QOBUZ Connect integration on VOLUMIO streamers
I’ve upgraded to Superstar sub so Qobuz connect is enabled for me…
I installed the volumio update (published this week). Works perfectly with dsp and peppy spectrum!
Congratulations, I can now use the same UI for playing music on my phone, PC, RPI and car. Using QOBUZ connect . This is a real great hudge improvment. The Qobuz UI is more powerful in filtering, sort etc.
Does Qobuz connect change the stream quality in comparison Volumio ?
Can you confirm if I still need to be PREMIUM to use QOBUZ Connect ?
Good JOB again, team !!! Being in the IT,
just by curiosity, can you tell me how man days were required to make QOBUZ connect integrated to Volumio ? 10, 50, 100 ?
Georges
Any news on an update to include the Connect feature in Bladelius Ask and Oden II Integrated amps(streamer is based on RPi)?
Qobuz on my Windows pc does not wake up Primo v2 in standby mode, so Qobuz does not appear as audio output. With android phone version it happens, and after that also Windows version is showing Primo output.
Hi, any news on Volumio v1?
Not yet, we’re currently working on a fix.
We kindly ask for your patience as our team is doing its best to resolve the issue as soon as possible.
Thank you for your understanding.
Best,
Davide
VOLUMIO TECH SUPPORT
Any plans to add Qobuz Connect functionality for people with a virtuoso account?
I am seeing the same issue (including the error message) with RP3B and HifiBerry DAC2 PRO (PCM5122).
On top I am seeing an issue that albums play back on repeat. No way to stop as clicking pause simply skips to the next track. Not ideal.
Here’s a log http://logs.volumio.org/volumio/lrB76lP.html
We’ve had a lot of internal chats about this, and after careful consideration, we’ve decided not to add QOBUZ Connect to the Virtuoso plan. Since Virtuoso is an older, legacy plan that hasn’t been receiving updates for a while, adding new features like this would be tricky and could lead to confusion down the road.
That said, we truly appreciate all of you who’ve been with us for so long. Your support means the world to us. That’s why we’re working on something special: a one-year upgrade to Volumio Premium with a super generous offer, so you can enjoy QOBUZ Connect and all the latest features if you’d like to.
There are a few technical things we need to sort out with our payment provider, but we’re on it. As soon as everything’s ready, we’ll send out the offer by email to all Virtuoso users.
Same problem with a rpi 3b+ and a allo digione board. Pressing pauze gives the same error and skips to next track.
Also my dac (TEAC UD301) doesnt accept a Qobuz 192khz track, the “lock” led goes flickering like it doesnt get a signal.
log file: http://logs.volumio.org/volumio/kIHEhun.html
Obviously firewall problem. New Qobuz version needed new holes into firewall. Now working as expected.
Same issue with pressing pause in the Qobuz app and the app skipping to and playing the next track. Allo Digione signature on RPi 3b+. Volumio and Qobuz apps on most current versions. The skipping issue does not happen when multi room playback is turned on. The other player is also a RPi 3b+ with Hifi Berry Digi hat. Have not yet tried factory reset.
What about the ones who already upgraded to Premium from Virtuoso and payed the extra money?
I get the same behavior after some series of Volumio and Qobuz application updates over the last 2 weeks or so, although in my case it is with a USB connected external DAC and not only when pressing pause, just randomly skipping sometimes more than one track, or stop playing for no reason. That is with an RPi 4 (sorry if slightly off topic for this thread which appears to be for Volumio hardware).
please try with a factory reset first, then if the issue happens again, send a log link with the issue description to: support at volumio dot org
Thanks for the collaboration
Best
Davide
Superstar and Premium have the same access, so QOBUZ Connect is already enabled for those still on superstar
I know. But I’m talking about this:
PS: Qobuz Connect it’s working with no issue in my RPI 4.
Log sent.
On RP3 i did a factory reset and switch to Automatic IP on wired network. And now it works fine.
Could be a problem of network configuration ?
Before i was on fix IP adress.
We need you to paste the log link here
