- Please uninstall Peppy.
- Reboot
- Open a ssh connection and run
- sudo apt-get update
- Install Peppy again
@Wheaten Followed your instruction and now all is ok.
Thank’s you
Another question among FusionDsp and Peppymeter compatibility.
If i use togheter the 2 plugins,obiouvsly activating the Peppymeter’s FusionDsp integretion option, i hear stutterings and clicks, so i nedd to disactivate Fusion Dsp .
Someone could help me?
Hey @Roberto_Grieco
Now I don’t understand anything. PeppySreen - no clicks like before?
i.e.:
- Peppyscreen - NO stutterings and clicks (FusionDSP OFF - PeppyScreen ON)
- FusionDsp - NO stutterings and clicks (PeppyScreen OFF - FusionDSP ON)
- Peppyscreen + FusuionDSP (ON) - stutterings and clicks ???
Hi @Gelo5
- Peppymeter only: NO stutterings and clicks (FusionDSP OFF - PeppyMeter ON)
- FusionDsp only - NO stutterings and clicks ( FusionDSP ON - Peppymeter OFF)
3). Peppymeter + FusionDSP (ON) - stutterings and clicks (and selecting in Peppymeter option panel, the FusionDsp integration option)
Rpi5 8gb, Volumio 3.703 ,FusionDsp latest edition and Peppymeter 2.2.1
That’s my issue
Wasn’t this mentioned already to not use both at the same time, or am I missing something?
hi @Wheaten Surely i missed something…I ask my questoin because i saw in the Peppymeter option panel , an option for integration between Fusion DSP and Peppy, so i thought it was possible to use them togheter.
Now i’ts clear that it’not possible !
Thank’s
It’s possible (from ver 1.4), but something is clicking with you again
damn…and I upgraded also from rpi4 4gb, to Rpi5 8gb to have more computing power…I think the problem of stutters and clicks during playback is…just me, my presence near the streamer and to the DAC ![]()
There’s too much chi energy in your body. Not good for audiophile equipment ![]()
the problem is that peppy uses an Alsa pipe, not the power of the rPi4.
I wonder why only I have these clicks and stuttering problems…?
What am I doing wrong?
You could also try with tidal … now that it is cheaper .
because you keep on using Fusion and Peppy simultaneous?
Do you really need fusion dsp ?
@Wheaten @Lintbf
I naively thought that the two plugins could coexist together, to allow me to correct the sound of some albums or tracks that I didn’t like, simply adjusting the low, medium and high tones.
And seeing the various options of Peppymeter, I thought I could integrate them.
Furthermore, I am also curious and I like to experiment with the various possibilities of Volumio and its plugins.
But there’s no problem, I will listen to my liquid music in Pure direct mode !
I’ll say it again: they can
What DAC are you using ?
Can you post your /boot/config.txt
Thank you.
I had the same problem, I am using InnoMaker DAC HAT ( I2S DAC ), I have to edit /boot/config.txt, at the bottom line
Volumio i2s setting below: do not alter
dtoverlay=allo-boss-dac-pcm512x-audio,slave
dtoverlay is the DAC overlay, depend on what DAC you use,
InnoMaker DAC Hat use Allo Boss-DAC-pcm512x
remove the “,slave” at the end of the line , like this
it will let DAC not use slave mode, then save config.txt and reboot, the click and pop sound disappear.
maybe you can try it, hope you succeed.
@dewen I use a Topping E30 II USB DAC, but unfortunately from yesterday evening my Rpi5 don’t boot anymore…and i can’t post config.file.
I’m very unfortunately with this streaming project , as @dc2geeks said, these too much Qi energy on my project.
I hope to resolve my boot problem, otherwise i need to change my Rpi5 witn Amzn…
Had the same issue with my 1st rPi5 (first release batch).
