Currently the GPIO buttons and push button in Rotary encoder ain’t working. These plugins needs to be rewritten in order to support the change Raspberry made in Kernel 6.6 to the GPIO.
ver 3.759
does not fill the 1920x1080 screen.
Peppymeter - reduced screen,
Now playing - reduced screen.
Data not touched in userconfig.txt.
RPi4
In one word - it decalibrates plugins
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=2
the same for three years
Hey @Gelo5,
Can you edit volumioconfig.txt and change:
display_auto_detect=1
to
display_auto_detect=0
Test after reboot if it makes a difference.
Hey @nerd , unfortunately the same
Hey @Gelo5,
Let’s take a look at this. Full HD 1920x1080 (16x9 ratio) should not need any special parameters, as this is a standard CVT class 4.15.
Changes in the 3.759 are mainly for DRM/KMS DSI/SPI attached displays autodetection, HDMI has not been changed. There are two parameters modified in the volumioconfig.txt though.
Please execute two tests:
Test 1 (full autodetect):
Revert to display_auto_detect=1 in volumioconfig.txt and comment out all screen handling parameters in userconfig.txt.
Test 2 (manual settings):
Comment out lines dtoverlay=vc4-kms-v3d and display_auto_detect=1 in [all] subsection in the volumioconfig.txt and revert changes back in your userconfig.txt
Hey @nerd again
Test 1 - it didn’t work
Test2 - extra, super, hyper. Works as it should
Thank you very much and best regards
Hey @Gelo5,
If you can conduct one more regression test:
Uncomment only display_auto_detect=1 in [all] subsection in the volumioconfig.txt and check after reboot.
Yes @nerd -
It also works fine. It must be the driver
update to 3.759 touchscreen does not turn on.
raspberry pi5 7.9 inch HDMI waveshare.
also error connecting to xserver, happens when off and on plugin.
http://logs.volumio.org/volumio/kyE7t5h.html
Hey @michel8166
It seems we have regression in 3.759
Comment out line dtoverlay=vc4-kms-v3d in [all] subsection in the volumioconfig.txt
Updated build is underway and will be available shortly.
I don’t see that rule anywhere.
ahh volumioconfig.txt.
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
gpu_mem=128
gpu_mem_256=32
gpu_mem_512=32
gpu_mem_1024=128
max_usb_current=1
[pi5]
usb_max_current_enable=1
[all]
include volumioconfig.txt
include userconfig.txt
dtoverlay=hifiberry-dacplus-pro
userconfig
# Add your custom config.txt options to this file, which will be preserved duri$
# ian canada FifoPI MA
#dtoverlay=hifiberry-dacplus
#dtparam=i2c_arm_baudrate=1000000
# power off button
dtoverlay=gpio-shutdown,gpio_pin=13
#dtoverlay=gpio-shutdown,gpio_pin=13,active_low=1,gpio_pull=up=gpio-shutdown
# led + op gpio-5 en massa
gpio=5=op,dh
display_lcd_rotate=3
display_hdmi_rotate=3
doesn’t work, have rebooted and turned off.
I’m updating now.
[cm4]
dtoverlay=dwc2,dr_mode=host
otg_mode=1
[pi5]
dtparam=nvme
dtparam=pciex1_gen=2
[all]
#dtoverlay=vc4-kms-v3d
arm_64bit=0
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
3.759 - 3.761 (OTA) - everything works
@nerd I updated to v3.761, no success, 7.9 inch screen does not turn on.
in the meantime also updated the touch plugin to beta 3.5.1, also no success.
3.761 is available via OTA? Is it beta release ?
Beta
RPI5 8Go OTA 3.761 ok but HDMI screen dead
Oct 11 19:33:09 volumio-rpi5 volumio[1253]: error: touch_display: Connecting to the Xserver failed.
Oct 11 19:33:09 volumio-rpi5 volumio[1253]: info: touch_display: X display number found:
Oct 11 19:33:09 volumio-rpi5 startx[3812]: X.Org X Server 1.20.4
Oct 11 19:33:09 volumio-rpi5 startx[3812]: X Protocol Version 11, Revision 0
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Current Operating System: Linux volumio-rpi5 6.6.47-v8+ #1792 SMP PREEMPT Thu Aug 22 15:11:43 BST 2024 aarch64
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:59:25:94 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=UUID=7462f9ec-50f6-4f55-9f22-79cca1bee42a imgfile=/volumio_current.sqsh bootpart=UUID=6B37-2179 datapart=UUID=2294ffa2-8d99-43b5-b51e-8c72e51d7736 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Build Date: 04 April 2023 07:50:56AM
Oct 11 19:33:09 volumio-rpi5 startx[3812]: xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Current version of pixman: 0.36.0
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Before reporting problems, check http://wiki.x.org
Oct 11 19:33:09 volumio-rpi5 startx[3812]: to make sure that you have the latest version.
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Markers: (--) probed, (**) from config file, (==) default setting,
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (++) from command line, (!!) notice, (II) informational,
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 11 19:33:09 2024
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (EE)
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Fatal server error:
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (EE) no screens found(EE)
Oct 11 19:33:09 volumio-rpi5 startx[3812]: Please consult the The X.Org Foundation support
Oct 11 19:33:09 volumio-rpi5 startx[3812]: at http://wiki.x.org
Oct 11 19:33:09 volumio-rpi5 startx[3812]: for help.
Oct 11 19:33:09 volumio-rpi5 startx[3812]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
