Both :slight_smile:
Thanks for answer . Currently I have one waveshare 4 inch and I am planning to buy one but I do not know whatsize … 7.9 inch or 1920x1080 but small …
@Gelo5 Please what model is the 14 inch one ?
It’s best to buy 1280x400 HDMI (Wave)
or:
1280x800 updated. (13 new skins meter+spectrum), Files separated by 20
Good evening. Will there be skins for 1024x600?
They will. All resolutions will be there. It takes a lot of time. Be patient, use it without spectrum for now
The final v2.1.0 is now available
post 7
Happy meters
2aCD
Hi, I am using both:-
(1) 7.9” WAVESHARE touchscreen LCD with HDMI (much preferred) input for 400 x 1280 (same as Gelo5) and
(2) 55” TCL 4K LED TV for 1980 x 1080 format
to display the screensaver
Hello ,
One question pls .
1 Have you ordered directly from wavehsare or from aliexpress /
2. What shipment method had you used /
Waveshare direct from waveshare or from your local market (The price is approximately 80-100 USD ). Other monitors from Aliexpress
Remember: order HDMI!
It was ordered from WAVESHARE shipped via airfreight
Thanks a lot ! It fixed the Spotify click problem.
Just a quick test, I found @Gelo5 Spec&Met-720 1920x1080
102G5_Sansui S+M, only meter works, but no spectrum.
I remember it works in the previous 2.0.0 beta ?
I have this option :
Thanks a lot for HDMI info .
If I turn off Now Playing plugin ( 0.5.6 ), the 120G5_OldPipe Spectrum runs much better in Pi 4.
There must be some setting wrong in my “Now Playing” pluginsetting, it seems take a lot of CPU usage ( > 100% ), after some modify ( set to default…ect ), everything seems normal… still trying to find what setting cause the problem.
Interesting observation , I will try also with peppyapectrum .
FIX - Please overwrite the entire folder (template spectrum) - 1920x1080
templates_spectrum 1920x1080.zip (6.6 MB)
Old folder - delete it
Edit: it’s already changed in the download section
It’s working ! thank you for the quick fix and great artwork !
I’m facing the problem. Did you find the solution?
Write what problem you have. What hardware and software do you have?
Sorry I didn’t explain the issue since I was replying to an older thread.
I have a Volumio 3.6 installed on Allo USBridge Signature device, and I added the PeppyMeter screensaver v1,5.0 zip following the instructions on this forum. The skins are looking great, thanks for all that work.
The issue I was having was the song name didn’t get updated when the track changes. So it shows the first track correct, the it stays the name during playing the same album. To avoid this issue I was thinking why not keeping the existing volumio UI and use a lower resolution PeppyMeter folder to overlay on top of the UI. Then the problem of positioning arised, since the lower PeppyMeter will always show on top left corner of the screen, partially covering the UI.
So, to summarize I have 2 issues
  • the PeppyMeter skins (1920x1080 as provided with the 1.5.0 zip) do not update the track name during play
  • how to position a PeppyMeter skin when lower resolution the screen is used; it always show on top left corner.
    I hope this is not too confusing.
    Thank you,
    Sorin
