Could you please provide some more details about the procedure? I had a look but it’s not very clear to me.
Sure, say the plugin is GPIO Buttons - this is probably the error you get:
error: The plugin system_controller/gpio-buttons failed to load, setting it to stopped. Error: Error: The module '/data/p
May 27 10:09:41 volumio volumio[722]: was compiled against a different Node.js version using
May 27 10:09:41 volumio volumio[722]: NODE_MODULE_VERSION 57. This version of Node.js requires
May 27 10:09:41 volumio volumio[722]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
So we need to recompile the native module epoll
that is used to access the sys class…
# pick up some build tools
sudo apt install build-essential
cd /data/plugins/system_controller/gpio-buttons/
# Update the ancient onoff so that you can use epoll@4.0.0
npm install --save onoff@6.0.0
# Restart volumio
volumio vrestart
That should work, hopefully there aren’t many breaking changes in onoff’s api from 1.xx to 6.xx
I believer there were a few more minor api fixes I had to do for onoff (to work with the Ampswitch plugin) but I won’t be near that device for a few weeks to check and confirm.
Thanks for the clear instructions, I followed them for both plugins and those are the results:
GPIO-Buttons can be enabled and works fine
GPIO-Control can’t be enabled
volumio[1638]: info: Enabling plugin gpio_control
volumio[1638]: info: Loading plugin "gpio_control"...
volumio[1638]: error: !!!! WARNING !!!!
volumio[1638]: error: The plugin system_controller/gpio_control failed to load, setting it to stopped. Error: Error: The module '/data/plugins/system_controller/gpio_control/node_modules/sleep/build/Release/node_sleep.node'
volumio[1638]: was compiled against a different Node.js version using
volumio[1638]: NODE_MODULE_VERSION 57. This version of Node.js requires
volumio[1638]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
volumio[1638]: the module (for instance, using `npm rebuild` or `npm install`).
volumio[1638]: error: Stack trace: Error: The module '/data/plugins/system_controller/gpio_control/node_modules/sleep/build/Release/node_sleep.node'
GPIO-Control can’t be enabledvolumio[1638]: info: Enabling plugin gpio_control volumio[1638]: info: Loading plugin "gpio_control"... volumio[1638]: error: !!!! WARNING !!!! volumio[1638]: error: The plugin system_controller/gpio_control failed to load, setting it to stopped. Error: Error: The module '/data/plugins/system_controller/gpio_control/node_modules/sleep/build/Release/node_sleep.node' volumio[1638]: was compiled against a different Node.js version using volumio[1638]: NODE_MODULE_VERSION 57. This version of Node.js requires volumio[1638]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing volumio[1638]: the module (for instance, using `npm rebuild` or `npm install`). volumio[1638]: error: Stack trace: Error: The module '/data/plugins/system_controller/gpio_control/node_modules/sleep/build/Release/node_sleep.node' volumio[1638]: was compiled against a different Node.js version using volumio[1638]: NODE_MODULE_VERSION 57. This version of Node.js requires volumio[1638]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing volumio[1638]: the module (for instance, using `npm rebuild` or `npm install`).
Looks like you fixed onoff
module, but the sleep
module also needs to be rebuilt
You could first try rebuilding the existing module
cd /data/plugins/system_controller/gpio_control/
# Rebuild the existing modules - Hopefully onoff has already been upgraded at this stage do confirm from package.json
npm rebuild
# Which will probably fail to build and spit out nan and v8 errors - you might have to bump up the `sleep` package similarly
npm install --save onoff@6.2.0
PS: I can’t find the authors repo - but they could all switch to the newer versions of onoff/epoll/sleep while maintaining current and future compatibility…
I think there is a typo in your instructions, it should be this:
npm install --save sleep@6.2.0
BTW, with this additional step the plugin is working
Any other test you would like to have?
Oops, sorry!
That is an interesting stack you got there - any posts about it?
It’s the stack I’m using for testing your Volumio builds
- Raspberry Pi Zero
- Waveshare USB Hat (4 USB and USB-to-UART)
- Home-made hat with 2x TFA9879 (I2S amplifiers), 2x SPH0645LM4H-B (I2S microphones), 1x RGB LED and 1x push button
The home-made hat was a hobby project I did while working at NXP. TFA9879 is a nice amplifier with HW volume control and HW equalizer. driver is already available in mainline kernel, but unfortunately I’m not able to create a proper dt-overlay for supporting it.
If someone is interested I can publish full design, several chinese manufacturers can produce few pieces (PCB+assembly) for little money.
Can we have a new build please? The latest release (26-5 - https://forum.volumio.org/changelog-t1575.html) has the volume issue resolved.
cheers
cheers
Hmm - if you are referring to to this fix (github.com/volumio/Volumio2/pull/1961) then it is already in there…
cd /volumio
git fetch --unshallow
git log
Hi Volumio team
Here is some feedback on the latest build Volumio-3.008-2020-05-23-raspberry, running on Raspberry Pi 3B+ with 7" official touchscreen and IQaudio DAC Pro.
- The kernel boot messages were displayed, no silent boot nor plymouth. I guess that was to be expected since it’s a testing image
- I have connected to the Volumio automatic Wifi hotspot without problem and successfully accessed the Web GUI through the MDNS hostname (volumio.local)
It seems to be absolutely fine on this first run. I’ll come back and post more if I encounter problems.
I look forward to this Buster release !
EDIT : it looks like the chromium-browser package doesn’t install properly for the touchscreen plugin. See the logs : https://pastebin.com/s6hidykE. The package manager chooses to remove Chromium at the end, and the install hangs there.
EDIT 2 : It seems to be because of a wrongly defined dependency on libraspberrypi0. See this log : https://pastebin.com/V3nHYVQA
It seems to be because of a wrongly defined dependency on libraspberrypi0. See this log : chromium-browser broken dependencies - Pastebin.com
Looks like chromium
depends on chromium-codecs-ffmpeg-extra
and chromium-codecs-ffmpeg
which depends on libraspberrypi0
( and thus on raspberrypi-kernel
which is currently pinned)
Are these codecs optional dependencies? I don’t have access to my pi right now, but does it help trying to install with the --no-install-recommends
flag?
Either way, you can always disable this pinning (as with kodi) and it should install
volumio@volumio:~$ sudo mv /etc/apt/preferences.d/raspberrypi-kernel ./ volumio@volumio:~$ apt-get install kodi
The second hack works to complete the installation. But now I have rebooted into a kernel panic.
That’s not good! Could you pop your SD out and check if /boot/config.txt
is empty?
@SuperBoby To me it seems the install script of the touch display plugin does not recognize that it is running on a Pi. In its line 3 the install script determines the hardware it is running on with HW=$(awk '/VOLUMIO_HARDWARE=/' /etc/*-release | sed 's/VOLUMIO_HARDWARE=//' | sed 's/\"//g')
. Only if the result is “pi” the required libraspberrypi0_0.0.1_all.deb, raspberrypi-bootloader_0.0.1_all.deb and raspberrypi-kernel_0.0.1_all.deb are installed.
Further more chromium vesion would be 56.0.2924.84 (at least on the current jessie based Volumio version) and not 48.0.2564.82-0. The package chromium-browser_48.0.2564.82-0ubuntu0.15.04.1.1193_armhf.deb only gets downloaded if the hardware is not “pi”. Same goes for chromium-codecs-ffmpeg-extra_48.0.2564.82-0ubuntu0.15.04.1.1193_armhf.deb.
Hmm, that is my doing. I found pi
to ambiguous a name when building the images, and instead called it:
VOLUMIO_HARDWARE="raspberry"
VOLUMIO_DEVICENAME="Raspberry Pi"
I just tried installing the chromium-browser
, and phew that is a LOT of stuff for just a browser
So after ~1Gig of packages this is what I have:
volumio@volumio:~$ uname -a
Linux volumio 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
volumio@volumio:~$ cat /proc/cpuinfo | grep Model
Model : Raspberry Pi 4 Model B Rev 1.1
volumio@volumio:~$ apt list --installed | grep chromium
chromium-browser-l10n/testing,now 78.0.3904.108-rpt1 all [installed,automatic]
chromium-browser/testing,now 78.0.3904.108-rpt1 armhf [installed]
chromium-codecs-ffmpeg-extra/testing,now 78.0.3904.108-rpt1 armhf [installed,automatic]
[OT Rant]
We should have a common way to figure out what hardware Volumio is running on, there seems to be a lot of glue code sprinkled around to do this. Even the Node backend doesn’t have this streamlined…
From the shell, it could be as simple as:
source /etc/os-release
echo $VOLUMIO_HARDWARE
[/OT Rant]
If VOLUMIO_HARDWARE
is “raspberry” the hardware detection of the plugin will fail for, well, raspberries. The help documentation in the build script defines the names of the different hardware platforms. That’s what the plugin’s install script relies on.
+1 on a establishing a common way to figure out the hardware - albeit I think that’s what VOLUMIO_HARDWARE
is/was intended for
If
VOLUMIO_HARDWARE
You’re 100% right, hopefully I can convince everyone everyone to use raspberry
now and cause more churn through the Volumio ecosystem
I have managed to get chromium-browser
installed and the device survives reboots with no kernel panics. But I don’t have access to a mirco HDMI cable for the pi4 to test the plugin itself. I’ll try patching the pi/raspberry
later this week and see if the fake libraspberrypi0
packages work!
Sorry I did not have time to look into this after my last report. Do you need more information on the current state of my SD card ? I haven’t touched it since. Shall I wait for a new image to test this again ?
/boot/config.txt
is empty?
Just this for now should suffice
Well, not really – there isn’t really anything new that need a new image + I’m running out of space of my Google Drive…
/boot/config.txt
contains :
# Disable audio (added by raspberrypi-sys-mods)
dtparam=audio=no
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
enable_uart=1
include userconfig.txt
dtoverlay=iqaudio-dacplus,unmute_amp
/boot/userconfig.txt
contains :
dtoverlay=pi3-miniuart-bt
So how should I work around this confusion about $VOLUMIO_HARDWARE
