouble shoot better
Or better yet, use a fresh install and confirm if your issues come from the installed mods?
OK, so we are seeing the “Nov 22 07:06 : player: Decoder is too slow; playing silence to avoid xrun” errors, which is why you were running the mpd_radio_fix.service presumably … but this doesn’t sort the problem. I don’t know the cause of this error … hopefully some one else will chip in here.
You’re still using the same source though. Can you try another radio stream (from a different provider) please?
Edit: As @asthespy says, a fresh install with no modifications would be useful.
Edit 2: I’ve read the whole of the original thread that sparked your “fix” now, and it is obviously a strange one that is difficult to reproduce on every system. Also, the number of people affected seems relatively small … I wasn’t aware of it as a problem at all from forum posts. One suggestion, which no one seemed to try, was to use a later version of MPD … have a go with Volumio3, and see how you get on with that (with your source for which you are seeing the problem).
I have installed on Pi an official volumio image 1 year and did regularly volumio upgrades. I recently upgraded using the Volumio UI the version to 2.917
