No, no. you have to “modify” all graphics: bgr with empty space, fgr with empty space, screen must be removed (jpg has no transparency) or change to png with empty.
I have not tested such a solution. I don’t need it
Just a thought…. Perhaps it’s just me being lazy, but having so many different screens and having to choose which ones to use, I’ve been putting off sorting through them. Life would be a lot easier if there was a button to temporarily show the screen filename somewhere on the display so that a user could make a note of which ones to discard and which ones to put into the wanted list.
Hi @Gelo5
Thank you for the test.zip, I test it but it still “mask” the lower half of the screen to dark, maybe I need to modify the screen ( DF202114P.png ) to transparency, or it is already done transparency ? anyway, it seems beyond my knowledge and I will give it up
Maybe someday I will learn more and “transfer” some 1920x515 to 1920x1080 as you taught. Thank you !
So haven’t followed this post for 10 days… and the world has changed!!!
Just installed V2.2.0 and try to run one of my templates designed for a very small screen.
For some strange reason I have an offset on the top and right side, which was previously working.
Did I miss something?
yeah, not sure why I have to manually add the screensize to the config.txt
But if people complain, you have the solution.
But for the rest all is working fine.
(socket.io is not new but a newer version, better response times)
Just tested the new version (V2.2.1) and the personal customization for locating the meters and adding the metersize as folder name is marvelous.
Now I can simply add the meters as overlay to the manifest or Now Playing UI Now Playing:
The Meter and Now Playing use the same “Vinyl” as background, so it can match together. If you want “screen protection over-burn”, you may need to set the background to black.
When using the peppymeter, I found that many songs only swing in a small range, rarely exceeding 90 degrees. Can the swing amplitude of the pointer be adjusted? How should it be adjusted? In addition, can the time display be displayed as increments? How should it be adjusted? Thank you!
Hi at all.
On my new Rpi5 8gb, i installed latest Volumio 3.703 ,TouchPlugin and Peppymeter 2.2.1 in sequence.
I’m not to be able to activate peppymeter, after installed touchplugin, i followed the normal instructions as Gelo’s. The installation finished without errors, but when i try to active it in in the installed plugin window, i put the slide in “on” position but the plugin is disabled (red dot) and if i go on settings the windows is empty( no configuration available)
