Hi Robert,
ok - not professional - but i do other things than changing background images with that system and therefore i am still happy with it with just playing music…
Best Regards
Josef
different users - different requirements
Hi Robert,
Best Regards
Josef
Keep in mind with new development/releases, running in sprints, there is always the question, Is it a showstopper? Just some minor defects, should not prohibit a new release. (even though some might be very annoying in your case).
What’s more important is that Volumio publish their findings on reported defects, which I have requested a couple of times. So the testers see that their feedback is evaluated or even confirmed.
Because of the lack of this, testers like yourself, get the impression they are doing this for nothing.
(or in proper Dutch: Voor de kat zijn viool “For the cats violin”
Just something simple like:
Solved in this release:
Reported defects:
Confirmed defects:
Scheduled for next release:
you speak out of my mind
and again - the link to the change log doesn’t contain information to changes since the last version.
How do you think i could get my friends into Volumio this way ?
From what I saw, there was hardly any feedback from x86 users.
Not sure either how much x86 testing is done by the volumio team before releasing.
not sure if the volumio team is interested in that any longer - but i promise to do with the DELL device i got from you.
Unfortunately i am also short in time due to the current political crisis.
BR
Josef
I haven’t done any reporting for the x86 image (Dell wyse 3040), as this is my very basic all day player.
I haven’t been able to get it wrong, so for me the image is perfect.
Only a NFS connection
USB DAC (Project Pre-Box S2 Digital)
Qobuz
Spotify
Custom radio streams, with a manipulated webradio/index.js to display custom art work.
And a few plugins:
hey @Wheaten
that would be a bummer to know how you modded webradio/index.js - please
x86 is still an officially supported platform.
I maintain the x86 kernel (though not being involved directly in volumio development). In case x86 was being dropped, I would have known.
Hi Josef,
I see your point, but losing my local music database in several testcases is an issue that I don’t want to bother all the other users of volumio.
Though missing texts in the UI might not be a show stopper, but accepting this issue again and again which may be fixed in less than an hour I think is not a good idea.
Cheers, Robert
Be aware it will break the OTA updates. You need to roll back the modification before you upgrade ![]()
So I have the original index.js renamed to index.js.bak. If I need to update I move it back.
results:
100% agreed
Sometimes it’s hard to understand what kind of issue is defined a showstopper or not and why.
Best regards,
Robert
I am not sure what the criteria for Volumio is.
But in my line of work, depending on the size of a project and what is in the pipeline:
Hello @Wheaten ,
I can see this criteria and they make sense of course. I know that most of the volumio developers are part time workers or have more than one project on their list. I definitely appreciate your dedication and your excellent work!
But in consequence this criteria will end up in:
Further I see a contradiction in the statement: “Playing HiFi music has first priority” and the fact “High bit rate playback via HDMI is not working.”
I definitely support the requirement informing the community in detail about the fixes and the known issues of every release that is published.
Cheers,
Robert
Hi Robert, I can understand your frustration but bugs are generally prioritized by how many are impacted, how serious the bug is and whether there is a workaround. If you are the only person who reported being affected by this (and it’s not a show stopper) while there are other issues being reported by dozens of testers, I think you can understand why your issue didn’t make the latest round of bug fixes. I hope it will be fixed soon. We all want to see a super stable Volumio
I am not working for Volumio, just a community visitor
Hi @Robert.Hecht,
I understand your frustration. You are putting in a lot of effort to test the releases, and we really appreciate that. You are providing a lot of detailed insight.
As @Wheaten correctly stated, we are working in sprints, which have a focus on specific features. Not every bug or issue is in the scope of a release.
I am currently making the backlog for the next hotfix release, and the next major release. I will make inventory of your issues and try to address them soon. You could help me with sending me a summary.
Again, thanx for your hard work! Cheers!
Mervin
Dear Robert,
please don’t think for a second that your reports were not taken into consideration.
I think that Wheaten and Mervinio explained very well the level of prioritization we have to do before a release is vetted, and hope that helps you understand where our focus goes.
Just one example: the fact that the UI crashes when an albumart is uploaded was deemed to be WONTFIX as with the new Manifest UI by default, there would be no background upload anymore.
But, since you seem to be happier with Contemporary UI, I am happy to tell that this issue was just fixed (it happened only on x64, when uploading a file more than 3MB):
Please keep on sending your fidings (all of the one you sent are now in our backlog of things to do) and we’ll try to do a better job communicating what we are prioritizing and why.
There are community visitors and then there is @Wheaten!
Hi them all,
thanks a lot for the volumi(n)ous discussion about testing, prioritization and considering test results.
It’s a pleasure to work with you all!
I’m looking forward to new versions with focus on stability and robustness as well as technical improvements.
@mervinio do you still need a summary?
Cheers, Robert
Hi Michelangelo,
in fact I switch between the UI schemes - on a smaller display I like the “Classic” - on a larger display “Contemporary” fits my needs and sometimes I try “Manifest” as well. Excellent that you could fix the upload issue in Contemporary background image dialog! I hope it had no further causes - I did not try to copy files to the local storage via smb while music was playing… I consider this as a test case for the next beta phase.
Have fun,
Robert
