USB DAC compatibility List
Receiver:?
DAC: AK4490
Async:?
Working with Volumio: No
Tested Versions and Platforms:Raspberry Pi 4, Volumio 2.907
Hardware Mixer on Volumio: ?
HW Mixer string:?
Comments:Incompatibility of sample rate on USB from Volumio to BTA30 has been reported to FiiO here but does not appear to be resolved: DAC problems - General Discussion - FiiO Forums - Powered by Discuz!
I have confirmed USB input to the BTA30 does work on another device i.e.Windows laptop
Buying Link:https://www.fiio.com/bta30
Name: Cyrus ONE HD Internal DAC
Receiver: Cyrus ONE HD
DAC: up to 32bit 192kHz
Async: Yes
Working with Volumio: Yes
Tested Versions and Platforms: Working on Raspberry Pi 3 b with Volumio version v2.907
Hardware Mixer on Volumio: YES
HW Mixer string:
Comments: Generic IS2 DAC did not work so IS2 not selected. “Cyrus ONE HD” came up in the Output Device List, which seems to work perfectly with Tidal and NAS
Buying Link: https://www.cyrusaudio.com/products/cyrus-one-hd/
Name: Cambridge Audio EDGE A
Receiver: USB Receiver
DAC: Sabre (??)
Async: YES
Working with Volumio: YES
Tested Versions and Platforms: RPI 4 B with Volumio, all versions (verified from 2.7xx until 2.917)
Harware Mixer on Volumio:
HW Mixer string: N/A
Comments: Works with DSD direct for DSD64. Need DoP for DSD128 and DSD256.
After start Volumio sounds pink noise until it syncs with the DAC (10-15 seconds)
Name: Cambridge Audio Azur 851N
Receiver: USB Receiver using Class 2 USB Audio mode
DAC: 2x Analog Devices AD1955
Async: YES
    Volumio 2.917 / Pi 3B+
    851N service package v022-a-103+a / firmware 1.10+0.5+8e
Harware Mixer on Volumio: NO
Comments: DAC displays PCM 192 kHz with DSD direct setting, and DSD with DSD over PCM (DoP). Apparently that is due to the fact that 851N supports only DSD-over-PCM via USB and DSD direct is not supported
Receiver: XMOS SU216
DAC: ES9038Q2M
Async: YES
Tested Versions and Platforms: Volumio 2.917 / Pi 4B+
Comments: only tried with the PCM material, didn’t have any DSD material on-hand
Receiver: XMOS XU216
DAC: ES9068AS
Async: Yes
Tested Versions and Platforms: Rasberry Pi 4B, Volumio 3.251
Hardware Mixer on Volumio : -
HW Mixer string: -
Comments: Tested Hi-Res stream up to 192Khz/24bit and MQA
Name: Topping DX3 Pro +
Receiver: XMOS XU208
DAC: ES9038Q2M
Async: Yes
Tested Versions and Platforms: Orange Pi Lite (1GB), Volumio 3.236
Harware Mixer on Volumio: Yes
Comments: Works with DSD direct for DSD64-DSD256. No need DoP for DSD. Also tested Hi-Res stream up to 192Khz/24bit.
Receiver: XMOS XU-216
DAC: ES9038 PRO
Async: Yes
Tested Versions and Platforms: Volumio 3.324
Hardware Mixer on Volumio: No
HW Mixer string:
Comments: Tested on PCM up to 24bits 384KHz, DSD up to DSD512, DLNA, Qobuz, DSD not correct playing with software mixer on.
Buying Link: Hifi79Studio
Name: Cambridge Audio DacMagic 200M
DAC: Dual ESS ES9028Q2M
Async: Capable of Async Playback YES
Tested Versions and Platforms: Volumio 3.301 on Rasberry Pi 3B+ / 4B
Hardware Mixer on Volumio: not tested
Comments: none
Buying: iEar, Hifi Studio 79
Cambridge Audio DacMagic 200M also works brilliant with Volumio for x86, Odroid C4 and N2/N2+. With these 3 versions you also get DSD direct on top, due to a specific usb audio patch, which you will not get for any other linux platform for the foreseeable future
@gkkpch Can you please advice about wich Odroid version would be best for sound quality? And Volumio speed and stability?
please don’t go offtopic here, it is about DACs.
Name: Cambridge Audio CXA61
DAC: ESS Sabre ES9010K2M,
Async: YES
Tested Versions and Platforms: Working on PI
Harware Mixer on Volumio: YES
HW Mixer string:
Comments: Audiophile grade amplifier with integrated DAC, 32bit/348kHz and DSD256
Name: Soekris DAC 1421
DAC: R2R
Tested Versions and Platforms: Volumio 3.3xx on Rasberry Pi 4B
Hardware Mixer on Volumio: not working
Comments: DSD works
Buying: manufacturer: Soekris Audio ApS, Ordering
Name: T+A MP 3100 HV (SACD / Streamer / DAC)
Receiver: Thesycon USB receiver
DAC: PCM: Double-Differential-Quadruple-Converter with four 32-Bit Sigma Delta D/A converters per channel; DSD: T+A True-1Bit DSD D/A-Converter native bitstream
Async: Yes
Tested Versions and Platforms: PI4B
HW Mixer string:
Comments: Plays at least up to DSD256 in pure DSD (no DoP).
Buying Link: MP 3100 HV Multi Source Player
@OE333 - FYI;
DAC: ES9038Q2M
Async: Yes
Tested Versions and Platforms: Raspberry Pi4, Volumio v3.396
Hardware Mixer on Volumio: Yes
HW Mixer string: n/a
Comments: Immediately recognised by Volumio. Tested with .mp3, .flac (44.1 and 96 pcm) and .dsf (2.82 and 5.64 MHz / DSF 128).
Not tested with high res streaming.
Using the supplied USB cable there’s absolutely no noise. Recommended if you want a simple USB DAC only without pre-amp, etc.
Buying Link: https://www.hifistudio79.nl/product/topping-d10s-usb-dac-es9038q2m-dsd256-psd384/?lang=en
Name: Schiit Asgard 3 with Add-On Multibit DAC
Receiver: N/A
DAC: Schiit’s True Multibit DAC
Async: YES
Tested Versions and Platforms: Raspberry Pi 3 or 4 running 3.396 (and older)
Harware Mixer on Volumio: None
Comments: Works without an issue as long as no hardware mixer is selected.
Buying Link: https://www.schiit.com/
Name: Schiit Bifrost 2/64
Receiver: N/A
DAC: Schiit’s True Multibit (4 DAC8812 D/A converters)
Async: YES
Tested Versions and Platforms: Raspberry Pi 4 running 3.396 (and older)
Comments: No issues, and sounds great!
Name: Topping E30 II
DAC: Dual AK4493S
Async: YES
  • x86 => V3.396
  • rPi4-8GB => V3.416
  • Odroid N2+ => V3.417
Software Mixer on Volumio: YES
Comments: Works out of the box. Powered via a Lin. PSU (not included)
USB IN: 44,1 kHz-768 kHz/16 bit-32 bit
COAX/OPT IN: 44,1 kHz- 1 92 kHz/16 bit-24 bit
DSD (Native):
USB IN: DSD64-DSD512
DSD(DoP):
USB IN: DSD64-DSD256
Pre amp: Yes
Product Link: Topping E30 II
Buying Link: Topping E30 II
Review Link: Audiosciencereview
Great sound for a very small price. Seems Topping’s getting better each round.
Name: Breeze Audio Dac7
Receiver: C-Media CM6631A
DAC: Wolfson WM8741
Async: yes
Working with Volumio: yes
Tested Versions and Platforms: 3.396 on Raspberry PI 4b
Harware Mixer on Volumio: no
HW Mixer string:
Comments:
Buying Link: it was long time ago, on eBay, shop “miniShow”
