Trebz
February 23, 2025, 7:26pm
1
I am not sure if this is the right section to post this, but where are the release notes for system version 3.794. My Rivo+ updated recently for the first time since purchasing and it seems the I2S output has improved. I am curious what else changed.
Should normally be posted on this page, but it seems to have not been updated. @volumio
CHANGELOG
3.785 (18-12-2024) Hotfix release (Raspberry Pi only)
FIXES
Improved translations
Fix for Allo Piano DAC on RPi with kernel 6.6.x
NEW ADDITIONS
Add support for Raspberry Pi Display V2
Bump kernel to 6.6.62
3.779 (14-11-2024)
FIXES
Fix Multiroom Buffer Sizes
Increase results for Kana-Kanji Conversion
Fix for streaming interruptions
Fix pop noise on FS change and PCM/DSD transition on Motivo
Fix for HiFiBerry HATs not initialized properly on RPi
Fix …
Trebz
February 23, 2025, 7:51pm
3
Thanks. I will check back.
Darmur
February 24, 2025, 9:03am
4
His new release is specific for Rivo Plus, not available for the other devices.
I will add the changelog
