Do this:
*Install Buster 3.812
*Install Touch Display
*Install Peppymeter screensaver 2.2.1 or install Peppymeter Basic
But a better solution is:
*install Alpha v.69 Bookworm
*install Touch Display
*install Peppymeter Basic Peppymeter screensaver does not work with Bookworm! (yet)
I don’t know what resolution you have, but Peppymeter screensaver is compatible with Peppymeter Basic counters. Download from Github @balbuze. (mine are in my avatar)
P.S
If you are using only counters without metadata, why do you need Peppymeter screensaver? Install Peppymeter Basic
peppymeter basic plugin don’t run very well on versione 3.817
the peppy screensaver it’s the solution that i like. But, when start screensaver, i’d like see only meter
my 3,5" it’s too small for complete UI.
Unzip and place the entire folder in:
/data/INTERNAL/peppy_screensaver/templates
PS. Physical resolution 480x320, configurable software resolution up to 1920x1080
If you can force it to work in 1920x1080 resolution - it will be able to use skins for this resolution (completely different)
Is this an additional Spectrum plugin? Or a skin from Peppymeter screensaver?
Edit: I see now. Finally, do you want only meters or meters with metadata?
This isn’t my skin. Try mine.
i’d like create my personal skin…
i modify the meter.txt and spectrum.txt for use only spectrum into 1980x1920 pixel but i cannot enlarge the bar!
can help me?
