The new QOBUZ Connect application is currently in an advanced beta test phase, on streamers from various brands such as Auralic, WiiM, Naim, Lumin etc…
I was therefore curious to know if anyone is also carrying out tests and experiments on VOLUMIO streamers or if a future implementation as TIDAL Connect is planned.
Thanks for the timely and good news.
Released now for several players. Volumio update soon on this?
we have released and rolling out an update with Qobuz connect ready feature on all our products.
Please stay tuned ![]()
Davide
VOLUMIO TECH SUPPORT
Hello ,
On " all our products" means on all HW products or also on Volumio OS , that we can flash on RPI ?
Yes, on the whole Volumio line.
Hello, is Qobuz Connect available in Volumio yet?
I cannot see Qobuz Connect in plugin for installation.
Qobuz Connect resides like Tidal Connect under sources.
The latest version of the software which arrived on my Rivo + last week contained Qobuz Connect which you just need to turn on. You also need the latest Qobuz app (mine was way out of date - I don’t think it updates automatically). You then select the music you want to play on the Qobuz app and click the icon to select where you want to play it. Choose Volumio and it plays. No problems found, it plays fine.
Congratulations to the team for this major step. THANK YOU.
@gkkpch Will the Odroid C2 and N2 apps also be updated to get this feature?
Hello ,
Qobuz Connect is working by the metadata does not appear in the streamer …and the sound quality is down sampled . In Qobuz all the song is at 192khz but in the dac it displays 24 bit 44.1 khz …
Sorry … I guess it uses airplay …
You use airplay, not QC!
I guess o need to update Qobuz app on my iPhone …
I just got the update and in trying to enable the Qobuz Connect feature, the app says I need to upgrade my account. I have a lifetime “Superstar” account, is that insufficient for use with this feature or is this a bug/error?
Thanks for the heads-up. We added superstar now. Just reboot and it should work
We released the update for all platforms, tinkerboard and Primov1 are currently on hold.
Enjoy!!!
Had the same problem. Make sure to update the Qobuz app on the iPhone. Should be V9.0.0
