is there a detailed changelog between version 3.546 and 3.569.
Since 3.569 pirate audio plugin isn’t working anymore because of the following error:
volumio@volumio:/data/plugins/system_hardware/pirateaudio$ python3 ./display.py
File "./display.py", line 39, in <module>
offset_top=0 # v0.0.6
File "/usr/local/lib/python3.7/dist-packages/ST7789/__init__.py", line 139, in __init__
GPIO.setup(dc, GPIO.OUT)
RuntimeError: No access to /dev/mem. Try running as root!
I guess somehow all plugin which uses the RPI.gpio library in combination with python 3 are affected.
So for any other stumbling upon it and like me can’t wait for the next stable to fix this: You can fix this right now with
sudo sed -i 's/bcm2835-gpiomem/gpiomem/g' /etc/udev/rules.d/99-com.rules
It is also a good idea to make a backup of /etc/udev/rules.d/99-com.rules before this operation.
And be sure to really be on kernel 6.1.54 or newer - not to make things worse
This update coincided with me making some modifications with a soldering iron to my project so thought i’d killed my VFD! Glad it’s just udev rules. All good now
