Receiver:
DAC: ESS SABRE 9038PRO
Async: YES
Working with Volumio: YES
Tested Versions and Platforms: Windows 10 RPI
Harware Mixer on Volumio: YES
HW Mixer string:
Comments:
Buying Link: Discontinued
Name: ifi ZEN DAC
Receiver:
DAC: DS1793 Burr-Brown
Async: yes
Working with Volumio: yes
Tested Versions and Platforms:Volumio 2.861 on Pi3B
Harware Mixer on Volumio:no
HW Mixer string:
Comments:
Buying Link:
Name: T+A HA 200 (DAC+Headphone Amplifier)
Receiver: Proprietary T+A (based on STM32H743)
DAC: PCM:4xPCM1795, DSD: proprietary T+A “True 1-Bit DAC”
Async: Yes
Working with Volumio: Yes
Tested Versions and Platforms: PI
Harware Mixer on Volumio: No
HW Mixer string:
Comments: Tested up tp PCM768 and DSD512. DSD1024 might work, but could not be tested (due to lack of DSD1024 test file).
Buying Link: Headphone Amplifier
Name:Edifier A300 Pro
Receiver: built-in USB port
DAC: TLV320AIC3268
Async:
Tested Versions and Platforms: 2020Jan image on Rpi4B
HW Mixer string:
Comments:
Buying Link: Airpulse A300PRO - Edifier USA
Receiver: USB Receiver
DAC: AK4493
Async: Capable of Async Playback (YES\NO)
Tested Versions and Platforms: Working on PI or other platforms, with version name (most of times will be ALL or NONE): Rapsi 4 tested OK - Volumio 2.861
HW Mixer string: Look for hw mixer name on /etc/mpd.conf . Report this ONLY if you had to make manual adjustment to make it work.
Comments: Worked out of the box
Buying Link:
Receiver: XMOS XU208
DAC: AKM AK4497EQ
Async: YES
Tested Versions and Platforms: 2.861 on PC(Asrock-J4105-itx)
HW Mixer string: N/A
Comments: The M200 works with volumio only in PCM mode. When Direct_DSD is enabled, the DSF file is converted on the fly to PCM176 or PCM705.
Buying Link: S.M.S.L Audio Official -双木三林官网
Name: Matrix Audio Element H -> Minidsp SHD Studio -> Hegel H390
Amp: Hegel H390
DAC: Hegel H390
Async: Yes
Tested Versions and Platforms: x86 - Volumio 2.873
Hardware Mixer on Volumio: n/a
Comments: The x86 player uses the Element H USB interface card, which is connected to the Minidsp SHD, which in term is connected to the DAC of the Hegel H390.
Info Link:
Name: TEAC UD-503 USB DAC
Receiver: N/A
DAC: N/A
Async: Capable of Async Playback : Not stable
Working with Volumio: YES but Not stable
Tested Versions and Platforms: Mini PC flash Volumio Ver 2.873
Harware Mixer on Volumio: N/A
Comments: Very often error does not play music, cannot find devices, cannot run DSD native, can only run DSD on DOP and is also unstable. Teac UD-503 supports DSD up to 256 but Volumio only plays up to 128 …
Receiver: Savitech SA9023A
DAC: TI PCM5102A
Async: Unsure (Isochronous adaptive)
Working with Volumio: YES*
Tested Versions and Platforms: Raspberry Pi 4B 2GB rev 1.4, Volumio 2.873
Comments: *Only works with a USB A hub in between the Pi and the DAC. The hub does not need to be separately powered. Without the hub it has connectivity issues and will not function properly. (It might only be my specific Pi or my specific MX3 that does this). I am using a UGREEN 4 port USB 3.0 hub.
Name: EarMen Donald DAC
Receiver: XMOS 200
DAC: Cirrus Logic CS43198
Async: Unsure
Tested Versions and Platforms: Raspberry Pi 4B, Volumio 2.861
Comments: tested up to DSD256; Donald DAC is supposed to unfold MQA, but I don’t think MQA works with Volumio
Buying Link: https://earmen-shop.com/
Name: Topping D70S MQA
Receiver: XMOS XU216
DAC: dual AKM AK4497EQ
Async: yes
Tested Versions and Platforms: Volumio 2.873 on Pi3B
Harware Mixer on Volumio: no
HW Mixer string:
Comments: tested on MP3, FLAC, DSD up to DSD512, DLNA, Spotify, TIDAL - PCM 44.1-96 khz, MQA. Extremely well performing DAC. Please add as supported.
Buying Link:
A post was split to a new topic: miniDSP SHD not in DAC Compatibilly List
Name: Cambridge Audio CXA81
DAC: ESS Sabre ES9016K2M
Async: Capable of Async Playback YES
Tested Versions and Platforms: Working on PI 4 with volumio 2.873 and next
HW Mixer string:
Comments:
Buying Link:
Receiver: XMOS
DAC: 2x Wolfson WM8742
Async: YES
Tested Versions and Platforms: Working on Volumio Primo, with version v2.878
HW Mixer string:
Comments:
A post was split to a new topic: Firmware Update Topping D70
Receiver: CM6632A
DAC: dual ES9016
Async: YES
Tested Versions and Platforms: v2.916 for Sparky, v3.xxx for Pi4
Hardware Mixer on Volumio: NO
Comments: native dsd playback works according to volumio, dac reports high bitrate pcm
Receiver: XMOS
DAC: AK4490
Async: YES
Tested Versions and Platforms: v2.882 for Sparky
Hardware Mixer on Volumio: YES
Name: Steinberg / Yamaha UR24C
Receiver:unknown
DAC: unknown
Async: Not selectable with this version - so not tested
Tested Versions and Platforms: volumiobuster-3.073-2021-05-07-x86_amd64 , Fujitsu ESPRIMO Q956
Hardware Mixer on Volumio: No
HW Mixer string:
Comments: Tested with 16bit/44,1kHz, 24Bit/96kHz and 24Bit/192 kHz streaming from Synology NAS and Net Radio
Buying Link:`
Name: Mytek brooklyn dac+
DAC: Sabre ESS9028 Pro
Async:
Comments: Tidal Connect don’t work
A post was split to a new topic: Hardware Mixer a limitation of the Rotel DAC
Name: Topping D10 Balanced
Receiver: XMOS208
DAC: ES9038Q2M
Async: Yes
Tested Versions and Platforms: Rasberry Pi 4B, Volumio 2.907
Hardware Mixer on Volumio : Default
HW Mixer string: -
Comments: Tested FLAC and radio. Well behaved on power up and power down, no bursts of noise.
Buying Link: Amazon.com: TOPPING D10 Mini USB DAC CSS XMOS xu208 es9018k2m opa2134 Decoder Audio Amplifier (Black): MP3 Players & Accessories
