For waveshare 11.9 inch screen while setting up Volumio with Peppymeter, what are the things needs to be taken care and activeted during the installation. can you please share the list of those items. Also what would be the Peppymeter resolution for a 11.9 inch HDMI screen.
@michel8166 Hi,
thanks for the response, sorry I am so slow at responding. I do not have a music_service folder under plugins. mine looks like:
-plugins
|_miscellanea
|_user_interface
Also volspotify.tmpl sounds a lot like Spotify specific, I am using Tidal Connect and local (USB harddrive). That’s why I didn’t pay much attention to the post when I looked for a solution. I don’t know if it’s the same file I need to customize r there is a specific for tidal/local ?
@hifipi indeed was specific to spotify, sorry my mistake. I hadn’t seen that it was about the complete peppymeter needles that don’t move.
I had the same problem last week and had to install peppymeter again 2x before it worked, I wouldn’t know what caused that.
how did you install peppymeter?
it is best to use download as a plug-in.
in my case the meters only move when I select software mixer under playback options/mixer type.
I’ve been trying to install Peppymeter via the Plugin but can not find it. I went to /dev and clicked Test Plugins True , it didn’t stay highlighted. I went back and the same plugins were listed. I assume I’m doing something basic and have tried searching these forums. Thanks
