@Gelo5 after fifth clean instalation, still doing the same like on previuos install PM 1.3.9 with TD 3.3.8 works.
I don’t know where is problem. It was reason why I was away from PeppyMeter few months - unpredictability.
It is great plugin, but I never know will work after instal or no. Sometimes at first install, somethimes at fifth like today. Problem was on Pi4 and Pi5, on earlier 3.5xx and newer. On 7" and 11,9".
Now I know that I need … patience :upside_down_face:
@Gelo5 Thank you…will test
Hey Roberto_Grieco
can you say me, which soundcard you have installed. It seems this issue (Spotify stops play) is depend on the selected soundcard driver.
Hi together,
please do not reinstall PeppyMeter at time!!!
PeppyPlayer have update the source.
Some new name conventions in the config files needs to update also the Volumio plugin.
Please wait for a new version. I’m working on it :wink:
Hi @2aCD I use an smsl c100 external dac
Installed PM before seeing this this morning but everything is working 100% normal through my Pi4b, Innomaker pro DAC using Spotify. Is there something I should be watching for?
Maybe it is a reason why 1.3.9 installed one hour ago not working
:upside_down_face:
Thank you for the info.
Hi guys.
What is the recommended order of installation of individual plugins for Peppy Meter. From what I read, after installing Volumio, you should first install Touch Display → Peppy Meter → Now Playing. Something else? I also have a request to the 2aCD admin if it would be possible to describe more clearly which version and installation method is current. There are several versions of the software and descriptions of different installation variants and it is not clear which one to use.
Volumio → Touch Display–> Plugins
Wait, there will be a new version of Peppymeter Screen
Volumio 3 Issues?
Hey everyone! I had peppy meter installed on my volumio player and it was working fine. However, I recently formatted the SD card due to sone reason and did a fresh installation of volumio OS. After reinstalling peppy meter, it seems to have stopped working. Any ideas on what could be causing this? I could really use some help here.
John francis
Maby this.
Hi together,
the new plugin is now available. What’s new and download you find here:
Post 7
It is now compatible with latest PeppyMeter changes to place meter files outside of program folder.
many thanks to peppy.player, to work with me on all changes for our Volumio-Integration
best regards
2aCD
Works great! Thanks. This is it!
This replicates skin 1480x320 on a 1920x1080 monitor :joy:
Uninstalled 1.3.9
Reboot
Installed 1.4
Works at first time !!!
Great job with empty folders for other res.
Thank you @2aCD
Does the FusionDSP integration in combination with Spotify work for you?
Hello…Any idea when they’ll fix the current peppy meter problem? I’d like to be notified once it’s resolved.
Thank you
John francis
Have you tried this new version yet?
Hi… Tried to install tge latest version peppy meter but it is not working…please guide me how to install it.
John francis
there it is on post 7.
and link how to install.
Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #1212 by michel8166
