got it
Tell me if it works now
Regards
IMPOSSIBLE!
show me where you copied the files
OK, now it’s okay.
What screen is this?
skins are showing but screnn half only, 7.9 dsi waveshare
Resolution?
1280x400
Please open a ssh connection and type:
export DISPLAY=:0
xrandr --query
Paste the results here.
add to userconfig.txt
disable_overscan=1
can i reboot
Your display is running on 1280x800 not on 1280x400. So yes the screen is half filled.
how can i correct it
Download a 1280x800 template?
i tried this but not working
