I bought the new Hifiberry Amp 3, which needs a 5.15.67 kernel to work fine.
Can anyone give me the last kernel version used by Volumio on TEST channel ?
(Maybe the hifiberry driver can be backported to Volumio kernel, I don’t know…)
Volume control seems to me a top level control. You’ve moved it to second level. Also, I often change volume, but can no longer do so with my phone or computer controls. Instead I have to go one layer down and use hand or mouse to adjust. Finally, showing volume meter really helps me. I have my receiver set at a fairly high volume and use the software control to modulate using numeric cues. No longer possible.
there’s a 3.381 on the update server.
Could anyone please inform about the differences between 3.378 and 3.381?
Best regads,
Robert
Link to changelog lists it.
Regards,
3.381 is not included in the changelog.
I assume it’s a test version for a restricted group of testers.
@Robert.Hecht You’re correct, I got v3.381 after switching on the “Test Mode” here as suggested for beta testing. The main difference, if I recall correctly, was making the Manifest UI available for Free users as opposed to Premium. The current version available in the download link is still 3.378, which is the one listed in the change log.
Regards,
Any word on Airplay2?
Indeed! Couldn’t have expressed this better! This is actually one of the major challenges that we face, considering how complex and vertical an ecosystem like Volumio is.
Just re evaluating Volumio after a long break (Moode Audio) it’s going well and I am closer than ever to subscribe to myvolumio (Moode died for me when it locked my Pi up for the 100th time), but I can’t believe an A-Z on the library album list is not visible. I have a very large library and scrolling down the list every time is pants.
Am I doing something wrong here?
Every other player out there has that feature.
