I tried it, and got the same result
Please post the results of
cat /boot/config.txt
cat /boot/userconfig.txt
cat /var/log/Xorg.0.log
I have a new issue with the Rasberry PI5.
I plugged in my Pi4 SD card into the new Pi5 and all seemed to work fine for a couple of hours then the Pi started losing connectivity to the wireless network. When I reboot via pulling the power plug and starting over, it would not immediately connect, nor would it fall back to the hot spot.
So I would try over and over and sometimes it would work, or I could connect to hot spot and reconfigure wifi settings but only sometimes. In short when i finally get a connection it works great for a while but then loses connection and we start all over.
So I thought maybe i need a fresh install. So I went to the Rasbery pi installer and with a brand new SD card, installed volumio on the Pi5 setting thinking this would work better. Here nothing happens, cannot even boot Volumio to the set up point. It starts writing Volumio, and then when it gets to teh IP point it shuts down and I get all red on the Pi.
So I went back to initial card in Rasberry 4b and no problems at all.
Any thoughts?
The rPi 5 is very critical on the PSU. Make sure you use 5V/5A PSU.
Funny, I noticed that when it was booting up, it said “insufficient power” which I found odd because I simply plugged the power supply I was using with the 4b. Unfortunately, I took the 5 power supply to Florida for a Volumio set up down there not knowing they were different. So I have ordered a new one which should arrive within two days, and I will let you know what happens.
Thank you for your help.
The rPi4 is 5V/3A, it lacks power to support the rPi5. I expect when the PSU arrives it will work as intended.
I have just bought a Raspberry Pi 5 (thinking it would outperform a RPi 4), with the official RPi 5 power supply. To feed a Cambridge Audio DacMagic 100. My music collection is on a external USB drive (in FLAC, MP3,…).
Thing is, I have downloaded the latest release of Volumio (3.569 as of yesterday) and can install it without any visible problems. I can select my output as the Cambridge Audio connected via USB to the RPi 5.
The problem is that after plugging in the USB HD with the music, and pressing on update the music library, a visual indicator starts spinning for a few seconds and then stops, sometimes it starts counting albums… but stops after a few seconds, and the music library is never updated. I have tried updating and recreating the music library, and I have tried using the USB2 and the USB3 connector.
Has this happened to anyone else?, is it a know issue?, is it only me?, is there anything I can do to troubleshoot this?
Thanks.
as starters, post a log when this is happening.
Is the USB drive externally powered, as the rPi is not a USB hub.
Good question if use Pi5. I have Pi5 with Waveshare 11.9 and when connect 2T SSD NVMe Waveshare goes off or all system reset.
Pi4 with the same LCD and disk via USB works without problem.
I have over 5A linear PS with 6.25A transformer but it is not enough for Pi5 with all devices.
Yes, not that much experience with the rPi5 yet, as it’s pretty new. I know form the rPi4 it will go into protection when to much current is drawn (lowering the voltage) from the USB port, causing the system to become unstable.
I expect the same behavior with rpi5.
Had similar issues. What i found out was that there was too much voltage drop on the cable from the PSU to the PI. As mine is a diy PSU, i increased the voltage to 5.1V and changed to a better cable.
The Pi will not be happy if the voltage drops under 4.8V.
A thing to try, if you have a multimeter try measuring the voltage on pins 2 and 6, not on the PSU itsself.
Or Pin 2 on the PI and the + on the PSU to see the voltage drop.
In Pi5 If you are using a power supply that cannot provide 5A at +5V on first boot you will be warned by the operating system that the current draw to peripherals will be restricted to 600mA. That is on RaspiOs. You can use command in config to rise this 600mA. On default you can’t boot from SSD or USB on 3A PS, if you want… need change command in config.txt.
Yes, I done the same ( it is in “My oak volumio” thread ). My Pi5 is connected through GPIO and PSU bypassed Pi voltage regulator. Now I boot with SSD without original Pi5 PSU-PD.
I have playing with the RPi5 for a while now and everything is working great except it’s never completed adding my music (>100k songs) from my NAS. 10K+ songs is the most that it added and then stopped. Never had this issue with RPi4 nor TBS.
My solution was using a working copy (with >100k songs scanned) from RPi4 and tweak to work with RPi5. Now it works really good but I shouldn’t have to do this!!!
RPi5 - 8GB
Volumio - 3.588
Plugins:
Spotify - 4.0.4 (yes, meter VUs works)
PeppyMeter Screensaver - 1.3.1
Touch Display - 3.3.7
I am having some issues with an RP5 and TSOP4838 IR receiver.
At the RP4 this IR receiver worked fine. All plugins, settings and library at the same place in the new PR5 as it was at the old RP4, I get some errors at the RP5 and no IR is working:
Registered IR keymap rc-rc6-mce
[ 311.874621] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@17/rc/rc0
[ 311.874768] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[ 311.874998] input: gpio_ir_recv as /devices/platform/ir-receiver@17/rc/rc0/input2
[ 373.490306] OF: ERROR: memory leak, expected refcount 1 instead of 2, of_node_get()/of_node_put() unbalanced - destroy cset entry: attach overlay node /ir-receiver@17
[ 373.490548] OF: ERROR: memory leak before free overlay changeset, /ir-receiver@17
[ 373.546567] Registered IR keymap rc-rc6-mce
[ 373.546721] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0
[ 373.546883] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[ 373.547106] input: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0/input3
May some of you have an idea?
Thank you for your help!
@wheaton
Thanks again for your help. Your solution worked in part.
My biggest problem was that when flashing the Volumio image, and using the Pi Imager tool, I selected The Pi5 as my hardware (because it is) but it simply would not install. I finally went back and selected Pi4 and flashed and then everything was perfect. Installed, it is fast, seems a bit more stable. For instance when I switch DACs it just does it really quickly and dos not bomb like the 4 often did.
Very happy with the new Pi5b set up.
flashing as rPi5 with raspberry imager should work, just don’t use the image offered by raspberry imager. Make sure you choose custom and download the image from Volumio.com.
Do you know if it matters? Since I flashed with rPi4 as the hardware, everything is perfect. If I flashed with rPi5 as the hardware, would there be benefits?
Nope, the Volumio image is pretty universal for the rPi3,4 and 5. I expect if you load the original Raspbian the config.txt might be different. For Volumio it doesn’t matter.
On Pi5 with 3.584 and 3.595 I can not use “static IP”. I can turn off Auto IP and put my static IP but after save and restart is still the same auto IP.
The same on WIRED and WIFI connection. Netmask and Gatevay are correct. It works with Pi4 without problem.
It’s no metter what IP I use on my router is still the same:
I’m running 3.595 on RPi5 and don’t have this problem. I turned off AutoIP and input a static ip then restarted several times and the static ip is still there.
